Wow, Puki, vielen Dank für die ausführliche Anleitung.
Jetzt kribbelt es mir in den Fingern - ich glaub ich hab ein Wochenend-Projekt
#!/bin/sh -e # # rc.local # # This script is executed at the end of each multiuser runlevel. # Make sure that the script will "exit 0" on success or any other # value on error. # # In order to enable or disable this script just change the execution # bits. # # By default this script does nothing. # Print the IP address _IP=$(hostname -I) || true if [ "$_IP" ]; then printf "My IP address is %s\n" "$_IP" fi /etc/init.d/knxd start su root -c 'node /usr/src/homebridge/app.js < /dev/null &' exit 0
knxtool busmonitor1 ip:localhost
/usr/bin/knxd -u /tmp/eib -b ipt:192.168.xxx.xx
pi@raspberrypi:~ $ knxtool groupsocketlisten ip:localhost Write from 1.1.101 to 10/0/10: 00 Write from 1.1.101 to 10/1/21: 00 Write from 1.1.250 to 8/1/150: 01 Write from 1.1.204 to 8/2/150: 01
Homebridge is running on port 51826.
(node) warning: possible EventEmitter memory leak detected. 11 data listeners added. Use emitter.setMaxListeners() to increase limit. Trace at Socket.addListener (events.js:239:17) at Socket.Readable.on (_stream_readable.js:655:33) at Connection.openTGroup (/usr/local/lib/node_modules/homebridge-knx/node_modules/eibd/lib/connection.js:142:15) at Object.<anonymous> (/usr/local/lib/node_modules/homebridge-knx/index.js:475:20) at emitOne (events.js:82:20) at Socket.emit (events.js:169:7) at onwriteError (_stream_writable.js:304:10) at onwrite (_stream_writable.js:322:5) at WritableState.onwrite (_stream_writable.js:89:5) at fireErrorCallbacks (net.js:442:13) _stream_writable.js:0 (function (exports, require, module, __filename, __dirname) { // A bit simpler than readable streams. ^ RangeError: Maximum call stack size exceeded at decodeChunk (_stream_writable.js:243:21) at writeOrBuffer (_stream_writable.js:256:11) at Socket.Writable.write (_stream_writable.js:207:11) at Socket.write (net.js:618:40) at Connection.sendRequest (/usr/local/lib/node_modules/homebridge-knx/node_modules/eibd/lib/connection.js:187:15) at Connection.openTGroup (/usr/local/lib/node_modules/homebridge-knx/node_modules/eibd/lib/connection.js:144:8) at Object.<anonymous> (/usr/local/lib/node_modules/homebridge-knx/index.js:475:20) at emitOne (events.js:82:20) at Socket.emit (events.js:169:7) at onwriteError (_stream_writable.js:304:10)
"name": "Homebridge", "username": "CC:22:3D:E3:CE:31", "port": 51826, "pin": "031-45-154"
