Der Ofen-Baustein hat ein Problem mit dem Umlauten beim Programm:
Kannst du das eventuell fixen? Ansonsten läuft das alles problemlos.
2022-10-06 17:51:20 | 378405 | 25974 | debug | LBS19002524 [v0.3.2]: force refresh |
2022-10-06 17:51:20 | 378937 | 25974 | debug | LBS19002524 [v0.3.2]: call exec |
2022-10-06 17:51:25 | 085665 | 3820 | debug | EXE19002524 [v0.3.2]: unknown for Output key: LaundryCare.Washer.Setting.IDos1BaseLevel value: 80 |
2022-10-06 17:51:25 | 086693 | 3820 | debug | EXE19002524 [v0.3.2]: unknown for Output key: LaundryCare.Washer.Setting.IDos2BaseLevel value: 80 |
2022-10-06 17:51:25 | 235131 | 3820 | debug | EXE19002524 [v0.3.2]: unknown for Output key: LaundryCare.Washer.Option.WaterPlus value: |
2022-10-06 17:51:25 | 235733 | 3820 | debug | EXE19002524 [v0.3.2]: unknown for Output key: LaundryCare.Washer.Option.IDos1DosingLevel value: LaundryCare.Washer.EnumType.IDosingLevel.Strong |
2022-10-06 17:51:25 | 236188 | 3820 | debug | EXE19002524 [v0.3.2]: unknown for Output key: LaundryCare.Washer.Option.IDos2DosingLevel value: LaundryCare.Washer.EnumType.IDosingLevel.Off |
2022-10-06 17:51:25 | 236597 | 3820 | debug | EXE19002524 [v0.3.2]: unknown for Output key: LaundryCare.Washer.Option.RinsePlus value: LaundryCare.Washer.EnumType.RinsePlus.Off |
2022-10-06 17:51:25 | 237013 | 3820 | debug | EXE19002524 [v0.3.2]: unknown for Output key: LaundryCare.Washer.Option.Stains value: LaundryCare.Washer.EnumType.Stains.Off |
2022-10-06 17:51:25 | 237420 | 3820 | debug | EXE19002524 [v0.3.2]: unknown for Output key: LaundryCare.Washer.Option.Prewash value: |
2022-10-06 17:51:25 | 237822 | 3820 | debug | EXE19002524 [v0.3.2]: unknown for Output key: LaundryCare.Washer.Option.LessIroning value: |
2022-10-06 17:51:25 | 238233 | 3820 | debug | EXE19002524 [v0.3.2]: unknown for Output key: LaundryCare.Common.Option.VarioPerfect value: LaundryCare.Common.EnumType.VarioPerfect.Off |
2022-10-06 17:51:35 | 970124 | 25974 | debug | LBS19002524 [v0.3.2]: call exec |
2022-10-06 17:51:36 | 018575 | 3856 | debug | EXE19002524 [v0.3.2]: postdata: |
2022-10-06 17:51:36 | 018748 | 3856 | debug | EXE19002524 [v0.3.2]: ================ ARRAY/OBJECT START ================ |
2022-10-06 17:51:36 | 018841 | 3856 | debug | EXE19002524 [v0.3.2]: "{ "data": { "key": "LaundryCare.Washer.Program.Cotton", "options": [{ "key": "BSH.Common.Option.FinishInRelative", "value": 9600, "unit": "seconds", "name": "Zeitversetzter Betrieb" }, { "key": "LaundryCare.Washer.Option.Temperature", "value": "LaundryCare.Washer.EnumType.Temperature.GC40" , "name": "Temperatur", "displayvalue": "40°C" }, { "key": "LaundryCare.Washer.Option.SpinSpeed", "value": "LaundryCare.Washer.EnumType.SpinSpeed.RPM1200 ", "name": "Drehzahl", "displayvalue": "1200 U/min" }, { "key": "LaundryCare.Washer.Option.WaterPlus", "value": false, "name": "Wasser Plus" }, { "key": "LaundryCare.Washer.Option.IDos1DosingLevel", "value": "LaundryCare.Washer.EnumType.IDosingLevel.Stro ng", "name": "i-Dos Dosierstärke Waschmittel", "displayvalue": "Stark" }, { "key": "LaundryCare.Washer.Option.IDos2DosingLevel", "value": "LaundryCare.Washer.EnumType.IDosingLevel.Off" , "name": "i-Dos Dosierstärke Weichspüler oder Waschmittel", "displayvalue": "Aus" }, { "key": "LaundryCare.Washer.Option.RinsePlus", "value": "LaundryCare.Washer.EnumType.RinsePlus.Off", "name": "Extraspülen", "displayvalue": "Aus" }, { "key": "LaundryCare.Washer.Option.Stains", "value": "LaundryCare.Washer.EnumType.Stains.Off", "name": "Antiflecken-System", "displayvalue": "Aus" }, { "key": "LaundryCare.Washer.Option.Prewash", "value": false, "name": "Vorwäsche" }, { "key": "LaundryCare.Washer.Option.LessIroning", "value": false, "name": "Knitterschutz" }, { "key": "LaundryCare.Common.Option.VarioPerfect", "value": "LaundryCare.Common.EnumType.VarioPerfect.Off" , "name": "varioPerfect", "displayvalue": "Aus" }], "name": "Baumwolle" }}" |
2022-10-06 17:51:36 | 018909 | 3856 | debug | EXE19002524 [v0.3.2]: ================ ARRAY/OBJECT END ================ |
2022-10-06 17:51:36 | 294091 | 3856 | debug | EXE19002524 [v0.3.2]: status |
2022-10-06 17:51:36 | 294193 | 3856 | debug | EXE19002524 [v0.3.2]: ================ ARRAY/OBJECT START ================ |
2022-10-06 17:51:36 | 294250 | 3856 | debug | EXE19002524 [v0.3.2]: "100" |
2022-10-06 17:51:36 | 294294 | 3856 | debug | EXE19002524 [v0.3.2]: ================ ARRAY/OBJECT END ================ |
2022-10-06 17:51:36 | 295902 | 3856 | debug | EXE19002524 [v0.3.2]: Send header HTTP/1.1 100 Continue[CR][LF][CR][LF]HTTP/1.1 409 Conflict[CR][LF]Date: Thu, 06 Oct 2022 15:51:36 GMT[CR][LF]Content-Type: application/vnd.bsh.sdk.v1+json[CR][LF]Content-Length: 140[CR][LF]Connection: keep-alive[CR][LF]access-control-allow-origin: *[CR][LF]access-control-allow-methods: GET,POST,OPTIONS,PUT,DELETE[CR][LF]access-control-allow-credentials: true[CR][LF]access-control-allow-headers: Authorization,Content-Type,Accept,Cache-Control,Last-Event-ID,If-Modified-Since,X-Requested-With,X-Events-Facade,User-Agent[CR][LF]referrer-policy: origin[CR][LF]x-frame-options: sameorigin[CR][LF]x-content-type-options: nosniff[CR][LF]x-xss-protection: 1; mode=block[CR][LF]api-gateway-service: api-gateway[CR][LF]hc-env: EU-PRD[CR][LF]x-vcap-request-id: 580b5d37-fb04-4fdc-767d-5ebec28ff393[CR][LF][CR][LF] |
{ "data": { "key": "LaundryCare.Washer.Program.Cotton", "options": [{ "key": "BSH.Common.Option.FinishInRelative", "value": 9600, "unit": "seconds", "name": "Zeitversetzter Betrieb" }]}}
