Hallo Michel,
danke für Deine Antwort! Bin gern bereit zu Testen.
Hans
Hans
2015-03-24 17:20:25,766 INFO Main Start SmartHome.py 1.0-35-gf62db45+ -- smarthome.py:__init__:231 2015-03-24 17:20:25,766 DEBUG Main Python 3.2.3 -- smarthome.py:__init__:232 2015-03-24 17:20:25,767 INFO Main Init Scheduler -- scheduler.py:__init__:86 2015-03-24 17:20:25,767 INFO Main Init Plugins -- smarthome.py:start:274 2015-03-24 17:20:25,768 DEBUG Main Plugin: knx -- plugin.py:__init__:43 2015-03-24 17:20:25,770 DEBUG Main Plugin: visu -- plugin.py:__init__:43 2015-03-24 17:20:25,773 DEBUG Scheduler creating 5 workers -- scheduler.py:run:93 2015-03-24 17:20:25,775 DEBUG Main Plugin: cli -- plugin.py:__init__:43 2015-03-24 17:20:25,776 DEBUG Main Plugin: sql -- plugin.py:__init__:43 2015-03-24 17:20:25,778 DEBUG Main SQLite 3.7.13 -- __init__.py:__init__:62 2015-03-24 17:20:25,893 DEBUG Main SQLite: database integrity ok -- __init__.py:__init__:78 2015-03-24 17:20:25,894 DEBUG Main SQLite pack next time: 2015-03-25 03:02:00+01:00 -- scheduler.py:_next_time:289 2015-03-24 17:20:25,894 DEBUG Main Plugin: mail -- plugin.py:__init__:43 2015-03-24 17:20:25,903 DEBUG Main Plugin: uzsu -- plugin.py:__init__:43 2015-03-24 17:20:25,906 INFO Main Init UZSU -- __init__.py:__init__:36 2015-03-24 17:20:25,906 INFO Main Init Items -- smarthome.py:start:280 2015-03-24 17:20:25,941 DEBUG Main Item env.core.memory = 19595264.0 via SQLite None None -- item.py:set:472 2015-03-24 17:20:25,952 DEBUG Main Item env.core.threads = 7.0 via SQLite None None -- item.py:set:472 2015-03-24 17:20:25,964 DEBUG Main Item env.core.garbage = 0.0 via SQLite None None -- item.py:set:472 2015-03-24 17:20:25,964 DEBUG Main Item env.core: no type specified. -- item.py:__init__:242 2015-03-24 17:20:25,965 DEBUG Main KNX: Tag reply to 0/0/1 -- __init__.py:parse_item:267 2015-03-24 17:20:25,965 DEBUG Main KNX: Nacht reply to 0/0/2 -- __init__.py:parse_item:267 2015-03-24 17:20:25,967 DEBUG Main Item env.location: no type specified. -- item.py:__init__:242 2015-03-24 17:20:25,979 DEBUG Main Item env.system.load = 0.01 via SQLite None None -- item.py:set:472 2015-03-24 17:20:25,992 DEBUG Main Item env.system: no type specified. -- item.py:__init__:242 2015-03-24 17:20:25,992 DEBUG Main Item env: no type specified. -- item.py:__init__:242 2015-03-24 17:20:25,994 DEBUG Main KNX: aussen.strasse.spot listen on and init with cache 1/2/10 -- __init__.py:parse_item:254 2015-03-24 17:20:25,994 DEBUG Main Item aussen.strasse: no type specified. -- item.py:__init__:242 2015-03-24 17:20:25,995 DEBUG Main KNX: aussen.eingang.spot listen on and init with cache 1/2/8 -- __init__.py:parse_item:254 2015-03-24 17:20:25,995 DEBUG Main Item aussen.eingang: no type specified. -- item.py:__init__:242 2015-03-24 17:20:25,995 DEBUG Main KNX: aussen.einfahrt.spot listen on and init with cache 1/2/9 -- __init__.py:parse_item:254 2015-03-24 17:20:25,996 DEBUG Main Item aussen.einfahrt: no type specified. -- item.py:__init__:242 2015-03-24 17:20:25,996 DEBUG Main Item aussen: no type specified. -- item.py:__init__:242 2015-03-24 17:20:25,996 DEBUG Main Item kueche.licht: no type specified. -- item.py:__init__:242 2015-03-24 17:20:25,997 DEBUG Main Item kueche.spuele: no type specified. -- item.py:__init__:242 2015-03-24 17:20:25,998 DEBUG Main KNX: kueche.rollo.position listen on and init with cache 3/3/4 -- __init__.py:parse_item:254 2015-03-24 17:20:25,998 DEBUG Main Item kueche.rollo: no type specified. -- item.py:__init__:242 2015-03-24 17:20:25,998 DEBUG Main Item kueche: no type specified. -- item.py:__init__:242 2015-03-24 17:20:26,001 DEBUG Main KNX: eg.wohnen.steckdose1 listen on and init with cache 1/2/10 -- __init__.py:parse_item:254
[uzsu] class_name = UZSU class_path = plugins.uzsu
[eg] [[wohnen]] [[[steckdose1]]] type = bool visu_acl = rw knx_dpt = 1 knx_cache = 1/2/10 knx_send = 1/1/10 [[[[uzsu]]]] type = dict uzsu_item = eg.wohnen.steckdose1 cache = True visu_acl = rw
{{ basic.switch('eg.wohnen.steckdose1', 'eg.wohnen.steckdose1', icon1~'message_socket.png', icon0~'message_socket.png') }}Steckdose Fenster rechts {{ uzsu.uzsu_icon('uzsu1', 'eg.wohnen.steckdose1.uzsu', 'Steckdose Fenster') }}
