Anbindung Modbus / Nibe
    Ja bitte, poste mal das Plugin. Wg. der Last ich habe dzt. auf meinem virtuellen Server auch eine Last von ca. 5% CPU (und das läuft auf einem Xeon). Allerdings glaube ich, dass mein USB-Passthrough ein wenig verbuggt ist, da auch das D&W KWL Plugin von sh.py über FTDI 99% Last verursacht.
      Hier die benötigten Dateien
      smarthome/plugins/nibe/__init__py
      #!/usr/bin/env python3
      # vim: set encoding=utf-8 tabstop=4 softtabstop=4 shiftwidth=4 expandtab
      #  Copyright 2013 KNX-User-Forum e.V.           https://knx-user-forum.de/
      #  NIBE plugin for SmartHome.py.         http://mknx.github.io/smarthome/
      #  This plugin is free software: you can redistribute it and/or modify
      #  it under the terms of the GNU General Public License as published by
      #  the Free Software Foundation, either version 3 of the License, or
      #  (at your option) any later version.
      #  This plugin is distributed in the hope that it will be useful,
      #  but WITHOUT ANY WARRANTY; without even the implied warranty of
      #  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
      #  GNU General Public License for more details.
      #  You should have received a copy of the GNU General Public License
      #  along with this plugin. If not, see <http://www.gnu.org/licenses/>.
      import logging
      import serial
      import re
      import time
      import termios
      from struct import *
      logger = logging.getLogger('NIBE')
      class NIBE():
          def __init__(self, smarthome, serialport):
              self._sh = smarthome
              self._nibe_regs = {}
              self._serial = serial.Serial(serialport, 19200, bytesize=serial.EIGHTBITS, stopbits=serial.STOPBITS_ONE, timeout=3)
              iflag, oflag, cflag, lflag, ispeed, ospeed, cc = termios.tcgetattr(self._serial)
              CMSPAR = 0x40000000
              cflag |= termios.PARENB | CMSPAR | termios.PARODD # to select MARK parity
              termios.tcsetattr(self._serial, termios.TCSANOW, [iflag, oflag, cflag, lflag, ispeed, ospeed, cc])
          def run(self):
              self.alive = True
              try:
                  while self.alive:
                      #time.sleep(0.001)
                      if self._serial.read(1)[0] != 0x03:
                          continue
                      ret = self._serial.read(2)
                      if ret[0] != 0x00 or ret[1] != 0x14:
                          continue
                      self._serial.write(b"\x06")
                      frm = bytes()
                      frm += self._serial.read(4) #<C0> <00> <59> <len>
                      if frm[0] == 0x03:
                          continue
                      l = int(frm[3])
                      frm += self._serial.read(l+1)
                      crc = 0
                      for i in frm[:-1]:
                          crc ^= i
                      if crc != frm[-1]:
                          logger.warning("frame crc error")
                          continue
                      msg = frm[4:-1]
                      l = len(msg)
                      i = 4
                      while i <= l:
                          reg = msg[i-3]
                          if i != l and (msg[i] == 0x00 or i == (l-1)):
                              raw = bytes([msg[i-2],msg[i-1]])
                              i+=4
                          else:
                              raw = bytes([msg[i-2]])
                              i+=3
                          if not reg in self._nibe_regs:
                              continue
                          if self._nibe_regs[reg]['raw'] == raw:
                              continue
                          value = self._decode(reg, raw)
                          logger.debug("update_item: reg:{0} = {1}".format(reg,value))
                          self._nibe_regs[reg]['raw'] = raw
                          for item in self._nibe_regs[reg]['items']:
                              item(value, 'NIBE', 'REG {}'.format(reg))
              except Exception as e:
                  logger.warning("nibe: {0}".format(e))
          def stop(self):
              self.alive = False
              self._serial.close()
          def parse_item(self, item):
              if 'nibe_reg' in item.conf:
                  logger.debug("parse item: {0}".format(item))
                  nibe_reg = int(item.conf['nibe_reg'])
                  if not nibe_reg in self._nibe_regs:
                      self._nibe_regs[nibe_reg] = {'items': [item], 'logics': [], 'raw':0}
                  else:
                      self._nibe_regs[nibe_reg]['items'].append(item)
              return None
          def _decode(self, reg, raw):
              if len(raw) == 2:
                  value = unpack('>H',raw)[0]
              else:
                  value = unpack('B',raw)[0]
              if reg in [0,32,33,34,35,36,38,44,45,46,48,100,101,102,103,104,105]:
                  #0    CPUID
                  #32   Zusatzheizung erlaubt
                  #33   Max dF Commpressor
                  #34   Verd. Freq. regP
                  #35   Min Startzeit Freq min
                  #36   Minzeit konst. Freq min
                  #38   Verd. Freq. GradMin
                  #44   Pumpengeschwindigkeit %
                  #45   Bw reg P
                  #46   Bw reg Q
                  #48   Bw reg Wert xP %
                  #100  Datum - Jahr
                  #101  Datum - Monat
                  #102  Datum - Tag
                  #103  Uhrzeit - Stunde
                  #104  Uhrzeit - Minute
                  #105  Uhrzeit - Sekunden
                  return int(value)
              if reg == 31:
                  #31   Status Heizung
                  #1 Auto
                  #3 Heizung
                  #5 Brauchwasser
                  #6 Zusatzheizung
                  return int(value)
              if reg in [4,8]: #signed
                  #4    Heizkurvenverschiebung
                  #8    Gradminuten
                  return int(unpack('h',pack('H',value))[0]/10)
              if reg == 25: #unsigned
                  #25   Verdichterstarts
                  return int(value/10)
              if reg in [1,5,6,7,11,12,13,14,15,16,17,18,21,23,27,37]: #signed
                  #1    Aussentemp °C
                  #5    Vorlauf Soll °C
                  #6    Vorlauf Ist °C
                  #7    Ruecklauf °C
                  #11   Kondensator aus (MAX) °C
                  #12   Brauchwasser oben °C
                  #13   Brauchwasser unten °C
                  #14   Verd. Temp. Tho-R1 °C
                  #15   Verd. Temp. Tho-R2 °C
                  #16   Sauggas Temp. Tho-S °C
                  #17   Heissgas Temp. Tho-D °C
                  #18   Fluessigkeitstemp AMS °C
                  #21   Atemp. am AMS Tho-A °C
                  #23   Invertertemp. Tho-IP °C
                  #27   Vorlauf °C
                  #37   Max Diff. soll-ber °C
                  return float(unpack('h',pack('H',value))[0]/10)
              if reg in [9,10,19,20,22,24]: #unsigned
                   #9    Verd. Freq. Soll Hz
                  #10   Verd. Freq. Ist Hz
                  #19   Hochdruck bar
                  #20   Niederdruck bar
                  #22   AMS Phase Ist A
                  #24   Verdichterlaufzeit h
                  return float(value/10)
              if reg in [40,47]: #unsigned
                  #40   Hysterese °C
                  #47   Bw reg xP
                  return float(value/2)
              if reg in [43,49,50]:
                  #43   Stopptemp. Heizen °C
                  #49   Brauchwasser StartTemp °C 1.2
                  #50   Brauchwasser StopTemp °C  1.3
                  return float(value)
              #2    ?
              #3    ?
              #26   ?
              #28   ?
              #29   ?
              #30   ?
              #39   ?
              #41   ?
              #42   ?
              return value
      smarthome/items/nibe.conf
      [heating]
      	[[operating_state]]
      		type = num
      		nibe_reg = 31
      	[[heating_curve]]
      		type = num
      		nibe_reg = 4
      	[[circ_pump_speed_heat_p]]
      		type = num
      		nibe_reg = 44
      	[[number_of_starts]]
      		type = num
      		nibe_reg = 25
      	[[outdoor_temp_c]]
      		type = num
      		nibe_reg = 1
      	[[supply_temp_c]]
      		type = num
      		nibe_reg = 6
      	[[return_temp_c]]
      		type = num
      		nibe_reg = 7
      	[[run_time_compressor_h]]
      		type = num
      		nibe_reg = 24
      	[[hot_water_temp_c]]
      		type = num
      		nibe_reg = 12
      	[[degree_minutes]]
      		type = num
      		nibe_reg = 8
      smarthome/etc/plugin.conf
      [nibe]
          class_name = NIBE
          class_path = plugins.nibe
          serialport = /dev/ttyUSB0
      serialport natürlich anpassen.
      Eduard
        Wenn ich eine RS485/USB Konverter (J34 Free Shipping USB to RS485 485 Converter Adapter Support Win7 XP Vista Linux Mac OS WinCE5.0 on Aliexpress.com | Alibaba Group) an die Nibe 1250 und einen RasPi anschließe, dann friert bei mir sofort das Display ein (RCU=on).
        Wie habt ihr das umgangen? Muss man erst das Programm starten, damit die Acks gesendet werden? So ganz transparent ist mir dieser Punkt nicht.
        @brandst: wie hast Du das Problem gelöst?
          Hast du in dem Menü Logging aktiviert? Bei mir ist das Display nur eingefroren, wenn ich probiert habe mich über den Raspberry mittels stty an den Datenstrom zu hängen. Das bloße Anstecken der Leitung hat bei mir keine Probleme gemacht. Deinem Link zu urteilen, gibt es bei dem Umwandler kein GND sondern nur die Datenbelegung - vielleicht ist es das?
          Vorgehensweise meiner Meinung nach:
          1. Logging Konfiguration überprüfen (siehe diesen Thread)
          2. Verkabelung überprüfen (steht glaub ich auf Seite 2)
          3. Kabeln anstecken - überprüfen ob das Display noch funktioniert und Komm-Fehler auswirft (passiert, wenn das Programm ohne "w" Parameter aufgerufen wurde.
          4. Programm starten
            So, kleiner Zwischenstand:
            Ich habe alles noch einmal auseinandergeschraubt und das Kabel neu gecrimpt.
            Jetzt bekomme ich Werte über /dev/ttyUSB0 und das Display friert auch nicht mehr ein (juhu!). (Hinweis: Raspi-User in Gruppe dialout aufnehmen)
            Eine GND-Verbindung ist nicht notwendig. Es sind nur D+ und D- verbunden.
            Nun geht es an die Auswertung :-)
              Wen ich dass nun auch mit smartVISU bzw. smarthome.py machen möchte fehlt mir irgendwie die Oberfläche dazu.
              Hat jemand da schon etwas gebastelt?
              Im logfile steht bei mir: 2015-02-20 14:25:35 WARNING nibe nibe: index out of range
                Wenn ich mit 19.200 lese, dann bekomme ich bei meiner 1240 folgenden output:
                0004760 f6 fe 56 fa 00 7e 7e 54 7e d5 0e f6 fe 56 fa 00
                v ~ V z nul ~ ~ T ~ U so v ~ V z nul
                0005000 7e 7e 34 7e 7e 5c 00 34 7e 7e 5c 00 34 7e 25 0e
                ~ ~ 4 ~ ~ \ nul 4 ~ ~ \ nul 4 ~ % so
                0005020 fe 5e 00 fd 7e 25 1a e2 54 e4 b4 ec 54 bc dc 8c
                ~ ^ nul } ~ % sub b T d 4 l T < \ ff
                0005040 60 e4 00 34 7e cd 0e f2 fe fe fe 84 cc f2 00 54
                ` d nul 4 ~ M so r ~ ~ ~ eot L r nul T
                0005060 7e d5 0e f6 fe 56 fa 00 7e 7e 54 7e d5 0e f6 fe
                ~ U so v ~ V z nul ~ ~ T ~ U so v ~
                0005100 56 fa 00 7e 7e 34 7e d7 0e d2 7e fc fc fc 5c 3c
                V z nul ~ ~ 4 ~ W so R ~ | | | \ <
                0005120 8c 44 7c 91 f3 fe cc f2 00 34 7e d6 0e aa 3a 8c
                ff D | dc1 s ~ L r nul 4 ~ V so * : ff
                0005140 7c fc fc fc fc fc fc fc fc fc fc fc fc 6c 6c 2c
                | | | | | | | | | | | | | l l ,
                0005160 74 54 fe 52 60 f2 00 34 7e 6b 0e ba f6 6c f4 54
                t T ~ R ` r nul 4 ~ k so : v l t T
                0005200 e4 bc 44 f4 64 64 d4 6c 5c d4 94 7c fc 8a cc f2
                d < D t d d T l \ T dc4 | | nl L r
                Das sieht nicht wirklich nach einzelnen Frames aus, oder? Ich kann zumindest kein 06 03 00 erkennen.
                Was könnte hier falsch sein?
                  Bei mir nähert sich der Bau langsam der Fertigstellung. Es ist eine Nibe F1145 verbaut.
                  Da es sich um ein aktuelles Gerät handelt, habe ich überlegt Daten ggf. per Webcrawler aus dem Nibe Uplink Webinterface zu holen.
                  Die hier beschriebene Methode sieht mir allerdings umfänglicher aus.
                  Leider kann ich keine Info mehr finden, wo genau ich den Pin-Header finde.
                  Hat jemand von euch mal ein Foto von seinem Aufbau an der WP?
                    Hallo Seppel, bin nach langer KNXUF-Abstinenz mal wieder hier. Bist Du mit dem Nibe Uplink zufrieden oder kommt native RS485 Anbindung doch in Frage? Wollte demnächst mal an dem Projekt weiterarbeiten...
                      Wenn es dir rein um die Daten geht, ich habe das so gelöst.
                      https://knx-user-forum.de/forum/%C3%...mepumpe-mit-hs
                        Für meine WP (Nibe Split) gibt es das Nibe Uplink nicht...
                          melde mich auch wieder mal zu Wort. Meine Anbindung mit dem sh.py Plugin von Eddso funktioniert noch immer einwandfrei. Das einzige was ich vermisse ist Schreibzugriff. Das wird jedoch aufgrund des nicht offen gelegten Protokolls nie funktionieren soweit ich das verstanden habe. Somit - Top Arbeit von ctr und eddso.
                            Hallo ctr,
                            prinzipiell bin ich zufrieden. Habe das mit einem sh.py Plugin gelöst. Findet sich im entsprechenden Forenbereich und auf Github.
                            Das Problem dabei ist, dass die Lösung nur "online" funktioniert. Also nur wenn die WP und der "Server" Internetverbindung haben.
                            Ich habe mal versucht die Daten lokal zu bekommen - also direkt von der WP im LAN, aber da bin ich nicht sonderlich weiter gekommen - mangels Zeit.
                            Pinzipiell würde ich die Variante Modbus gerne mal probieren. Wäre also sehr an Fotos vom Anschluss interessiert.
                            Zuletzt geändert von DerSeppel; 13.01.2016, 15:28.
                              Ok, dann werde ich das mal dokumentieren, muss bei mir sowieso noch auseinandernehmen. Irgendwann dieses Jahr werde ich mich auch mal mit dem "Senden" versuchen... habe es bisher immer auf "außerhalb der Heizperiode" geschoben, aber dann gibt es auch nicht viel zu steuern!
                                Bei meiner F1240 bekomme ich zwar eine Ausgabe der Daten, aber ich sehe keine Telegramme, die mit 5C 00 20 anfangen. Hat die F1240 möglicherweise andere Codes?
