Hi jonofe ,
danke nochmals für die MQTT LBSe funktionieren ziemlich gut!
Aber ich hab ein kleines Problem mit dem 1052.
Nach dem Aktivieren des Projekts bekomme ich ab und zu folgende Fehler im Log und der LBS ist nicht aktiv.
Im LBS Log steht folgendes:
Irgendeine Idee was es sein könnte?
017-11-01 10:02:57483480?20870Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19001052.php | Fehlercode: 8 | Zeile: 83 | Undefined variable: clientERROR 2017-11-01 10:02:57483644?20870Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19001052.php | Fehlercode: 1 | Zeile: 83 | Call to a member function loop() on a non-objectFATALERROR
[TABLE="class: log, border: 0, cellpadding: 0, cellspacing: 0, width: 0, height: 12"]
[TR]
[TD]2017-11-01 10:02:28[/TD]
[TD]238745[/TD]
[TD]12207[/TD]
[TD]debug[/TD]
[TD]EXE19001052 [v0.5]: MQTT Subscribe Server daemon stopped (2840)[/TD]
[/TR]
[TR]
[TD]2017-11-01 10:02:57[/TD]
[TD]458806[/TD]
[TD]20849[/TD]
[TD]debug[/TD]
[TD]LBS19001052 [v0.5]: LBS MQTT Subscribe Server started (2840)[/TD]
[/TR]
[TR]
[TD]459693[/TD]
[TD]20849[/TD]
[TD]debug[/TD]
[TD]LBS19001052 [v0.5]: MSGQID generated: 1336425939 (2840)[/TD]
[/TR]
[TR]
[TD]462883[/TD]
[TD]20849[/TD]
[TD]debug[/TD]
[TD]LBS19001052 [v0.5]: Message: (2840)[/TD]
[/TR]
[TR]
[TD]462985[/TD]
[TD]20849[/TD]
[TD]debug[/TD]
[TD]LBS19001052 [v0.5]: ================ ARRAY/OBJECT START ================[/TD]
[/TR]
[TR]
[TD]463042[/TD]
[TD]20849[/TD]
[TD]debug[/TD]
[TD]LBS19001052 [v0.5]: {"start":{"ip":"openhabian.knx.local","port":"8883","user":"edomi","pwd":"*****","plain":null,"regexp":null,"qos":"1","retain":"0","sub":["edomi\/set\/#","edomi\/get\/#"],"tls":"1","caPath":"\/etc\/ssl\/certs\/ca-bundle.crt"}}[/TD]
[/TR]
[TR]
[TD]463088[/TD]
[TD]20849[/TD]
[TD]debug[/TD]
[TD]LBS19001052 [v0.5]: ================ ARRAY/OBJECT END ================[/TD]
[/TR]
[TR]
[TD]463548[/TD]
[TD]20849[/TD]
[TD]debug[/TD]
[TD]LBS19001052 [v0.5]: MSGQID used: 1336425939 (2840)[/TD]
[/TR]
[TR]
[TD]483273[/TD]
[TD]20870[/TD]
[TD]debug[/TD]
[TD]EXE19001052 [v0.5]: MSGQID: 1336425939 (2840)[/TD]
[/TR]
[TR]
[TD]493928[/TD]
[TD]20849[/TD]
[TD]debug[/TD]
[TD]LBS19001052 [v0.5]: LBS MQTT Subscribe Server ended (2840)[/TD]
[/TR]
[/TABLE]
