Baustein ist online, wer mag kann testen und Feedback geben. Danke.
https://service.knx-user-forum.de/?c...ad&id=19002600
David
David
[TABLE="border: 0, cellpadding: 0, cellspacing: 0"] [TR] [TD]2023-01-11 10:47:55[/TD] [TD]089587[/TD] [TD]23405[/TD] [TD]debug[/TD] [TD]EXE19002271 [v0.4]: LBS started[/TD] [/TR] [TR] [TD]2023-01-11 10:47:55[/TD] [TD]090550[/TD] [TD]23405[/TD] [TD]debug[/TD] [TD]EXE19002271 [v0.4]: url-Ertrag - Dach 1: https://api.forecast.solar//estimate/watts/xx,xxxxxx/x,xxxxxx/24/5/12,8.xml[/TD] [/TR] [TR] [TD]2023-01-11 10:47:55[/TD] [TD]325115[/TD] [TD]23405[/TD] [TD]debug[/TD] [TD]EXE19002271 [v0.4]: XML-Error - Dach 1:[/TD] [/TR] [TR] [TD]2023-01-11 10:47:55[/TD] [TD]327327[/TD] [TD]23405[/TD] [TD]debug[/TD] [TD]EXE19002271 [v0.4]: Fehlertext:[/TD] [/TR] [TR] [TD]2023-01-11 10:47:55[/TD] [TD]328783[/TD] [TD]23405[/TD] [TD]debug[/TD] [TD]EXE19002271 [v0.4]: Fehler:1[/TD] [/TR] [TR] [TD]2023-01-11 10:47:55[/TD] [TD]329348[/TD] [TD]23405[/TD] [TD]debug[/TD] [TD]EXE19002271 [v0.4]: LBS stopped[/TD] [/TR] [/TABLE]
2023-01-11 10:47:55321594?23405Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19002271.php | Fehlercode: 2 | Zeile: 63 | simplexml_load_string(): Entity: line 1: parser error : Start tag expected, '<' not foundERROR2023-01-11 10:47:55321775?23405Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19002271.php | Fehlercode: 2 | Zeile: 63 | simplexml_load_string(): There is a syntax error in your request, please check.ERROR2023-01-11 10:47:55321851?23405Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19002271.php | Fehlercode: 2 | Zeile: 63 | simplexml_load_string(): ^ERROR2023-01-11 10:47:55322784?23405Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19002271.php | Fehlercode: 8 | Zeile: 66 | Undefined variable: jsonERROR2023-01-11 10:47:55325216?23405Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19002271.php | Fehlercode: 8 | Zeile: 74 | Undefined variable: arrayERROR2023-01-11 10:47:55325299?23405Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19002271.php | Fehlercode: 8 | Zeile: 74 | Trying to get property 'message' of non-objectERROR2023-01-11 10:47:55325371?23405Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19002271.php | Fehlercode: 8 | Zeile: 74 | Trying to get property 'code' of non-objectERROR2023-01-11 10:47:55325438?23405Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19002271.php | Fehlercode: 8 | Zeile: 687 | Undefined variable: arrayERROR2023-01-11 10:47:55325503?23405Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19002271.php | Fehlercode: 8 | Zeile: 687 | Trying to get property 'message' of non-objectERROR2023-01-11 10:47:55325592?23405Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19002271.php | Fehlercode: 8 | Zeile: 687 | Trying to get property 'text' of non-objectERROR2023-01-11 10:47:55326152?23405Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19002271.php | Fehlercode: 8 | Zeile: 688 | Undefined variable: arrayERROR2023-01-11 10:47:55326245?23405Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19002271.php | Fehlercode: 8 | Zeile: 688 | Trying to get property 'message' of non-objectERROR2023-01-11 10:47:55326309?23405Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19002271.php | Fehlercode: 8 | Zeile: 688 | Trying to get property 'text' of non-objectERROR
<response> <result> <data> <key>2023-01-11 08:12:00</key> <value>0</value> </data> <data> <key>2023-01-11 09:00:00</key> <value>420</value> </data> <data> <key>2023-01-11 10:00:00</key> <value>804</value> </data> <data> <key>2023-01-11 11:00:00</key> <value>1037</value> </data> <data> <key>2023-01-11 12:00:00</key> <value>1108</value> </data> <data> <key>2023-01-11 13:00:00</key> <value>1092</value> </data> <data> <key>2023-01-11 14:00:00</key> <value>1001</value> </data> <data> <key>2023-01-11 15:00:00</key> <value>735</value> </data> <data> <key>2023-01-11 16:00:00</key> <value>282</value> </data> <data> <key>2023-01-11 16:48:00</key> <value>0</value> </data> <data> <key>2023-01-12 08:11:00</key> <value>0</value> </data> <data> <key>2023-01-12 09:00:00</key> <value>617</value> </data> <data> <key>2023-01-12 10:00:00</key> <value>807</value> </data> <data> <key>2023-01-12 11:00:00</key> <value>1044</value> </data> <data> <key>2023-01-12 12:00:00</key> <value>1117</value> </data> <data> <key>2023-01-12 13:00:00</key> <value>1091</value> </data> <data> <key>2023-01-12 14:00:00</key> <value>986</value> </data> <data> <key>2023-01-12 15:00:00</key> <value>717</value> </data> <data> <key>2023-01-12 16:00:00</key> <value>279</value> </data> <data> <key>2023-01-12 16:49:00</key> <value>0</value> </data> </result> <message> <code>0</code> <type>success</type> <text/>
// request json data
$url .= '.json?';
