LBS Tasmota (14331)
    Zitat von richardpub Beitrag anzeigen
    Achtung die Tasmota Knx sind nicht mit ETS5 kompatibel? Sie müssen den Thelsing Knx-Github verwenden
    We don't talk about the KNX Stack Communication for Tasmota here. This LBS is for HTTP Communication.
      Zitat von Opelpower Beitrag anzeigen
      Bei Tasmota AUS
      PHP-Code:
      {"Time":"2021-12-18T11:42:23","Uptime":"0T00:32:45","UptimeSec":196 5,"Heap":21,"SleepMode":"Dynamic","Sleep":50,"Load Avg":19,"MqttCount":0,"POWER":"OFF","Wifi":{"AP":1 ,"SSId":"FRITZ!Box Fon WLAN 7490","BSSId":"'*******","Channel":11,"RSSI":60,"Signal":-70,"LinkCount":1,"Downtime":"0T00:00:05"}}
      Bei Tasmota AN
      PHP-Code:
      {"Time":"2021-12-18T11:43:48","Uptime":"0T00:34:10","UptimeSec":205 0,"Heap":21,"SleepMode":"Dynamic","Sleep":50,"Load Avg":19,"MqttCount":0,"POWER":"ON","Wifi":{"AP":1, "SSId":"FRITZ!Box Fon WLAN 7490","BSSId":"********","Channel":11,"RSSI":56,"Signal":-72,"LinkCount":1,"Downtime":"0T00:00:05"}}
      Danke, da is der richtige Wert enthalten, komisch ... magst du mal gucken ob es ne Exception vorher gibt? Auf der Debug Seite vom HS
        V0.2
        - Channel Auswahl hinzugefügt
        Mit E8 kann man jetzt den Channel angeben sollte das Geräte mehrere haben.
          Zitat von derPaul Beitrag anzeigen
          Ah stimmt hier könnt das an den Channels liegen ... da wäre das mal sehr Interessant was der Befehl bei dir ausgibt ... kannst du mir den mal eben zukommen lassen ?
          Ich denke Du hast Recht.
          12:19:31.986 MQT: stat/tasmota_F377FC/RESULT = {"Time":"2021-12-18T12:19:31","Uptime":"0T00:01:05","UptimeSec":65, "Heap":21,"SleepMode":"Dynamic","Sleep":50,"LoadAv g":19,"MqttCount":1,"POWER1":"ON","POWER2":"OFF"," Wifi":{"AP":1,"SSId":"UFK2","BSSId":"F0:9F:C2:7A:2 8:7B","Channel":6,"Mode":"11n","RSSI":78,"Signal":-61,"LinkCount":1,"Downtime":"0T00:00:04"}}
          12:19:36.238 MQT: stat/tasmota_F377FC/RESULT = {"POWER1":"ON"}
          12:19:36.243 MQT: stat/tasmota_F377FC/POWER1 = ON
          12:19:37.091 MQT: stat/tasmota_F377FC/RESULT = {"Time":"2021-12-18T12:19:37","Uptime":"0T00:01:11","UptimeSec":71, "Heap":21,"SleepMode":"Dynamic","Sleep":50,"LoadAv g":19,"MqttCount":1,"POWER1":"ON","POWER2":"OFF"," Wifi":{"AP":1,"SSId":"UFK2","BSSId":"F0:9F:C2:7A:2 8:7B","Channel":6,"Mode":"11n","RSSI":78,"Signal":-61,"LinkCount":1,"Downtime":"0T00:00:04"}}
          12:19:38.542 MQT: stat/tasmota_F377FC/RESULT = {"POWER1":"ON"}
          12:19:38.547 MQT: stat/tasmota_F377FC/POWER1 = ON
          12:19:42.195 MQT: stat/tasmota_F377FC/RESULT = {"Time":"2021-12-18T12:19:42","Uptime":"0T00:01:16","UptimeSec":76, "Heap":21,"SleepMode":"Dynamic","Sleep":50,"LoadAv g":19,"MqttCount":1,"POWER1":"ON","POWER2":"OFF"," Wifi":{"AP":1,"SSId":"UFK2","BSSId":"F0:9F:C2:7A:2 8:7B","Channel":6,"Mode":"11n","RSSI":78,"Signal":-61,"LinkCount":1,"Downtime":"0T00:00:04"}}
          12:19:47.302 MQT: stat/tasmota_F377FC/RESULT = {"Time":"2021-12-18T12:19:47","Uptime":"0T00:01:21","UptimeSec":81, "Heap":20,"SleepMode":"Dynamic","Sleep":50,"LoadAv g":19,"MqttCount":1,"POWER1":"ON","POWER2":"OFF"," Wifi":{"AP":1,"SSId":"UFK2","BSSId":"F0:9F:C2:7A:2 8:7B","Channel":6,"Mode":"11n","RSSI":78,"Signal":-61,"LinkCount":1,"Downtime":"0T00:00:04"}}
          12:19:50.456 MQT: stat/tasmota_F377FC/RESULT = {"POWER1":"OFF"}
          12:19:50.460 MQT: stat/tasmota_F377FC/POWER1 = OFF
          12:19:52.361 MQT: stat/tasmota_F377FC/RESULT = {"Time":"2021-12-18T12:19:52","Uptime":"0T00:01:26","UptimeSec":86, "Heap":21,"SleepMode":"Dynamic","Sleep":50,"LoadAv g":19,"MqttCount":1,"POWER1":"OFF","POWER2":"OFF", "Wifi":{"AP":1,"SSId":"UFK2","BSSId":"F0:9F:C2:7A: 28:7B","Channel":6,"Mode":"11n","RSSI":76,"Signal" :-62,"LinkCount":1,"Downtime":"0T00:00:04"}}
          12:19:57.425 MQT: stat/tasmota_F377FC/RESULT = {"Time":"2021-12-18T12:19:57","Uptime":"0T00:01:31"
          Die Keys heißen bei mir POWER1 und POWER2. Wenn die die Exception recht verstehe, erwartet der LBS den Key POWER:
            ahhh perfekt ... ja Channel hab ich gerade eingebaut, aber nicht bei der Ausgabe ... sekunde das hol ich nach ...
              V0.3
              - Channel Ausgang angepasst
              Bitte mit der V0.3 noch mal probieren ... :-)
                Gerade ausprobiert, aber leider ändert sich immer noch nichts am Ausgang 1.
                Habe es einfach mal mit Channel 0 und 1 ausprobiert.
                Unter Exceptions wird bei mir nichts angezeigt mit Tasmota
                  0 bringt nichts ... er checkt auf beide Keys "POWER" und "POWERx" (wobei X dann die Channel ID ist) ...
                  Ich gehe ganz fest davon aus das bei ufkel das damit behoben ist. Wieso er das bei dir nicht macht ... gute Frage.
                  Guckst du nur im Experten in der Live Ansicht oder auch wirklich die GA in die du das schreiben willst?
                    Ich gucke momentan immer im Experten in der Live Ansicht.
                    Habe den Eingang + Triggereingang jetzt mehrmals verändert, aber bei Status Ausgang bleibt immer die 1. tasmota.png
                    Zuletzt geändert von MarkF-081; 18.12.2021, 14:35.
                      Prüf mal bitte das GA in echt 😅
                        Muss jetzt erst die Kinder baden..............
                          Das hab ich aufgegeben ... sind danach eh immer wieder direkt schmutzig ... 😂
                            Also, dies musst du mir jetzt echt mal erklären.
                            Eines Vorweg: Mit einer echten GA funktioniert es!?
                            Und mit einer internen geht es auch.
                            Im Grunde funktioniert der Baustein.
                            Der Zähler vom Ausgang A1 bleibt allerdings bei mir immer auf 0, wenn ich ihn im Experte beobachtet.
                            Stoppe und Starte ich die Beobachtung Neu, zeigt er auch den richtigen Ausgangsstatus.
                            Dachte eigentlich man könnte sich auf die interne Diagnose verlassen.
                              Kann ich nicht, hab ich leider auch noch nicht verstanden! Hat mich aber schon mal nen halben Tag gekostet bis ich darauf gekommen war das eigentlich alles lief 😅🙈…
                              Gut also bei dir geht es! Und mit der V0.3 müsste das auch mit mehreren Channels gehen.
                              Sehr gut 😊
                                Ich versuche jetzt mal die nächsten Tage alles auf deinen Baustein umzustellen.
                                Hab allerdings nur recht wenig Zeit, weil ich jetzt auch Weihnachten/Silvester komplett durcharbeiten muss.
                                Eine kleine Spende sollte auch noch drin sein
