LBS19000(195|196|305) - HUE Bridge | Light | Plug
    Ich habe jetzt mal denn White Light LBS nur mit der BridgeID versehen und neu gestartet. Anschließend Live im Logikeditor nacheinander die Leuchte 3, 1 und 4 angewählt. Das Ergebnis im Bridge Log sieht folgendermaßen aus, hilft das weiter?
     [TABLE="border: 0, cellpadding: 0, cellspacing: 0"]
    [TR]
    [TD]2017-01-30 19:30:27[/TD]
     			[TD]081440[/TD]
     			[TD]15194[/TD]
     			[TD]debug[/TD]
     			[TD]EXE19000195 [v0.9]: Command received[/TD]
     		[/TR]
    [TR]
     			[TD]081579[/TD]
     			[TD]15194[/TD]
     			[TD]debug[/TD]
     			[TD]EXE19000195 [v0.9]: ================ ARRAY/OBJECT START ================[/TD]
     		[/TR]
    [TR]
     			[TD]081621[/TD]
     			[TD]15194[/TD]
     			[TD]debug[/TD]
     			[TD]EXE19000195 [v0.9]: cmd => changeLight[/TD]
     		[/TR]
    [TR]
     			[TD]081657[/TD]
     			[TD]15194[/TD]
     			[TD]debug[/TD]
     			[TD]EXE19000195 [v0.9]: no => 3[/TD]
     		[/TR]
    [TR]
     			[TD]081691[/TD]
     			[TD]15194[/TD]
     			[TD]debug[/TD]
     			[TD]EXE19000195 [v0.9]: ================ ARRAY/OBJECT END ================[/TD]
     		[/TR]
    [TR]
     			[TD]120726[/TD]
     			[TD]15194[/TD]
     			[TD]debug[/TD]
     			[TD]EXE19000195 [v0.9]: Received command from light 3 (see array)[/TD]
     		[/TR]
    [TR]
     			[TD]120840[/TD]
     			[TD]15194[/TD]
     			[TD]debug[/TD]
     		[/TR]
    [TR]
     			[TD]120877[/TD]
     			[TD]15194[/TD]
     			[TD]debug[/TD]
     		[/TR]
    [TR]
    [TD]2017-01-30 19:31:08[/TD]
     			[TD]462572[/TD]
     			[TD]15194[/TD]
     			[TD]debug[/TD]
     		[/TR]
    [TR]
     			[TD]462690[/TD]
     			[TD]15194[/TD]
     			[TD]debug[/TD]
     		[/TR]
    [TR]
     			[TD]462730[/TD]
     			[TD]15194[/TD]
     			[TD]debug[/TD]
     		[/TR]
    [TR]
     			[TD]462764[/TD]
     			[TD]15194[/TD]
     			[TD]debug[/TD]
     			[TD]EXE19000195 [v0.9]: no => 1[/TD]
     		[/TR]
    [TR]
     			[TD]462799[/TD]
     			[TD]15194[/TD]
     			[TD]debug[/TD]
     		[/TR]
    [TR]
     			[TD]503036[/TD]
     			[TD]15194[/TD]
     			[TD]debug[/TD]
     			[TD]EXE19000195 [v0.9]: Received command from light 1 (see array)[/TD]
     		[/TR]
    [TR]
     			[TD]503148[/TD]
     			[TD]15194[/TD]
     			[TD]debug[/TD]
     		[/TR]
    [TR]
     			[TD]503204[/TD]
     			[TD]15194[/TD]
     			[TD]debug[/TD]
     		[/TR]
    [TR]
    [TD]2017-01-30 19:31:18[/TD]
     			[TD]455429[/TD]
     			[TD]15194[/TD]
     			[TD]debug[/TD]
     		[/TR]
    [TR]
     			[TD]455543[/TD]
     			[TD]15194[/TD]
     			[TD]debug[/TD]
     		[/TR]
    [TR]
     			[TD]455584[/TD]
     			[TD]15194[/TD]
     			[TD]debug[/TD]
     		[/TR]
    [TR]
     			[TD]455619[/TD]
     			[TD]15194[/TD]
     			[TD]debug[/TD]
     			[TD]EXE19000195 [v0.9]: no => 4[/TD]
     		[/TR]
    [TR]
     			[TD]455652[/TD]
     			[TD]15194[/TD]
     			[TD]debug[/TD]
     		[/TR]
    [TR]
     			[TD]495076[/TD]
     			[TD]15194[/TD]
     			[TD]debug[/TD]
     			[TD]EXE19000195 [v0.9]: Received command from light 4 (see array)[/TD]
     		[/TR]
    [TR]
     			[TD]495186[/TD]
     			[TD]15194[/TD]
     			[TD]debug[/TD]
     		[/TR]
    [TR]
     			[TD]495223[/TD]
     			[TD]15194[/TD]
     			[TD]debug[/TD]
     		[/TR]
    [/TABLE]
    NACHTRAG:
    Seltsames Verhalten. Ich habe nur einen Bridge-LBS und einen White Light auf der selben Logikseite. Wenn ich nun den Bridge-ID Ausgang des Bridge LBS direkt mit dem Bridge-ID Eingang des White Light LBS verbinde und die Device ID fest vorgebe, registriert sich der Light LBS sauber und der Status kommt an.
    Wenn ich die direkte Verbindung trenne und statt dessen das iKO des Bridge-ID LBS an den Light LBS hänge, funktioniert es nicht.
    NACHTRAG 2:
    Fehler vermutlich gefunden:
    Das Bridge-ID iKO war als Remanent konfiguriert. Sobald ich das entfernt habe, läuft es auch wenn die Bridge-ID über ein iKO an den Light LBS übergeben wird. Das ändern der Device-ID im laufenden Betrieb geht aber nicht, bin aber nicht sicher ob das überhaupt vorgesehen ist?
    Zuletzt geändert von NurMa; 30.01.2017, 20:07.
      [TR]
      [TD]081440[/TD]
      [TD]15194[/TD]
      [TD]debug[/TD]
      [/TR]
      [TR]
      [TD]081579[/TD]
      [TD]15194[/TD]
      [TD]debug[/TD]
      [/TR]
      [TR]
      [TD]081621[/TD]
      [TD]15194[/TD]
      [TD]debug[/TD]
      [/TR]
      [TR]
      [TD]081657[/TD]
      [TD]15194[/TD]
      [TD]debug[/TD]
      [/TR]
      [TR]
      [TD]081691[/TD]
      [TD]15194[/TD]
      [TD]debug[/TD]
      [/TR]
      [TR]
      [TD]120726[/TD]
      [TD]15194[/TD]
      [TD]debug[/TD]
      [/TR]
      [TR]
      [TD]120840[/TD]
      [TD]15194[/TD]
      [TD]debug[/TD]
      [/TR]
      [TR]
      [TD]120877[/TD]
      [TD]15194[/TD]
      [TD]debug[/TD]
      [/TR]
      [TR]
      [TD]462572[/TD]
      [TD]15194[/TD]
      [TD]debug[/TD]
      [/TR]
      [TR]
      [TD]462690[/TD]
      [TD]15194[/TD]
      [TD]debug[/TD]
      [/TR]
      [TR]
      [TD]462730[/TD]
      [TD]15194[/TD]
      [TD]debug[/TD]
      [/TR]
      [TR]
      [TD]462764[/TD]
      [TD]15194[/TD]
      [TD]debug[/TD]
      [/TR]
      [TR]
      [TD]462799[/TD]
      [TD]15194[/TD]
      [TD]debug[/TD]
      [/TR]
      [TR]
      [TD]503036[/TD]
      [TD]15194[/TD]
      [TD]debug[/TD]
      [/TR]
      [TR]
      [TD]503148[/TD]
      [TD]15194[/TD]
      [TD]debug[/TD]
      [/TR]
      [TR]
      [TD]503204[/TD]
      [TD]15194[/TD]
      [TD]debug[/TD]
      [/TR]
      [TR]
      [TD]455429[/TD]
      [TD]15194[/TD]
      [TD]debug[/TD]
      [/TR]
      [TR]
      [TD]455543[/TD]
      [TD]15194[/TD]
      [TD]debug[/TD]
      [/TR]
      [TR]
      [TD]455584[/TD]
      [TD]15194[/TD]
      [TD]debug[/TD]
      [/TR]
      [TR]
      [TD]455619[/TD]
      [TD]15194[/TD]
      [TD]debug[/TD]
      [/TR]
      [TR]
      [TD]455652[/TD]
      [TD]15194[/TD]
      [TD]debug[/TD]
      [/TR]
      [TR]
      [TD]495076[/TD]
      [TD]15194[/TD]
      [TD]debug[/TD]
      [/TR]
      [TR]
      [TD]495186[/TD]
      [TD]15194[/TD]
      [TD]debug[/TD]
      [/TR]
      [TR]
      [TD]495223[/TD]
      [TD]15194[/TD]
      [TD]debug[/TD]
      [/TR]
      [/TABLE]
      NACHTRAG:
      NACHTRAG 2:
      Okay, das darf natürlich nicht sein, denn so startet der LBS zunächst mit der alten ID, registriert sich dann quasi an einer Bridge, die es gar nicht gibt.
      Das wird es wohl sein ...
        Das scheint es tatsächlich gewesen zu sein. Vielen Dank für Deine Geduld!
          Kein Ding. Man lernt nie aus. Es gibt immer wieder Fehlerbilder, auf die man nicht so schnell kommt.
            Hatte jemand eine Lampe schon mit einem Tastsensor in Betrieb?
            Schalten geht ja. Aber wie kann ich über den Tastsensor dimmen (über das 4bit KO)?
            Und ein 2. Problem habe ich jetzt auch noch. Auf einmal wird kein Status mehr am LPS 19000584 ausgegeben. (Ich hoffe ich bin hier richtig)
            Licht ein und aus Schalten funktioniert. Auch über meine Tastsensoren am Bett. Bildschirmfoto 2017-02-02 um 18.28.03.png
            Zuletzt geändert von nektar; 02.02.2017, 19:35.
              Zitat von nektar Beitrag anzeigen
              Hatte jemand eine Lampe schon mit einem Testsensor in Betrieb?
              Schalten geht ja. Aber wie kann ich über den Testsensor dimmen (über das 4bit KO)?
              Was genau ist ein Testsensor? Meinst Du KNX Tastsensor?
              Du musst halt bei jedem Tastendrucken einen höheren bzw. geringeren Dimwert auf E6 senden. Z.B. in dem du einer Wippe zwei KNX GAs zuweist und je nach KNX GA dann in EDOMI den Brightnesswert (iKO) an E6 erhöhst oder verringerst. Das Dimmen wie mit KNX Dimmern funktioniert, d.h. lange festhalten, habe ich noch nicht ausprobiert. Hängt dann davon ab, was der KNX Tastsensor daraus macht und wie du das in EDOMI in veränderte Brightnesswerte umsetzen kannst.
              Das kein Status kommt kann ich mir kaum erklären, es sei denn du hast das iKO auf E1 als remanent definiert.
                Genau, das war es bei mir.
                  jonofe Ja genau, ich meine Tastsensoren. Diese blöde Autokorrektur.
                  Habe in der Tat den iKO auf remanent gesetzt.
                    da bist du nicht alleine
                    Gibts da eigentlich nen Grund für warum man genau dieses iKO auf remanent setzt? hab ich da irgendwas in der Doku missverständlich beschrieben?
                      Habe mich auch schon gefragt wieso ich das gemacht hatte. Von remanent steht in der Hilfe ja nichts.
                      Vielen Dank aber für die schnelle Hilfe.
                        Habe noch einmal eine Frage.
                        Ist es richtig, bzw. hat es einen Grund das beim Ausgang Brightness keine 0 ausgegeben wird wenn ich die Lampe ausschalte?
                        Egal ob ich über ein/aus oder über Brightness die Lampe ausschalte.
                          ja, dazu gab es m.W. eine Diskussion weiter vorn in diesem Thread...
                            Habe es gerade noch mal geprüft. Ich finde keinen Fehler und in der Bridge wird derselbe Code zum setzen der ColorTemp verwendet wie bei den Extended Color Lights. Und das habe ich gerade noch mal erfolgreich getestet. Am besten zu postest mal das Logfile des Hue White Light LBS, nach dem du die Colortemp gesetzt hast. Und auch das Log der Bridge für denselben Zeitraum. Dann kann man sehen, ob die Kommunikation erfolgreich war.
                            Hi!
                            So, nach mehreren Wochen Abstinenz habe ich mich mal wieder mit der Sache beschäftigt.
                            In der Zwischenzeit nutze ich auch nur noch zwei neue Bridges. Die alte Runde ist nicht mehr in Betrieb.
                            Mit den aktuellen LBS funktioniert es tatsächlich bei beiden Lampen: GU10 und E27 (Color temperature light).
                            Helligkeit und Farbtemperatur lassen sich einstellen. Ein/Aus geht auch.
                            Es gibt aber noch einen kleinen Bug im LBS Hue-Devices.
                            Dort muss noch folgendes Case dazu, sonst gibt es einen Fehler im Log:
                             case 'COLOR TEMPERATURE LIGHT' : $type = 'Color Temperature Light'; break;
                              Danke für den Hinweis. Ist korrigiert. Version 0.1.1.
                                Mhmm. Was leider nicht geht, ist die Status-Rückmeldung am Ausgang A7 des Bausteins "White Light 0.2", ob die Lampe ein oder aus ist.
                                Ich sehe in den Logs der Bausteine auch keinerlei Rückmeldung der Bridge?!
                                Update mode: all
                                Update interval: 500ms
                                Zur Info: Die Lampe kann auch über die Hue-FB geschaltet werden. Ich hätte erwartet, dass die Bridge den aktuellen Zustand aller Lichter kennt.
                                Zuletzt geändert von Nanosonde; 24.02.2017, 14:57.
