auf "local" läuft das Backup durch. Auf dem NFS bricht er ab... also ist der Container ansich ja in Ordnung.
kann das was mit der Dateiendung zu tun haben? .tmp zum Beispiel?
Aber ich werde da zuhause nochmal genau schauen...
systemctl start sshd
Jun 15 15:31:08 edomi2 ntpd[1201]: 0.0.0.0 c615 05 clock_sync Jun 15 15:31:08 edomi2 ntpd[1201]: ntp_adjtime() failed: Operation not permitted Jun 15 15:32:08 edomi2 ntpd[1201]: ntp_adjtime() failed: Operation not permitted Jun 15 15:34:23 edomi2 ntpd[1201]: ntp_adjtime() failed: Operation not permitted Jun 15 15:35:26 edomi2 systemd[1]: user.slice: Failed to set invocation ID on control group /user.slice, ignoring: Operation not permitted Jun 15 15:35:26 edomi2 systemd[1]: user-0.slice: Failed to set invocation ID on control group /user.slice/user-0.slice, ignoring: Operation not permitted Jun 15 15:35:26 edomi2 systemd[1]: Created slice User Slice of root. Jun 15 15:35:26 edomi2 systemd[1]: user.slice: Failed to set invocation ID on control group /user.slice, ignoring: Operation not permitted Jun 15 15:35:26 edomi2 systemd[1]: user-0.slice: Failed to set invocation ID on control group /user.slice/user-0.slice, ignoring: Operation not permitted Jun 15 15:35:26 edomi2 systemd[1]: user@0.service: Failed to set invocation ID on control group /user.slice/user-0.slice/user@0.service, ignoring: Operation not permitted Jun 15 15:35:26 edomi2 systemd[1]: Starting User Manager for UID 0... Jun 15 15:35:26 edomi2 systemd[1]: session-c1.scope: Failed to set invocation ID on control group /user.slice/user-0.slice/session-c1.scope, ignoring: Operation not permitted
systemctl enable sshd
dd if=/dev/zero of=zero bs=64k; sync; sync; sync; rm -f zero
/etc/pve/local/lxc/<container-ID>.conf /var/lib/lxc/<container-ID>/config.
sudo pct mount <container-ID> sudo nano /var/lib/lxc/<container-ID>/rootfs/etc/systemd/system/edomi.service sudo pct unmount <container-ID>
sudo pct mount <container-ID> sudo pct start <container-ID> sudo pct enter <container-ID> wget https://copr.fedorainfracloud.org/coprs/jsynacek/systemd-backports-for-centos-7/repo/epel-7/jsynacek-systemd-backports-for-centos-7-epel-7.repo -O /etc/yum.repos.d/jsynacek-systemd-centos-7.repo yum update systemd exit sudo pct stop <container-ID> sudo pct unmount <container-ID>
WARN: old systemd (< v232) detected, container won't run in a pure cgroupv2 environment! Please see documentation -> container -> cgroup version. Task finished with 1 warning(s)!
yum update systemd
yum update --downloadonly --downloaddir=/var/lib/lxc/<container-ID>/rootfs/var/cache/yum/x86_64/7/??? systemd
yum update systemd
