Wetterabfrage mit openweathermap.org am HS
    Hallo Leute!
    Ich versuche gerade eine Wetterabfrage über openweatherwap.org am Homeserver einzurichten. openweatherwap.org liefert ein JSON mit 40 Datensätzen mit je ca. 20 Einzeldaten. Die 40 Datensätze sind fix, bei den Einzeldaten können unzutreffende Daten auch fehlen.
    Die Idee ist, über eine Webabfrage mit komplexer Auswertung zunächst einmal die Antwort auf 40 Datensätze aufzuteilen und in 40 KO's abzulegen.
    Das empfangene JSON von openweatherwap.org sieht so aus:
    {"cod":"200","message":0.0061,"cnt":40,"list":[{"dt":1545998400,"main":{"temp":8.18,"temp_min":6.26,"temp_max":8.18,"pressure":991.71,"sea_level":1038.01,"grnd_level":991.71,"humidity":79,"temp_kf":1.92},"weather":[{"id":802,"main":"Clouds","description":"Überwiegend bewölkt","icon":"03d"}],"clouds":{"all":48},"wind":{"speed":4.12,"deg":293.501},"sys":{"pod":"d"},"dt_txt":"2018-12-28 12:00:00"},{"dt":1546009200,"main":{"temp":5.98,"temp_min":4.54,"temp_max":5.98,"pressure":992.56,"sea_level":1038.82,"grnd_level":992.56,"humidity":75,"temp_kf":1.44},"weather":[{"id":800,"main":"Clear","description":"Klarer Himmel","icon":"01d"}],"clouds":{"all":0},"wind":{"speed":4.25,"deg":303.503},"sys":{"pod":"d"},"dt_txt":"2018-12-28 15:00:00"},{"dt":1546020000,"main":{"temp":3.32,"temp_min":2.36,"temp_max":3.32,"pressure":993.97,"sea_level":1040.57,"grnd_level":993.97,"humidity":77,"temp_kf":0.96},"weather":[{"id":800,"main":"Clear","description":"Klarer Himmel","icon":"01n"}],"clouds":{"all":0},"wind":{"speed":3.41,"deg":311.501},"sys":{"pod":"n"},"dt_txt":"2018-12-28 18:00:00"},{"dt":1546030800,"main":{"temp":1.79,"temp_min":1.31,"temp_max":1.79,"pressure":995.28,"sea_level":1042.05,"grnd_level":995.28,"humidity":83,"temp_kf":0.48},"weather":[{"id":500,"main":"Rain","description":"Leichter Regen","icon":"10n"}],"clouds":{"all":48},"wind":{"speed":3.17,"deg":322.001},"rain":{"3h":0.005},"sys":{"pod":"n"},"dt_txt":"2018-12-28 21:00:00"},{"dt":1546041600,"main":{"temp":0.73,"temp_min":0.73,"temp_max":0.73,"pressure":996.09,"sea_level":1043.03,"grnd_level":996.09,"humidity":86,"temp_kf":0},"weather":[{"id":500,"main":"Rain","description":"Leichter Regen","icon":"10n"}],"clouds":{"all":64},"wind":{"speed":3.01,"deg":322.501},"rain":{"3h":0.015},"sys":{"pod":"n"},"dt_txt":"2018-12-29 00:00:00"},{"dt":1546052400,"main":{"temp":0.73,"temp_min":0.73,"temp_max":0.73,"pressure":996.49,"sea_level":1043.53,"grnd_level":996.49,"humidity":89,"temp_kf":0},"weather":[{"id":500,"main":"Rain","description":"Leichter Regen","icon":"10n"}],"clouds":{"all":68},"wind":{"speed":2.97,"deg":321.506},"rain":{"3h":0.03},"snow":{"3h":0.005},"sys":{"pod":"n"},"dt_txt":"2018-12-29 03:00:00"},{"dt":1546063200,"main":{"temp":0.37,"temp_min":0.37,"temp_max":0.37,"pressure":997.03,"sea_level":1044.15,"grnd_level":997.03,"humidity":89,"temp_kf":0},"weather":[{"id":500,"main":"Rain","description":"Leichter Regen","icon":"10n"}],"clouds":{"all":68},"wind":{"speed":3.11,"deg":319.01},"rain":{"3h":0.015},"snow":{"3h":0.0475},"sys":{"pod":"n"},"dt_txt":"2018-12-29 06:00:00"},{"dt":1546074000,"main":{"temp":1.1,"temp_min":1.1,"temp_max":1.1,"pressure":997.47,"sea_level":1044.44,"grnd_level":997.47,"humidity":89,"temp_kf":0},"weather":[{"id":800,"main":"Clear","description":"Klarer Himmel","icon":"01d"}],"clouds":{"all":12},"wind":{"speed":2.97,"deg":314.501},"rain":{},"snow":{"3h":0.005},"sys":{"pod":"d"},"dt_txt":"2018-12-29 09:00:00"},{"dt":1546084800,"main":{"temp":2.95,"temp_min":2.95,"temp_max":2.95,"pressure":996.44,"sea_level":1043.1,"grnd_level":996.44,"humidity":84,"temp_kf":0},"weather":[{"id":803,"main":"Clouds","description":"Überwiegend bewölkt","icon":"04d"}],"clouds":{"all":56},"wind":{"speed":3.63,"deg":305.001},"rain":{},"snow":{},"sys":{"pod":"d"},"dt_txt":"2018-12-29 12:00:00"},{"dt":1546095600,"main":{"temp":1.88,"temp_min":1.88,"temp_max":1.88,"pressure":996.3,"sea_level":1043.11,"grnd_level":996.3,"humidity":77,"temp_kf":0},"weather":[{"id":500,"main":"Rain","description":"Leichter Regen","icon":"10d"}],"clouds":{"all":24},"wind":{"speed":3.86,"deg":301.003},"rain":{"3h":0.005},"snow":{},"sys":{"pod":"d"},"dt_txt":"2018-12-29 15:00:00"},{"dt":1546106400,"main":{"temp":0.42,"temp_min":0.42,"temp_max":0.42,"pressure":995.92,"sea_level":1043.06,"grnd_level":995.92,"humidity":78,"temp_kf":0},"weather":[{"id":800,"main":"Clear","description":"Klarer Himmel","icon":"02n"}],"clouds":{"all":8},"wind":{"speed":4.36,"deg":294},"rain":{},"snow":{},"sys":{"pod":"n"},"dt_txt":"2018-12-29 18:00:00"},{"dt":1546117200,"main":{"temp":0.92,"temp_min":0.92,"temp_max":0.92,"pressure":994.42,"sea_level":1041.81,"grnd_level":994.42,"humidity":78,"temp_kf":0},"weather":[{"id":802,"main":"Clouds","description":"Überwiegend bewölkt","icon":"03n"}],"clouds":{"all":48},"wind":{"speed":4.76,"deg":292.002},"rain":{},"snow":{},"sys":{"pod":"n"},"dt_txt":"2018-12-29 21:00:00"},{"dt":1546128000,"main":{"temp":1.91,"temp_min":1.91,"temp_max":1.91,"pressure":993.07,"sea_level":1040.19,"grnd_level":993.07,"humidity":77,"temp_kf":0},"weather":[{"id":803,"main":"Clouds","description":"Überwiegend bewölkt","icon":"04n"}],"clouds":{"all":80},"wind":{"speed":5.56,"deg":286.5},"rain":{},"snow":{},"sys":{"pod":"n"},"dt_txt":"2018-12-30 00:00:00"},{"dt":1546138800,"main":{"temp":2.56,"temp_min":2.56,"temp_max":2.56,"pressure":991.21,"sea_level":1038.03,"grnd_level":991.21,"humidity":86,"temp_kf":0},"weather":[{"id":500,"main":"Rain","description":"Leichter Regen","icon":"10n"}],"clouds":{"all":80},"wind":{"speed":5.11,"deg":283.001},"rain":{"3h":0.51},"snow":{},"sys":{"pod":"n"},"dt_txt":"2018-12-30 03:00:00"},{"dt":1546149600,"main":{"temp":1.62,"temp_min":1.62,"temp_max":1.62,"pressure":991.43,"sea_level":1038.3,"grnd_level":991.43,"humidity":90,"temp_kf":0},"weather":[{"id":500,"main":"Rain","description":"Leichter Regen","icon":"10n"}],"clouds":{"all":76},"wind":{"speed":6.36,"deg":288.5},"rain":{"3h":0.605},"snow":{"3h":0.03},"sys":{"pod":"n"},"dt_txt":"2018-12-30 06:00:00"},{"dt":1546160400,"main":{"temp":2.88,"temp_min":2.88,"temp_max":2.88,"pressure":991.11,"sea_level":1037.74,"grnd_level":991.11,"humidity":91,"temp_kf":0},"weather":[{"id":500,"main":"Rain","description":"Leichter Regen","icon":"10d"}],"clouds":{"all":80},"wind":{"speed":7.46,"deg":289.5},"rain":{"3h":0.235},"snow":{"3h":0.0025},"sys":{"pod":"d"},"dt_txt":"2018-12-30 09:00:00"},{"dt":1546171200,"main":{"temp":4.16,"temp_min":4.16,"temp_max":4.16,"pressure":991.96,"sea_level":1038.19,"grnd_level":991.96,"humidity":92,"temp_kf":0},"weather":[{"id":500,"main":"Rain","description":"Leichter Regen","icon":"10d"}],"clouds":{"all":56},"wind":{"speed":7.76,"deg":300},"rain":{"3h":0.34},"snow":{},"sys":{"pod":"d"},"dt_txt":"2018-12-30 12:00:00"},{"dt":1546182000,"main":{"temp":3.45,"temp_min":3.45,"temp_max":3.45,"pressure":992.95,"sea_level":1039.3,"grnd_level":992.95,"humidity":85,"temp_kf":0},"weather":[{"id":500,"main":"Rain","description":"Leichter Regen","icon":"10d"}],"clouds":{"all":68},"wind":{"speed":7.46,"deg":297.509},"rain":{"3h":0.14},"snow":{},"sys":{"pod":"d"},"dt_txt":"2018-12-30 15:00:00"},{"dt":1546192800,"main":{"temp":2.94,"temp_min":2.94,"temp_max":2.94,"pressure":992.64,"sea_level":1039.14,"grnd_level":992.64,"humidity":84,"temp_kf":0},"weather":[{"id":500,"main":"Rain","description":"Leichter Regen","icon":"10n"}],"clouds":{"all":68},"wind":{"speed":7.57,"deg":295.5},"rain":{"3h":0.105},"snow":{},"sys":{"pod":"n"},"dt_txt":"2018-12-30 18:00:00"},{"dt":1546203600,"main":{"temp":2.42,"temp_min":2.42,"temp_max":2.42,"pressure":992.44,"sea_level":1039.02,"grnd_level":992.44,"humidity":92,"temp_kf":0},"weather":[{"id":500,"main":"Rain","description":"Leichter Regen","icon":"10n"}],"clouds":{"all":88},"wind":{"speed":7.63,"deg":300.501},"rain":{"3h":0.615},"snow":{},"sys":{"pod":"n"},"dt_txt":"2018-12-30 21:00:00"},{"dt":1546214400,"main":{"temp":2.38,"temp_min":2.38,"temp_max":2.38,"pressure":992.87,"sea_level":1039.53,"grnd_level":992.87,"humidity":98,"temp_kf":0},"weather":[{"id":500,"main":"Rain","description":"Leichter Regen","icon":"10n"}],"clouds":{"all":92},"wind":{"speed":6.27,"deg":316},"rain":{"3h":1.38},"snow":{"3h":0.06},"sys":{"pod":"n"},"dt_txt":"2018-12-31 00:00:00"},{"dt":1546225200,"main":{"temp":2.53,"temp_min":2.53,"temp_max":2.53,"pressure":992.73,"sea_level":1039.38,"grnd_level":992.73,"humidity":93,"temp_kf":0},"weather":[{"id":500,"main":"Rain","description":"Leichter Regen","icon":"10n"}],"clouds":{"all":88},"wind":{"speed":5.72,"deg":325.004},"rain":{"3h":0.18},"snow":{"3h":0.155},"sys":{"pod":"n"},"dt_txt":"2018-12-31 03:00:00"},{"dt":1546236000,"main":{"temp":1.71,"temp_min":1.71,"temp_max":1.71,"pressure":993.12,"sea_level":1039.82,"grnd_level":993.12,"humidity":87,"temp_kf":0},"weather":[{"id":500,"main":"Rain","description":"Leichter Regen","icon":"10n"}],"clouds":{"all":44},"wind":{"speed":6.01,"deg":329.502},"rain":{"3h":0.02},"snow":{"3h":0.05},"sys":{"pod":"n"},"dt_txt":"2018-12-31 06:00:00"},{"dt":1546246800,"main":{"temp":1.52,"temp_min":1.52,"temp_max":1.52,"pressure":994.7,"sea_level":1041.38,"grnd_level":994.7,"humidity":89,"temp_kf":0},"weather":[{"id":800,"main":"Clear","description":"Klarer Himmel","icon":"01d"}],"clouds":{"all":80},"wind":{"speed":6.01,"deg":328},"rain":{},"snow":{"3h":0.01},"sys":{"pod":"d"},"dt_txt":"2018-12-31 09:00:00"},{"dt":1546257600,"main":{"temp":1.49,"temp_min":1.49,"temp_max":1.49,"pressure":995.54,"sea_level":1042.17,"grnd_level":995.54,"humidity":89,"temp_kf":0},"weather":[{"id":500,"main":"Rain","description":"Leichter Regen","icon":"10d"}],"clouds":{"all":88},"wind":{"speed":6.11,"deg":331},"rain":{"3h":0.05},"snow":{"3h":0.07},"sys":{"pod":"d"},"dt_txt":"2018-12-31 12:00:00"},{"dt":1546268400,"main":{"temp":0.89,"temp_min":0.89,"temp_max":0.89,"pressure":998.03,"sea_level":1044.78,"grnd_level":998.03,"humidity":88,"temp_kf":0},"weather":[{"id":500,"main":"Rain","description":"Leichter Regen","icon":"10d"}],"clouds":{"all":88},"wind":{"speed":5.34,"deg":333.504},"rain":{"3h":0.02},"snow":{"3h":0.09},"sys":{"pod":"d"},"dt_txt":"2018-12-31 15:00:00"},{"dt":1546279200,"main":{"temp":0.24,"temp_min":0.24,"temp_max":0.24,"pressure":1000.23,"sea_level":1047.32,"grnd_level":1000.23,"humidity":85,"temp_kf":0},"weather":[{"id":500,"main":"Rain","description":"Leichter Regen","icon":"10n"}],"clouds":{"all":68},"wind":{"speed":5.16,"deg":329.003},"rain":{"3h":0.010000000000001},"snow":{"3h":0.08},"sys":{"pod":"n"},"dt_txt":"2018-12-31 18:00:00"},{"dt":1546290000,"main":{"temp":-0.41,"temp_min":-0.41,"temp_max":-0.41,"pressure":1001.72,"sea_level":1049.09,"grnd_level":1001.72,"humidity":86,"temp_kf":0},"weather":[{"id":600,"main":"Snow","description":"Mäßiger Schnee","icon":"13n"}],"clouds":{"all":56},"wind":{"speed":5.11,"deg":323.501},"rain":{},"snow":{"3h":0.05},"sys":{"pod":"n"},"dt_txt":"2018-12-31 21:00:00"},{"dt":1546300800,"main":{"temp":-1.15,"temp_min":-1.15,"temp_max":-1.15,"pressure":1002.51,"sea_level":1049.93,"grnd_level":1002.51,"humidity":86,"temp_kf":0},"weather":[{"id":800,"main":"Clear","description":"Klarer Himmel","icon":"01n"}],"clouds":{"all":48},"wind":{"speed":4.71,"deg":321.5},"rain":{},"snow":{"3h":0.01},"sys":{"pod":"n"},"dt_txt":"2019-01-01 00:00:00"},{"dt":1546311600,"main":{"temp":-1.47,"temp_min":-1.47,"temp_max":-1.47,"pressure":1001.38,"sea_level":1049.03,"grnd_level":1001.38,"humidity":82,"temp_kf":0},"weather":[{"id":800,"main":"Clear","description":"Klarer Himmel","icon":"02n"}],"clouds":{"all":8},"wind":{"speed":4.11,"deg":312.5},"rain":{},"snow":{},"sys":{"pod":"n"},"dt_txt":"2019-01-01 03:00:00"},{"dt":1546322400,"main":{"temp":-0.88,"temp_min":-0.88,"temp_max":-0.88,"pressure":999.87,"sea_level":1047.63,"grnd_level":999.87,"humidity":78,"temp_kf":0},"weather":[{"id":801,"main":"Clouds","description":"Ein paar Wolken","icon":"02n"}],"clouds":{"all":20},"wind":{"speed":4.01,"deg":298.501},"rain":{},"snow":{},"sys":{"pod":"n"},"dt_txt":"2019-01-01 06:00:00"},{"dt":1546333200,"main":{"temp":1.3,"temp_min":1.3,"temp_max":1.3,"pressure":998.44,"sea_level":1045.8,"grnd_level":998.44,"humidity":81,"temp_kf":0},"weather":[{"id":800,"main":"Clear","description":"Klarer Himmel","icon":"02d"}],"clouds":{"all":8},"wind":{"speed":5.21,"deg":291.006},"rain":{},"snow":{},"sys":{"pod":"d"},"dt_txt":"2019-01-01 09:00:00"},{"dt":1546344000,"main":{"temp":3.75,"temp_min":3.75,"temp_max":3.75,"pressure":995.76,"sea_level":1042.54,"grnd_level":995.76,"humidity":76,"temp_kf":0},"weather":[{"id":800,"main":"Clear","description":"Klarer Himmel","icon":"01d"}],"clouds":{"all":0},"wind":{"speed":5.56,"deg":289.002},"rain":{},"snow":{},"sys":{"pod":"d"},"dt_txt":"2019-01-01 12:00:00"},{"dt":1546354800,"main":{"temp":3.4,"temp_min":3.4,"temp_max":3.4,"pressure":993.28,"sea_level":1040.11,"grnd_level":993.28,"humidity":73,"temp_kf":0},"weather":[{"id":801,"main":"Clouds","description":"Ein paar Wolken","icon":"02d"}],"clouds":{"all":12},"wind":{"speed":5.67,"deg":285.503},"rain":{},"snow":{},"sys":{"pod":"d"},"dt_txt":"2019-01-01 15:00:00"},{"dt":1546365600,"main":{"temp":2.88,"temp_min":2.88,"temp_max":2.88,"pressure":991.55,"sea_level":1038.26,"grnd_level":991.55,"humidity":80,"temp_kf":0},"weather":[{"id":500,"main":"Rain","description":"Leichter Regen","icon":"10n"}],"clouds":{"all":44},"wind":{"speed":6.81,"deg":289.002},"rain":{"3h":0.08},"snow":{},"sys":{"pod":"n"},"dt_txt":"2019-01-01 18:00:00"},{"dt":1546376400,"main":{"temp":3,"temp_min":3,"temp_max":3,"pressure":989.64,"sea_level":1036.16,"grnd_level":989.64,"humidity":81,"temp_kf":0},"weather":[{"id":500,"main":"Rain","description":"Leichter Regen","icon":"10n"}],"clouds":{"all":12},"wind":{"speed":7.36,"deg":288.004},"rain":{"3h":0.069999999999999},"snow":{},"sys":{"pod":"n"},"dt_txt":"2019-01-01 21:00:00"},{"dt":1546387200,"main":{"temp":3.46,"temp_min":3.46,"temp_max":3.46,"pressure":987.24,"sea_level":1033.68,"grnd_level":987.24,"humidity":79,"temp_kf":0},"weather":[{"id":800,"main":"Clear","description":"Klarer Himmel","icon":"01n"}],"clouds":{"all":0},"wind":{"speed":8.61,"deg":289.001},"rain":{},"snow":{},"sys":{"pod":"n"},"dt_txt":"2019-01-02 00:00:00"},{"dt":1546398000,"main":{"temp":3.62,"temp_min":3.62,"temp_max":3.62,"pressure":985.64,"sea_level":1031.87,"grnd_level":985.64,"humidity":81,"temp_kf":0},"weather":[{"id":500,"main":"Rain","description":"Leichter Regen","icon":"10n"}],"clouds":{"all":36},"wind":{"speed":8.96,"deg":294.503},"rain":{"3h":0.24},"snow":{},"sys":{"pod":"n"},"dt_txt":"2019-01-02 03:00:00"},{"dt":1546408800,"main":{"temp":3.31,"temp_min":3.31,"temp_max":3.31,"pressure":986.21,"sea_level":1032.51,"grnd_level":986.21,"humidity":87,"temp_kf":0},"weather":[{"id":500,"main":"Rain","description":"Leichter Regen","icon":"10n"}],"clouds":{"all":88},"wind":{"speed":8.42,"deg":311.5},"rain":{"3h":0.52},"snow":{},"sys":{"pod":"n"},"dt_txt":"2019-01-02 06:00:00"},{"dt":1546419600,"main":{"temp":2.05,"temp_min":2.05,"temp_max":2.05,"pressure":987.92,"sea_level":1034.4,"grnd_level":987.92,"humidity":94,"temp_kf":0},"weather":[{"id":500,"main":"Rain","description":"Leichter Regen","icon":"10d"}],"clouds":{"all":80},"wind":{"speed":7.51,"deg":327.002},"rain":{"3h":0.59},"snow":{"3h":0.38},"sys":{"pod":"d"},"dt_txt":"2019-01-02 09:00:00"}],"city":{"id":2768348,"name":"Pressbaum","coord":{"lat":48.1833,"lon":16.0833},"country":"AT"}}
    Die einzelnen Datensätze lassen sich mit folgender Regular Expression extrahieren (getestet mit https://regex101.com):
    \"dt\":.*?\"dt_txt\":\".*?\"
    "dt" ist dabei das 1. Element, "dt_txt" ist las letzte Element eines Datensatzes. Im Experten habe ich dazu bei der Webafrage 40 KO's eingetragen. Funktioniert aber nicht: Auf der Debug-Seite schaut der Anfang der Anwort richtig aus, aber die KO's werden nicht befüllt, und bei der Abfrage wird der eingetragene Befehl für nicht erfolgreiche Ausführung ausgeführt.
    Um mich heranzutasten, habe ich mal versucht, eine ganz einfache Regular Expression einzugeben:
    mess
    Dazu nur ein KO in der Webabfrage. Der String "mess" kommt in der Antwort nur 1x vor, also hätte ich erwartet, dass das KO mit "mess" befüllt wird. Aber auch schon dieses einfache Beispiel funktioniert nicht. Auch hier wird der Befehl für fehlerhafte Ausführung ausgeführt und auf der Debug-Seite endet die Abfrage mit
    (Gesamt: 1) (Work: 0) (Typ: RegExp) (OK: 0)
    also fehlerhaft. Was ist hier falsch?
    GKap
    Hast du mal http://service.knx-user-forum.de/?co...nload&id=12739 versucht?
    Nils
    aktuelle Bausteine:
      Hallo NilsS!
      Ja, den Baustein kenne ich. Ich möchte allerdings die Webabfragen mit Regular Expressions verstehen und benutzen können!
      Die Auswertung eines Strings (d.h. also die Webseite oder der JSON-Text) mit einer Regular Expression liefert doch einen oder mehrere Strings, das kann ich mit RegEx-Testern ausprobieren. Meine Annahme war nun, dass dieser eine oder auch mehrere Strings in die KO's übernommen werden, die ich bei "Datenblöcke" angebe. Das passiert aber im HS nicht so!
      Ich habe auch schon überlegt, ob ich hier an die Grenzen des HS gestoßen bin. Mein JSON-Text ist ca. 15kB groß, aber lt. Hilfe sollten bis zu 500kB möglich sein.
      Wo liegt hier das Problem?
      GKap
        Hab gerade das gleiche Problem. RegEx scheint nicht voll implementiert zu sein.
        Bei mir geht es dann noch darum true und false auszuwerten. Hier gibt es ja diese Vorgabeliste. Die ist dann bei Regex aber nur eine Zeile und nicht ein größeres Feld. Damit kann man dann nicht die Ersetzungen eintragen.
          Also der Regex wird mit re.M | re.S kompiliert.
          Was natürlich beim HS immer problematisch ist, ist die | (PIPE). Da diese ja als Trenner in hs.dat verwendet wird, wird die wohl nicht so übernommen werden.
          Einen komplexen Regex ohne PIPE zu machen wird sicher auch nicht ganz leicht.
          Nils
          aktuelle Bausteine:
            Hi GKap
            ehrlich gesagt verstehe ich noch nicht, warum es regex sein muss. Warum nicht die json Info direkt über ein Modul im HS auswerten und darstellen.
            Ich habe es bsp. bei einem meiner Module (SONOS) genauso gemacht. Wenn Du Dir mal den Quelltext des Moduls 13620_DJ_SonosState.hsl anschaust (im Download-Bereich), dann hast Du bereits die Lösung.
            Die Art und Weise, wie die json Info ausgewertet wird, berücksichtigt auch, dass ggf. der eine oder andere Parameter mal fehlt usw.
            Ciao
            Der DJ
            Darf man fremden Leuten eigentlich Fragen stellen, nachdem sie im Bus telefoniert haben und einem noch etwas unklar ist?
            Projects: Sonos Gateway (Musterprojekt) - KNX-MonAMI - Nutzer-Profile
              Hallo
              Hab mal zwei kleine Bausteine zur Abfrage erstellt. 13208_OpenWeatherMap.zip 13209_OpenWeatherForecast.zip
              Gruss, Holger
              ECMACOM GmbH
              Konzeption, Planung, Implementation, Unterhalt
              www.ecmacom.ch
              www.knxshop4u.ch
                Hallo zusammen
                Da ich noch mit der 4.1 arbeite, wollte ich fragen, ob es diese Bausteine auch für eine ältere Firmware gibt??
                Da meine Anlage soweit gut und störungsfrei läuft, sehe ich eher getrübt an einem Update.
                Gruss Pit
                  Was funktioniert mit der 4.1 an den Bausteinen nicht?
                  Die sehen nicht so aus als wären sie Versionsabhängig
                  Nils
                  aktuelle Bausteine:
                    Hallo Holger
                    Die beiden Bausteine funktionieren erst ab der HS Firmware Version 4.7, ist das richtig?? Gibt es die Möglichkeit diesen Baustein auch mit einer älteren Firmware-Version zu betreiben??
                    Besten Dank im voraus.
                    Gruss Pit
                      Wie kommst du darauf das die erst mit der 4.7 funktionieren sollen?
                      Das ist ein ganz normaler Bytecode Baustein. Nix hsl20 Mist
                      Nils
                      aktuelle Bausteine:
                        Hallo Pit
                        Ich hab den mit 2.7 kompiliert und 4.8 getestet. Da ich seit Weihnachten selbst auf 4.8 bin werde ich auch nicht nehr auf älteren Versionen testen.
                        Möglich, dass der mit 4.1 auch läuft, kann aber auch sein, dass die Webabfrage mit dem SSL motzt.
                        Gruss, Holger
                        ECMACOM GmbH
                        www.ecmacom.ch
                        www.knxshop4u.ch
                          Da ist ja nix kompiliert. Das ist ein Base64 Baustein.
                          Nils
                          aktuelle Bausteine:
                            Meine, dass Logikgen.py bei mir unter Python 2.7 läuft
                            Gruss, Holger
                            ECMACOM GmbH
                            www.ecmacom.ch
                            www.knxshop4u.ch
                              Hallo Holger
                              Bei mir funktionieren Deine Bausteine leider nicht.... aber besten Dank das Du diese zur Verfügung stellst.
                              Gruss Pit
