Ich habe noch Logs gehabt und die zum Zeitpunkt relevanten kopiert:
2022-01-16 14:18:37 Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19001929.php | Fehlercode: 8 | Zeile: 311 | Array to string conversion 2022-01-16 14:18:37 Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19001929.php | Fehlercode: 8 | Zeile: 1043 | Array to string conversion 2022-01-16 14:29:45 Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19001929.php | Fehlercode: 8 | Zeile: 1043 | Array to string conversion 2022-01-16 14:30:29 Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19001929.php | Fehlercode: 2 | Zeile: 1887 | sizeof(): Parameter must be an array or an object that implements Countable
2022-01-16 14:17:55 cmd::array(2) {[LF] ["method"]=>[LF] string(14) "load_multi_map"[LF] ["params"]=>[LF] array(1) {[LF] [0]=>[LF] int(0)[LF] }[LF]}[LF]
2022-01-16 14:17:55 {"method":"load_multi_map","params":[0]}
2022-01-16 14:17:55 resp::array(3) {[LF] ["id"]=>[LF] int(3826)[LF] ["error"]=>[LF] array(2) {[LF] ["code"]=>[LF] int(-10007)[LF] ["message"]=>[LF] string(14) "invalid status"[LF] }[LF] ["exe_time"]=>[LF] int(101)[LF]}[LF]
2022-01-16 14:19:05 cmd::array(2) {[LF] ["method"]=>[LF] string(14) "load_multi_map"[LF] ["params"]=>[LF] array(1) {[LF] [0]=>[LF] int(0)[LF] }[LF]}[LF]
2022-01-16 14:19:05 {"method":"load_multi_map","params":[0]}
2022-01-16 14:19:05 resp::array(3) {[LF] ["id"]=>[LF] int(3841)[LF] ["error"]=>[LF] array(2) {[LF] ["code"]=>[LF] int(-10007)[LF] ["message"]=>[LF] string(14) "invalid status"[LF] }[LF] ["exe_time"]=>[LF] int(101)[LF]}[LF]
2022-01-16 14:27:28 cmd::array(2) {[LF] ["method"]=>[LF] string(14) "load_multi_map"[LF] ["params"]=>[LF] array(1) {[LF] [0]=>[LF] int(0)[LF] }[LF]}[LF]
2022-01-16 14:27:28 {"method":"load_multi_map","params":[0]}
2022-01-16 14:27:28 resp::array(3) {[LF] ["id"]=>[LF] int(4052)[LF] ["error"]=>[LF] array(2) {[LF] ["code"]=>[LF] int(-10007)[LF] ["message"]=>[LF] string(14) "invalid status"[LF] }[LF] ["exe_time"]=>[LF] int(101)[LF]}[LF]
2022-01-16 14:30:24 cmd::array(2) {[LF] ["method"]=>[LF] string(14) "load_multi_map"[LF] ["params"]=>[LF] array(1) {[LF] [0]=>[LF] int(0)[LF] }[LF]}[LF]
2022-01-16 14:30:24 {"method":"load_multi_map","params":[0]}
2022-01-16 14:30:24 resp::array(3) {[LF] ["id"]=>[LF] int(4088)[LF] ["error"]=>[LF] array(2) {[LF] ["code"]=>[LF] int(-10007)[LF] ["message"]=>[LF] string(14) "invalid status"[LF] }[LF] ["exe_time"]=>[LF] int(101)[LF]}[LF]
2022-01-16 14:30:29 miIO.Info not supported!!
