Hi Jonofe,
Thank you for all those infos, appreciated !
How did you get that ? Maybe playing with the language parameter and looking in the source code of the management page ? If so, I should have thought about that.
Well, things are going weird.
I re-tried the original syntax from Taxus, and it works fine, for all states. The clock display doesn't work anymore.
The behaviour is irrational, I've the impression it is based on a previous state or command execution, but no clue as to which one.
I'm the only one having Firmware: 1.67 (BETA) ?
PS: If I want to play MP3 files, is it sufficient to copy the files somewhere on a remote web server like the example
or is it mandatory to have a streaming application available on that remote web server ?
Zitat von jonofe
Zitat von jonofe
