hallo Puki,
das Image von Thorsten enthält doch gar nicht den eibd.
Hast du den eibd nachträglich installiert?
Michael
Michael
Loaded plugin: homebridge-knx
Registering platform 'homebridge-knx.KNX'
Loaded config.json with 0 accessories and 1 platforms.
Loading 1 platforms...
[KNX] Initializing KNX platform...
[KNX] Fetching KNX devices.
[KNX] parsing acc 0 of 1
[KNX] push new device Esstischlicht
[KNX] Accessory constructor called
[KNX] created Esstischlicht accessory
[KNX] returning 1 accessories
[KNX] Initializing platform accessory 'Esstischlicht'...
[KNX] Preparing Services: 1
[KNX] Preparing Service: 0 of type Lightbulb
[KNX] [Esstischlicht]:Lightbulb on/off characteristic enabled
[KNX] knx registering BOOLEAN 8/2/10
[KNX] [Esstischlicht]:[On]: Issuing read requests on the KNX bus...
[KNX] [knxdevice:knxread] preparing knx request for 8/2/10
[KNX] [Esstischlicht]:Lightbulb Brightness characteristic enabled
[KNX] knx registering PERCENT 8/2/12
[KNX] [Esstischlicht]:[Brightness]: Issuing read requests on the KNX bus...
[KNX] [knxdevice:knxread] preparing knx request for 8/2/12
>>> knxd groupsocketlisten starting <<<
Scan this code with your HomeKit App on your iOS device to pair with Homebridge:
┌────────────┐ │ 031-45-154 │
Homebridge is running on port 51826.
Scan this code with your HomeKit App on your iOS device to pair with Homebridge: ┌────────────┐ │ 031-45-154 │ └────────────┘ Homebridge is running on port 51826.
sudo /etc/init.d/eibd start bzw. stop
sudo /etc/Default/eibd start oder stop
sudo: /etc/default/eibd: command not found
[B]einzugebende Texte[/B] als Code
pi
raspberry
sudo raspi-config
sudo apt-get update
sudo apt-get upgrade
Y
g++-4.9 -v
sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-4.9 60 --slave /usr/bin/g++ g++ /usr/bin/g++-4.9
g++ -v
wget https://nodejs.org/dist/v4.0.0/node-v4.0.0-linux-armv7l.tar.gz
tar -xvf node-v4.0.0-linux-armv7l.tar.gz
cd node-v4.0.0-linux-armv7l
sudo cp -R * /usr/local/
node -v
cd ..
sudo apt-get install libavahi-compat-libdnssd-dev
Y
sudo apt-get install git
sudo npm install -g homebridge
sudo npm install -g homebridge-knx
homebridge
"bridge": {
"name": "Homebridge",
"username": "CC:22:3D:E3:CE:30",
"port": 51826,
"pin": "031-45-154"
"description": "This is an example configuration file for KNX platform shim",
"hint": "Always paste into jsonlint.com validation page before starting your homebridge, saves a lot of frustration",
"hint2": "Replace all group addresses by current addresses of your installation, these are arbitrary examples!",
"hint3": "For valid services and their characteristics have a look at the KNX.md file in folder platforms!",
"hint99": "Everything that is named description or hint is not used by homebridge but decriptive only, you may change or remove at will",
"platforms": [{
"platform": "KNX",
"name": "KNX",
"knxd_ip": "127.0.0.1",
"knxd_port": 6720,
"knxd_do_not_read_set_groups": true,
"accessories": [{
"name": "Testraum",
"services": [{
"type": "Lightbulb",
"description": "iOS8 Lightbulb type, supports On (Switch) and Brightness",
"name": "Testleuchte",
"On": {
"Set": "1/1/1",
"Listen": ["1/1/2"]
"Brightness": {
"Set": "1/1/3",
"Listen": ["1/1/4"]
sudo wget http://michlstechblog.info/blog/download/electronic/install_eibd_usb_with_cemi_patches_systemd.sh
sudo chmod +x install_eibd_usb_with_cemi_patches_systemd.sh
sudo ./install_eibd_usb_with_cemi_patches_systemd.sh
sudo reboot
1
raspberry
ps ax|grep eibd
vbusmonitor1 ip:localhost
homebridge
