Ich würde es mit einem oder zwei Wertauslöser LBS bauen.
Grüsse
Grüsse
| Datei: /usr/local/edomi/main/include/php/Phue/library/Phue/Command/CreateGroup.php | Fehlercode: 8 | Zeile: 104 | Undefined offset: 2 |
| {EDOMI,CUSTOMLOG_HUE_Group-LBS19000375.htm,29.07.2020,13:51:02,628237,3332} | ||||
| Zeitstempel | ms | PID | LogLevel | Meldung |
| 2020-07-29 13:51:02 | 628199 | 3332 | debug | LBS19000375 [v0.3]: LBS started (478) |
| 2020-07-29 13:51:02 | 628779 | 3332 | debug | LBS19000375 [v0.3]: LBS stopped (478) |
| 2020-07-29 13:51:02 | 787448 | 3332 | debug | LBS19000375 [v0.3]: LBS started (478) |
| 2020-07-29 13:51:02 | 788948 | 3332 | debug | LBS19000375 [v0.3]: tmpID: 4984 (478) |
| 2020-07-29 13:51:02 | 794152 | 3332 | debug | LBS19000375 [v0.3]: LBS stopped (478) |
| 2020-07-29 13:51:02 | 821816 | 3389 | debug | EXE19000375 [v0.3]: HUE Group daemon started (group tmp ID: 4984) (478) |
| 2020-07-29 13:51:06 | 737143 | 3389 | debug | EXE19000375 [v0.3]: GROUPID message received from bridge (478) |
| 2020-07-29 13:51:06 | 737195 | 3389 | debug | EXE19000375 [v0.3]: ================ ARRAY/OBJECT START ================ |
| 2020-07-29 13:51:06 | 737235 | 3389 | debug | EXE19000375 [v0.3]: {"cmd":"GROUPID","groupid":null} |
| 2020-07-29 13:51:06 | 737260 | 3389 | debug | EXE19000375 [v0.3]: ================ ARRAY/OBJECT END ================ |
| 2020-07-29 13:51:13 | 778861 | 3332 | debug | LBS19000375 [v0.3]: LBS started (478) |
| 2020-07-29 13:51:13 | 779674 | 3332 | debug | LBS19000375 [v0.3]: Sending command to Bridge LBS: (478) |
| 2020-07-29 13:51:13 | 779706 | 3332 | debug | LBS19000375 [v0.3]: ================ ARRAY/OBJECT START ================ |
| 2020-07-29 13:51:13 | 779736 | 3332 | debug | LBS19000375 [v0.3]: {"on":"1","cmd":"changeGroup","no":null} |
| 2020-07-29 13:51:13 | 779755 | 3332 | debug | LBS19000375 [v0.3]: ================ ARRAY/OBJECT END ================ |
| 2020-07-29 13:51:13 | 780065 | 3332 | debug | LBS19000375 [v0.3]: LBS stopped (478) |
| 2020-07-29 13:51:21 | 479175 | 3332 | debug | LBS19000375 [v0.3]: LBS started (478) |
| 2020-07-29 13:51:21 | 479935 | 3332 | debug | LBS19000375 [v0.3]: Sending command to Bridge LBS: (478) |
| 2020-07-29 13:51:21 | 479969 | 3332 | debug | LBS19000375 [v0.3]: ================ ARRAY/OBJECT START ================ |
| 2020-07-29 13:51:21 | 479990 | 3332 | debug | LBS19000375 [v0.3]: {"on":"1","cmd":"changeGroup","no":null} |
| 2020-07-29 13:51:21 | 480006 | 3332 | debug | LBS19000375 [v0.3]: ================ ARRAY/OBJECT END ================ |
| 2020-07-29 13:51:21 | 480329 | 3332 | debug | LBS19000375 [v0.3]: LBS stopped (478) |
| 2020-07-29 13:51:55 | 448658 | 3332 | debug | LBS19000375 [v0.3]: LBS started (478) |
| 2020-07-29 13:51:55 | 449259 | 3332 | debug | LBS19000375 [v0.3]: Sending command to Bridge LBS: (478) |
| 2020-07-29 13:51:55 | 449287 | 3332 | debug | LBS19000375 [v0.3]: ================ ARRAY/OBJECT START ================ |
| 2020-07-29 13:51:55 | 449309 | 3332 | debug | LBS19000375 [v0.3]: {"cmd":"changeGroup","no":null} |
| 2020-07-29 13:51:55 | 449325 | 3332 | debug | LBS19000375 [v0.3]: ================ ARRAY/OBJECT END ================ |
| 2020-07-29 13:51:55 | 449619 | 3332 | debug | LBS19000375 [v0.3]: LBS stopped (478) |
| 2020-07-29 13:51:59 | 194185 | 3332 | debug | LBS19000375 [v0.3]: LBS started (478) |
| 2020-07-29 13:51:59 | 195023 | 3332 | debug | LBS19000375 [v0.3]: Sending command to Bridge LBS: (478) |
| 2020-07-29 13:51:59 | 195054 | 3332 | debug | LBS19000375 [v0.3]: ================ ARRAY/OBJECT START ================ |
| 2020-07-29 13:51:59 | 195075 | 3332 | debug | LBS19000375 [v0.3]: {"on":"1","cmd":"changeGroup","no":null} |
| 2020-07-29 13:51:59 | 195091 | 3332 | debug | LBS19000375 [v0.3]: ================ ARRAY/OBJECT END ================ |
| 2020-07-29 13:51:59 | 195410 | 3332 | debug | LBS19000375 [v0.3]: LBS stopped (478) |
| 2020-07-29 13:51:14 | 101211 | 3352 | debug | EXE19000195 [v1.4]: Command received (254) |
| 2020-07-29 13:51:14 | 101265 | 3352 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT START ================ |
| 2020-07-29 13:51:14 | 101286 | 3352 | debug | EXE19000195 [v1.4]: {"on":"1","cmd":"changeGroup","no":null} |
| 2020-07-29 13:51:14 | 101304 | 3352 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT END ================ |
| 2020-07-29 13:51:14 | 144372 | 3352 | debug | EXE19000195 [v1.4]: Received command from group (see array) (254) |
| 2020-07-29 13:51:14 | 144428 | 3352 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT START ================ |
| 2020-07-29 13:51:14 | 144448 | 3352 | debug | EXE19000195 [v1.4]: {"on":"1"} |
| 2020-07-29 13:51:14 | 144464 | 3352 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT END ================ |
Und sorry für die verspätete Rückmeldung...| 2020-08-27 15:01:23 | 126447 | 9398 | debug | LBS19000195 [v1.4]: HUE Bridge LBS started (502) |
| 2020-08-27 15:01:23 | 130680 | 9398 | debug | LBS19000195 [v1.4]: HUE Bridge LBS stopped (502) |
| 2020-08-27 15:01:23 | 158911 | 9419 | debug | EXE19000195 [v1.4]: HUE Bridge daemon started (502) |
| 2020-08-27 15:01:23 | 160605 | 9419 | debug | EXE19000195 [v1.4]: Create Message Queue with ID: 5f47aea326d4a (502) |
| 2020-08-27 15:01:23 | 169298 | 9419 | debug | EXE19000195 [v1.4]: Command received (502) |
| 2020-08-27 15:01:23 | 169358 | 9419 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT START ================ |
| 2020-08-27 15:01:23 | 169393 | 9419 | debug | EXE19000195 [v1.4]: {"cmd":"updateDeviceList"} |
| 2020-08-27 15:01:23 | 169416 | 9419 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT END ================ |
| 2020-08-27 15:01:23 | 219983 | 9419 | debug | EXE19000195 [v1.4]: Devices connected to HUE bridge: 1 lay:Extended color light|2:Play rechts:Extended color light|4:Bettlampe links immable light|5:Kücheninsel:Extended color light|6:Bettlampe rechts immable light|7:Hue Argenta color spot 1:Extended color light|8:Hue Argenta color spot 2:Extended color light|1 aylight aylight|2:Hue dimmer switch 1:ZLLSwitch (502) |
| 2020-08-27 15:01:23 | 753619 | 9419 | debug | EXE19000195 [v1.4]: Command received (502) |
| 2020-08-27 15:01:23 | 753669 | 9419 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT START ================ |
| 2020-08-27 15:01:23 | 753690 | 9419 | debug | EXE19000195 [v1.4]: {"cmd":"registerLight","no":"1"} |
| 2020-08-27 15:01:23 | 753706 | 9419 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT END ================ |
| 2020-08-27 15:01:23 | 799418 | 9419 | debug | EXE19000195 [v1.4]: Light 1 registered (502) |
| 2020-08-27 15:01:23 | 832222 | 9419 | debug | EXE19000195 [v1.4]: Update of HUE device 1 (see array) (502) |
| 2020-08-27 15:01:23 | 832288 | 9419 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT START ================ |
| 2020-08-27 15:01:23 | 832324 | 9419 | debug | EXE19000195 [v1.4]: {"id":1,"name":"play","type":"Extended color light","model":"LCT024","swVersion":"1.50.2_r30933 ","on":false,"alert":"none","hue":"a4","satura tion ":"4e","brightness":"3f","hsv":"a44e3f","x":0. 5117 ,"y":0.3321,"xy":"0.5117|0.3321","r":"2c","g":" 2e" ,"b":"3f","rgb":"2c2e3f","effect":"none","color Tem p":153,"colorMode":"xy","reachable":"0","cmd":" sta tusUpdate"} |
| 2020-08-27 15:01:23 | 832356 | 9419 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT END ================ |
| 2020-08-27 15:01:23 | 832792 | 9419 | debug | EXE19000195 [v1.4]: PING HUE device 1 (502) |
| 2020-08-27 15:01:24 | 334341 | 9419 | debug | EXE19000195 [v1.4]: Command received (502) |
| 2020-08-27 15:01:24 | 334397 | 9419 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT START ================ |
| 2020-08-27 15:01:24 | 334417 | 9419 | debug | EXE19000195 [v1.4]: {"cmd":"registerLight","no":"4"} |
| 2020-08-27 15:01:24 | 334433 | 9419 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT END ================ |
| 2020-08-27 15:01:24 | 378767 | 9419 | debug | EXE19000195 [v1.4]: Light 4 registered (502) |
| 2020-08-27 15:01:24 | 411739 | 9419 | debug | EXE19000195 [v1.4]: Update of HUE device 4 (see array) (502) |
| 2020-08-27 15:01:24 | 411808 | 9419 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT START ================ |
| 2020-08-27 15:01:24 | 411842 | 9419 | debug | EXE19000195 [v1.4]: {"id":4,"name":"Bettlampe links","type":"Dimmable light","model":"LWO001","swVersion":"1.65.9_hB3217 DF","on":false,"alert":"select","brightness":"fe ", "reachable":"1","cmd":"statusUpdate"} |
| 2020-08-27 15:01:24 | 411870 | 9419 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT END ================ |
| 2020-08-27 15:01:24 | 412302 | 9419 | debug | EXE19000195 [v1.4]: PING HUE device 4 (502) |
| 2020-08-27 15:01:24 | 914228 | 9419 | debug | EXE19000195 [v1.4]: Command received (502) |
| 2020-08-27 15:01:24 | 914294 | 9419 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT START ================ |
| 2020-08-27 15:01:24 | 914314 | 9419 | debug | EXE19000195 [v1.4]: {"cmd":"registerLight","no":"2"} |
| 2020-08-27 15:01:24 | 914330 | 9419 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT END ================ |
| 2020-08-27 15:01:24 | 959431 | 9419 | debug | EXE19000195 [v1.4]: Light 2 registered (502) |
| 2020-08-27 15:01:24 | 993256 | 9419 | debug | EXE19000195 [v1.4]: Update of HUE device 2 (see array) (502) |
| 2020-08-27 15:01:24 | 993328 | 9419 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT START ================ |
| 2020-08-27 15:01:24 | 993365 | 9419 | debug | EXE19000195 [v1.4]: {"id":2,"name":"Play rechts","type":"Extended color light","model":"LCT024","swVersion":"1.50.2_r30933 ","on":false,"alert":"none","hue":"f8","satura tion ":"7e","brightness":"3f","hsv":"f87e3f","x":0. 5122 ,"y":0.3319,"xy":"0.5122|0.3319","r":"3f","g":" 20" ,"b":"25","rgb":"3f2025","effect":"none","color Tem p":467,"colorMode":"xy","reachable":"0","cmd":" sta tusUpdate"} |
| 2020-08-27 15:01:24 | 993393 | 9419 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT END ================ |
| 2020-08-27 15:01:24 | 993803 | 9419 | debug | EXE19000195 [v1.4]: PING HUE device 2 (502) |
| 2020-08-27 15:01:25 | 495702 | 9419 | debug | EXE19000195 [v1.4]: Command received (502) |
| 2020-08-27 15:01:25 | 495781 | 9419 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT START ================ |
| 2020-08-27 15:01:25 | 495804 | 9419 | debug | EXE19000195 [v1.4]: {"cmd":"registerLight","no":"5"} |
| 2020-08-27 15:01:25 | 495820 | 9419 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT END ================ |
| 2020-08-27 15:01:25 | 541122 | 9419 | debug | EXE19000195 [v1.4]: Light 5 registered (502) |
| 2020-08-27 15:01:25 | 614298 | 9419 | debug | EXE19000195 [v1.4]: Update of HUE device 5 (see array) (502) |
| 2020-08-27 15:01:25 | 614361 | 9419 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT START ================ |
| 2020-08-27 15:01:25 | 614398 | 9419 | debug | EXE19000195 [v1.4]: {"id":5,"name":"K\u00fccheninsel","type":"Exten ded color light","model":"LST002","swVersion":"1.50.2_r30933 ","on":false,"alert":"select","hue":"b7","satu rati on":"fe","brightness":"01","hsv":"b7fe01","x":0. 15 32,"y":0.0475,"xy":"0.1532|0.0475","r":"00","g":" 0 0","b":"01","rgb":"000001","effect":"none","col orT emp":153,"colorMode":"hs","reachable":"1","cmd":" s tatusUpdate"} |
| 2020-08-27 15:01:25 | 614428 | 9419 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT END ================ |
| 2020-08-27 15:01:25 | 614830 | 9419 | debug | EXE19000195 [v1.4]: PING HUE device 5 (502) |
| 2020-08-27 15:01:26 | 116863 | 9419 | debug | EXE19000195 [v1.4]: Command received (502) |
| 2020-08-27 15:01:26 | 116921 | 9419 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT START ================ |
| 2020-08-27 15:01:26 | 116942 | 9419 | debug | EXE19000195 [v1.4]: {"cmd":"registerLight","no":"6"} |
| 2020-08-27 15:01:26 | 116959 | 9419 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT END ================ |
| 2020-08-27 15:01:26 | 161472 | 9419 | debug | EXE19000195 [v1.4]: Light 6 registered (502) |
| 2020-08-27 15:01:26 | 195595 | 9419 | debug | EXE19000195 [v1.4]: Update of HUE device 6 (see array) (502) |
| 2020-08-27 15:01:26 | 195662 | 9419 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT START ================ |
| 2020-08-27 15:01:26 | 195698 | 9419 | debug | EXE19000195 [v1.4]: {"id":6,"name":"Bettlampe rechts","type":"Dimmable light","model":"LWO001","swVersion":"1.65.9_hB3217 DF","on":false,"alert":"select","brightness":"fe ", "reachable":"1","cmd":"statusUpdate"} |
| 2020-08-27 15:01:26 | 195769 | 9419 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT END ================ |
| 2020-08-27 15:01:26 | 196338 | 9419 | debug | EXE19000195 [v1.4]: PING HUE device 6 (502) |
| 2020-08-27 15:01:26 | 697659 | 9419 | debug | EXE19000195 [v1.4]: Command received (502) |
| 2020-08-27 15:01:26 | 697734 | 9419 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT START ================ |
| 2020-08-27 15:01:26 | 697760 | 9419 | debug | EXE19000195 [v1.4]: {"cmd":"registerSensor","no":"2"} |
| 2020-08-27 15:01:26 | 697776 | 9419 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT END ================ |
| 2020-08-27 15:01:26 | 742048 | 9419 | debug | EXE19000195 [v1.4]: Sensor 2 registered (502) |
| 2020-08-27 15:01:26 | 757379 | 9419 | debug | EXE19000195 [v1.4]: Update of HUE sensor 2 (see array) (502) |
| 2020-08-27 15:01:26 | 757435 | 9419 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT START ================ |
| 2020-08-27 15:01:26 | 757457 | 9419 | debug | EXE19000195 [v1.4]: {"name":"Hue dimmer switch 1","type":"ZLLSwitch","modelId":"RWL021","manuf act urer":"Signify Netherlands B.V.","swVersion":"6.1.1.28573","uniqueId":"00:17: 88:01:08:6b:04:7a-02-fc00","on":true,"reachable":true,"battery":100,"se nsorId":"2","cmd":"statusUpdate"} |
| 2020-08-27 15:01:26 | 757476 | 9419 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT END ================ |
| 2020-08-27 15:01:26 | 757883 | 9419 | debug | EXE19000195 [v1.4]: PING HUE sensor 2 (502) |
| 2020-08-27 15:01:27 | 275816 | 9419 | debug | EXE19000195 [v1.4]: Command received (502) |
| 2020-08-27 15:01:27 | 275872 | 9419 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT START ================ |
| 2020-08-27 15:01:27 | 275893 | 9419 | debug | EXE19000195 [v1.4]: {"cmd":"createGroup","no":6592,"name":"Schlafzi mme rBett","lights":"4,6"} |
| 2020-08-27 15:01:27 | 275911 | 9419 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT END ================ |
| 2020-08-27 15:01:27 | 320863 | 9419 | debug | EXE19000195 [v1.4]: gLights: (502) |
| 2020-08-27 15:01:27 | 320938 | 9419 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT START ================ |
| 2020-08-27 15:01:27 | 320970 | 9419 | debug | EXE19000195 [v1.4]: [4,6] |
| 2020-08-27 15:01:27 | 320996 | 9419 | debug | EXE19000195 [v1.4]: ================ ARRAY/OBJECT END ================ |
