z.B. Telegrammgenerator
Oder den Binäreingang auf zyklisch Senden konfigurieren.
2018-06-25 15:25:23 320411 19433 debug LBS19000301 [v0.4]: TTS LBS started (1446)
2018-06-25 15:25:23 329050 19433 debug LBS19000301 [v0.4]: Got text:Hallo, das ist ein Test! (1446)
2018-06-25 15:25:23 330202 19433 debug LBS19000301 [v0.4]: TTS LBS ended (1446)
2018-06-25 15:25:23 408947 19847 debug EXE19000301 [v0.4]: TextToSpeech-EXEC : ### INFO ### - Directory: /usr/local/edomi/www/data/tmp/tts (1446)
2018-06-25 15:25:23 410222 19847 debug EXE19000301 [v0.4]: Text-To-Speech execution started (1446)
2018-06-25 15:25:23 411269 19847 debug EXE19000301 [v0.4]: Creating output file: /usr/local/edomi/www/data/tmp/tts/edomi_20180625-152523.mp3 (1446)
2018-06-25 15:25:23 412380 19847 debug EXE19000301 [v0.4]: Executing command: /usr/local/bin/nanotts -v de-DE --speed 1 --pitch 1 --volume 1 --no-play -c -w 'Hallo, das ist ein Test!'| /usr/bin/lame -r -s 16 --bitwidth 16 -m m -b 192 -h - /usr/local/edomi/www/data/tmp/tts/edomi_20180625-152523.mp3 (1446)
2018-06-25 15:25:23 435791 19847 debug EXE19000301 [v0.4]: Result: a:5:{i:0;s:27:"Assuming raw pcm input file";i:1;s:39:"LAME 3.99.5 64bits (http://lame.sf.net)";i:2;s:33:"polyphase lowpass filter disabled";i:3;s:79:"Encoding <stdin> to /usr/local/edomi/www/data/tmp/tts/edomi_20180625-152523.mp3";i:4;s:68:"Encoding as 16 kHz single-ch MPEG-2 Layer III (1.3x) 160 kbps qval=2";} (1446)
2018-06-25 15:25:23 442480 19847 debug EXE19000301 [v0.4]: Text-To-Speech execution finished (1446)
[root@edomi tmp]# git clone https://github.com/gmn/nanotts Initialized empty Git repository in /tmp/nanotts/.git/ error: while accessing https://github.com/gmn/nanotts/info/refs fatal: HTTP request failed
git clone https://github.com/jonofe/nanotts cd nanotts make
[root@edomi-test nanotts]# [COLOR=#FF0000][B]./nanotts -h[/B][/COLOR]
usage: nanotts [options]
-h, --help displays this
-v <voice> select voice. Default: en-GB
-l <directory> Lingware voices directory.
-w <words> words. must be correctly quoted.
-f <filename> filename to read input from
-o <filename> write output to single file; overrides prefix
--no-play|-m do NOT play output on PC's soundcard
-c send PCM output to stdout
--speed <0.2-5.0> change voice speed
--pitch <0.5-2.0> change voice pitch
--volume <0.0-5.0> change voice volume (>1.0 may result in degraded quality)
Possible Voices:
en-US, en-GB, de-DE, es-ES, fr-FR, it-IT
Examples:
nanotts -f <filename> -o file1.wav --no-play
echo "Mary had a little lamb" | nanotts
nanotts -w "Once upon a midnight dreary" -v en-US --speed 0.5 --pitch 0.5
