Zitat von Stoxn
Apple - HomeKit - Schnittstelle zur Heimautomation
Hi Stoxn wie sieht denn Deine Gad-Struktur für diese Funktionen aus? Ich will nicht immer nur von meiner ausgehen, sondern gerne Eure Ideen mit einbauen!
Deutschsprachiges homebridge-knx-Forum unter https://github.com/snowdd1/homebridge-knx-de
Hi, ich hatte nur Probleme mit dem Node.js unter meinem Ubuntu Linux. Auf dem RPI hat es weit geklappt, leider bekomme ich jetzt folgenden Fehler:
Code:node BridgedCore.js *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi. *** WARNING *** Please fix your application to use the native API of Avahi! *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node> *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi. *** WARNING *** Please fix your application to use the native API of Avahi! *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister> HAP-NodeJS starting... Cannot find secret key, creating One... TCP server accepting connection on port: 51826 HAP Server is listening /home/pi/HAP-NodeJS-KNX/node_modules/eibd/lib/tools.js:7 var buf = new Buffer(data.length); ^ RangeError: Maximum call stack size exceeded at Object.module.exports.pack (/home/pi/HAP-NodeJS-KNX/node_modules/eibd/lib/tools.js:7:13) at Connection.sendRequest (/home/pi/HAP-NodeJS-KNX/node_modules/eibd/lib/connection.js:185:19) at Connection.openGroupSocket (/home/pi/HAP-NodeJS-KNX/node_modules/eibd/lib/connection.js:82:8) at Socket.<anonymous> (/home/pi/HAP-NodeJS-KNX/accessories/busMonitor.js:21:8) at Socket.emit (events.js:129:20) at onwriteError (_stream_writable.js:317:10) at onwrite (_stream_writable.js:335:5) at WritableState.onwrite (_stream_writable.js:105:5) at fireErrorCallbacks (net.js:456:13) at Socket._destroy (net.js:467:5)
Hast du die (immer noch) kaputte esf Datei aus GitHub verwendet, oder eine eigene?Deutschsprachiges homebridge-knx-Forum unter https://github.com/snowdd1/homebridge-knx-de
Hallo snowdd,
ich habe mehrere Versuche gestartet, auch mit deiner Anleitung den Raspberry herzurichten. Leider jedesmal ohne Erfolg. Besteht die Möglichkeit eine Kopie von einer fertigen SD-Kart zu bekommen? Nur für den Anfang.
Gruß RalfZuletzt geändert von aralf; 15.08.2015, 16:17.Mein KNX: HS3, Agfeo 191 plus EIB, Elsa SunTracer, 24 LJ Dimm, 36 LJ Schalt, 18 LJ Roll,
Multiroom: 2 Sonos Play3, 1 Sonos Connact/Amp
WireGate: bestellt, geliefert, angeschlossen, läuft. einfach klasse
Hi aralf , muss ich mal sehen ob ich ein "neutrales" Image aus meiner laufenden Installation machen kann. Ich würde aber gerne wissen, woran es derzeit bei Dir scheitert, kannst Du ein paar Details posten? Vielleicht ist meine Anleitung ja nicht vollständig, das würde ich dann mal korrigieren wollen!Deutschsprachiges homebridge-knx-Forum unter https://github.com/snowdd1/homebridge-knx-de
snowdd
Habe gerade einen neuen Versuch mit neuer SD-Card begonnen. Werde dann sofort den ersten Fehler posten.
Gruß Ralf
bei mir funktioniert alles bestens. Allerdings habe ich keine lokale USB-Schnittstelle sondern nutze den EIBD des vorhandenen Wiregates als Schnittstelle.
Auch mit iOS 9.0 beta 5 keine Probleme.
Den Start des "Servers" habe ich über forever gelöst.
Dazu einfach
und ein Start-Script mit folgendem Inhalt erstellen und dies ausführbar machen:Code:[FONT=Menlo][SIZE=11px]sudo npm install -g forever[/SIZE][/FONT]
@snowdd: Vielen Dank für die Arbeit, die du da rein steckst.Code:[COLOR=#34BBC7][FONT=Menlo][SIZE=11px]#!/bin/bash[/SIZE][/FONT][/COLOR] [FONT=Menlo][SIZE=11px][COLOR=#5330e1][B]cd[/B][/COLOR] HAP-NodeJS-KNX/[/SIZE][/FONT] [FONT=Menlo][SIZE=11px]forever start BridgedCore.js[/SIZE][/FONT]
Johannes
Hurra, bin einen Schritt weiter. IP-Adresse auf Wirkgate geändert läuft.
Nun wird auf dem Handy Node Bridge angezeigt. Nach anwahl kommt aber keine Verbindung zu Stande.
Wenn jemand eine Lösung hat bitte mitteilen. Werde weiter auf Fehlersuche gehen.
Leider sitzt der Fehler meistens vor dem Monitor.
Ralf
irgendwie komme ich nicht weiter.
pi@raspberrypi ~/HAP-NodeJS-KNX $ node BridgedCore.js
knxfunctions.read: in callback parser at end
Wo kann ich noch suchen?
Danke Ralf
Ich glaube es liegt an den doofen esf-Dateien. Ich denke mir wohl doch noch ein einfaches, von Hand zu pflegendes Format aus.
Ich wollte ja eigentlich vermeiden dass man die Adressen zwei Mal (ets und Homekit) pflegen muss, aber die Exportmöglichkeit der ets (zumindest bei meiner 4er) sind beschränkt...
vielleicht kann ich nächstes Wochenende etwas zimmern.Deutschsprachiges homebridge-knx-Forum unter https://github.com/snowdd1/homebridge-knx-de
Guten Tag,
habe mich entschlossen, statt des "nackten" HAP-nodeJS auf die "Homebridge" aufzusetzen. Für homebridge gibt es schon eine Reihe fertige Hardware-Integrationen, so wie Sonos, Wink, und etliche mehr.
Ich habe einen Pull-Request gestartet, um meine Entwicklung darin aufzunehmen. Solange stehen sie noch in meinem Fork.
Grundsätzliche Änderungen:- Keine Verwendung von ETS-Exporten mehr. Das hat mehr Probleme verursacht als dass es Arbeit gespart hätte. Die Konfiguration der Elemente, die über HomeKit ansprechbar (sogar wörtlich per Siri) sein sollen, muss nun in einer JSON-Datei gemacht werden.
- Man kann die Zuordnung von Geräten zu Diensten ("accessories and Services") frei vornehmen. Da man "Geräte" den Räumen zuordnet, hat man weniger Arbeit, wenn man Licht, Thermostat, Rollo (ab iOS9, noch nicht implementiert) etc. in ein Gerät packt. Allerdings kommen die HomeKit-Softwaren (myTouchHome, EVE) unterschiedlich gut damit zurecht, wenn man mehrere Services eines Types in ein Gerät steckt.
An die "Early Adopters" unter Euch: Ich freue mich auf Feedback!
Raoul
Menno! Ich habe seit gestern Abend versucht Deinen Fork zum Laufen zu bekommen und war kurz davor das es geklappt hat. :/ Wenn ich irgendwie unterstützen kann gib ein Zeichen.
EDIT 20:00Uhr : 30min später habe ich die Homebridge-Lösung auf meinem Cubietruck am laufen, habe eben per SIRI mein Arbeitszimmerlich eingeschaltet und bin sehr sehr begeistert!!! Dickes Danke! Wenn ich bei der Weiterentwicklung behilflich sein kann lass mich es mit offenen Aufgaben wissen.
CarstenZuletzt geändert von Netsrac80; 06.09.2015, 19:00.
