LBS19000809 - Alexa Control
    Ah, ok. Vielen Dank.
    Leider scheint immer noch etwas nicht zu stimmen. Es erfolgt keine Sprachausgabe.
    Das Log schaut so aus:
    2023-04-18 08:24:51    161534    23109    debug    LBS19000809 [v3.1]: LBS started
    2023-04-18 08:24:51    164330    23109    debug    LBS19000809 [v3.1]: LBS ended
    2023-04-18 08:24:51    167949    1599    debug    EXE19000809 [v3.1]: Message received:
    2023-04-18 08:24:51    168205    1599    debug    EXE19000809 [v3.1]: ================ ARRAY/OBJECT START ================
    2023-04-18 08:24:51    168389    1599    debug    EXE19000809 [v3.1]: {"setDevice":"EchoDotUhr"}
    2023-04-18 08:24:51    168515    1599    debug    EXE19000809 [v3.1]: ================ ARRAY/OBJECT END ================
    2023-04-18 08:24:51    224935    1599    debug    EXE19000809 [v3.1]: NEW_LOGIN_HEADERS:
    2023-04-18 08:24:51    226830    1599    debug    EXE19000809 [v3.1]: NEW_LOGIN_BODY:
    2023-04-18 08:24:51    228681    1599    debug    EXE19000809 [v3.1]: File: /usr/local/edomi/www/data/liveproject/lbs/EXE19000809.php | Error: 2 | Line: 1750 | Invalid argument supplied for foreach()
    2023-04-18 08:24:51    253453    1599    debug    EXE19000809 [v3.1]: File: /usr/local/edomi/www/data/liveproject/lbs/EXE19000809.php | Error: 2 | Line: 1797 | file_get_contents(/tmp/.alexa-.cookie): failed to open stream: No such file or directory
    2023-04-18 08:24:51    270191    1599    debug    EXE19000809 [v3.1]: File: /usr/local/edomi/www/data/liveproject/lbs/EXE19000809.php | Error: 2 | Line: 1797 | file_get_contents(/tmp/.alexa-.cookie): failed to open stream: No such file or directory
    2023-04-18 08:24:51    287698    1599    debug    EXE19000809 [v3.1]: File: /usr/local/edomi/www/data/liveproject/lbs/EXE19000809.php | Error: 2 | Line: 1797 | file_get_contents(/tmp/.alexa-.cookie): failed to open stream: No such file or directory
    2023-04-18 08:24:51    289689    1599    debug    EXE19000809 [v3.1]: NEW_LOGIN_CSRF: ERROR! NO CSRF received
    2023-04-18 08:24:59    221235    23109    debug    LBS19000809 [v3.1]: LBS started
    2023-04-18 08:24:59    223490    23109    debug    LBS19000809 [v3.1]: LBS ended
    2023-04-18 08:24:59    318011    1599    debug    EXE19000809 [v3.1]: Message received:
    2023-04-18 08:24:59    318305    1599    debug    EXE19000809 [v3.1]: ================ ARRAY/OBJECT START ================
    2023-04-18 08:24:59    318442    1599    debug    EXE19000809 [v3.1]: {"speak":"50|Hallo|30"}
    2023-04-18 08:24:59    318562    1599    debug    EXE19000809 [v3.1]: ================ ARRAY/OBJECT END ================
    2023-04-18 08:24:59    362870    1599    debug    EXE19000809 [v3.1]: NEW_LOGIN_HEADERS:
    2023-04-18 08:24:59    364765    1599    debug    EXE19000809 [v3.1]: NEW_LOGIN_BODY:
    2023-04-18 08:24:59    366527    1599    debug    EXE19000809 [v3.1]: File: /usr/local/edomi/www/data/liveproject/lbs/EXE19000809.php | Error: 2 | Line: 1750 | Invalid argument supplied for foreach()
    2023-04-18 08:24:59    383842    1599    debug    EXE19000809 [v3.1]: File: /usr/local/edomi/www/data/liveproject/lbs/EXE19000809.php | Error: 2 | Line: 1797 | file_get_contents(/tmp/.alexa-.cookie): failed to open stream: No such file or directory
    2023-04-18 08:24:59    401194    1599    debug    EXE19000809 [v3.1]: File: /usr/local/edomi/www/data/liveproject/lbs/EXE19000809.php | Error: 2 | Line: 1797 | file_get_contents(/tmp/.alexa-.cookie): failed to open stream: No such file or directory
    2023-04-18 08:24:59    418775    1599    debug    EXE19000809 [v3.1]: File: /usr/local/edomi/www/data/liveproject/lbs/EXE19000809.php | Error: 2 | Line: 1797 | file_get_contents(/tmp/.alexa-.cookie): failed to open stream: No such file or directory
    2023-04-18 08:24:59    420655    1599    debug    EXE19000809 [v3.1]: NEW_LOGIN_CSRF: ERROR! NO CSRF received​
    Ich vermute noch, dass das Token nicht funktioniert.
    Den kompletten weissen String kopiere ich in E57, richtig?
      Hast du die Eingänge statisch belegt?
      Mit iKOs kann es sein, dass es nicht funktioniert.
      Der komplette String an E57 ist korrekt. Aber keine leading oder trailing spaces. Da noch mal prüfen, dass es wirklich nur der String ist.
      Ist der Echo Device Name korrekt? Das ist der, den du in der Alexa App vergeben hast.
      Am besten mal Edomi stoppen. Logfile löschen. Dann EDOMI aktivieren und das neue Logfile posten, d.h. direkt ab EDOMI Start.
        Ich hatte die Werte "Live" eingegeben.
        Nun aber statisch hinterlegt-siehe Foto.
        Der Name des EchoDot stimmt, und der Token hat keine Leerzeichen. Trotzdem irritiert mich "Atnr|" am Anfang des Token.
        Zum Protokoll:
        Edomi pausiert, Log gelöscht, Edomi gestartet und danach den Baustein noch einmal an E1 getriggert:
        2023-04-18 09:27:12    996104    30677    debug    LBS19000809 [v3.1]: LBS started
        2023-04-18 09:27:12    997878    30677    debug    LBS19000809 [v3.1]: LBS ended
        2023-04-18 09:35:43    175730    30677    debug    LBS19000809 [v3.1]: LBS started
        2023-04-18 09:35:43    177428    30677    debug    LBS19000809 [v3.1]: EXEC
        2023-04-18 09:35:43    245322    30677    debug    LBS19000809 [v3.1]: exec(): Daemon is not running
        2023-04-18 09:35:43    252372    30677    debug    LBS19000809 [v3.1]: Starting Alexa Control daemon...
        2023-04-18 09:35:43    253906    30677    debug    LBS19000809 [v3.1]: EXEC
        2023-04-18 09:35:43    313925    30677    debug    LBS19000809 [v3.1]: exec(): Daemon is not running
        2023-04-18 09:35:43    315352    30677    debug    LBS19000809 [v3.1]: exec(): Starting daemon ...
        2023-04-18 09:35:43    379997    30677    debug    LBS19000809 [v3.1]: LBS ended
        2023-04-18 09:35:43    437628    24933    debug    EXE19000809 [v3.1]: EXEC daemon started with msg_queue_id: 1763498622435220
        2023-04-18 09:35:43    439207    24933    debug    EXE19000809 [v3.1]: Message received:
        2023-04-18 09:35:43    439297    24933    debug    EXE19000809 [v3.1]: ================ ARRAY/OBJECT START ================
        2023-04-18 09:35:43    439380    24933    debug    EXE19000809 [v3.1]: {"start":1}
        2023-04-18 09:35:43    439446    24933    debug    EXE19000809 [v3.1]: ================ ARRAY/OBJECT END ================
        2023-04-18 09:35:43    441973    24933    debug    EXE19000809 [v3.1]: Running in auto mode
        2023-04-18 09:35:43    442935    24933    debug    EXE19000809 [v3.1]: Is manual mode?
        2023-04-18 09:35:43    443876    24933    debug    EXE19000809 [v3.1]: Is autol mode ? 1
        2023-04-18 09:35:43    735934    24933    debug    EXE19000809 [v3.1]: NEW_LOGIN_HEADERS:
        2023-04-18 09:35:43    737370    24933    debug    EXE19000809 [v3.1]: NEW_LOGIN_BODY:
        2023-04-18 09:35:43    738349    24933    debug    EXE19000809 [v3.1]: File: /usr/local/edomi/www/data/liveproject/lbs/EXE19000809.php | Error: 2 | Line: 1750 | Invalid argument supplied for foreach()
        2023-04-18 09:35:43    762922    24933    debug    EXE19000809 [v3.1]: File: /usr/local/edomi/www/data/liveproject/lbs/EXE19000809.php | Error: 2 | Line: 1797 | file_get_contents(/tmp/.alexa-.cookie): failed to open stream: No such file or directory
        2023-04-18 09:35:43    778734    24933    debug    EXE19000809 [v3.1]: File: /usr/local/edomi/www/data/liveproject/lbs/EXE19000809.php | Error: 2 | Line: 1797 | file_get_contents(/tmp/.alexa-.cookie): failed to open stream: No such file or directory
        2023-04-18 09:35:43    796264    24933    debug    EXE19000809 [v3.1]: File: /usr/local/edomi/www/data/liveproject/lbs/EXE19000809.php | Error: 2 | Line: 1797 | file_get_contents(/tmp/.alexa-.cookie): failed to open stream: No such file or directory
        2023-04-18 09:35:43    797295    24933    debug    EXE19000809 [v3.1]: NEW_LOGIN_CSRF: ERROR! NO CSRF received
        2023-04-18 09:35:43    798783    24933    debug    EXE19000809 [v3.1]: Amazon Alexa Connection failed​
          Das Problem geht auf jeden Fall beim leeren NEW_LOGIN_HEADERS los. Ich habe keine Ahnung warum das leer ist. Der Rest sind dann vermutlich Folgefehler.
          Das einzige, was bei dieser Login Anfrage von der Eingangsdaten gesendet wird, ist das Refresh-Token. Das würde ich mal neu generieren. Hast du Multi-Factor-Authentication aktiviert? Evtl. ist auch das Voraussetzung, dass es funktioniert. Ist aber nur eine Vermutung. Die Aktivierung ist natürlich immer eine gute Idee.
            leider bisher ohne Erfolg.
            Mulit-factor-Auth (2-Schritt-Verifizierung) habe ich in meinem Amazon-Account eingestellt.
            Muss für die reine Ansage ebenfalls das ausgeführt werden
            Packages to be installed: php-process epel-release oathtool openssl
            Please execute the following commands in a root shell:
            yum install -y php-process epel-release oathtool openssl
            cd /etc/ssl/certs && wget https://curl.haxx.se/ca/cacert.pem -O /etc/ssl/certs/cacert-Mozilla.pem
            echo "curl.cainfo=/etc/ssl/certs/cacert-Mozilla.pem" >> /etc/php.d/curl.ini
            /etc/init.d/httpd restart​
            Und die Dateien in der ZIP in Verzeichnisse kopiert werden?
            Danke und Grüße,
            Lio
              Du solltest alle Installationen machen, die in der Anleitung beschrieben sind.
              MFA war aber im obigen Screenshot nicht konfiguriert. (E45)
                ok, dann zurück auf LOS:
                Nachdem ganz zu Beginn die Installtion nicht geklappt hatte, habe ich hier im Forum gelesen und bin davon ausgegangen, dass das Problem mit dem Amazonlogin in Verbindung steht und den Mißerfolg der Installation nicht weiterverfolgt. Ist aber wohl ein andere Sache.
                Bei der Installation kam der Fehler, dass ein Zertifikat abgelaufen ist und die Meldung erfolgt immer noch:
                --2023-04-19 17:46:07--  https://curl.haxx.se/ca/cacert.pem
                Auflösen des Hostnamen »curl.haxx.se (curl.haxx.se)«... 2a04:4e42:6f::561, 19                                               9.232.190.49
                Verbindungsaufbau zu curl.haxx.se (curl.haxx.se)|2a04:4e42:6f::561|:443... verbu                                               nden.
                HTTP-Anforderung gesendet, warte auf Antwort... 301 Moved Permanently
                Platz: https://curl.se/ca/cacert.pem[folge]
                --2023-04-19 17:46:07--  https://curl.se/ca/cacert.pem
                Auflösen des Hostnamen »curl.se (curl.se)«... 2a04:4e42:400::347, 2a04:4e42:c                                               00::347, 2a04:4e42:e00::347, ...
                Verbindungsaufbau zu curl.se (curl.se)|2a04:4e42:400::347|:443... verbunden.
                FEHLER: Kann das Zertifikat von »curl.se« nicht prüfen, ausgestellt von »»/                                               C=US/O=Let's Encrypt/CN=R3««:.
                  Das ausgestellte Zertifikat ist nicht mehr gültig.
                Verwenden Sie »--no-check-certificate«, um zu dem Server »curl.se« eine nich                                               t gesicherte Verbindung aufzubauen.
                [root@edomi certs]#
                  jonofe
                  Kurze Rückmeldung:
                  Habe mir alle Posts durchgelsen und im westentlich das befolgt, was ungefähr zwischen Post 640-660 behandelt wurde.
                  Fazit geht jetzt!
                  Danke, Andre für den Support und den tollen Baustein!
                  Lio
                    Ich habe gerade meine Edomi neu gestartet und nun habe ich folgenden Fehler im Error Log und
                    2023-06-08 17:39:51    765985    ?    5280    Datei: /usr/local/edomi/www/data/liveproject/lbs/LBS19000809.php | Fehlercode: 2 | Zeile: 240 | msg_get_queue(): failed for key 0x6481f4445b223: No space left on device    ERROR
                    2023-06-08 17:39:51    766541    ?    5280    Datei: /usr/local/edomi/www/data/liveproject/lbs/LBS19000809.php | Fehlercode: 2 | Zeile: 241 | msg_send() expects parameter 1 to be resource, boolean given    ERROR
                    2023-06-08 17:39:51    803663    ?    5280    Datei: /usr/local/edomi/www/data/liveproject/lbs/LBS19000809.php | Fehlercode: 2 | Zeile: 240 | msg_get_queue(): failed for key 0x6481f444a08ec: No space left on device    ERROR
                    2023-06-08 17:39:51    804322    ?    5280    Datei: /usr/local/edomi/www/data/liveproject/lbs/LBS19000809.php | Fehlercode: 2 | Zeile: 241 | msg_send() expects parameter 1 to be resource, boolean given    ERROR
                    2023-06-08 17:39:51    816095    ?    5280    Datei: /usr/local/edomi/www/data/liveproject/lbs/LBS19000809.php | Fehlercode: 2 | Zeile: 240 | msg_get_queue(): failed for key 0x0: No space left on device    ERROR
                    2023-06-08 17:39:51    816669    ?    5280    Datei: /usr/local/edomi/www/data/liveproject/lbs/LBS19000809.php | Fehlercode: 2 | Zeile: 241 | msg_send() expects parameter 1 to be resource, boolean given    ERROR
                    2023-06-08 17:39:51    835963    ?    5280    Datei: /usr/local/edomi/www/data/liveproject/lbs/LBS19000809.php | Fehlercode: 2 | Zeile: 240 | msg_get_queue(): failed for key 0x6481f444e678a: No space left on device    ERROR
                    2023-06-08 17:39:51    836649    ?    5280    Datei: /usr/local/edomi/www/data/liveproject/lbs/LBS19000809.php | Fehlercode: 2 | Zeile: 241 | msg_send() expects parameter 1 to be resource, boolean given    ERROR
                    2023-06-08 17:39:51    860110    ?    5280    Datei: /usr/local/edomi/www/data/liveproject/lbs/LBS19000809.php | Fehlercode: 2 | Zeile: 240 | msg_get_queue(): failed for key 0x6481f44539199: No space left on device    ERROR
                    2023-06-08 17:39:51    860752    ?    5280    Datei: /usr/local/edomi/www/data/liveproject/lbs/LBS19000809.php | Fehlercode: 2 | Zeile: 241 | msg_send() expects parameter 1 to be resource, boolean given    ERROR
                    2023-06-08 17:41:49    062283    ?    5280    Datei: /usr/local/edomi/www/data/liveproject/lbs/LBS19000809.php | Fehlercode: 2 | Zeile: 240 | msg_get_queue(): failed for key 0x6481f44413a06: No space left on device    ERROR
                    2023-06-08 17:41:49    063416    ?    5280    Datei: /usr/local/edomi/www/data/liveproject/lbs/LBS19000809.php | Fehlercode: 2 | Zeile: 241 | msg_send() expects parameter 1 to be resource, boolean given    ERROR
                    2023-06-08 17:41:49    081559    ?    5280    Datei: /usr/local/edomi/www/data/liveproject/lbs/LBS19000809.php | Fehlercode: 2 | Zeile: 240 | msg_get_queue(): failed for key 0x0: No space left on device    ERROR
                    2023-06-08 17:41:49    082243    ?    5280    Datei: /usr/local/edomi/www/data/liveproject/lbs/LBS19000809.php | Fehlercode: 2 | Zeile: 241 | msg_send() expects parameter 1 to be resource, boolean given    ERROR
                    2023-06-08 17:41:49    105588    ?    5280    Datei: /usr/local/edomi/www/data/liveproject/lbs/LBS19000809.php | Fehlercode: 2 | Zeile: 240 | msg_get_queue(): failed for key 0x6481f4445b223: No space left on device    ERROR
                    2023-06-08 17:41:49    106235    ?    5280    Datei: /usr/local/edomi/www/data/liveproject/lbs/LBS19000809.php | Fehlercode: 2 | Zeile: 241 | msg_send() expects parameter 1 to be resource, boolean given    ERROR
                    2023-06-08 17:41:49    124494    ?    5280    Datei: /usr/local/edomi/www/data/liveproject/lbs/LBS19000809.php | Fehlercode: 2 | Zeile: 240 | msg_get_queue(): failed for key 0x6481f444a08ec: No space left on device    ERROR
                    2023-06-08 17:41:49    125197    ?    5280    Datei: /usr/local/edomi/www/data/liveproject/lbs/LBS19000809.php | Fehlercode: 2 | Zeile: 241 | msg_send() expects parameter 1 to be resource, boolean given    ERROR
                    2023-06-08 17:41:49    140322    ?    5280    Datei: /usr/local/edomi/www/data/liveproject/lbs/LBS19000809.php | Fehlercode: 2 | Zeile: 240 | msg_get_queue(): failed for key 0x0: No space left on device    ERROR
                    2023-06-08 17:41:49    140975    ?    5280    Datei: /usr/local/edomi/www/data/liveproject/lbs/LBS19000809.php | Fehlercode: 2 | Zeile: 241 | msg_send() expects parameter 1 to be resource, boolean given    ERROR
                    2023-06-08 17:41:49    159086    ?    5280    Datei: /usr/local/edomi/www/data/liveproject/lbs/LBS19000809.php | Fehlercode: 2 | Zeile: 240 | msg_get_queue(): failed for key 0x6481f444e678a: No space left on device    ERROR
                    2023-06-08 17:41:49    159760    ?    5280    Datei: /usr/local/edomi/www/data/liveproject/lbs/LBS19000809.php | Fehlercode: 2 | Zeile: 241 | msg_send() expects parameter 1 to be resource, boolean given    ERROR
                    2023-06-08 17:41:49    179332    ?    5280    Datei: /usr/local/edomi/www/data/liveproject/lbs/LBS19000809.php | Fehlercode: 2 | Zeile: 240 | msg_get_queue(): failed for key 0x6481f44539199: No space left on device    ERROR
                    2023-06-08 17:41:49    180001    ?    5280    Datei: /usr/local/edomi/www/data/liveproject/lbs/LBS19000809.php | Fehlercode: 2 | Zeile: 241 | msg_send() expects parameter 1 to be resource, boolean given    ERROR​
                    und folgenden Fehler im LBS LOG
                    2023-06-08 17:27:19    731185    5555    debug    EXE19000809 [v3.0]: File: /usr/local/edomi/www/data/liveproject/lbs/EXE19000809.php | Error: 8 | Line: 375 | Undefined variable: update
                    2023-06-08 17:27:19    834429    5555    debug    EXE19000809 [v3.0]: File: /usr/local/edomi/www/data/liveproject/lbs/EXE19000809.php | Error: 2 | Line: 56 | msg_receive() expects parameter 1 to be resource, boolean given
                    2023-06-08 17:27:19    837743    5555    debug    EXE19000809 [v3.0]: File: /usr/local/edomi/www/data/liveproject/lbs/EXE19000809.php | Error: 8 | Line: 375 | Undefined variable: update
                    2023-06-08 17:27:19    941076    5555    debug    EXE19000809 [v3.0]: File: /usr/local/edomi/www/data/liveproject/lbs/EXE19000809.php | Error: 2 | Line: 56 | msg_receive() expects parameter 1 to be resource, boolean given
                    2023-06-08 17:27:19    944778    5555    debug    EXE19000809 [v3.0]: File: /usr/local/edomi/www/data/liveproject/lbs/EXE19000809.php | Error: 8 | Line: 375 | Undefined variable: update​
                    auch ein Update auf die Version 3.1 mit Refresh Token hat keine Änderung gebracht. Festplatte sollte nicht das Problem sein?
                    Kennt das jemand kann mir jemand helfen?
                    image.png​
                      Einfach mal neu booten...
                        Hallo jonofe
                        Am Wochenende hat nun auch bei mir der Login mit Username/Passwort nicht mehr geklappt und ich bin auf den neuen LBS mit Refreshtoken umgestiegen.
                        Der Control LBS scheint auch zu funktionieren, allerdings funktioniert der Last Echo LBS nicht immer.
                        Zu manchen Tageszeiten funktioniert er mehrmals hintereinander problemlos und zu anderen Zeiten auch nach mehreren Versuchen gar nicht.
                        Im Log wird dann der Quellcode einer Amazon Loginseite ausgegeben.
                        EXE19001202 [v0.1]: Last active ECHO not found. response body: [LF][LF][LF][LF][LF][LF][LF]<!doctype html><html class="a-no-js a-touch a-mobile" data-19ax5a9jf="mongoose">[LF] <head>[LF]<script type='text/javascript'>var ue_t0=ue_t0||+new Date();</script>[LF]<script type='text/javascript ... usw.
                        Hat das Problem sonst noch wer?
                          der LBS läuft eigentlich super, hab auch auf die neue Token basierte Anmeldung mittels E57 umgestellt, nur jetzt hätte ich einen Anwendungsfall um auf einem Echo einen Radiosender automatisch zu starten über E20.
                          Dabei kommen aber folgende Fehlermeldungen im log:
                          HTML-Code:
                          EXE19000809 [v3.1]: File: /usr/local/edomi/www/data/liveproject/lbs/EXE19000809.php | Error: 2 | Line: 2346 | file_get_contents(): SSL operation failed with code 1. OpenSSL Error messages:[LF]error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed 2023-09-30 22:36:25 957348 8753 debug
                          EXE19000809 [v3.1]: File: /usr/local/edomi/www/data/liveproject/lbs/EXE19000809.php | Error: 2 | Line: 2346 | file_get_contents(): Failed to enable crypto 2023-09-30 22:36:25 968497 8753 debug
                          EXE19000809 [v3.1]: File: /usr/local/edomi/www/data/liveproject/lbs/EXE19000809.php | Error: 2 | Line: 2346 | file_get_contents(https://tunein.com/search/?query=SWR3): failed to open stream: operation failed  ​
                          Funktioniert E20 überhaupt noch (TuneIn scheint ja abgeschaltet, allerdings finde ich im Log einen Hinweis bei V2.4 daß auf eine andere API umgebaut wurde)?
                          Falls ja, wie komme ich denn nun an eine korrekte Radio Station ID für die neue Amazon entertainment API?
                          Danke schon mal und einen schönen Abend!
                          Andi
                            Scheint eher ein Zertifikatsproblem zu sein. Hast du mal die root Zertifikate geupdated? (ca-certificates)
                            Wieso ist tune-in abgeschaltet?
                              ja, Ca-certificates hatte ich heute schon upgedatet. Wenn ich tunein.com im browser aufrufen will kommt da nur ein error!
                              aber ich hab es jetzt geschafft: Im Logfile des LBS kann man die Stationsnummer sxxxxx finden wenn man den Sender über Sprachbefehl startet. Und mit der sxxxxx Nummer klappt es dann an E20 auch!
                              Die bisherige Suchfunktion für einen Klartext des Radiosenders an E20 geht wohl nicht mehr.
                              Problem für mich damit gelöst! Danke!
                              Andi
                                Guten Morgen, ich habe die Suche schon bemüht, bin aber nicht so recht fündig geworden. Kann man mit dem LBS auch Gruppen ansteuern? Also z.B. Texte ausgeben.
