Zitat von makki
(Ich habe es einmal probiert, ging tadellos)
TODO:
- kein "-strip"! Eher "-static"
./configure --without-pth-test enable-onlyeibd --enable-eibnetip --enable-eibnetiptunnel --enable-eibnetipserver --enable-groupcache
Von http://bcusdk.sourceforge.net/ folgende Pakete holen:
- pthsem-2.0.7.tar.gz
- argp-standalone-1.3.tar.gz
- bcusdk_0.0.4.tar.gz
Füge die Cross-Compile-Toolchain dem Pfad hinzu:
export PATH=$PATH:/usr/mipsel-linux-uclibc/bin/
Entpacke argp-standalone-1.3.tar.gz
cd argp-standalone-1.3
mkdir FritzBoxFiles
cd FritzBoxFiles
../configure --prefix=`pwd` --host=mipsel-linux-uclibc
make
==> argp-standalone-1.3/FritzBoxFiles/libargp.a wird erstellt
Entpacke pthsem-2.0.7.tar.gz
make
==> pthsem-2.0.7/libpthsem.la wird erstellt
Entpacke bcusdk_0.0.4.tar.gz
cd bcusdk-0.0.4
mkdir FritzBoxFiles
cd FritzBoxFiles
../configure --prefix=`pwd` --host=mipsel-linux-uclibc --without-pth-test --enable-onlyeibd --enable-eibnetip --enable-eibnetiptunnel --enable-eibnetipserver --enable-groupcache CPPFLAGS=-I/home/cm/devel/argp-standalone-1.3/ LDFLAGS="-L/home/cm/devel/argp-standalone-1.3/FritzBoxFiles -L/home/cm/devel/pthsem-2.0.7/.libs -strip"
eibd: 632544 bytes
groupwrite: 76132 bytes
Speicheroptimiert:
../configure --prefix=`pwd` --host=mipsel-linux-uclibc --without-pth-test --enable-onlyeibd --enable-eibnetip --enable-eibnetiptunnel --enable-eibnetipserver --enable-groupcache CPPFLAGS="-I/home/cm/devel/argp-standalone-1.3/ -Os -fmerge-constants" LDFLAGS="-L/home/cm/devel/argp-standalone-1.3/FritzBoxFiles -L/home/cm/devel/pthsem-2.0.7/.libs -strip"
eibd: 2098507 bytes, stripped: 632544 bytes
######## linkx
./configure --prefix=`pwd` --host=mipsel-linux-uclibc --without-pth-test CFLAGS="-I/home/cm/devel/argp-standalone-1.3/ -Os -fmerge-constants" LDFLAGS="-L/home/cm/devel/argp-standalone-1.3/FritzBoxFiles -L/home/cm/devel/pthsem-2.0.7/.libs -strip"
make
mipsel-linux-uclibc-strip -s -x -X --strip-unneeded linknx
./linknx --config=linknx.xml --daemon=linknx.out --pid-file=linknx.pid --write=linknx.write
Übertrage auf Fritz!Box
./eibd -c -i -R -S -T --daemon=eibd.out --pid-file=eibd.pid ip:
oder ohne Router und Tunnel, nur Bus-Zugriff:
./eibd -c -i -S --daemon=eibd.out --pid-file=eibd.pid ip:
dort: ./eibd ./eibd -c -R -S -T ip:
../configure --prefix=`pwd` --host=mipsel-linux-uclibc --without-pth-test --enable-onlyeibd --enable-eibnetip --enable-eibnetiptunnel --enable-eibnetipserver --enable-groupcache CPPFLAGS=-I/home/cm/devel/argp-standalone-1.3/ LDFLAGS=-L/home/cm/devel/argp-standalone-1.3/FritzBoxFiles
mkdir FritzBoxFiles
cd FritzBoxFiles
../configure --without-pth-test --enable-onlyeibd --enable-eibnetip --enable-eibnetiptunnel --enable-eibnetipserver --enable-groupcache --prefix=`pwd` --host=mipsel-linux-uclibc
lighttpd:
http://www.ip-phone-forum.de/showthread.php?t=136258
ln -s /var/media/ftp/Kingston-DataTraveler2-0-01/lighttpd/ /var/tmp/lighttpd
./lighttpd -f lighttpd.conf
