Hallo Stefan,
danke für die schnelle Hilfe.
Meinst du so?
Das funktioniert nicht, da bekomme ich dann:
Gruß und danke Manuel
Meinst du so?
loggers:
knx_busmonitor:
level: INFO
handlers: [busmonitor_file ]
plugins.sonos:
level: Error
smarthome@SmarthomeNG:~ $ systemctl status smarthome.service ● smarthome.service - SmartHomeNG daemon Loaded: loaded (/lib/systemd/system/smarthome.service; enabled; vendor preset: enabled) Active: failed (Result: exit-code) since Tue 2018-01-30 19:11:11 CET; 1min 16s ago Process: 576 ExecStart=/usr/bin/python3 /usr/local/smarthome/bin/smarthome.py (code=exited, status=1/FAILURE) Jan 30 19:11:11 SmarthomeNG python3[576]: logging.config.dictConfig(doc) Jan 30 19:11:11 SmarthomeNG python3[576]: File "/usr/lib/python3.5/logging/config.py", line 795, in dictConfig Jan 30 19:11:11 SmarthomeNG python3[576]: dictConfigClass(config).configure() Jan 30 19:11:11 SmarthomeNG python3[576]: File "/usr/lib/python3.5/logging/config.py", line 615, in configure Jan 30 19:11:11 SmarthomeNG python3[576]: '%r: %s' % (name, e)) Jan 30 19:11:11 SmarthomeNG python3[576]: ValueError: Unable to configure logger 'plugins.sonos': Unknown level: 'Error' Jan 30 19:11:11 SmarthomeNG systemd[1]: smarthome.service: Control process exited, code=exited status=1 Jan 30 19:11:11 SmarthomeNG systemd[1]: Failed to start SmartHomeNG daemon. Jan 30 19:11:11 SmarthomeNG systemd[1]: smarthome.service: Unit entered failed state. Jan 30 19:11:11 SmarthomeNG systemd[1]: smarthome.service: Failed with result 'exit-code'.
