Die üblichen Verdächtigen sind:
node version und npm Versionsnummer
beide bekommst du mit -v als Parameter
root@osboxes:/home/thorsten# nodejs -v v0.10.29 root@osboxes:/home/thorsten# npm -v 1.4.21 root@osboxes:/home/thorsten# node -v root@osboxes:/home/thorsten#
pi@raspberrypi ~ $ sudo npm install -g node-gyp /usr/local/bin/node: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.20' not found (required by /usr/local/bin/node) /usr/local/bin/node: /lib/arm-linux-gnueabihf/libc.so.6: version `GLIBC_2.16' not found (required by /usr/local/bin/node)
cd /usr/src wget https://s3-eu-west-1.amazonaws.com/conoroneill.net/wp-content/uploads/2015/03/node-v0.12.1-linux-arm-pi.tar.gz tar -zxvf node-v0.12.1-linux-arm-pi.tar.gz cd node-v0.12.1-linux-arm-pi sudo cp -R * /usr/local/
