Hallo Udo,
stimmt wieder ! ;-)
Vielen Dank!
Ralf
stimmt wieder ! ;-)
Vielen Dank!
Ralf
apt-get install docker [COLOR=#000000]mkdir knxdocker cd knxdocker cat [/COLOR][COLOR=#000000]<<[/COLOR][COLOR=#000000]EOF [/COLOR][COLOR=#000000]>[/COLOR][COLOR=#000000] Dockerfile [/COLOR] # knxd # # FROM ubuntu:14.04 MAINTAINER Hendrik Friedel hendrik@friedels.name RUN apt-get -y update && apt-get -y upgrade && apt-get -y install git-core wget build-essential debhelper autotools-dev autoconf automake libtool pkg-config libsystemd-daemon-dev libusb-1.0-0-dev base-files debianutils cdbs dh-systemd systemd-services libsystemd-daemon-dev libsystemd-daemon0 RUN git clone https://github.com/knxd/knxd.git # Install pthsem ############################# RUN sudo apt-get -y install libusb-1.0-0 libusb-1.0-0-dev RUN wget https://www.auto.tuwien.ac.at/~mkoegler/pth/pthsem_2.0.8.tar.gz RUN tar xzf pthsem_2.0.8.tar.gz && cd pthsem-2.0.8 && dpkg-buildpackage -b -uc && cd .. RUN sudo dpkg -i libpthsem*.deb RUN sudo apt-get install -y owfs ## now build+install knxd itself RUN cd knxd && sed -i "s/libsystemd-daemon-dev (>= 200) | base-files (<< 8),/base-files (<< 8),/" ./debian/control && dpkg-buildpackage -b -uc && cd .. && sudo dpkg -i knxd_*.deb knxd-tools_*.deb #RUN sudo apt-get install -y software-properties-common libusb-1.0-0 && sudo add-apt-repository -y ppa:timo-wingender/knxd-daily && sudo apt-get update && apt-get install knxd [COLOR=#000000]EOF[/COLOR] docker build -t user/knxd .
# knxd # # FROM ubuntu:14.04 MAINTAINER Hendrik Friedel hendrik@friedels.name RUN apt-get -y update && apt-get -y upgrade && apt-get -y install git-core wget build-essential debhelper autotools-dev autoconf automake libtool pkg-config libusb-1.0-0-dev base-files debianutils cdbs RUN git clone https://github.com/knxd/knxd.git # Install pthsem ############################# RUN sudo apt-get -y install libusb-1.0-0 libusb-1.0-0-dev RUN wget https://www.auto.tuwien.ac.at/~mkoegler/pth/pthsem_2.0.8.tar.gz RUN tar xzf pthsem_2.0.8.tar.gz && cd pthsem-2.0.8 && dpkg-buildpackage -b -uc && cd .. RUN sudo dpkg -i libpthsem*.deb RUN sudo apt-get install -y owfs ## now build+install knxd itself RUN cd knxd && sed -i "s/libsystemd-daemon-dev (>= 200) | base-files (<< 8),/base-files (<< 8),/" ./debian/control && dpkg-buildpackage -b -uc && cd .. && sudo dpkg -i knxd_*.deb knxd-tools_*.deb #RUN sudo apt-get install -y software-properties-common libusb-1.0-0 && sudo add-apt-repository -y ppa:timo-wingender/knxd-daily && sudo apt-get update && apt-get install
