Timer issue in HS3
    Timer issue in HS3
    Good day all,
    The HS3 is switching the outside lights OFF at 23:00
    I used to do this in the Graphic Logic Editor, Hour=23 --> Switch Object outside lights set to 0.
    Much later I discovered the possibility to create a time clock event in the Gira iPad app, used that one to switch the lights OFF at 23:00 and removed the function from the Graphic Logic Editor.
    Recently I changed the switch OFF time into Sunrise-0:20 minutes.
    The issue I now have is that the lights are still being switched OFF by the HS3 at 23:00
    Workaround I use is switching the lights ON again using a time clock event in the Gira iPad app at 23:02
    I cannot find the reason why this switching time is still in the HS3.
    When I look at the communication objects, select the outside lights and look at the References I can see it's only used in the GLE to record the last switch ON/OFF date/time (as input) and in QC Config.
    Even with all switching events removed in the iPad app the switching still occurs at 23:00
    Could the info in hslist tell me where the switching event comes from??
    I uploaded a different project and after some time uploaded the previous project again without changing the issue.
    Attached a screenshot from the hslist and from the eib monitor.
    Zuletzt geändert von 747driver; 10.01.2020, 15:19.
    you can try HS-Insight and use the command listuhrproto to view this list translated to humans
    Nils
    aktuelle Bausteine:
      Thanks Nils but:
      "NameError: name 'listuhrproto' is not defined"
      I'm using HS Expert 4.5.0 for my HS3 and downloaded 12243_HS-Insight_2.6.hsl
      Connected a dummy bit object with value 1 to the aktiv input and dummy bit object to the aktiv output.
      Would that be correct?
        Yep that is correct. Did you downloaded the 26 Version from the last post of the insight thread ?
        Nils
        aktuelle Bausteine:
          I don't think so.
          Believe I took the first I saw (Version 0.25).
          Will try the last one.
            Die aktuelle Version ist 0.44 https://knx-user-forum.de/forum/%C3%...58#post1449858
            Nils
            aktuelle Bausteine:
              Got it running.
              Had trouble to get the Putty colours correct so I'm using netcat on my mac (nc hs-ip-address 23).
              As listuhrproto only seems to show clock events which happened after a HS restart I will have to wait another day to see the 23:00 switch event.
              Had a look at listuhr.
              To see how it works I entered a new clock event in the Gira iPad app and I could see by the colour of the "* Zeitschaltuhr 'k.A.' (UZSU1000000659)" line whether the time clock was active or not.
              Cool, donation on its way
              I also saw a couple active Zeitschaltuhr which I cannot see in the Gira app and which should not be there!
              One of them was indeed the switching OFF of the outside lights at 23:00...
              The other one is the switching OFF of the central heating at 22:00
              It is as if I used a function in QuadConfig in which I used the Time clock, activated a Time clock switch event and then removed the function but the Time clock switch event is still there.
              Is that possible?
              How do I remove ALL Time clock events from the HS3?
                I think the issue has been solved.
                In QuadConfig I checked Project/QuadClient/Functions
                Went through the whole list and discovered functions which are not in use anymore but which did have "Use time clock" active.
                I've put these functions in Building structure/Room and indeed, one of them had the "Switch the outside lights OFF at 23:00" event....
                Removed the faulty time clock events and removed the functions and all seems to be well now.
                Your 12243_HS-Insight_2.6.hsl helped by making the list of time clock events easily readable.
                Thanks Nils!
                Zuletzt geändert von 747driver; 11.01.2020, 09:03. Grund: Typo
