Was kann da passiert sein? Bin auf CentOS6.5
Kann mir jemand einen Tipp geben, was ich machen kann.
[root@edomi tmp]# rpm -q centos-release centos-release-6-5.el6.centos.11.1.x86_64 [root@edomi tmp]#
[root@edomi tmp]# yum update nss
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
* base: mirror.inode.at
* extras: mirror.digitalnova.at
* updates: mirror.digitalnova.at
http://mirror.inode.at/data/centos/6.9/os/x86_64/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
Trying other mirror.
http://mirror.nextlayer.at/centos/6.9/os/x86_64/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://centos.mirroraustria.at/6.9/os/x86_64/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://ftp.tugraz.at/mirror/centos/6.9/os/x86_64/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://centos.schlundtech.de/6.9/os/x86_64/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://mirror.easyname.at/centos/6.9/os/x86_64/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://centosmirror.netcup.net/centos/6.9/os/x86_64/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://centos.mirror.iphh.net/CentOS/6.9/os/x86_64/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://ftp.plusline.de/centos/6.9/os/x86_64/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://gd.tuwien.ac.at/opsys/linux/centos/6.9/os/x86_64/repodata/repomd.xml: [Errno 14] PYCURL ERROR 6 - "Couldn't resolve host 'gd.tuwien.ac.at'"
Setting up Update Process
Resolving Dependencies
--> Running transaction check
---> Package nss.x86_64 0:3.15.1-15.el6 will be updated
--> Processing Dependency: nss = 3.15.1-15.el6 for package: nss-sysinit-3.15.1-15.el6.x86_64
--> Processing Dependency: nss(x86-64) = 3.15.1-15.el6 for package: nss-tools-3.15.1-15.el6.x86_64
---> Package nss.x86_64 0:3.36.0-9.el6_10 will be an update
--> Processing Dependency: nss-util >= 3.36.0 for package: nss-3.36.0-9.el6_10.x86_64
--> Processing Dependency: nss-softokn(x86-64) >= 3.14.3-22 for package: nss-3.36.0-9.el6_10.x86_64
--> Processing Dependency: nspr >= 4.19.0 for package: nss-3.36.0-9.el6_10.x86_64
--> Processing Dependency: libnssutil3.so(NSSUTIL_3.33)(64bit) for package: nss-3.36.0-9.el6_10.x86_64
--> Processing Dependency: libnssutil3.so(NSSUTIL_3.31)(64bit) for package: nss-3.36.0-9.el6_10.x86_64
--> Processing Dependency: libnssutil3.so(NSSUTIL_3.24)(64bit) for package: nss-3.36.0-9.el6_10.x86_64
--> Processing Dependency: libnssutil3.so(NSSUTIL_3.21)(64bit) for package: nss-3.36.0-9.el6_10.x86_64
--> Processing Dependency: libnssutil3.so(NSSUTIL_3.17.1)(64bit) for package: nss-3.36.0-9.el6_10.x86_64
---> Package nss-softokn.x86_64 0:3.14.3-9.el6 will be updated
---> Package nss-softokn.x86_64 0:3.14.3-23.3.el6_8 will be an update
--> Processing Dependency: nss-softokn-freebl(x86-64) >= 3.14.3-23.3.el6_8 for package: nss-softokn-3.14.3-23.3.el6_8.x86_64
--> Processing Dependency: nspr >= 4.10.6 for package: nss-softokn-3.14.3-23.3.el6_8.x86_64
---> Package nss-sysinit.x86_64 0:3.15.1-15.el6 will be updated
---> Package nss-sysinit.x86_64 0:3.36.0-9.el6_10 will be an update
---> Package nss-tools.x86_64 0:3.15.1-15.el6 will be updated
---> Package nss-tools.x86_64 0:3.36.0-9.el6_10 will be an update
---> Package nss-util.x86_64 0:3.15.1-3.el6 will be updated
---> Package nss-util.x86_64 0:3.27.1-3.el6 will be an update
---> Package nspr.x86_64 0:4.10.0-1.el6 will be updated
---> Package nspr.x86_64 0:4.13.1-1.el6 will be an update
---> Package nss-softokn-freebl.x86_64 0:3.14.3-9.el6 will be updated
---> Package nss-softokn-freebl.x86_64 0:3.14.3-23.3.el6_8 will be an update
--> Finished Dependency Resolution
Error: Package: nss-3.36.0-9.el6_10.x86_64 (updates)
Requires: nspr >= 4.19.0
Installed: nspr-4.10.0-1.el6.x86_64 (@anaconda-CentOS-201311272149.x86_64/6.5)
nspr = 4.10.0-1.el6
Available: nspr-4.13.1-1.el6.i686 (base)
nspr = 4.13.1-1.el6
Removing: nspr-4.10.0-1.el6.x86_64 (@anaconda-CentOS-201311272149.x86_64/6.5)
nspr = 4.10.0-1.el6
Updated By: nspr-4.13.1-1.el6.x86_64 (base)
nspr = 4.13.1-1.el6
Requires: libnssutil3.so(NSSUTIL_3.31)(64bit)
Requires: libnssutil3.so(NSSUTIL_3.33)(64bit)
Requires: nss-util >= 3.36.0
Removing: nss-util-3.15.1-3.el6.x86_64 (@anaconda-CentOS-201311272149.x86_64/6.5)
nss-util = 3.15.1-3.el6
Updated By: nss-util-3.27.1-3.el6.x86_64 (base)
nss-util = 3.27.1-3.el6
Installed: nss-util-3.15.1-3.el6.x86_64 (@anaconda-CentOS-201311272149.x86_64/6.5)
Available: nss-util-3.27.1-3.el6.i686 (base)
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
[root@edomi tmp]#
