Alexa Smarthome Skill (Payload Version 3)
    lordofchaos
    Die "Security Profiles" sind jetzt unter "Settings" zu finden. Die Punkte
    Consent Privacy Notice URL:https://www.amazon.com/gp/help/custo...?nodeId=468496
    Consent Logo Image:ein 512px Logo liegt dem LBS bei
    fallen an der Stelle weg.
    Ciao Jochen
      ich habe heute auf meinen pi versucht letsencrypt zu aktualisieren.
      anbei kommt unten stehende Fehlermeldung. Weis jemand voran das liegt?
      jonofe kann das auch was mit dem OAuth Problem zusammen hängen? Wobei der customer Skill noch immer geht
      (Alexa starte edomi ....)
      root@raspberrypi:/opt/letsencrypt# ./letsencrypt-auto certonly --standalone --rsa-key-size 4096 -d xxxxxxde
      Saving debug log to /var/log/letsencrypt/letsencrypt.log
      Plugins selected: Authenticator standalone, Installer None
      Cert is due for renewal, auto-renewing...
      Renewing an existing certificate
      Performing the following challenges:
      http-01 challenge for loc.my-homeip.de
      Waiting for verification...
      Cleaning up challenges
      Failed authorization procedure. xxxx.de (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://xxxx.de/.well-known/acme-challenge/EPNfxxxxxxxxxxxxxxxxxxxxxxxFg38: Error getting validation data
      IMPORTANT NOTES:
       - The following errors were reported by the server:
         Domain: xxx.de
         Type:   connection
         Detail: Fetching
         http://xxxx.de/.well-known/acme-challenge/EPNfLRjxxxxxxxxxxxxxxxxxxxxxxxxWaFg38:
         To fix these errors, please make sure that your domain name was
         entered correctly and the DNS A/AAAA record(s) for that domain
         contain(s) the right IP address. Additionally, please check that
         your computer has a publicly routable IP address and that no
         firewalls are preventing the server from communicating with the
         client. If you're using the webroot plugin, you should also verify
         that you are serving files from the webroot path you provided.
      Zuletzt geändert von lordofchaos; 15.12.2018, 11:21.
        Hallo
        ich habe heute mal versucht alles einzurichten. Bin eigentlich auch der Meinung, dass alles soweit in Ordnung war. Leider kann ich den Skill nicht aktivieren, da die Kontoverknüpfung nicht klappt. Hatte das schonmal jemand und könnte mir helfen ?
        Danke und Gruß
        Olli
          lordofchaos Sieht aus als hättest du Port 80 nicht weitergeleitet.
            Zitat von olli71 Beitrag anzeigen
            Hallo
            Danke und Gruß
            Olli
            sieht so aus, als ob die UserID nicht stimmt.....dies steht im LOG
            Source : OK
            User-ID : FAIL
            OAUTH Access Token invalid
              Man müsste mal das komplette Log ab Aktivierungsversuch in der App sehen
                habe den Fehler selber gefunden. (habe falsche config geschrieben)
                Zuletzt geändert von olli71; 16.12.2018, 00:00.
                  olli71 : Das heißt der Skill funktioniert jetzt bei dir?
                    Zumindest hat er die Konten verknüpft und mein Testgerät gefunden.
                    Olli
                      Dann solltest du das Testgerät auch schalten können und die Anleitung sollte halbwegs stimmig sein.
                        Ja, gerade getestet. Klappt einwandfrei.
                        Danke und Gruß
                        Olli
                          Kannst du mir bitte genau sagen wo dein Fehler war. Ich habe genau das selbe Problem und finde den Fehler leider nicht. Hab sogar alles nochmal von vorne mittlerweile gemacht und noch immer der selbe Fehler.
                          edit:
                          ok nicht ganz das selbe im log
                          Source : ist auch faild bei mir
                          aber konnte den skill auch nicht aktivieren
                          Zuletzt geändert von lordofchaos; 16.12.2018, 13:25. Grund: Kommentar hinzugefügt
                            ja das stimmt nur 443. Dachte 80 brauch man nicht.
                            edit:
                            Hat nun funktioniert. Hab zwar momentan zu Hause kein ipfire mehr laufen dachte aber das ich früher auch nur 443 weiter geleitet hatte an den pi.
                            Zuletzt geändert von lordofchaos; 16.12.2018, 13:28. Grund: Kommentar hinzugefügt
                              Ja, habe ich aber weiter oben geschrieben, dass letsencrypt im Januar 2018 etwas geändert hat und daher auch Port 80 notwendig ist.
                                Die ARN Nummer die ich angeben muss beginnt doch mit
                                arn:aws:lambda:eu-west-xxxxxxxxxxxxxxxxxx
