Xiaomi / Roboroc Baustein 19001929
    Ich habe noch Logs gehabt und die zum Zeitpunkt relevanten kopiert:
    2022-01-16 14:18:37 Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19001929.php | Fehlercode: 8 | Zeile: 311 | Array to string conversion
    2022-01-16 14:18:37 Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19001929.php | Fehlercode: 8 | Zeile: 1043 | Array to string conversion
    2022-01-16 14:29:45 Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19001929.php | Fehlercode: 8 | Zeile: 1043 | Array to string conversion
    2022-01-16 14:30:29 Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19001929.php | Fehlercode: 2 | Zeile: 1887 | sizeof(): Parameter must be an array or an object that implements Countable
    2022-01-16 14:17:55 cmd::array(2) {[LF] ["method"]=>[LF] string(14) "load_multi_map"[LF] ["params"]=>[LF] array(1) {[LF] [0]=>[LF] int(0)[LF] }[LF]}[LF]
    2022-01-16 14:17:55 {"method":"load_multi_map","params":[0]}
    2022-01-16 14:17:55 resp::array(3) {[LF] ["id"]=>[LF] int(3826)[LF] ["error"]=>[LF] array(2) {[LF] ["code"]=>[LF] int(-10007)[LF] ["message"]=>[LF] string(14) "invalid status"[LF] }[LF] ["exe_time"]=>[LF] int(101)[LF]}[LF]
    2022-01-16 14:19:05 cmd::array(2) {[LF] ["method"]=>[LF] string(14) "load_multi_map"[LF] ["params"]=>[LF] array(1) {[LF] [0]=>[LF] int(0)[LF] }[LF]}[LF]
    2022-01-16 14:19:05 {"method":"load_multi_map","params":[0]}
    2022-01-16 14:19:05 resp::array(3) {[LF] ["id"]=>[LF] int(3841)[LF] ["error"]=>[LF] array(2) {[LF] ["code"]=>[LF] int(-10007)[LF] ["message"]=>[LF] string(14) "invalid status"[LF] }[LF] ["exe_time"]=>[LF] int(101)[LF]}[LF]
    2022-01-16 14:27:28 cmd::array(2) {[LF] ["method"]=>[LF] string(14) "load_multi_map"[LF] ["params"]=>[LF] array(1) {[LF] [0]=>[LF] int(0)[LF] }[LF]}[LF]
    2022-01-16 14:27:28 {"method":"load_multi_map","params":[0]}
    2022-01-16 14:27:28 resp::array(3) {[LF] ["id"]=>[LF] int(4052)[LF] ["error"]=>[LF] array(2) {[LF] ["code"]=>[LF] int(-10007)[LF] ["message"]=>[LF] string(14) "invalid status"[LF] }[LF] ["exe_time"]=>[LF] int(101)[LF]}[LF]
    2022-01-16 14:30:24 cmd::array(2) {[LF] ["method"]=>[LF] string(14) "load_multi_map"[LF] ["params"]=>[LF] array(1) {[LF] [0]=>[LF] int(0)[LF] }[LF]}[LF]
    2022-01-16 14:30:24 {"method":"load_multi_map","params":[0]}
    2022-01-16 14:30:24 resp::array(3) {[LF] ["id"]=>[LF] int(4088)[LF] ["error"]=>[LF] array(2) {[LF] ["code"]=>[LF] int(-10007)[LF] ["message"]=>[LF] string(14) "invalid status"[LF] }[LF] ["exe_time"]=>[LF] int(101)[LF]}[LF]
    2022-01-16 14:30:29 miIO.Info not supported!!
    ...and I thought my jokes were bad!
      Kurzer Zwischenstand:
      Dank exec konnte ich mir das RSSI-Problem per Teamviewer anschauen, was der Roboter ausgibt. Beim S7 ist das RSSI ist zwar vorhanden, aber der Roboter gibt den Wert nicht aus. Vondaher kann man hier leider nichts machen.
      Den anderen Fehler konnte ich (und auch exec) bisher nicht wieder reproduzieren.
        Moin zusammen,
        hat noch jemand seit ein paar Tagen diesen Fehler:
          Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19001929.php | Fehlercode: 8 | Zeile: 1051 | Trying to access array offset on value of type null
        Bei mir füllt sich langsam das Errorlog. Ein Neustart des Robos hat nichts gebracht.
        Jascha
          Hat schon jemand den LBS mit dem Roborock S7 MaxV plus/ultra im Einsatz? Sind hier Probleme zu erwarten?
          sipiyou : Kann man schon jetzt oder auch in einem zukünftigen Release auch die Absaugstation (Staub/Wasser) triggern?
            jonofe: Ich gehe nicht davon aus, dass hier Probleme zu erwarten sind, falls doch sehe ich auch hier kein Problem, wenn du mir per Teamviewer Zugriff geben kannst.
            Hat der Ultra einen zusätzlichen Trigger für die Absaugstation ? Wenn es da was gibt, lässt es sich sicherlich irgendwie implementieren. Wenn du einen hast, dann würde ich gerne paar json-Dateien mir anschauen, was der unter status usw. ausgibt.
              Okay, das klingt gut.
              Habe ich zumindest so verstanden, dass man bei der S7 MaxV+ die Absaugstation entweder über die App oder automatisch (wenn voll) aktivieren kann. Bei der S7 MaxV Ultra zusätzlich noch die Absaugung des Schmutzwassers und Auffüllen des Frischwassers.
              Ich melde mich dann nochmal, sobald den S7 MaxV+ habe.
                ich habe seit kurzen den Q7 Max+ in Betrieb. Das Q-Modell ist ja quasi die abgespeckte Variante des S7 MaxV. Die Aufschaltung mit dem LBS hat problemlos funktioniert. Wie bereits oben vermutet müsste die Funktionen der Docking-Station in den LBS nachgepflegt werden, wobei dies sich beim Q7 auf die Absaugfunktion beschränkt.
                  meisterschaf: Wenn du lust hast, hätt ich eine beta für dich zum testen. Da zeigt der Dir schonmal die Anzahl der Absaugvorgänge an.
                  Könntest du mir hier aber noch sagen, wie der Menüpunkt bei dir in der App unter den Statistiken genau heisst ?
                  Kannst du mir da auch nochmal erklären, was du da genau machen kannst ? Sprich: musst du den Absaugvorgang dann manuell in der App triggern ?
                    Vielen Dank an dieser Stelle nochmal an meisterschaf für's beta testen.
                    Über E14 gibt es nun 2 weitere Kommandos - siehe Hilfe - womit die Absaugfunktion manuell gestartet und auch abgebrochen werden kann.
                    Weiterhin gibt es unter den Statistiken über A23 die Anzahl der Absaugvorgänge.
                    Zuguterletzt hab ich noch einen Fehler behoben, bei dem PHP einen Fehler in der Log generiert hat.
                      Perfektes Timing. Heute hat meine Frau den S7 MaxV Plus zum Geburtstag bekommen. Werde in den nächsten Tagen testen und berichten. Danke schon mal vorab für den LBS!
                        Danke Sipiyou fürs update! Noch keine Absaug Station ..aber das hole ich sicher nach!
                        Bin vom Gen1 auf den S7 gewechselt. ..is schon nen sprung wenn auch kein Quantensprung ;-)
                        So wie ich verstanden habe ist der zuletzt aktive Modus (Vac+Mob oder nur Mob oder nur Vac) in der Xiaomi app doch auch der Modus mit das
                        Startkommando gestartet wird....oder?
                        Kann ich den Baustein so triggern das er "nur" saugt und nicht auch gleichzeitig wischt egal was in der App und aktuellen Karte als Modus gerade zuletzt verwendet wurde?
                        LG
                        Zuletzt geändert von trollmar; 20.06.2022, 20:54.
                          trollmar: Ist jetzt eine gute Frage. Ich hab nur den S6 und den S6maxV. Wenn ich das Reinigungstuch andocke, dann ist der automatisch auf saugen und wischen.
                          Du kannst über die App dann einstellen, wie feucht welcher Raum gewischt werden soll, wenn das Tüchlein unten dran ist.
                          Wie das beim S7 und co ist, kann ich nicht sagen. Ich könnte mir aber auch vorstellen, dass du das in der App einstellen kannst, ob welcher Raum gemoppt werden soll.
                          Das Kommando ist nur "Starten". Schau mal bitte, wie das in der App beim S7 ist.
                          Wenn es dort die Funktion gibt, dann schau ich, wie die Funktion im LBS abgebildet werden kann.
                            Ich bekomme den LBS leider nicht zum Laufen.
                            Ich habe den S7 MaxV in der MiHome App registriert und den LBS mit meinem MiHome Account Daten an E2/E3 gestartet, Debug=2, Geräte-ID=0.
                            Im Log konnte ich dann identifizieren, dass die Geräte-ID wohl die 9 ist. Außerdem erscheint das Cloud Token kurz nach dem Start dann an A10.
                            Diese ID habe ich dann im LBS eingetragen und das Cloud Token über ein iKO an E7 verbunden.
                            Beim Neustart sehe ich nun auch die IP des Saugers im Log (s.u.), aber alle Ausgänge bleiben leer. Außerdem sehe ich nach jedem Start ein neues Cloud Token an A10, keine Ahnung warum.
                            2022-06-20 23:22:55 744947 13197 Info Login erfolgreich!
                            2022-06-20 23:22:55 745101 13197 Debug uid=158####860; ssecurity=RMA3PLFK#####iC7XP2wtg==; serviceToken= 2N7lziJ2Ct#####pxzUvf0n4Td/xiC#####x9oB4bCH5a1uVDxMETMTYBOm80jTcoWko3aJfToxhJ zSreEeCOukm8gaoSRDVltzZYD+aT34XWtYc5/RfQTHHCsM7pD/CcR7IvC4o8KQzPQEomz#####YWtISyA4lbC8R5UTQkoc=
                            2022-06-20 23:22:55 745126 13197 Debug ip: bzw. token : sind leer. Cloud->getDeviceStatus()
                            2022-06-20 23:22:55 921572 13197 Info DeviceStatus ok[LF]
                            2022-06-20 23:22:55 922188 13197 Debug ip = 10.0.20.105; token = 59654c4f4f656b6######576e39596d[LF]
                            2022-06-20 23:22:55 922358 13197 Debug CloudStateInformation:array(10) [9]=>[LF] array(27) {[LF] ["did"]=>[LF] string(9) "5353####24"[LF] ["token"]=>[LF] string(32) "59654c4f4#####69576e39596d"[LF] ["longitude"]=>[LF] string(3) "0.0"[LF] ["latitude"]=>[LF] string(3) "0.0"[LF] ["name"]=>[LF] string(16) "Roborock S7 MaxV"[LF] ["pid"]=>[LF] string(1) "0"[LF] ["localip"]=>[LF] string(11) "10.0.20.105"[LF] ["mac"]=>[LF] string(17) "B0:4A:39:47:90:10"[LF] ["ssid"]=>[LF] string(8) "FELD-IOT"[LF] ["bssid"]=>[LF] string(17) "02:0C:42:6E:B5:12"[LF] ["parent_id"]=>[LF] string(0) ""[LF] ["parent_model"]=>[LF] string(0) ""[LF] ["show_mode"]=>[LF] int(1)[LF] ["model"]=>[LF] string(19) "roborock.vacuum.a27"[LF] ["adminFlag"]=>[LF] int(1)[LF] ["shareFlag"]=>[LF] int(0)[LF] ["permitLevel"]=>[LF] int(16)[LF] ["isOnline"]=>[LF] bool(true)[LF] ["desc"]=>[LF] string(14) "Gerät online "[LF] ["extra"]=>[LF] array(5) {[LF] ["isSetPincode"]=>[LF] int(0)[LF] ["pincodeType"]=>[LF] int(0)[LF] ["fw_version"]=>[LF] string(10) "4.1.5_4676"[LF] ["needVerifyCode"]=>[LF] int(0)[LF] ["isPasswordEncrypt"]=>[LF] int(0)[LF] }[LF] ["uid"]=>[LF] int(15#####0)[LF] ["pd_id"]=>[LF] int(72166)[LF] ["password"]=>[LF] string(0) ""[LF] ["p2p_id"]=>[LF] string(0) ""[LF] ["rssi"]=>[LF] int(-51)[LF] ["family_id"]=>[LF] int(0)[LF] ["reset_flag"]=>[LF] int(0)[LF] }[LF]}[LF]
                            2022-06-20 23:22:55 922518 13197 Debug cloud->isAccessible:Y-E10=-E11=
                            2022-06-20 23:22:55 922538 13197 Debug RoborockMe:: ip = 10.0.20.105; token = 59654c4f#######4e69576e39596d; SequenceID: 0
                            Zusätzlich erscheinen bei jedem Start des Projekts zwei Einträge im Fehlerlog:
                            2022-06-20 23:20:33 070550 ? 13089 Datei: /usr/local/edomi/www/data/liveproject/lbs/LBS19001929.php | Fehlercode: 8 | Zeile: 20 | Undefined offset: 1 ERROR
                            2022-06-20 23:20:33 070640 ? 13089 Datei: /usr/local/edomi/www/data/liveproject/lbs/LBS19001929.php | Fehlercode: 8 | Zeile: 20 | Undefined offset: 2 ERROR
                            Kann mir jemand einen Tip geben?
                            Ich sehe gerade: Kann es sein, dass ich nicht das Token von A10 (sehr langes Token + UID) an E7 verwenden muss, sondern das Token aus dem Log, dass mit 5965.... anfängt? Das teste ich mal kurz ...
                            EDIT:
                            Hat nicht geholfen. Allerdings sind die beiden Fehler jetzt weg. An E7 wird wohl ein durch NEWLINE "\n" getrenntes Token erwartet, welches man aber so einfach nicht in einem iKO ablegen kann. Daher habe ich ein iKO an E7 gehängt, dieses Remanent gesetzt und dann in der Liveansicht das Token inkl. der Linebreaks eingefügt. Danach sind die Fehler dann weg. Aber der LBS sagt nach wie vor nichts ...
                            Bei jedem erneuten Triggern mit E1=1 bekommen ich folgendes im Log:
                            2022-06-21 00:04:42 995786 15352 Debug Cloud-Daten aus Cache verwenden. Kein Login!
                            2022-06-21 00:04:42 995964 15352 Debug V3=sgbgEbuTrtsiSQKrLO45JOMQ/XxO5MH8FCUOetVUmuM0jHqxGNIjw+mEiDFs/WgWA92C4b1Dj2lMxruMcGB6U7sS9v6 FtwaYMW1ogb5XCLmcI6QbFH6DNneFPkXrS00zUdKHYOET0WR8A 9EjYOBf1Oc=V4=tKtBO/5lXWLmhIP15D8KSg==V5=1585584860
                            2022-06-21 00:04:42 995999 15352 Debug cloud->isAccessible:Y-E10=-E11=
                            2022-06-21 00:04:42 996020 15352 Debug RoborockMe:: ip = 10.0.20.105; token = 59654c4##############d; SequenceID: 0
                            2022-06-21 00:05:03 013848 15352 Debug roborocMe:: ok
                            2022-06-21 00:05:03 013940 15352 Info Roboter reagiert nicht.
                            2022-06-21 00:05:03 014533 15352 Debug Ausführungszeit: 20.019255161285 [s]
                            Zuletzt geändert von jonofe; 20.06.2022, 23:07.
                              Moin,
                              ich habe noch bei E10 die lokale IP Adresse und bei E11 noch das lokale Token eingetragen.
                              Ansonsten sieht es so aus wie bei mir
                                Eins ist mir noch aufgefallen A10 und E7 sind bei mir identisch. Bei Dir nicht.
