MQTT API Server und MQTT Clients - LBS19001051 - LBS19001054
    Was kann da passiert sein? Bin auf CentOS6.5
    Kann mir jemand einen Tipp geben, was ich machen kann.
    [root@edomi tmp]# rpm -q centos-release
    centos-release-6-5.el6.centos.11.1.x86_64
    [root@edomi tmp]#
    [root@edomi tmp]# yum update nss
    Loaded plugins: fastestmirror
    Loading mirror speeds from cached hostfile
     * base: mirror.inode.at
     * extras: mirror.digitalnova.at
     * updates: mirror.digitalnova.at
    http://mirror.inode.at/data/centos/6.9/os/x86_64/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
    Trying other mirror.
    http://mirror.nextlayer.at/centos/6.9/os/x86_64/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
    http://centos.mirroraustria.at/6.9/os/x86_64/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
    http://ftp.tugraz.at/mirror/centos/6.9/os/x86_64/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
    http://centos.schlundtech.de/6.9/os/x86_64/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
    http://mirror.easyname.at/centos/6.9/os/x86_64/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
    http://centosmirror.netcup.net/centos/6.9/os/x86_64/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
    http://centos.mirror.iphh.net/CentOS/6.9/os/x86_64/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
    http://ftp.plusline.de/centos/6.9/os/x86_64/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
    http://gd.tuwien.ac.at/opsys/linux/centos/6.9/os/x86_64/repodata/repomd.xml: [Errno 14] PYCURL ERROR 6 - "Couldn't resolve host 'gd.tuwien.ac.at'"
    Setting up Update Process
    Resolving Dependencies
    --> Running transaction check
    ---> Package nss.x86_64 0:3.15.1-15.el6 will be updated
    --> Processing Dependency: nss = 3.15.1-15.el6 for package: nss-sysinit-3.15.1-15.el6.x86_64
    --> Processing Dependency: nss(x86-64) = 3.15.1-15.el6 for package: nss-tools-3.15.1-15.el6.x86_64
    ---> Package nss.x86_64 0:3.36.0-9.el6_10 will be an update
    --> Processing Dependency: nss-util >= 3.36.0 for package: nss-3.36.0-9.el6_10.x86_64
    --> Processing Dependency: nss-softokn(x86-64) >= 3.14.3-22 for package: nss-3.36.0-9.el6_10.x86_64
    --> Processing Dependency: nspr >= 4.19.0 for package: nss-3.36.0-9.el6_10.x86_64
    --> Processing Dependency: libnssutil3.so(NSSUTIL_3.33)(64bit) for package: nss-3.36.0-9.el6_10.x86_64
    --> Processing Dependency: libnssutil3.so(NSSUTIL_3.31)(64bit) for package: nss-3.36.0-9.el6_10.x86_64
    --> Processing Dependency: libnssutil3.so(NSSUTIL_3.24)(64bit) for package: nss-3.36.0-9.el6_10.x86_64
    --> Processing Dependency: libnssutil3.so(NSSUTIL_3.21)(64bit) for package: nss-3.36.0-9.el6_10.x86_64
    --> Processing Dependency: libnssutil3.so(NSSUTIL_3.17.1)(64bit) for package: nss-3.36.0-9.el6_10.x86_64
    ---> Package nss-softokn.x86_64 0:3.14.3-9.el6 will be updated
    ---> Package nss-softokn.x86_64 0:3.14.3-23.3.el6_8 will be an update
    --> Processing Dependency: nss-softokn-freebl(x86-64) >= 3.14.3-23.3.el6_8 for package: nss-softokn-3.14.3-23.3.el6_8.x86_64
    --> Processing Dependency: nspr >= 4.10.6 for package: nss-softokn-3.14.3-23.3.el6_8.x86_64
    ---> Package nss-sysinit.x86_64 0:3.15.1-15.el6 will be updated
    ---> Package nss-sysinit.x86_64 0:3.36.0-9.el6_10 will be an update
    ---> Package nss-tools.x86_64 0:3.15.1-15.el6 will be updated
    ---> Package nss-tools.x86_64 0:3.36.0-9.el6_10 will be an update
    ---> Package nss-util.x86_64 0:3.15.1-3.el6 will be updated
    ---> Package nss-util.x86_64 0:3.27.1-3.el6 will be an update
    ---> Package nspr.x86_64 0:4.10.0-1.el6 will be updated
    ---> Package nspr.x86_64 0:4.13.1-1.el6 will be an update
    ---> Package nss-softokn-freebl.x86_64 0:3.14.3-9.el6 will be updated
    ---> Package nss-softokn-freebl.x86_64 0:3.14.3-23.3.el6_8 will be an update
    --> Finished Dependency Resolution
    Error: Package: nss-3.36.0-9.el6_10.x86_64 (updates)
               Requires: nspr >= 4.19.0
               Installed: nspr-4.10.0-1.el6.x86_64 (@anaconda-CentOS-201311272149.x86_64/6.5)
                   nspr = 4.10.0-1.el6
               Available: nspr-4.13.1-1.el6.i686 (base)
                   nspr = 4.13.1-1.el6
               Removing: nspr-4.10.0-1.el6.x86_64 (@anaconda-CentOS-201311272149.x86_64/6.5)
                   nspr = 4.10.0-1.el6
               Updated By: nspr-4.13.1-1.el6.x86_64 (base)
                   nspr = 4.13.1-1.el6
               Requires: libnssutil3.so(NSSUTIL_3.31)(64bit)
               Requires: libnssutil3.so(NSSUTIL_3.33)(64bit)
               Requires: nss-util >= 3.36.0
               Removing: nss-util-3.15.1-3.el6.x86_64 (@anaconda-CentOS-201311272149.x86_64/6.5)
                   nss-util = 3.15.1-3.el6
               Updated By: nss-util-3.27.1-3.el6.x86_64 (base)
                   nss-util = 3.27.1-3.el6
               Installed: nss-util-3.15.1-3.el6.x86_64 (@anaconda-CentOS-201311272149.x86_64/6.5)
               Available: nss-util-3.27.1-3.el6.i686 (base)
     You could try using --skip-broken to work around the problem
     You could try running: rpm -Va --nofiles --nodigest
    [root@edomi tmp]#
      Du kannst mal schauen was in /etc/yum.repos.d/CentOS-Base.repo steht?
      Kann es dann mal heute Abend vergleichen mit dem was bei mir drin steht.
        Danke!
        Anbei die CentOS-Base.repo
        # CentOS-Base.repo
        # The mirror system uses the connecting IP address of the client and the
        # update status of each mirror to pick mirrors that are updated to and
        # geographically close to the client.  You should use this for CentOS updates
        # unless you are manually picking other mirrors.
        # If the mirrorlist= does not work for you, as a fall back you can try the
        # remarked out baseurl= line instead.
        [base]
        name=CentOS-$releasever - Base
        mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=os
        #baseurl=http://mirror.centos.org/centos/$releasever/os/$basearch/
        gpgcheck=1
        gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-CentOS-6
        #released updates
        [updates]
        name=CentOS-$releasever - Updates
        mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=updates
        #baseurl=http://mirror.centos.org/centos/$releasever/updates/$basearch/
        gpgcheck=1
        #additional packages that may be useful
        [extras]
        name=CentOS-$releasever - Extras
        mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=extras
        #baseurl=http://mirror.centos.org/centos/$releasever/extras/$basearch/
        gpgcheck=1
        #additional packages that extend functionality of existing packages
        [centosplus]
        name=CentOS-$releasever - Plus
        mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=centosplus
        #baseurl=http://mirror.centos.org/centos/$releasever/centosplus/$basearch/
        gpgcheck=1
        enabled=0
        #contrib - packages by Centos Users
        [contrib]
        name=CentOS-$releasever - Contrib
        mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=contrib
        #baseurl=http://mirror.centos.org/centos/$releasever/contrib/$basearch/
        gpgcheck=1
        enabled=0
          Hab folgendes versucht.
           # If the mirrorlist= does not work for you, as a fall back you can try the # remarked out baseurl= line instead.
          Hat auch funktioniert, aber ich Idiot habe zum testen yum update eingegeben und mit y bestätigt. Mein System wird glaube ich gerade auf 6.10 geupdatet. Wie schlimm ist so ein Update bzügl. Edomi Oder soll ich gleich komplett neu installieren?
            Ich denke nicht dass es schlimm ist. musst nur vermutlich die Firewall jetzt deaktivieren, da diese bei einem Update automatisch aktiviert wird.
            service iptables stop
            chkconfig iptables off
              Danke für deine Hilfe!
              Habe die LBSen auch zum laufen gebracht und habe einige Tests mit Node-Red gemacht.
              Funktioniert soweit auch.
              Von Edomi zu Node-Red kommt alles etwa 10-30sec verzögert.
              Node-Red zu Edomi ca. 3-5 sec.
              Habe aber folgende Probleme:
              Info:
              Mein Edomi läuft auf einem Futro S900 mit 2GB Ram
              Bei Aktivierung der LBSen ist die CPU auf Anschlag.
              CPU ohne LBSen:
              CPU mit LBSen:
              Die Logic Queued schaukelt sich hoch und es wird alles verzögert. Visu ist kaum bedienbar und auf den KNX schreiben auch sehr verzögert (im Minuten Bereich)
              Habe das ganze auch auf meinem Testsystem in einer VM beobachtet.
              Liegt es an der Hardware? Oder übersehe ich noch etwas?
              Der Broker läuft auf einem Raspi.
              Schöne Grüße
              Gernot
                Das klingt seltsam. Wie sehen deine Logik Seiten mit dem MQTT LBSen aus? Insbesondere die beiden Server LBS sollten nur einmal vorhanden sein.
                Hast du die aktuellste Version der LBSen verwendet? Was sagen die Logs der LBSen?
                  Ja gestern runter geladen.
                  Habe mich noch etwas beschäftigt und konnte das Problem auf den Publish Server eingrenzen:
                  Ist der Baustein aktiviert steigt die CPU auf Anschlag. Es wird auch kein Logfile geschrieben.
                  In Node-Red kommt der Minuten trigger aber an.
                  Sind nur einmal vorhanden.
                  So sieht die Logikseite aus:
                  Die Logfiles, merkwürdigerweise wird für den Publishserver kein Logfile geschrieben:
                   [TABLE="class: log, border: 0, cellpadding: 0, cellspacing: 0, width: 0, height: 12"]
                   	 		[TR]
                   			[TD="colspan: 5"]{EDOMI,CUSTOMLOG_MQTT_Subscribe_Server-LBS19001052.htm,18.10.2018,22:14:01,757939,1778}[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]Zeitstempel[/TD]
                   			[TD]ms[/TD]
                   			[TD]PID[/TD]
                   			[TD]LogLevel[/TD]
                   			[TD]Meldung[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-18 22:14:01[/TD]
                   			[TD]757663[/TD]
                   			[TD]1778[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001052 [v0.5]: LBS MQTT Subscribe Server started (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]792192[/TD]
                   			[TD]1778[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001052 [v0.5]: MSGQID generated: 78987827 (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]844742[/TD]
                   			[TD]1778[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001052 [v0.5]: Message: (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]845135[/TD]
                   			[TD]1778[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001052 [v0.5]: ================ ARRAY/OBJECT START ================[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]845344[/TD]
                   			[TD]1778[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001052 [v0.5]: {"start":{"ip":null,"port":"1883","user":null,"pwd":null,"plain":null,"regexp":null,"qos":"1","retain":"0","sub":["edomi\/set\/#","edomi\/get\/#"],"tls":"0","caPath":"\/etc\/ssl\/certs\/ca-bundle.crt"}}[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]845511[/TD]
                   			[TD]1778[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001052 [v0.5]: ================ ARRAY/OBJECT END ================[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]863032[/TD]
                   			[TD]1778[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001052 [v0.5]: MSGQID used: 78987827 (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]868499[/TD]
                   			[TD]1778[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001052 [v0.5]: LBS MQTT Subscribe Server ended (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-18 22:14:02[/TD]
                   			[TD]557133[/TD]
                   			[TD]1992[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: MSGQID: 78987827 (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]563376[/TD]
                   			[TD]1992[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: Command received by daemon: start (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]573040[/TD]
                   			[TD]1992[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: Starting MQTT Subscribe Server daemon (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-18 23:06:40[/TD]
                   			[TD]517704[/TD]
                   			[TD]22318[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]552109[/TD]
                   			[TD]22318[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001052 [v0.5]: MSGQID generated: 1380948111 (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]626151[/TD]
                   			[TD]22318[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]626540[/TD]
                   			[TD]22318[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]627325[/TD]
                   			[TD]22318[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001052 [v0.5]: {"start":{"ip":"192.168.179.144","port":"1883","user":null,"pwd":null,"plain":null,"regexp":null,"qos":"1","retain":"0","sub":["edomi\/set\/#","edomi\/get\/#"],"tls":"0","caPath":"\/etc\/ssl\/certs\/ca-bundle.crt"}}[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]627691[/TD]
                   			[TD]22318[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]639118[/TD]
                   			[TD]22318[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001052 [v0.5]: MSGQID used: 1380948111 (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]651674[/TD]
                   			[TD]22318[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-18 23:06:41[/TD]
                   			[TD]344928[/TD]
                   			[TD]22552[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: MSGQID: 1380948111 (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]357923[/TD]
                   			[TD]22552[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]369513[/TD]
                   			[TD]22552[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]376342[/TD]
                   			[TD]22552[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: Setting LWT: (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]376687[/TD]
                   			[TD]22552[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: ================ ARRAY/OBJECT START ================[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]377825[/TD]
                   			[TD]22552[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: ["edomi\/offline","192.168.179.63|2018-10-18_23:06:41",2,0][/TD]
                   		[/TR]
                   		[TR]
                   			[TD]378118[/TD]
                   			[TD]22552[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: ================ ARRAY/OBJECT END ================[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]387821[/TD]
                   			[TD]22552[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: Resubscribing topics (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]388115[/TD]
                   			[TD]22552[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]388257[/TD]
                   			[TD]22552[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: {"edomi\/set\/#":"1","edomi\/get\/#":"1"}[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]388385[/TD]
                   			[TD]22552[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]406399[/TD]
                   			[TD]22552[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: Resubscribing topic: edomi/set/# with QoS: 1 (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]420299[/TD]
                   			[TD]22552[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: Resubscribing topic: edomi/get/# with QoS: 1 (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-18 23:23:04[/TD]
                   			[TD]549159[/TD]
                   			[TD]22552[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: Topic: edomi/set/knx/1-0-50 - Payload: 0 (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]580131[/TD]
                   			[TD]22552[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: MQTT find Query: SELECT id,ga,name FROM edomiLive.RAMko WHERE (ga="1/0/50" OR name="1/0/50") (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]588198[/TD]
                   			[TD]22552[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: MQTT Set Query: INSERT INTO edomiLive.RAMknxRead (mode,gatyp,gaid,value) VALUES (4,0,"133","0") (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]602916[/TD]
                   			[TD]22552[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: SUCCESS: 1-0-50 GA: 1/0/50 (Zi Tata DL) set to: 0 (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-18 23:46:44[/TD]
                   			[TD]413264[/TD]
                   			[TD]22552[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: MQTT Subscribe Server daemon stopped (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 00:33:39[/TD]
                   			[TD]135040[/TD]
                   			[TD]5923[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]165445[/TD]
                   			[TD]5923[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001052 [v0.5]: MSGQID generated: 1975047074 (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]237883[/TD]
                   			[TD]5923[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]238739[/TD]
                   			[TD]5923[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]239034[/TD]
                   			[TD]5923[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]239280[/TD]
                   			[TD]5923[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]253004[/TD]
                   			[TD]5923[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001052 [v0.5]: MSGQID used: 1975047074 (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]258852[/TD]
                   			[TD]5923[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]948096[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: MSGQID: 1975047074 (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]957684[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]964891[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]971123[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]971405[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]971565[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: ["edomi\/offline","192.168.179.63|2018-10-19_00:33:39",2,0][/TD]
                   		[/TR]
                   		[TR]
                   			[TD]971730[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]979957[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]980253[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]980398[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]980525[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]989510[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]998991[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 00:35:54[/TD]
                   			[TD]524991[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]541714[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]612683[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]622306[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 00:36:28[/TD]
                   			[TD]135430[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]163834[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]187424[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]213984[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 00:36:44[/TD]
                   			[TD]678896[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: Topic: edomi/set/knx/1-0-50 - Payload: 1 (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]698374[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]723925[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: MQTT Set Query: INSERT INTO edomiLive.RAMknxRead (mode,gatyp,gaid,value) VALUES (4,0,"133","1") (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]738363[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: SUCCESS: 1-0-50 GA: 1/0/50 (Zi Tata DL) set to: 1 (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 00:44:52[/TD]
                   			[TD]940315[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]944370[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]954099[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]959935[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 00:45:51[/TD]
                   			[TD]835313[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]872937[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]949832[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]972548[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 00:47:18[/TD]
                   			[TD]097742[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: Topic: edomi/set/knx/1-0-50 - Payload: Hallo Edomi (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]154961[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]186520[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: MQTT Set Query: INSERT INTO edomiLive.RAMknxRead (mode,gatyp,gaid,value) VALUES (4,0,"133","Hallo Edomi") (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]228976[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: SUCCESS: 1-0-50 GA: 1/0/50 (Zi Tata DL) set to: Hallo Edomi (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 00:48:40[/TD]
                   			[TD]241976[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: Topic: edomi/set/knx/1-0-50 - Payload: 99999 (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]302551[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]375503[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: MQTT Set Query: INSERT INTO edomiLive.RAMknxRead (mode,gatyp,gaid,value) VALUES (4,0,"133","99999") (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]379797[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: SUCCESS: 1-0-50 GA: 1/0/50 (Zi Tata DL) set to: 99999 (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 00:49:47[/TD]
                   			[TD]584980[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: Topic: edomi/set/knx/1-0-50 - Payload: {"Hallo":"EDOMI"} (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]607302[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]640727[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: MQTT Set Query: INSERT INTO edomiLive.RAMknxRead (mode,gatyp,gaid,value) VALUES (4,0,"133","{\"Hallo\":\"EDOMI\"}") (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]686130[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: SUCCESS: 1-0-50 GA: 1/0/50 (Zi Tata DL) set to: {\"Hallo\":\"EDOMI\"} (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 01:04:21[/TD]
                   			[TD]886624[/TD]
                   			[TD]6163[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 01:12:00[/TD]
                   			[TD]661071[/TD]
                   			[TD]982[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]695116[/TD]
                   			[TD]982[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001052 [v0.5]: MSGQID generated: 1193575484 (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]763950[/TD]
                   			[TD]982[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]765171[/TD]
                   			[TD]982[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]767429[/TD]
                   			[TD]982[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]767802[/TD]
                   			[TD]982[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]780066[/TD]
                   			[TD]982[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001052 [v0.5]: MSGQID used: 1193575484 (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]789968[/TD]
                   			[TD]982[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 01:12:01[/TD]
                   			[TD]533657[/TD]
                   			[TD]1234[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: MSGQID: 1193575484 (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]540811[/TD]
                   			[TD]1234[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]547996[/TD]
                   			[TD]1234[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]556926[/TD]
                   			[TD]1234[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]557234[/TD]
                   			[TD]1234[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]557396[/TD]
                   			[TD]1234[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: ["edomi\/offline","192.168.179.63|2018-10-19_01:12:01",2,0][/TD]
                   		[/TR]
                   		[TR]
                   			[TD]557528[/TD]
                   			[TD]1234[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]567789[/TD]
                   			[TD]1234[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]568098[/TD]
                   			[TD]1234[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]570177[/TD]
                   			[TD]1234[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]570476[/TD]
                   			[TD]1234[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]579951[/TD]
                   			[TD]1234[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]585804[/TD]
                   			[TD]1234[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 01:28:24[/TD]
                   			[TD]404789[/TD]
                   			[TD]1234[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 09:38:33[/TD]
                   			[TD]153955[/TD]
                   			[TD]3159[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]218991[/TD]
                   			[TD]3159[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001052 [v0.5]: MSGQID generated: 1607460112 (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]306998[/TD]
                   			[TD]3159[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]307378[/TD]
                   			[TD]3159[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]307629[/TD]
                   			[TD]3159[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]307830[/TD]
                   			[TD]3159[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]322942[/TD]
                   			[TD]3159[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001052 [v0.5]: MSGQID used: 1607460112 (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]324888[/TD]
                   			[TD]3159[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]968255[/TD]
                   			[TD]3391[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: MSGQID: 1607460112 (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]989644[/TD]
                   			[TD]3391[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]999157[/TD]
                   			[TD]3391[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 09:38:34[/TD]
                   			[TD]007175[/TD]
                   			[TD]3391[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]008275[/TD]
                   			[TD]3391[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]008508[/TD]
                   			[TD]3391[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: ["edomi\/offline","192.168.179.63|2018-10-19_09:38:33",2,0][/TD]
                   		[/TR]
                   		[TR]
                   			[TD]008688[/TD]
                   			[TD]3391[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]023509[/TD]
                   			[TD]3391[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]023817[/TD]
                   			[TD]3391[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]023973[/TD]
                   			[TD]3391[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]024104[/TD]
                   			[TD]3391[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]034653[/TD]
                   			[TD]3391[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]046361[/TD]
                   			[TD]3391[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 09:43:59[/TD]
                   			[TD]479491[/TD]
                   			[TD]3159[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]494719[/TD]
                   			[TD]3159[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]495942[/TD]
                   			[TD]3159[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]496237[/TD]
                   			[TD]3159[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001052 [v0.5]: {"stop":1}[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]502235[/TD]
                   			[TD]3159[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]510657[/TD]
                   			[TD]3159[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]525012[/TD]
                   			[TD]3159[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]646146[/TD]
                   			[TD]3391[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: Command received by daemon: stop (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]649039[/TD]
                   			[TD]3391[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: Stopping MQTT Subscribe Server daemon (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]764445[/TD]
                   			[TD]3391[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: Exception caught: The client is not currently connected. (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]769742[/TD]
                   			[TD]3391[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 10:08:42[/TD]
                   			[TD]366794[/TD]
                   			[TD]3159[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]378194[/TD]
                   			[TD]3159[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001052 [v0.5]: MSGQID generated: 1251233339 (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]407828[/TD]
                   			[TD]3159[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]408747[/TD]
                   			[TD]3159[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]409090[/TD]
                   			[TD]3159[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]409307[/TD]
                   			[TD]3159[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]418174[/TD]
                   			[TD]3159[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001052 [v0.5]: MSGQID used: 1251233339 (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]420268[/TD]
                   			[TD]3159[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]564091[/TD]
                   			[TD]28465[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: MSGQID: 1251233339 (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]567435[/TD]
                   			[TD]28465[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]569958[/TD]
                   			[TD]28465[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]574491[/TD]
                   			[TD]28465[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]574837[/TD]
                   			[TD]28465[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]575004[/TD]
                   			[TD]28465[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: ["edomi\/offline","192.168.179.63|2018-10-19_10:08:42",2,0][/TD]
                   		[/TR]
                   		[TR]
                   			[TD]575133[/TD]
                   			[TD]28465[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]577377[/TD]
                   			[TD]28465[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]578007[/TD]
                   			[TD]28465[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]578217[/TD]
                   			[TD]28465[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]578342[/TD]
                   			[TD]28465[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]581162[/TD]
                   			[TD]28465[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]584001[/TD]
                   			[TD]28465[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 10:09:08[/TD]
                   			[TD]393311[/TD]
                   			[TD]28465[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]398113[/TD]
                   			[TD]28465[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]405069[/TD]
                   			[TD]28465[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]409312[/TD]
                   			[TD]28465[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 10:15:33[/TD]
                   			[TD]282296[/TD]
                   			[TD]28465[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]288362[/TD]
                   			[TD]28465[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]302916[/TD]
                   			[TD]28465[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]305406[/TD]
                   			[TD]28465[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 10:16:44[/TD]
                   			[TD]548089[/TD]
                   			[TD]28465[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]552103[/TD]
                   			[TD]28465[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]559097[/TD]
                   			[TD]28465[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]561765[/TD]
                   			[TD]28465[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 10:18:20[/TD]
                   			[TD]270730[/TD]
                   			[TD]28465[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: Topic: edomi/set/knx/1-0-51 - Payload: {"Hallo2":"EDOMI"} (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]274050[/TD]
                   			[TD]28465[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: MQTT find Query: SELECT id,ga,name FROM edomiLive.RAMko WHERE (ga="1/0/51" OR name="1/0/51") (2247)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]281312[/TD]
                   			[TD]28465[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001052 [v0.5]: ERROR: 1-0-51 GA: 1/0/51 not found in EDOMI database (2247)[/TD]
                   		[/TR]
                   	 [/TABLE]
                   	 		[TR]
                   			[TD="colspan: 5"]{EDOMI,CUSTOMLOG_MQTT_Publish_Client-LBS19001053.htm,19.10.2018,00:42:19,396147,13704}[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]ms[/TD]
                   			[TD]PID[/TD]
                   			[TD]LogLevel[/TD]
                   			[TD]Meldung[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 00:42:19[/TD]
                   			[TD]395720[/TD]
                   			[TD]13704[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001053 [v0.3.1]: MQTT Publish Client started (2248)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]429866[/TD]
                   			[TD]13704[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001053 [v0.3.1]: Publishing topic: with payload: 30 and qos: 1 and retain: 1 (2248)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 00:43:00[/TD]
                   			[TD]024128[/TD]
                   			[TD]14232[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]057600[/TD]
                   			[TD]14232[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001053 [v0.3.1]: Publishing topic: edomi/status/internal/26 with payload: 36 and qos: 1 and retain: 1 (2248)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]265419[/TD]
                   			[TD]14232[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001053 [v0.3.1]: MQTT Publish Client ended (2248)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 00:43:27[/TD]
                   			[TD]747859[/TD]
                   			[TD]14615[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]782500[/TD]
                   			[TD]14615[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001053 [v0.3.1]: Publishing topic: edomi/status/internal/26 with payload: 40 and qos: 1 and retain: 1 (2248)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]989351[/TD]
                   			[TD]14615[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 00:50:38[/TD]
                   			[TD]540812[/TD]
                   			[TD]20278[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]575402[/TD]
                   			[TD]20278[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001053 [v0.3.1]: Publishing topic: edomi/status/internal/26 with payload: 80 and qos: 1 and retain: 1 (2248)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]793499[/TD]
                   			[TD]20278[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 00:51:20[/TD]
                   			[TD]266690[/TD]
                   			[TD]20865[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]350400[/TD]
                   			[TD]20865[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001053 [v0.3.1]: Publishing topic: edomi/status/internal/26 with payload: 99 and qos: 1 and retain: 1 (2248)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]558974[/TD]
                   			[TD]20865[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 10:11:16[/TD]
                   			[TD]092963[/TD]
                   			[TD]28896[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]097889[/TD]
                   			[TD]28896[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001053 [v0.3.1]: Publishing topic: edomi/status/internal/26 with payload: Hello and qos: 1 and retain: 1 (2248)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]304616[/TD]
                   			[TD]28896[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 10:11:24[/TD]
                   			[TD]763552[/TD]
                   			[TD]28908[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]771837[/TD]
                   			[TD]28908[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]978071[/TD]
                   			[TD]28908[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   	 [/TABLE]
                   	 		[TR]
                   			[TD="colspan: 5"]{EDOMI,CUSTOMLOG_MQTT_Subscribe_Client-LBS19001054.htm,18.10.2018,22:14:01,943242,1778}[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]ms[/TD]
                   			[TD]PID[/TD]
                   			[TD]LogLevel[/TD]
                   			[TD]Meldung[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]943037[/TD]
                   			[TD]1778[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001054 [v0.2.4]: LBS MQTT Subscribe Client started (2249)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]988468[/TD]
                   			[TD]1778[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001054 [v0.2.4]: MSGQID generated: 1106533622 (2249)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]090293[/TD]
                   			[TD]1778[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001054 [v0.2.4]: Message: (2249)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]090769[/TD]
                   			[TD]1778[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001054 [v0.2.4]: ================ ARRAY/OBJECT START ================[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]090962[/TD]
                   			[TD]1778[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001054 [v0.2.4]: {"start":{"ip":null,"port":"1883","user":null,"pwd":null,"plain":null,"regexp":null,"qos":"1","sub":null,"tls":"0","caPath":"\/etc\/ssl\/certs\/ca-bundle.crt"}}[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]091131[/TD]
                   			[TD]1778[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001054 [v0.2.4]: ================ ARRAY/OBJECT END ================[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]108510[/TD]
                   			[TD]1778[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001054 [v0.2.4]: MSGQID used: 1106533622 (2249)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]115897[/TD]
                   			[TD]1778[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001054 [v0.2.4]: LBS MQTT Subscribe Client ended (2249)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]691778[/TD]
                   			[TD]1994[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001054 [v0.2.4]: MSGQID: 1106533622 (2249)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]699430[/TD]
                   			[TD]1994[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001054 [v0.2.4]: Command received by daemon: start (2249)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]702497[/TD]
                   			[TD]1994[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001054 [v0.2.4]: Starting MQTT Subscribe Client daemon (2249)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]745556[/TD]
                   			[TD]22318[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]798394[/TD]
                   			[TD]22318[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001054 [v0.2.4]: MSGQID generated: 1653399208 (2249)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]888515[/TD]
                   			[TD]22318[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]889511[/TD]
                   			[TD]22318[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]890808[/TD]
                   			[TD]22318[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001054 [v0.2.4]: {"start":{"ip":"192.168.179.144","port":"1883","user":null,"pwd":null,"plain":null,"regexp":null,"qos":"1","sub":null,"tls":"0","caPath":"\/etc\/ssl\/certs\/ca-bundle.crt"}}[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]891026[/TD]
                   			[TD]22318[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]909564[/TD]
                   			[TD]22318[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001054 [v0.2.4]: MSGQID used: 1653399208 (2249)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]923280[/TD]
                   			[TD]22318[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]571942[/TD]
                   			[TD]22555[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001054 [v0.2.4]: MSGQID: 1653399208 (2249)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]594293[/TD]
                   			[TD]22555[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]601253[/TD]
                   			[TD]22555[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]606050[/TD]
                   			[TD]22555[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001054 [v0.2.4]: Resubscribing topics (2249)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]606338[/TD]
                   			[TD]22555[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001054 [v0.2.4]: ================ ARRAY/OBJECT START ================[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]606512[/TD]
                   			[TD]22555[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001054 [v0.2.4]: [][/TD]
                   		[/TR]
                   		[TR]
                   			[TD]606671[/TD]
                   			[TD]22555[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001054 [v0.2.4]: ================ ARRAY/OBJECT END ================[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]377944[/TD]
                   			[TD]22555[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001054 [v0.2.4]: MQTT Subscribe Client daemon stopped (2249)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]329121[/TD]
                   			[TD]5923[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]372270[/TD]
                   			[TD]5923[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001054 [v0.2.4]: MSGQID generated: 832111787 (2249)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]448236[/TD]
                   			[TD]5923[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]448765[/TD]
                   			[TD]5923[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]448976[/TD]
                   			[TD]5923[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]449156[/TD]
                   			[TD]5923[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]455667[/TD]
                   			[TD]5923[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001054 [v0.2.4]: MSGQID used: 832111787 (2249)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]468874[/TD]
                   			[TD]5923[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 00:33:40[/TD]
                   			[TD]060904[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001054 [v0.2.4]: MSGQID: 832111787 (2249)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]068623[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]074647[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]079732[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]080029[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]080205[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]080334[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 00:45:45[/TD]
                   			[TD]218148[/TD]
                   			[TD]5923[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]239154[/TD]
                   			[TD]5923[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]240072[/TD]
                   			[TD]5923[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]240333[/TD]
                   			[TD]5923[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001054 [v0.2.4]: {"subscribe":{"qos":"1","topic":"edomi\/status\/internal\/26"}}[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]240483[/TD]
                   			[TD]5923[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]251408[/TD]
                   			[TD]5923[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]274965[/TD]
                   			[TD]5923[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]375535[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001054 [v0.2.4]: Command received by daemon: subscribe (2249)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]382050[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001054 [v0.2.4]: Added subscription: edomi/status/internal/26 with QoS: 1 (2249)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]521596[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001054 [v0.2.4]: Topic: edomi/status/internal/26 - Payload: 1 (2249)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 00:46:18[/TD]
                   			[TD]452568[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 00:46:32[/TD]
                   			[TD]706314[/TD]
                   			[TD]5923[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]721833[/TD]
                   			[TD]5923[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]722162[/TD]
                   			[TD]5923[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]722538[/TD]
                   			[TD]5923[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001054 [v0.2.4]: {"subscribe":{"qos":"1","topic":"edomi\/set\/knx\/1-0-50"}}[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]722732[/TD]
                   			[TD]5923[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]733848[/TD]
                   			[TD]5923[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]746485[/TD]
                   			[TD]5923[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]769407[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]776412[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001054 [v0.2.4]: Added subscription: edomi/set/knx/1-0-50 with QoS: 1 (2249)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 00:47:17[/TD]
                   			[TD]981163[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001054 [v0.2.4]: Topic: edomi/set/knx/1-0-50 - Payload: Hallo Edomi (2249)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 00:47:19[/TD]
                   			[TD]323400[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]113516[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001054 [v0.2.4]: Topic: edomi/set/knx/1-0-50 - Payload: 99999 (2249)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 00:49:03[/TD]
                   			[TD]201189[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]490617[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001054 [v0.2.4]: Topic: edomi/set/knx/1-0-50 - Payload: {"Hallo":"EDOMI"} (2249)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 00:50:01[/TD]
                   			[TD]872468[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]724699[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001054 [v0.2.4]: Topic: edomi/status/internal/26 - Payload: 80 (2249)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 00:51:14[/TD]
                   			[TD]522715[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]750441[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001054 [v0.2.4]: Topic: edomi/status/internal/26 - Payload: 99 (2249)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 00:52:21[/TD]
                   			[TD]454272[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 00:53:13[/TD]
                   			[TD]808181[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 00:54:21[/TD]
                   			[TD]581486[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 00:55:21[/TD]
                   			[TD]867294[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 00:56:38[/TD]
                   			[TD]624942[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 00:57:40[/TD]
                   			[TD]898399[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 00:58:34[/TD]
                   			[TD]587762[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 00:59:54[/TD]
                   			[TD]277923[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 01:01:03[/TD]
                   			[TD]067399[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 01:01:53[/TD]
                   			[TD]869445[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 01:03:15[/TD]
                   			[TD]579263[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]2018-10-19 01:04:18[/TD]
                   			[TD]620706[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]830378[/TD]
                   			[TD]6165[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]862514[/TD]
                   			[TD]982[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]920727[/TD]
                   			[TD]982[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001054 [v0.2.4]: MSGQID generated: 1074712548 (2249)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]028815[/TD]
                   			[TD]982[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]029206[/TD]
                   			[TD]982[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]029437[/TD]
                   			[TD]982[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]029720[/TD]
                   			[TD]982[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]049212[/TD]
                   			[TD]982[/TD]
                   			[TD]debug[/TD]
                   			[TD]LBS19001054 [v0.2.4]: MSGQID used: 1074712548 (2249)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]065551[/TD]
                   			[TD]982[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]649319[/TD]
                   			[TD]1236[/TD]
                   			[TD]debug[/TD]
                   			[TD]EXE19001054 [v0.2.4]: MSGQID: 1074712548 (2249)[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]656246[/TD]
                   			[TD]1236[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]661263[/TD]
                   			[TD]1236[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]666960[/TD]
                   			[TD]1236[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]667254[/TD]
                   			[TD]1236[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]667426[/TD]
                   			[TD]1236[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]667550[/TD]
                   			[TD]1236[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   		[TR]
                   			[TD]615034[/TD]
                   			[TD]1236[/TD]
                   			[TD]debug[/TD]
                   		[/TR]
                   	 [/TABLE]
                    Kann sein, dass du da eine Schleife gebaut hast. Bin da nicht wirklich sicher, aber Subscribe und Publish Client sind in erster Linie dafür gedacht eigene Topics zu publishen oder zu subscriben. Du solltest hier nicht die Struktur verwenden, die die beiden Server LBS verwenden.
                    Zum Test würde ich mal alle die Clients und den Subscribe Server LBS deaktivieren und nur den Publish Server aktivieren.
                    Dann dann neu aktivieren und schauen was die CPU Last macht und zusätzlich ein tail -f auf das Mosquitto Log machen. Dort sollten dann alle EDOMI iKO und KNX GAs auftauchen.
                      Nun läuft nur mer der Publishserver
                      CPU 100%
                      Die Logicqueued hält sich aber in grenzen.
                      Doch aus dem log werde ich nicht schlau.
                      1539940798: New connection from 192.168.179.63 on port 1883.
                      1539940798: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940798: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940798: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940798: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940799: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940799: New connection from 192.168.179.63 on port 1883.
                      1539940799: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940799: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940799: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940800: New connection from 192.168.179.63 on port 1883.
                      1539940800: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940800: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940800: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940800: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940801: New connection from 192.168.179.63 on port 1883.
                      1539940801: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940801: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940801: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940801: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940802: New connection from 192.168.179.63 on port 1883.
                      1539940802: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940802: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940802: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940802: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940803: New connection from 192.168.179.63 on port 1883.
                      1539940803: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940803: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940803: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940803: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940804: New connection from 192.168.179.63 on port 1883.
                      1539940804: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940804: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940804: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940804: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940805: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940805: New connection from 192.168.179.63 on port 1883.
                      1539940805: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940805: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940805: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940806: New connection from 192.168.179.63 on port 1883.
                      1539940806: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940806: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940806: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940806: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940807: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940807: New connection from 192.168.179.63 on port 1883.
                      1539940807: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940808: New connection from 192.168.179.63 on port 1883.
                      1539940808: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940808: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940808: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940808: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940809: New connection from 192.168.179.63 on port 1883.
                      1539940809: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940809: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940809: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940809: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940810: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940810: New connection from 192.168.179.63 on port 1883.
                      1539940810: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940810: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940810: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940811: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940811: New connection from 192.168.179.63 on port 1883.
                      1539940811: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940812: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940812: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940812: New connection from 192.168.179.63 on port 1883.
                      1539940812: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940812: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940813: New connection from 192.168.179.63 on port 1883.
                      1539940813: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940813: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940813: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940813: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940814: New connection from 192.168.179.63 on port 1883.
                      1539940814: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940814: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940814: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940814: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940815: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940815: New connection from 192.168.179.63 on port 1883.
                      1539940815: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940815: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940815: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940816: New connection from 192.168.179.63 on port 1883.
                      1539940816: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940816: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940817: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940817: New connection from 192.168.179.63 on port 1883.
                      1539940817: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940818: New connection from 192.168.179.63 on port 1883.
                      1539940818: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940818: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940821: New connection from 192.168.179.63 on port 1883.
                      1539940821: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940821: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940821: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940821: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940829: New connection from 192.168.179.63 on port 1883.
                      1539940829: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940829: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940830: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940830: New connection from 192.168.179.63 on port 1883.
                      1539940830: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940830: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940830: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940831: New connection from 192.168.179.63 on port 1883.
                      1539940831: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940831: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940831: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940831: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940832: New connection from 192.168.179.63 on port 1883.
                      1539940832: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940832: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940832: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940832: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940833: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940833: New connection from 192.168.179.63 on port 1883.
                      1539940833: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940833: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940833: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940834: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940834: New connection from 192.168.179.63 on port 1883.
                      1539940834: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940834: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940834: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940835: New connection from 192.168.179.63 on port 1883.
                      1539940835: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940835: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940836: New connection from 192.168.179.63 on port 1883.
                      1539940836: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940836: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940836: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940836: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940837: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940837: New connection from 192.168.179.63 on port 1883.
                      1539940837: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940838: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940838: New connection from 192.168.179.63 on port 1883.
                      1539940838: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940838: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940838: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940839: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940839: New connection from 192.168.179.63 on port 1883.
                      1539940839: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940839: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940839: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940840: New connection from 192.168.179.63 on port 1883.
                      1539940840: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940840: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940840: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940840: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940841: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940841: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940841: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940841: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940841: New connection from 192.168.179.63 on port 1883.
                      1539940842: New connection from 192.168.179.63 on port 1883.
                      1539940842: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940842: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940842: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940842: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940843: New connection from 192.168.179.63 on port 1883.
                      1539940843: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940843: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940843: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940843: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940844: New connection from 192.168.179.63 on port 1883.
                      1539940844: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940844: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940844: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940844: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940845: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940845: New connection from 192.168.179.63 on port 1883.
                      1539940845: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940845: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940845: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940846: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940846: New connection from 192.168.179.63 on port 1883.
                      1539940846: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940847: New connection from 192.168.179.63 on port 1883.
                      1539940847: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940847: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940847: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940847: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940848: New connection from 192.168.179.63 on port 1883.
                      1539940848: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940848: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940848: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940848: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940849: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940849: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940849: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940849: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940849: New connection from 192.168.179.63 on port 1883.
                      1539940850: New connection from 192.168.179.63 on port 1883.
                      1539940850: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940850: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940850: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940850: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940851: New connection from 192.168.179.63 on port 1883.
                      1539940851: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940851: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940851: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940851: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940852: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940852: New connection from 192.168.179.63 on port 1883.
                      1539940852: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940852: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940852: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940853: New connection from 192.168.179.63 on port 1883.
                      1539940853: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940853: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940853: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940853: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940854: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940854: New connection from 192.168.179.63 on port 1883.
                      1539940854: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940854: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940854: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940855: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940855: New connection from 192.168.179.63 on port 1883.
                      1539940855: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940855: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940855: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940856: New connection from 192.168.179.63 on port 1883.
                      1539940856: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940856: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940857: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940857: New connection from 192.168.179.63 on port 1883.
                      1539940857: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940857: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940857: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940858: New connection from 192.168.179.63 on port 1883.
                      1539940858: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940858: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940858: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940858: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940859: New connection from 192.168.179.63 on port 1883.
                      1539940859: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940859: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940859: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940859: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940860: New connection from 192.168.179.63 on port 1883.
                      1539940860: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940860: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940860: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940860: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940861: New connection from 192.168.179.63 on port 1883.
                      1539940861: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940861: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940861: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940861: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940862: New connection from 192.168.179.63 on port 1883.
                      1539940862: Client EDOMI MQTT Publish Server (2246) already connected, closing old connection.
                      1539940862: Socket error on client EDOMI MQTT Publish Server (2246), disconnecting.
                      1539940862: New client connected from 192.168.179.63 as EDOMI MQTT Publish Server (2246) (c1, k60, u'').
                      1539940862: Client EDOMI MQTT Publish Server (2246) disconnected.
                      1539940863: Client EDOMI MQTT Publish Server (2246) disconnected.
                        Das sind nur die Connections, die von EDOMI kommen.
                        Wenn du im config des Mosquitto
                        log_type all
                        einfügst, dann siehst du auch die KOs.
                        Eigentlich sieht es ganz normal aus. Ggf. ist es tatsächlich ein Performance Problem.
                          Danke für deine Hilfe jonofe !
                          Den Publishserver benötige ich zum einarbeiten nicht.
                          Ich bin ganz paff was da für eine Tür aufgeht, echt Respekt für deine Arbeit
                          Zum Testen reichen die restlichen LBSen vollkommen.
                          Wenn das Projekt wächst werde ich mich dann mit dem Puplishserver beschäftigen und ggf die Hardware wechseln.
                          Schöne Grüße
                          Gernot
                            Hi Jonofe,
                            erstmal Danke für die tollen LBS. Habe den Publish-Client und den Publish-Server installiert. Der Publish-Client funktioniert einwandfrei, aber der Publish-Server gibt leider keinen Mucks von sich - Einstellungen sind exact dieselben wie beim Client. Ich nutze einen externen Mosquitto-Server. Ich habe die ganzen Dependencies aus der Client-Hilfe installiert - beim Server habe ich nichts mehr installiert, da das aus meiner Sicht die gleichen Dependencies wie beim Client sind - oder habe ich etwas übersehen?
                            VG,
                            Thomas
                            KNX-Neuling - wir werden unser neues Haus mit KNX bauen - den Baufortschritt inkl. KNX dokumentieren wir auf unserem Hausbaublog.
                              Hi zusammen,
                              hat sich erledigt - war offensichtlich irgendein user-conflict - habe einen weiteren User angelegt und jetzt funktioniert es.
                                Hi
                                kurze frage zum MQTT Publish server (0.3.2): ich habe mir mal meine logs angeschaut.
                                Es scheint als wenn der Publish-Server sekündlich connected - und disconnected.
                                1541107246: New client connected from 192.168.0.11 as EDOMI MQTT Publish Server (4733) (c1, k60, u'edomipublish').
                                1541107246: Client EDOMI MQTT Publish Server (4733) disconnected.
                                1541107246: New connection from 192.168.0.11 on port 1883.
                                (und das kommt sekündlich)
                                Ist das normal?
                                Thorsten
