[B]pi@raspberrypi[/B]:[B]~ $[/B] sudo systemctl status homebridge
[B]●[/B] homebridge.service - Homebridge Automation Service
Loaded: loaded (/etc/systemd/system/homebridge.service; enabled)
Active: [B]failed[/B] (Result: start-limit) since Mo 2016-11-21 19:47:26 CET; 1h 43min ago
Docs: https://github.com/nfarina/homebridge
Process: 530 ExecStart=/usr/bin/node /home/pi/node_modules/homebridge/bin/homebridge -D [B](code=exited, status=1/FAILURE)[/B]
Main PID: 530 (code=exited, status=1/FAILURE)
Nov 21 19:47:25 raspberrypi homebridge.service[530]: at startup (bootstrap_node.js:149:9)
Nov 21 19:47:25 raspberrypi homebridge.service[530]: at bootstrap_node.js:509:3
Nov 21 19:47:25 raspberrypi systemd[1]: [B]homebridge.service: main process exited, code=exited, status=1/FAILURE[/B]
Nov 21 19:47:25 raspberrypi systemd[1]: [B]Unit homebridge.service entered failed state.[/B]
Nov 21 19:47:26 raspberrypi systemd[1]: homebridge.service holdoff time over, scheduling restart.
Nov 21 19:47:26 raspberrypi systemd[1]: Stopping Homebridge Automation Service...
Nov 21 19:47:26 raspberrypi systemd[1]: Starting Homebridge Automation Service...
Nov 21 19:47:26 raspberrypi systemd[1]: [B]homebridge.service start request repeated too quickly, refusing to start.[/B]
Nov 21 19:47:26 raspberrypi systemd[1]: [B]Failed to start Homebridge Automation Service.[/B]
Nov 21 19:47:26 raspberrypi systemd[1]: [B]Unit homebridge.service entered failed state.[/B]
okay dann werde ich mal von neuen anfangen müssen.
