Eine pa sollte immer nur ein Gerät am Bus haben.
WLAN Steckdose mit KNX schalten
ich habe jetzt noch eine weiter Steckdose geflascht da ist das gleiche.
So sieht es aus in der Konsole wenn ich nicht auf das Rückmelde objekt höre dann geht es. Ich kann aber nicht die Rückmeldeadresse abfragen.
Output 1 -> 1 / 4 / 60
1 / 1 / 60 -> Output 1
Code:22:41:11 KNX: Received from 1.1.60 Command Write: to Output 1 22:41:11 KNX: Output 1 = 0 sent to 1.4.60 22:41:11 RSL: stat/tasmota/RESULT = {"POWER":"OFF"} 22:41:11 RSL: stat/tasmota/POWER = OFF 22:41:13 KNX: Received from 1.1.60 Command Write: 22:41:13 KNX: Output 1 = 1 sent to 1.4.60 22:41:13 RSL: stat/tasmota/RESULT = {"POWER":"ON"} 22:41:13 RSL: stat/tasmota/POWER = ON 22:41:14 KNX: Received from 1.1.60 Command Write: to Output 1 22:41:14 KNX: Output 1 = 0 sent to 1.4.60 22:41:14 RSL: stat/tasmota/RESULT = {"POWER":"OFF"} 22:41:14 RSL: stat/tasmota/POWER = OFF
1 / 4 / 60 -> Output 1
Code:22:48:56 KNX: Received from 1.4.60 Command Write: 22:48:56 KNX: Output 1 = 1 sent to 1.4.60 22:48:56 RSL: stat/tasmota/RESULT = {"POWER":"ON"} 22:48:56 RSL: stat/tasmota/POWER = ON 22:48:56 KNX: Received from 1.4.60 Command Write: to Output 1 22:48:56 KNX: Output 1 = 0 sent to 1.4.60 22:48:56 RSL: stat/tasmota/RESULT = {"POWER":"OFF"} 22:48:56 RSL: stat/tasmota/POWER = OFF 22:48:56 KNX: Received from 1.4.60 Command Write: 22:48:56 KNX: Output 1 = 1 sent to 1.4.60 22:48:56 RSL: stat/tasmota/RESULT = {"POWER":"ON"} 22:48:56 RSL: stat/tasmota/POWER = ON 22:48:56 KNX: Received from 1.4.60 Command Write: to Output 1
Das ist mein Log bei Ein- und Ausschalten via KNX:
Code:10:36:54 KNX: Received from 1.1.9 Command Write: 10:36:54 KNX: Output 1 = 1 sent to 1.2.8 10:36:54 MQT: /gosund_1/stat/RESULT = {"POWER":"ON"} 10:36:54 MQT: /gosund_1/stat/POWER = ON 10:37:12 KNX: Received from 1.1.9 Command Write: to Output 1 10:37:12 KNX: Output 1 = 0 sent to 1.2.8 10:37:12 MQT: /gosund_1/stat/RESULT = {"POWER":"OFF"} 10:37:12 MQT: /gosund_1/stat/POWER = OFF
Output 1 -> 1 / 2 / 8
1 / 1 / 9 -> Output 1
1 / 2 / 8 -> Output 1
Wie sind denn deine Verknüpfungen in der ETS?
Ich habe nur einen simplen Schalter mit LED. Das ist es nicht das Problem kommt ja aus dem Aktor.
Ich tippe langsam auf meinem eibd vom Wiregate.Zuletzt geändert von heckmannju; 10.05.2020, 22:23.
Zitat von Opelpower Beitrag anzeigenMeine SP111 sind heute angekommen und das flashen over the Air hat funktioniert.
Welches Modul muss ich denn auswählen, weil das Gosund nicht in der Liste ist?
https://templates.blakadder.com/plug.html
Vernehmt ihr auch ein "Fiepen" bei den Gosund SP111, wenn diese an sind?
Habe das hier gefunden:
https://robinclarke.net/archives/sto...n-gosund-sp111
Hat das schonmal jemand getestet, ob das was bringt?
schau mal unter: https://tasmota.github.io/docs/Commands/
Dort sind alle Befehle aufgelistet. Die für dich relevanten Befehle dürften unter Power Monitoring liegen.
Diese müsstest du dann per Rule verbinden, soweit mein theoretisches Verständnis. Praktisch habe ich das selbst noch nie ausprobiert.
Mal eine prinzipielle Frage an die Runde....
Wo nutzt ihr die WLAN Steckdosen?
Macht es Sinn zum Beispiel damit ein Handy-Ladekabel, dass immer in der Steckdose ist Ein und Auszuschalten?
Wenn nichts am Handyladekabel angeschlossen ist, habe ich 0,0 W Verbrauche des Ladekabels gemessen. Dies habe ich nicht mit der WLAN Steckdose gemessen, sondern mit einem ext. "Tool".
Die WLAN Steckdose (zum Beispiel Gosund SP111) benötigt dauerhaft 1,4 Watt. Das würde den Einsatz einer WLAN - Steckdose bei zum Beispiel einem Handyladekabel ausschließen, oder?
Zitat von Opelpower Beitrag anzeigenIch benutze den SP111 für die WM+Trockner, um eine Fertigmeldung zu bekommen.
Der Energieverbrauch bei mir (Gosund SP111) beträgt im Standby (Relais Aus) ca. 0,2-0,5 Watt und bei Relais An 0,8 Watt.
