Oh äh ja sorry hab ich nicht dazu geschrieben. Sry!
***censored***
***censored***
[module.c:111] error: Failed to open module esd: libesd.so.0: cannot open shared object file: No such file or directory
aplay -l aplay: device_list:207: no soundcards found...
/proc/asound# ls -l insgesamt 0 -r--r--r-- 1 root root 0 7. M?r 21:23 cards -r--r--r-- 1 root root 0 7. M?r 21:23 devices -r--r--r-- 1 root root 0 7. M?r 21:23 hwdep -r--r--r-- 1 root root 0 7. M?r 21:23 modules dr-xr-xr-x 2 root root 0 7. M?r 21:23 oss -r--r--r-- 1 root root 0 7. M?r 21:23 pcm dr-xr-xr-x 2 root root 0 7. M?r 21:23 seq -r--r--r-- 1 root root 0 7. M?r 21:23 timers -r--r--r-- 1 root root 0 7. M?r 21:23 version
aplay /home/Applause Playing WAVE '/home/Applause' : Signed 16 bit Little Endian, Rate 11025 Hz, Mono root@wiregate286:/etc/modprobe.d# mpg123 /home/breathe.mp3 High Performance MPEG 1.0/2.0/2.5 Audio Player for Layers 1, 2 and 3 version 1.4.3; written and copyright by Michael Hipp and others free software (LGPL/GPL) without any warranty but with best wishes Directory: /home/ Playing MPEG stream 1 of 1: breathe.mp3 ... Title: Breathe (radio edit) Artist: t*l*popmusik Comment: 000006FD 00000753 000032F4 00002F21 0000C37E 0000C37E 00008000 00007F37 0000EAA5 0000EAA5 Album: Breathe Single-CD Year: 2002 Genre: Electronica/Dance MPEG 1.0 layer III, 96 kbit/s, 44100 Hz joint-stereo ^C [2:36] Decoding of breathe.mp3 finished.
lsusb Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 006: ID 04fa:2490 Dallas Semiconductor DS1490F 2-in-1 Fob, 1-Wire adapter Bus 001 Device 005: ID 04fa:2490 Dallas Semiconductor DS1490F 2-in-1 Fob, 1-Wire adapter Bus 001 Device 004: ID 0d8c:0102 C-Media Electronics, Inc. CM106 Like Sound Device Bus 001 Device 003: ID 1a40:0101 TERMINUS TECHNOLOGY INC. USB-2.0 4-Port HUB Bus 001 Device 002: ID 1a40:0201 TERMINUS TECHNOLOGY INC. Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
root@wiregate286:~# lspci 00:01.0 Host bridge: Advanced Micro Devices [AMD] CS5536 [Geode companion] Host Bridge (rev 33) 00:01.1 VGA compatible controller: Advanced Micro Devices [AMD] Geode LX Video 00:01.2 Entertainment encryption device: Advanced Micro Devices [AMD] Geode LX AES Security Block 00:0d.0 Ethernet controller: VIA Technologies, Inc. VT6105M [Rhine-III] (rev 96) 00:0f.0 ISA bridge: Advanced Micro Devices [AMD] CS5536 [Geode companion] ISA (rev 03) 00:0f.2 IDE interface: Advanced Micro Devices [AMD] CS5536 [Geode companion] IDE (rev 01) 00:0f.3 Multimedia audio controller: Advanced Micro Devices [AMD] CS5536 [Geode companion] Audio (rev 01) 00:0f.4 USB Controller: Advanced Micro Devices [AMD] CS5536 [Geode companion] OHC (rev 02) 00:0f.5 USB Controller: Advanced Micro Devices [AMD] CS5536 [Geode companion] EHC (rev 02) root@wiregate286:~#
Mar 25 16:47:41 homeserver pulseaudio[11037]: main.c: System-Modus aktiv, jeodch --disallow-exit nicht gesetzt! Mar 25 16:47:41 homeserver pulseaudio[11037]: main.c: System-Modus aktiv, jedoch --disallow-module-loading nicht gesetzt! Mar 25 16:47:41 homeserver pulseaudio[11037]: main.c: System-Modus aktiv, SHM-Modus gezwungenermaßen deaktiviert! Mar 25 16:47:41 homeserver pulseaudio[11037]: main.c: System-Modus aktiv, Exit-Idle-Time gezwungenermaßen deaktiviert! Mar 25 16:47:41 homeserver pulseaudio[11039]: main.c: OK, nun wird PA im System Mode betrieben. Vorsicht, dies sollte man nicht tun. Mar 25 16:47:41 homeserver pulseaudio[11039]: main.c: Bei Nichtbeachtung, selber Schuld wenn Dinge nicht funktionieren. Mar 25 16:47:41 homeserver pulseaudio[11039]: main.c: Für eine Erklärung warum System Mode eine schlechte Idee ist, bitte http://pulseaudio.org/wiki/WhatIsWrongWithSystemMode lesen
Mar 25 18:12 : output: Failed to open "test" [pulse]: Cannot connect to PulseAudio server: Connection refused Mar 25 18:12 : client: [35] command returned 0 Mar 25 18:12 : client: [35] closed Mar 25 18:12 : client: [36] opened from 127.0.0.1:50787 Mar 25 18:12 : client: [36] process command "commands" Mar 25 18:12 : client: [36] command returned 0 Mar 25 18:12 : client: [36] process command "status" Mar 25 18:12 : client: [36] command returned 0 Mar 25 18:12 : client: [37] opened from 127.0.0.1:50788 Mar 25 18:12 : client: [37] process command "plchanges "2"" Mar 25 18:12 : client: [37] command returned 0 Mar 25 18:12 : client: [37] closed Mar 25 18:12 : client: [36] closed
pid_file "/var/run/mpd/pid-1"
state_file "/var/lib/mpd/state-1"
port "6601"
zeroconf_enabled "yes"
zeroconf_name "test"
audio_output {
type "pulse"
name "test"
sink "test"
## immer TCP nutzen, darum 127.0.0.1
server "127.0.0.1"
user "root"
log_level "verbose"
music_directory "/medien/musik"
playlist_directory "/medien/playlist"
db_file "/var/lib/mpd/tag_cache-1"
#sticker_file "/var/lib/mpd/sticker-1_db"
error_file "/var/log/mpd/errors-1.log"
log_file "/var/log/mpd/mpd-1.log"
bind_to_address "127.0.0.1"
bind_to_address "192.168.115.1"
audio_output_format "44100:16:2"
samplerate_converter "Fastest Sinc Interpolator"
mixer_type "software"
#replaygain "track"
#replaygain_preamp "0"
volume_normalization "yes"
max_playlist_length "200"
#audio_buffer_size "2048"
#buffer_before_play "10%"
filesystem_charset "UTF-8"
id3v1_encoding "UTF-8"
#metadata_to_use "artist,album,title,track,name,genre,date,composer,performer,disc"
homeserver:/etc/pulse# pulseaudio --system -vvv W: main.c: System-Modus aktiv, jeodch --disallow-exit nicht gesetzt! W: main.c: System-Modus aktiv, jedoch --disallow-module-loading nicht gesetzt! N: main.c: System-Modus aktiv, SHM-Modus gezwungenermaßen deaktiviert! N: main.c: System-Modus aktiv, Exit-Idle-Time gezwungenermaßen deaktiviert! D: core-rtclock.c: Timer slack is set to 50 us. D: core-util.c: setpriority() worked. I: core-util.c: Successfully gained nice level -11. I: main.c: Benutzer 'pulse' (UID 112) und Gruppe 'pulse' (GID 116) gefunden. I: main.c: Root-Berechtigungen erfolgreich zurückgesetzt. I: main.c: Dies ist PulseAudio 0.9.21-rebootstrapped-dirty D: main.c: Kompilier-Host: i486-pc-linux-gnu D: main.c: Kompilier-CFLAGS: -g -O2 -g -Wall -O2 -Wall -W -Wextra -pipe -Wno-long-long -Winline -Wvla -Wno-overlength-strings -Wunsafe-loop-optimizations -Wundef -Wformat=2 -Wlogical-op -Wsign-compare -Wformat-security -Wmissing-include-dirs -Wformat-nonliteral -Wold-style-definition -Wpointer-arith -Winit-self -Wdeclaration-after-statement -Wfloat-equal -Wmissing-prototypes -Wstrict-prototypes -Wredundant-decls -Wmissing-declarations -Wmissing-noreturn -Wshadow -Wendif-labels -Wcast-align -Wstrict-aliasing=2 -Wwrite-strings -Wno-unused-parameter -ffast-math -Wp,-D_FORTIFY_SOURCE=2 -fno-common -fdiagnostics-show-option D: main.c: Laufe auf Host: Linux i686 2.6.32-5-686 #1 SMP Mon Jan 16 16:04:25 UTC 2012 D: main.c: 4 CPUs gefunden. I: main.c: Seitengröße ist 4096 Bytes. D: main.c: Kompiliere mit Valgrind-Unterstützung: nein D: main.c: Läuft im Valgrind-Modus: no D: main.c: Running in VM: no D: main.c: Optimiertes Build: ja D: main.c: Alle Ansprüche aktiviert. I: main.c: System- ID ist 3b064ec91eb024cd4b6df5dd4f26f018. I: main.c: System- ID ist 3b064ec91eb024cd4b6df5dd4f26f018-1332692329.64877-2093726472. I: main.c: Nutze Laufzeit-Verzeichnis /var/run/pulse. I: main.c: Nutze Zustands-Verzeichnis /var/lib/pulse. I: main.c: Modul-Verzeichnis /usr/lib/pulse-0.9.21/modules benutzen. I: main.c: Laufe im System-Modus: yes W: main.c: OK, nun wird PA im System Mode betrieben. Vorsicht, dies sollte man nicht tun. W: main.c: Bei Nichtbeachtung, selber Schuld wenn Dinge nicht funktionieren. W: main.c: Für eine Erklärung warum System Mode eine schlechte Idee ist, bitte http://pulseaudio.org/wiki/WhatIsWrongWithSystemMode lesen E: pid.c: Daemon already running. E: main.c: pa_pid_file_create() fehlgeschlagen.
# This file is part of PulseAudio. # # PulseAudio is free software; you can redistribute it and/or modify # it under the terms of the GNU Lesser General Public License as published by # the Free Software Foundation; either version 2 of the License, or # (at your option) any later version. # # PulseAudio is distributed in the hope that it will be useful, but # WITHOUT ANY WARRANTY; without even the implied warranty of # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU # General Public License for more details. # # You should have received a copy of the GNU Lesser General Public License # along with PulseAudio; if not, write to the Free Software # Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 # USA. ## Configuration file for the PulseAudio daemon. See pulse-daemon.conf(5) for ## more information. Default values a commented out. Use either ; or # for ## commenting. ; daemonize = no ; fail = yes ; allow-module-loading = yes ; allow-exit = yes ; use-pid-file = yes ; system-instance = yes ; enable-shm = yes ; shm-size-bytes = 0 # setting this 0 will use the system-default, usually 64 MiB ; lock-memory = no ; cpu-limit = no ; high-priority = yes ; nice-level = -11 ; realtime-scheduling = yes ; realtime-priority = 5 ; exit-idle-time = 20 ; scache-idle-time = 20 ; dl-search-path = (depends on architecture) ; load-default-script-file = yes ; default-script-file = ; log-target = auto ; log-level = notice ; log-meta = no ; log-time = no ; log-backtrace = 0 ; resample-method = speex-float-3 ; enable-remixing = yes ; enable-lfe-remixing = no ; flat-volumes = yes ; rlimit-fsize = -1 ; rlimit-data = -1 ; rlimit-stack = -1 ; rlimit-core = -1 ; rlimit-as = -1 ; rlimit-rss = -1 ; rlimit-nproc = -1 ; rlimit-nofile = 256 ; rlimit-memlock = -1 ; rlimit-locks = -1 ; rlimit-sigpending = -1 ; rlimit-msgqueue = -1 ; rlimit-nice = 31 ; rlimit-rtprio = 9 ; rlimit-rttime = 1000000 ; default-sample-format = s16le ; default-sample-rate = 44100 ; default-sample-channels = 2 ; default-channel-map = front-left,front-right ; default-fragments = 4 ; default-fragment-size-msec = 25
