LBS mqtt (12981)
    Hallo derPaul,
    richtig da war doch was mit dem Eingang:-).
    Unabhängig von der Überwachung und dem Statusausgang habe ich einfach verglichen und konnte sehen, dass sich die Werte nicht aktualisiert haben.
    Danke für deine Mühe!
      Moin,
      so ich kann das jetzt nachstellen ... wenn der Broker weg bricht dann fliegt ne Exception und der reconnect verschluckt sich .... muss mal sehen wie ich das in den Griff bekomm.
        V1.15
        - Reconnect Fix​
        So damit sollte er sich auch nach nem Error wieder verbinden. Timeout sind fest 30 Sekunden.
        Also kommt es zu ner unerwarteten Unterbrechung wartet er immer 30 Sekunden und probiert es erneut.
          Where can I download the v1.15 of the LBS 12981?
            always on page one the first message ;-)
              Danke
                you are welcome
                  Hi, I wanted to verify the following:
                  1) Restart LBS is not implemented (not needed because of point 2)
                  2) Reconnection attempt after every 30 second when there is a lost connection
                  Right?
                    correct
                      One more question/remark about the broker status (text) and maybe a bug.
                      The broker status (text) only has a relevant output when you are subscribing. Right? When you publish something the connection is closed after the publish statement.
                      If the above is true then there is no relevant output in the LBS 12981 at the moment of publishing.
                      I created an end-to-end connection status by comparing the command with the status, see print screen.​
                      Maybe a bug
                      ​The broker status isn't consistently reporting. I have two subscribers. One gets the status subscribed the other gets the status false. Note that both subscribers work fine I get the status and power returned. I use the same logic for other Shellies and there the broker status (text) is for both of them false. Although the status and power work fine. Maybe something to look into?
                        how do you check these status fields? via expert live debugger?
                          Both as status strings in the application as with the live debugger (the live debugger seems to translate the word "true" automatically into a 1)Scherm­afbeelding 2023-05-31 om 22.38.08.png​
                          Zuletzt geändert von AdVanHooft; 31.05.2023, 21:39.
                            live debugger won‘t work… please don‘t use it for this logic
                              iGude,
                              vielleicht könnt ihr einem MQTT Noob helfen.....
                              Ich versuche eine OpenWB mit dem LBS Auszulesen. Eigentlich klappt das auch ganz gut.
                              Jedoch geht der LBS nach einiger Zeit in Stop. Im Debug fenster kommt, dass die Verbindung gecancelt wurde.
                              Im LBS Monitor steht bei Broker Status Subscribed. Den LBS Neustarten bringt leider auch keine Änderung.
                              File "hs_logik.py", line 230, in calc
                              File "formula", line 1, in [module]
                              TypeError: restartLBS() takes exactly 1 argument (2 given)
                              [5012L, 12981L, 0L, 'EC[13] and EN[13] == 1', 'pItem.LogikItem.SHARED_MQTT.restartLBS(pItem)', '', 0L, 0L, 0L, 0L]
                              File "hs_event.py", line 943, in doSend
                              File "lib_tcpclient.py", line 44, in connect
                              File "/usr/lib/python2.7/socket.py", line 228, in meth
                              return getattr(self._sock,name)(*args)
                              error: [Errno 113] No route to host
                              EDIT
                              Nachdem ich den Debugplayer gestopt und gestartet habe ist der Broker Status 1.
                              Aber die Meldungen oben in der Debug liste bleiben.
                              Ein Neustart des HS bringt hier kurz abhilfe.
                              Zuletzt geändert von larsrosen; 19.07.2023, 08:41.
                              Elektroinstallation-Rosenberg
                              -Systemintegration-
                              http://www.knx-haus.com
                                No route to host klingt danach als wenn der HS die Verbindung zum mqtt Server verliert ... Netzwerkaussetzer oder sowas ?!
