yuhuu läuft wieder,
die Lösung war: NanoUSB aus und einstecken...
jetzt geht es auch mit /dev/ttyACM0 in der ola-stageprofi.conf.
nur das knxdmxd läuft nicht... folgende config:
tut gar nix... steuerung nur über ola-webif möglich bis jetzt.
Danke
// CAUTION : never uses names starting with _ !!! These are used internally ! { "fixtures": [ // all fixture definitions { "name" : "Treppe", // name is optional, default is _f_<number> "channels" : [ // channel definition, dmx is mandatory, default name is _c_<number> ], "fading" : { "knx" : "1/6/170", "time": 1 } // knx-like dimming: fading is calculated for 0-100% }, { "name" : "Kueche", "channels" : [ { "name": "R", "knx" : "15/2/0", "dmx" : "1.1" }, { "name": "G", "knx" : "15/2/1", "dmx" : "1.2" }, { "name": "B", "knx" : "15/2/2", "dmx" : "1.3" } ], "fading" : { "knx" : "1/6/141", "time": 3.0 } } ], "scenes": [ ], "fading" : { // all fading times used on scene call ! "in" : 1.0, // for increasing intensity "out": 1.0, // for decreasing intensity } }, "channels" : [ ], "fading" : { "time" : 1 // used for in and out } } ], "cuelists": [ // all cuelists { "name" : "Treppe Disco", "trigger" : { "go" : { "knx" : "1/0/172", "value" : 1 }, "halt" : { "knx" : "1/0/172", "value" : 0 } }, "cues" : [ // cues are like scenes, just without individual triggers ], "waittime" : 3, // only relevant for loops "fading" : { "time" : 3 } }, { "name" : "obenan", "channels" : [ ], "waittime" : 3, "fading" : { "time" : 3 } }, { "name" : "beidean", "channels" : [ ], "waittime" : 3, // waittime start after calling previous cue ! "fading" : { "time" : 3 } }, { "name" : "untenan", "channels" : [ ], "waittime" : 3, "fading" : { "time" : 3 } }, { "link" : "allesaus" } ] } ] }
Danke
