Hallo Andreas,
Schock am Abend..
Nein, bei mir läuft es aktuell.
Gruß Jürgen
Schock am Abend..
Gruß Jürgen
2019-10-27 08:06:18 WARNING lib.plugin PluginWrapper __init__: Section alexa, classname alexap3, classpath plugins.alexa4p3 2019-10-27 08:06:18 ERROR lib.plugin Plugin 'alexa' exception during execution of plugin: module 'plugins.alexa4p3' has no attribute 'alexap3' Traceback (most recent call last): File "/usr/local/smarthome/lib/plugin.py", line 553, in __init__ exec("self.plugin = {0}.{1}.__new__({0}.{1})".format(classpath, classname)) File "<string>", line 1, in <module> AttributeError: module 'plugins.alexa4p3' has no attribute 'alexap3' 2019-10-27 08:06:18 ERROR lib.plugin Plugin 'alexa4p3' from section 'alexa' exception: 'PluginWrapper' object has no attribute 'plugin' Traceback (most recent call last): File "/usr/local/smarthome/lib/plugin.py", line 145, in __init__ plugin_thread = PluginWrapper(smarthome, plugin, classname, classpath, args, instance, self.meta, self._gtrans) File "/usr/local/smarthome/lib/plugin.py", line 571, in __init__ if isinstance(self.get_implementation(), SmartPlugin): File "/usr/local/smarthome/lib/plugin.py", line 715, in get_implementation return self.plugin AttributeError: 'PluginWrapper' object has no attribute 'plugin'
classname: alexap3
class_name: Alexa4P3 class_path: plugins.alexa4p3
alexa: plugin_name: alexa4p3 #sonst nix!
mail: plugin_name: mailsend #sonst nix!
