MPD
wichtig den TCP Socket nutzen, dann gibts auch keine Probleme mit der Berechtigung
pacmd funktioniert nur vernünftig als NICHT-SYSTEM, daher
pacmd ersetzen mit netcat localhost 4712
pid_file "/var/run/mpd/pid-1" state_file "/var/lib/mpd/state-1" port "6601" zeroconf_enabled "yes" zeroconf_name "Küche" audio_output { type "pulse" name "KuecheEQ" ## immer TCP nutzen, darum 127.0.0.1 server "127.0.0.1" sink "KuecheEQ" } user "mpd" #log_level "verbose" music_directory "/media/ixstore-pub/Media/Music" playlist_directory "/media/ixstore-pub/Media/playlists" db_file "/var/lib/mpd/tag_cache" sticker_file "/var/lib/mpd/sticker_db" #error_file "/var/log/mpd/errors.log" log_file "/var/log/mpd/mpd.log" bind_to_address "192.168.178.15" bind_to_address "127.0.0.1" audio_output_format "44100:16:2" samplerate_converter "Fastest Sinc Interpolator" mixer_type "software" #replaygain "track" #replaygain_preamp "0" volume_normalization "yes" max_playlist_length "100" #audio_buffer_size "2048" #buffer_before_play "10%" filesystem_charset "UTF-8" id3v1_encoding "UTF-8" #metadata_to_use "artist,album,title,track,name,genre,date,composer,performer,disc"
alias pacmd='netcat localhost 4712'
