24V Tunable White LEDs von Benory
    Zitat von 6ast Beitrag anzeigen
    Probleme ist genau das richtige Stichwort.
    Es besteht eben die Gefahr, daß so Probleme wie die dicken Frontringe untergehen und dann plötzlich die Spots nicht in die Fassung passen. Deshalb sollte man bei aller Begeisterung für die günstige Alternative aufmerksam bleiben und prüfen, wo mögliche Detailprobleme bestehen.
    Thanks for your feedback.
    We have the Black housing version,( dimension D49.6*H68mm ) , which can suitable for the smaller fixture well
    Please kindly find the attached details
      Thanks very much for your affirmation and sharing on our products.
      If any others interested, welcome contact us by below:
        Ok, so the front ring is thinner in the black version. Any other differences in light engine, or is housing the only difference?
        BTW, be careful with posts that look like advertising. The forum owners don't like that. Technical support should be fine, but for advertising you need to pre-register with the forum owners as a forum sponsor and pay a fee.
        Zuletzt geändert von Gast1961; 29.12.2020, 08:05.
          Ok, in your list the black and silver housing versions for fixed color (BNLSP08CW and -S) are listed with the same nominal power 8W ... but for the tunable white version you have listed 8W for silver housing and 10W for black housing ... and product numbers are the same as for the single color versions.
          From results reported here, we have seen that your light engines / COB have rather different quality, from good to poor. So what is in the box for the black housing TW version, the same 8W 2000-6000 light engine and COB as tested by forum members, or something else as indicated by the list (10W) ?
          Zuletzt geändert von Gast1961; 29.12.2020, 08:56.
            Okay, noted with thanks .
            They are supply in different wattage: The silver version in 8W and black version in 10W.
              They are with same quality COB chip and driver. just different in Wattage and Housing material cost.
              The black housing version can suppy in 8W or 10W for options; the sliver version can only in 8W in max. ( consider heat dissipation factor )
                schwarz eloxierte Oberflächen bewirken eine um ca. 8 bis 10% verbesserte Wärmeableitung bei freier Konvektion
                  Hab ich wieder was dazu gelernt. Ich habe mich gefragt, warum meine Module schwarz eloxiert sind wo man die doch im eingebauten Zustand nicht sieht.
                    ich dachte mir schon, dass das hier nicht allen bekannt ist
                    etwas mehr zum thema kühlkörper hier
                      What ist the maximum dimension of the thickness of the front ring at the black version? It would be good to add this measure in the drawings.
                      Zuletzt geändert von willisurf; 29.12.2020, 12:54.
                      Gruß Bernhard
                        The black housing version in 0.25mm thickness of the ring as below showed
                        This gallery has 1 photos.
                          0.25mm thickness
                          Thank you also for the picture. Are you sure, that the zero point was correct?
                          In the picture it really look like more than one millimeter.
                          Gruß Bernhard
                            Wow, hatte nicht einmal annähernd geahnt, dass man sich mit dem Thema so intensiv auseinander setzen kann. Wieder was dazu gelernt.
                            Dennoch mal meine (Laien-)Erfahrung dazu: Habe gerade 40x 8W 2700k-6000k mit DALI (MDT) und DALI Treibern und Einbaurahmen (auch von Benory geliefert) verbaut. WAF exterm hoch, nach vorher "muss das sein", jetzt "kann man da nicht noch ein paar mehr machen". War für mich alles Neuland und muss sagen, bin begeistert.
                            Zu einigen Themen:
                            • Kommunikation mit den Chinesen wie gewohnt hervorragend (Mail, Chat oder auch WeChat).
                            • Beratung: sehr kompetent, im Zweifel auch mal Rückfragen mit Engineering auf Chinesischer Seite
                            • Preise: Klasse. Aber man muss auch einige Punkte im Auge behalten:
                              • Man bekommt die Ware direkt vom Hersteller, und muss einiges selber abwickeln, was ansonsten ein Händler in Europa für einen erledigt (Import, Zoll, Versandkosten usw.)
                              • Aufgrund Entfernung, Zoll, Versanddauer, usw. ist eine Abwicklung von Garantiefällen ehr schwierig (das übernimmt ansonsten der Europäische Importeur). Mal eben eine Reklamation mit Vorabtausch zurückschicken, ist da etwas komplizierter
                            • Qualität: Bislang alles sehr gut, bislang keine Ausfälle (weder Treiber noch Spots).
                            ​​​​​​​Unterm Strich einiges an Geld gespart, aber man sollte auch Wissen, worauf man sich einlässt. Bei dem Preis kann man sich auch mal einige Lampen als Ersatz auf Lager legen und ich kann mich damit bei Eigenverbrauch arrangieren. Wenn es darum geht, einen Kunden damit zu beglücken, würde ich wohl doch ehr über den Händler in Deutschland gehen, denn für den höheren Preis muss der ja auch einige mehr tun..
                            Daher als Hobby macht mir das Spass, oder man macht es tatsächlich professionell und wird Importeur mit allem, was dazu gehört!
                            Als nächstes mache ich mich mal an die RGBW's ....
                            Georg
                              Zitat von MasterOfPuppets Beitrag anzeigen
                              Wow Bernhard ich bin echt beeindruckt von der Zeit die du hier investiert! Vielen Dank von meiner Seite! Wenn wirklich eine Sammelbestellung gestartet wird, wäre ich auch mit ca. 100 Stück dabei! Toll wäre es wenn Benory ebenfalls eine 6+6 Version bringen würde.
                              Bei 100 Stück lohnt sich das auch als Einzelbestellung. Kannst mir gerne mal ne PN schicken, wenn du dazu mehr infos brauchst.
                              Georg
                                Das Jahr hat jetzt begonnen, ich denke von meiner Seite aus gibt es nächste Woche Neuigkeiten
