Probleme mit KNXnet/IP-Tunnel und Routeranbindung
    irgendwie mag EDOMI meine Temperaturwerte nicht …?
    Hat jemand eine Idee ? Danke vorab !
     [TABLE="class: log, border: 0, cellpadding: 0, cellspacing: 0, width: 1, height: 12"]
     	 		[TR="class: sErr, bgcolor: #FF0000"]
     			[TD]2016-01-01 21:56:23[/TD]
     			[TD]904558[/TD]
     			[TD]KNX[/TD]
     			[TD]3089[/TD]
     			[TD]ERROR: IPRTR --> RECEIVE 1.1.24 ---> 0/3/4 = 2016-01-01 / Rtg:190!=191 Size:3 / 061004200017043fbe002900bce0111803040300800c47[/TD]
     			[TD]ERROR[/TD]
     		[/TR]
     			[TD]2016-01-01 22:05:23[/TD]
     			[TD]903980[/TD]
     			[TD]KNX[/TD]
     			[TD]3089[/TD]
     			[TD]ERROR: IPRTR --> RECEIVE 1.1.24 ---> 0/3/4 = 5.23:05:02 / Rtg:40!=41 Size:3 / 061004200017043f28002900bce0111803040300800c47[/TD]
     			[TD]ERROR[/TD]
     		[/TR]
     			[TD]2016-01-01 22:55:23[/TD]
     			[TD]916678[/TD]
     			[TD]KNX[/TD]
     			[TD]5689[/TD]
     			[TD]ERROR: IPRTR --> RECEIVE 1.1.24 ---> 0/3/4 = 21.88 / Rtg:46!=47 Size:3 / 06100420001704412e002900bce0111803040300800c46[/TD]
     			[TD]ERROR[/TD]
     		[/TR]
     			[TD]2016-01-02 00:09:13[/TD]
     			[TD]429194[/TD]
     			[TD]KNX[/TD]
     			[TD]5689[/TD]
     			[TD]ERROR: IPRTR --> RECEIVE 1.1.27 ---> 0/3/6 = 2016-01-02 / Rtg:121!=122 Size:3 / 061004200017044179002900bce0111b03060300800c28[/TD]
     			[TD]ERROR[/TD]
     		[/TR]
     			[TD]2016-01-02 00:09:22[/TD]
     			[TD]585752[/TD]
     			[TD]KNX[/TD]
     			[TD]5689[/TD]
     			[TD]ERROR: IPRTR --> RECEIVE 1.1.26 ---> 0/3/3 = 22.24 / Rtg:123!=124 Size:3 / 06100420001704417b002900bce0111a030303008007f1[/TD]
     			[TD]ERROR[/TD]
     		[/TR]
     			[TD]2016-01-02 00:17:23[/TD]
     			[TD]906258[/TD]
     			[TD]KNX[/TD]
     			[TD]5689[/TD]
     			[TD]ERROR: IPRTR --> RECEIVE 1.1.24 ---> 0/3/4 = 22.22 / Rtg:220!=221 Size:3 / 0610042000170441dc002900bce0111803040300800c57[/TD]
     			[TD]ERROR[/TD]
     		[/TR]
     			[TD]2016-01-02 00:21:25[/TD]
     			[TD]706733[/TD]
     			[TD]KNX[/TD]
     			[TD]5689[/TD]
     			[TD]ERROR: IPRTR --> RECEIVE 1.1.26 ---> 0/3/3 = 22.22 / Rtg:252!=253 Size:3 / 0610042000170441fc002900bce0111a030303008007f1[/TD]
     			[TD]ERROR[/TD]
     		[/TR]
     			[TD]2016-01-02 00:41:24[/TD]
     			[TD]148803[/TD]
     			[TD]KNX[/TD]
     			[TD]5689[/TD]
     			[TD]ERROR: IPRTR --> RECEIVE 1.1.29 ---> 0/3/1 = 19.82 / Rtg:225!=226 Size:3 / 0610042000170441e1002900bce0111d030103008007be[/TD]
     			[TD]ERROR[/TD]
     		[/TR]
     	 [/TABLE]
    Danke und LG, Dariusz
      ich habe auch das Problem, das ich eine 1 senden kann und bei einer 0 kommt ein Fehler.
      Ist das auch das Router Problem?
      Ich kann den Busverkehr in EDOMI sauber sehen, nach Import der GA
        @Coli 1. passen die Datentypen? (Doppelklick auf die GA)
        2. wie sind deine Tunnel konfiguriert? oder hast du nur Dummys eingefügt in der ETS
        @basaltnischl: passt die PA zur der PA die in Edomi eingestellt ist?
          SeatSLF
          1. die DPT sind 9
          2. die ETS läuft nicht, somit kann es damit nichts zu tun habe oder übersehe ich etwas ?
            Habe eine GIRA IP Router 216700
            Bei mir hat der Router 1.1.0 und EDOMI 0.0.1 bzw. habe ich jetzt mal geändert auf 1.1.2.
            Jedoch gleiches Verhalten
            bei 1.1.2 sieht es sogar schlimmer im Log aus, da stehen jetzt eine Menge dieser Meldungen
            2016-01-02 06:58:09 352212 KNX 1369 ERROR: IPRTR --> RECEIVE 1.1.4 ---> 6/0/12 = -0.58 / Rtg:40!=41 Size:3 / 061004200017043a28002900bce01104300c03008087c6 ERROR
            2016-01-02 06:58:10 362145 KNX 1369 ERROR: IPRTR --> DISCONNECT (TIMEOUT?) / ErrCode:0 / 0610020900103a000801c0a8b2340e57 ERROR
            2016-01-02 06:58:10 372665 KNX 1369 KNX-Verbindung verloren, Reconnect... ERROR
            2016-01-02 07:01:21 035554 KNX 1369 ERROR: IPRTR --> RECEIVE 1.1.110 ---> 6/2/4 = 0 / Rtg:22!=23 Size:1 / 061004200015043b16002900bce0116e3204010080 ERROR
            2016-01-02 07:01:22 045964 KNX 1369 ERROR: IPRTR --> DISCONNECT (TIMEOUT?) / ErrCode:0 / 0610020900103b000801c0a8b2340e57 ERROR
            2016-01-02 07:01:22 056555 KNX 1369 KNX-Verbindung verloren, Reconnect... ERROR
            2016-01-02 07:03:21 820358 KNX 1369 ERROR: IPRTR --> RECEIVE 1.1.110 ---> 6/2/3 = 3 / Rtg:21!=22 Size:3 / 061004200017043c15002900bce0116e3203030080012c ERROR
            2016-01-02 07:03:22 838521 KNX 1369 ERROR: IPRTR --> DISCONNECT (TIMEOUT?) / ErrCode:0 / 0610020900103c000801c0a8b2340e57 ERROR
            2016-01-02 07:03:22 848999 KNX 1369 KNX-Verbindung verloren, Reconnect... ERROR
            2016-01-02 07:03:55 103995 KNX 1369 ERROR: IPRTR --> RECEIVE 1.1.130 ---> 6/3/1 = 11 / Rtg:2!=3 Size:3 / 061004200017043d02002900bce011823301030080044c ERROR
            2016-01-02 07:03:56 116445 KNX 1369 ERROR: IPRTR --> DISCONNECT (TIMEOUT?) / ErrCode:0 / 0610020900103d000801c0a8b2340e57 ERROR
            2016-01-02 07:03:56 126960 KNX 1369 KNX-Verbindung verloren, Reconnect... ERROR
            2016-01-02 07:06:08 611814 MAIN 2238 ACHTUNG: EDOMI wurde unerwartet beendet! (Absturz?) ERROR
            2016-01-02 07:06:13 933326 KNX 2251 ERROR: IPRTR --> RECEIVE ---> = / ChannelId:62!=63 Rtg: Size: / 061004200017043e0e002900bce01104300c03008087cb ERROR
            2016-01-02 07:06:14 901331 KNX 2251 ERROR: IPRTR --> RECEIVE 1.1.4 ---> 6/0/12 = -0.53 / ChannelId:62!=63 Rtg:0 Size:3 / 061004200017043e0e002900bce01104300c03008087cb ERROR
            2016-01-02 07:06:15 908695 KNX 2251 ERROR: IPRTR --> DISCONNECT (TIMEOUT?) / ErrCode:0 / 0610020900103e000801c0a8b2340e57 ERROR
            2016-01-02 07:06:15 919326 KNX 2251 KNX-Verbindung verloren, Reconnect... ERROR
            2016-01-02 07:07:34 103413 KNX 2251 ERROR: IPRTR --> RECEIVE 1.1.148 ---> 8/2/130 = 20.25 / Rtg:18!=19 Size:3 / 061004200017044012002900bce01194428203008007e9 ERROR
            2016-01-02 07:07:35 120805 KNX 2251 ERROR: IPRTR --> DISCONNECT (TIMEOUT?) / ErrCode:0 / 06100209001040000801c0a8b2340e57 ERROR
            2016-01-02 07:07:35 131654 KNX 2251 KNX-Verbindung verloren, Reconnect...
            bei 0.0.1
            "nur" das beim senden einer 0
            2016-01-02 07:11:04 001142 KNX 1337 ERROR: EDOMI --> READ/WRITE: TIMEOUT REC / Rtg:4 / 06100421000a04460600 ERROR
            2016-01-02 07:11:08 004734 KNX 1337 ERROR: EDOMI --> READ/WRITE: TIMEOUT REC / Rtg:5 / 06100421000a04460900 ERROR
            2016-01-02 07:11:12 001832 KNX 1337 ERROR: EDOMI --> READ/WRITE: TIMEOUT REC / Rtg:6 / 06100421000a04460b00 ERROR
            2016-01-02 07:11:12 013483 KNX 1337 ERROR: EDOMI --> READ/WRITE: TOO MANY ATTEMPTS (3) / DROPED ERROR
              coliflower das wäre eigentlich der richtige DPT, spiele nimal mit den DPT, ich habe hier auch einen Sensor der die Temperatur als 4byte Wert rausgibt.
              versuch doch mal DPT 13
              basaltnischl ich habe leider keine Erfahrung mit dem Gira Router wie man dort die PAs der Tunnel vergibt, bei meinem Enertex geht das über Telnet zugang
              meine Fehler sahen genauso aus wo die PA nicht gepasst hat
                SeatSLF
                Es ist ja nicht, dass der ERROR Log ständig kommt, die Einträge oben gepostet sind bis jetzt nicht mehr gekommen …
                Andere DPT zu verwenden, ist das sauber ?
                  basaltnischl
                  Um den MarkusS zu zitieren … zwischen 1.1.x und 0.0.x gibt es 1.0.x … um zumindest die Topologie nicht zu „verbiegen“ :-)
                  https://knx-user-forum.de/forum/öffe...441#post893441
                    Hallo Christian,
                    Tolles Projekt! Macht wirklich Spaß.
                    Wenn man den HS kennt fühlt man sich gleich heimisch.
                    Edomi läuft mit dem Wiregate als Tunneling Server ohne Probleme.
                    Mit dem IP Router von Enertex (v1.030) geht es hier auch nicht.
                    Hatte versucht einen Irtrans LAN DB einzubinden. Das hat nicht funktioniert.
                    Da fehlt vermutlich der irserver in der VM oder Fehler auf Layer 8.
                    Gutes Neues.
                    Klaus
                    [ATTACH=CONFIG]n893487[/ATTACH]
                      Ich habe gestern den halben Tag getestet und gelesen. Habe es jedoch nicht geschafft den GIRA IP Router mit EDOMI sauber zum laufen zu bekommen.
                      Ich sehe den Busverkehr und kann eine 1 senden. Bei 0 bekomme ich eine Fehlermeldung.
                      Was mir dabei jedoch aufgefallen bei senden einer 1 (Licht geht an) bei 0 kommt die Fehlermeldung und noch mal gedrückt, also wieder 1 auch keine weitere Reaktion. Wenn ich jetzt mit dem Homeserver aber eine 0 sende, dann bekommt das EDOMI mit und sendet wieder eine 1 (aus dem 3. mal drücken).
                        Hilft evtl. auch ein Netzwerktrace à la Fiddler weiter?
                          oder den Tread mal im ganzen lesen? Vielleicht so ab Beitrag 248....
                            richtig :-) Deswegen verfolge ich den Tread schon seit Beitrag #1 ...
                            Jedoch bezieht sich fast alles auf den Enertex Router und die Einstellungen da. Im Handbuch den Gira Routers steht zum Tunnel fast nichts drin. Von Einstellungen des Enertex ganz zu schweigen. Und PA habe ich jetzt einige getestet, immer das gleiche Verhalten.
                            Hat jemand EDOMI am Gira Router sauber laufen?
                              Hast du über die ETS DER Routing Schnittstelle eine PA zugewiesen und kannst über diese auf den Bus zugreifen?
                              (siehe Anleitung Punkt 5.3)
                              Wenn ja, ETS beenden, der Router braucht minimum 2 Minuten um diese Tunneladresse wieder freizugeben!
                              Edomi gibst du dann diese Adresse, normalerweiße sollten über der PA die nächsten PA freigehalten werden für die anderen Tunnel.
                              Hast du den Router mal alle Filterfunktionen abgewöhnt?
                              Achja der HS kommuniziert über Multicast, hat also mit der Tunnel Funktion nichts zu tun.
                                Wenn ich es richtig verstanden habe dann muss ich in der edomi.ini ja die Geräte PA eintragen (ähnlich eine PA eines Aktors).
                                Die PA die du beschreibst ist die PA des Tunnels und nicht der Hardware ...
                                Soooo, was muss jetzt in der INI eingetragen werden, die PA der HW oder die PA des Tunnels (ich habe derzeit die PA der HW 1.0.2 eingetragen) ?
                                DANKE !
