Allowed memory size of 67108864 bytes exhausted (tried to allocate 71 bytes)
2022-04-11 19:21:09 905025 ? 10851 Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19000350.php | Fehlercode: 2 | Zeile: 178 | Illegal offset type in isset or empty ERROR 2022-04-12 01:43:34 950000 ? 10851 Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19000350.php | Fehlercode: 2 | Zeile: 178 | Illegal offset type in isset or empty ERROR 2022-04-12 12:47:35 954471 ? 10851 Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19000350.php | Fehlercode: 2 | Zeile: 178 | Illegal offset type in isset or empty ERROR 2022-04-12 15:03:39 827629 ? 10851 Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19000350.php | Fehlercode: 2 | Zeile: 178 | Illegal offset type in isset or empty ERROR 2022-04-12 16:51:22 852206 ? 10851 Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19000350.php | Fehlercode: 2 | Zeile: 178 | Illegal offset type in isset or empty ERROR 2022-04-12 21:29:35 731220 ? 10851 Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19000350.php | Fehlercode: 2 | Zeile: 178 | Illegal offset type in isset or empty ERROR 2022-04-12 23:41:03 460916 ? 10851 Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19000350.php | Fehlercode: 2 | Zeile: 178 | Illegal offset type in isset or empty ERROR 2022-04-13 07:25:59 470887 ? 10851 Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19000350.php | Fehlercode: 2 | Zeile: 178 | Illegal offset type in isset or empty ERROR 2022-04-13 07:29:25 509916 ? 10851 Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19000350.php | Fehlercode: 2 | Zeile: 178 | Illegal offset type in isset or empty ERROR 2022-04-13 07:32:49 684484 ? 10851 Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19000350.php | Fehlercode: 2 | Zeile: 178 | Illegal offset type in isset or empty ERROR 2022-04-13 12:26:22 312793 ? 10851 Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19000350.php | Fehlercode: 2 | Zeile: 178 | Illegal offset type in isset or empty ERROR 2022-04-13 13:29:11 856416 ? 10851 Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19000350.php | Fehlercode: 1 | Zeile: 126 | Allowed memory size of 67108864 bytes exhausted (tried to allocate 71 bytes) FATALERROR
