tut mir leid, irgendwie ist es von meiner TODO-Liste gerutscht. Ich wollte das schon viel früher posten.
Erstmal das init-Skript: /etc/init.d/openhab
Dann noch die Konfigurationsdatei /etc/default/openhab
Sorry für die lange Wartezeit,
Daniel
#! /bin/sh ### BEGIN INIT INFO # Provides: starts openhab from home # Required-Start: $network $remote_fs $syslog # Required-Stop: $network $remote_fs $syslog # Default-Start: 2 3 4 5 # Default-Stop: 0 1 6 # Short-Description: Kurze Beschreibung # Description: Längere Bechreibung ### END INIT INFO # Author: # set ports for HTTP(S) server HTTP_PORT=8080 HTTPS_PORT=8443 if test -f /etc/default/openhab; then . /etc/default/openhab else echo "Please set OPENHABPATH in /etc/default/openhab" exit 1 fi # Aktionen case "$1" in start) if [ -f /var/run/openhab.pid ]; then echo "openhab seems to run allready. If not, please delete /var/run/openhab.pid" else cd $OPENHABPATH # get path to equinox jar inside $OPENHABPATH folder cp=$(find ./server -name "org.eclipse.equinox.launcher_*.jar" | sort | tail -1); echo Launching the openHAB runtime.. java -Dosgi.clean=true -Declipse.ignoreApp=true -Dosgi.noShutdown=true -Djetty.port=$HTTP_PORT -Djetty.port.ssl=$HTTPS_PORT -Djetty.home=. -Dlogback.configurationFile=configurations/logback.xml -Dfelix.fileinstall.dir=addons -Djava.library.path=lib -Djava.security.auth.login.config=./etc/login.conf -Dorg.quartz.properties=./etc/quartz.properties -Dequinox.ds.block_timeout=240000 -Dequinox.scr.waitTimeOnBlock=60000 -Djava.awt.headless=true -jar $cp -console &> /dev/null echo $! > /var/run/openhab.pid fi ;; stop) echo "stopping openhab" kill `cat /var/run/openhab.pid` rm /var/run/openhab.pid ;; restart) echo "does not work" ;; esac exit 0
# PATH TO OPENHAB OPENHABPATH=/opt/openhab # set ports for HTTP(S) server HTTP_PORT=8080 HTTPS_PORT=8443
Daniel
