Good day all,
The HS3 is switching the outside lights OFF at 23:00
I used to do this in the Graphic Logic Editor, Hour=23 --> Switch Object outside lights set to 0.
Much later I discovered the possibility to create a time clock event in the Gira iPad app, used that one to switch the lights OFF at 23:00 and removed the function from the Graphic Logic Editor.
Recently I changed the switch OFF time into Sunrise-0:20 minutes.
The issue I now have is that the lights are still being switched OFF by the HS3 at 23:00
Workaround I use is switching the lights ON again using a time clock event in the Gira iPad app at 23:02
I cannot find the reason why this switching time is still in the HS3.
When I look at the communication objects, select the outside lights and look at the References I can see it's only used in the GLE to record the last switch ON/OFF date/time (as input) and in QC Config.
Even with all switching events removed in the iPad app the switching still occurs at 23:00
Could the info in hslist tell me where the switching event comes from??
I uploaded a different project and after some time uploaded the previous project again without changing the issue.
Attached a screenshot from the hslist and from the eib monitor.
