LBS 19000707 - Beschattungssteuerung-Rollo
    was genau heisst denn "mit Wert lesen"? Und zudem wäre das Log nicht schlecht (aber bitte in Code-Tags)...
    Kind regards,
    Yves
      Hallo anbei ein Auszug des Logs - habe leider keinen wo das Rollo hätten schalten sollen . . . . (kann ich aber nachliefern sobald die Sonne dann mal scheint ;-))
      2019-08-30 09:44:0016265215306INFO:===2019-08-30 09:44:0016279615306INFO:===2019-08-30 09:45:0039304515306INFO:======================================================================================2019-08-30 09:45:0039339815306INFO:===== === = LBS was triggered (v0.6) = === ==========================================2019-08-30 09:45:0039354315306INFO:<Input>: <Refreshed>|<Value>2019-08-30 09:45:0039444415306INFO:Trigger: 0|1 Trigger changed output: 0|1 Brightness: 0|15390.72 Brightness dawn: 0|988.8 Elevation: 1|30.414522739284 Azimut: 1|117.87296640841 Lockstate: 0|0 Lockstate with position: 0|0 Internal timer: 02019-08-30 09:45:0039477415306INFO:===== === = Elevation refreshed, starting LBS = === ==================================2019-08-30 09:45:0039740315306INFO:===== === = LBS locked, disabling update of position outputs = === ===================2019-08-30 09:45:0039774315306INFO:===== === = Brightness, Elevation or Azimut changed = === ====================2019-08-30 09:45:0039823215306INFO:=== Validating input values... ===2019-08-30 09:45:0039856415306INFO:=== Finished validation of input values ===2019-08-30 09:45:0039893515306INFO:=== Checking if facade is in sun... ===2019-08-30 09:45:0039918715306INFO:Virtual depth and height of sun position in 90° to the facade: -0.92136890150077, 0.58703728308496, effective Elevation: -32.5026785316022019-08-30 09:45:0039973315306INFO:UpdateAlways == false, previous value of A1 equals new value 0, skipping update2019-08-30 09:45:0040183715306INFO:UpdateAlways == false, previous value of A8 equals new value 0, skipping update2019-08-30 09:45:0040219415306INFO:=== Finished facade check, real azimut 117.87296640841° and facade at 275° -> NOT IN SUN (shadow side, at sun from 215° to 335°), effective elevation -32.502678531602° for given elevation of 30.414522739284° -> NOT in min-max-range (0-90) ===2019-08-30 09:45:0040236315306INFO:Storing current shutter state 0 and updating output if necessary2019-08-30 09:45:0040409315306INFO:UpdateAlways == false, previous value of A7 equals new value 0, skipping update2019-08-30 09:45:0040439015306INFO:=== Calculating shutter state... ===2019-08-30 09:45:0040483915306INFO:Handling current shutter state NEUTRAL (0)2019-08-30 09:45:0040511115306INFO:positionShutter(...), Value for height: 0%2019-08-30 09:45:0040571815306INFO:LBS locked, not updating outputs2019-08-30 09:45:0040747915306INFO:Timer already finished2019-08-30 09:45:0041158115306INFO:positionShutter(...) for height 0% finished2019-08-30 09:45:0041189215306INFO:Storing current shutter state 0 and updating output if necessary2019-08-30 09:45:0041367415306INFO:UpdateAlways == false, previous value of A7 equals new value 0, skipping update2019-08-30 09:45:0041524915306INFO:===== === = LBS finished = === ===============================================2019-08-30 09:45:0041555315306INFO:===2019-08-30 09:45:0041568515306INFO:===2019-08-30 09:46:0025313515306INFO:======================================================================================2019-08-30 09:46:0025350815306INFO:===== === = LBS was triggered (v0.6) = === ==========================================2019-08-30 09:46:0025365915306INFO:<Input>: <Refreshed>|<Value>2019-08-30 09:46:0025455915306INFO:Trigger: 0|1 Trigger changed output: 0|1 Brightness: 0|15390.72 Brightness dawn: 0|988.8 Elevation: 1|30.548853323888 Azimut: 1|118.11338654729 Lockstate: 0|0 Lockstate with position: 0|0 Internal timer: 02019-08-30 09:46:0025622515306INFO:===== === = Elevation refreshed, starting LBS = === ==================================2019-08-30 09:46:0025745215306INFO:===== === = LBS locked, disabling update of position outputs = === ===================2019-08-30 09:46:0025784915306INFO:===== === = Brightness, Elevation or Azimut changed = === ====================2019-08-30 09:46:0025844715306INFO:=== Validating input values... ===2019-08-30 09:46:0025873915306INFO:=== Finished validation of input values ===2019-08-30 09:46:0025889115306INFO:=== Checking if facade is in sun... ===2019-08-30 09:46:0025914015306INFO:Virtual depth and height of sun position in 90° to the facade: -0.91972980683791, 0.59019409305227, effective Elevation: -32.6884427472362019-08-30 09:46:0026085515306INFO:UpdateAlways == false, previous value of A1 equals new value 0, skipping update2019-08-30 09:46:0026292315306INFO:UpdateAlways == false, previous value of A8 equals new value 0, skipping update2019-08-30 09:46:0026327815306INFO:=== Finished facade check, real azimut 118.11338654729° and facade at 275° -> NOT IN SUN (shadow side, at sun from 215° to 335°), effective elevation -32.688442747236° for given elevation of 30.548853323888° -> NOT in min-max-range (0-90) ===2019-08-30 09:46:0026344115306INFO:Storing current shutter state 0 and updating output if necessary2019-08-30 09:46:0026515615306INFO:UpdateAlways == false, previous value of A7 equals new value 0, skipping update2019-08-30 09:46:0026545315306INFO:=== Calculating shutter state... ===2019-08-30 09:46:0026589215306INFO:Handling current shutter state NEUTRAL (0)2019-08-30 09:46:0026622515306INFO:positionShutter(...), Value for height: 0%2019-08-30 09:46:0026681915306INFO:LBS locked, not updating outputs2019-08-30 09:46:0026955315306INFO:Timer already finished2019-08-30 09:46:0027284115306INFO:positionShutter(...) for height 0% finished2019-08-30 09:46:0027318415306INFO:Storing current shutter state 0 and updating output if necessary2019-08-30 09:46:0027490915306INFO:UpdateAlways == false, previous value of A7 equals new value 0, skipping update2019-08-30 09:46:0027650915306INFO:===== === = LBS finished = === ===============================================2019-08-30 09:46:0027681815306INFO:===2019-08-30 09:46:0027694815306INFO:===
      Mit den Werten lesen meine ich, wenn ich in der ETS über die GA (rechts klick) die Werte auslese je Aktor.
      VG
        ok, ich habe das Problem bei mir wahrscheinlich gefunden.
        Das Problem war, dass nach der Beschattung der Rollo nicht mehr hochfuhr und auch das Schließen bei Dämmerung nicht funktionierte. Erst die Sperre mit Zwangsposition fuhr den Rollo zu.
        Im Log habe ich festgestellt, dass um 9:45 das LBS deaktiviert wurde, weil sich die Rollohöhe manuell geändert haben soll. Es hat aber niemand daran rumgespielt...
        Wo kommen die Werte 42/58 her? Meldet da ggf. mein Rolladenaktor etwas Falsches?
        LBS disabled through external height change (85 vs 42/58)
        Ich habe jetzt vorerst E9 unbeschaltet gelassen.
         [TABLE="class: log, border: 0, cellpadding: 0, cellspacing: 0"]
         	 		[TR]
         			[TD]2019-08-31 09:45:06[/TD]
         			[TD]009792[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         			[TD]======================================================================================[/TD]
         		[/TR]
         		[TR]
         			[TD]010034[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         			[TD]===== === = LBS was triggered (v0.6) = === ==========================================[/TD]
         		[/TR]
         		[TR]
         			[TD]010160[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         			[TD]<Input>: <Refreshed>|<Value>[/TD]
         		[/TR]
         		[TR]
         			[TD]010469[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         			[TD]Trigger: 0| Trigger changed output: 0| Brightness: 0|25784.32 Brightness dawn: 0| Elevation: 0|28.742478894452 Azimut: 0|111.218147656 Lockstate: 0|0 Lockstate with position: 0|0 Internal timer: 0[/TD]
         		[/TR]
         		[TR]
         			[TD]010772[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         			[TD]===== === = Nothing refreshed, nothing to do = === ===================================[/TD]
         		[/TR]
         		[TR]
         			[TD]2019-08-31 09:45:09[/TD]
         			[TD]467999[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         		[/TR]
         		[TR]
         			[TD]468274[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         		[/TR]
         		[TR]
         			[TD]468401[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         		[/TR]
         		[TR]
         			[TD]468966[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         		[/TR]
         		[TR]
         			[TD]471904[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         			[TD]UpdateAlways == false, previous A5: 0, updating with 1[/TD]
         		[/TR]
         		[TR]
         			[TD]472614[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         			[TD]LBS disabled through external height change (85 vs 42/58)[/TD]
         		[/TR]
         		[TR]
         			[TD]473443[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         		[/TR]
         		[TR]
         			[TD]2019-08-31 09:46:05[/TD]
         			[TD]933881[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         		[/TR]
         		[TR]
         			[TD]934159[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         		[/TR]
         		[TR]
         			[TD]934288[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         		[/TR]
         		[TR]
         			[TD]934863[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         			[TD]Trigger: 0| Trigger changed output: 0| Brightness: 1|25784.32 Brightness dawn: 0| Elevation: 0|28.742478894452 Azimut: 0|111.218147656 Lockstate: 0|0 Lockstate with position: 0|0 Internal timer: 0[/TD]
         		[/TR]
         		[TR]
         			[TD]935156[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         			[TD]===== === = Brightness refreshed, starting LBS = === =================================[/TD]
         		[/TR]
         		[TR]
         			[TD]935647[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         			[TD]===== === = LBS locked, disabling update of position outputs = === ===================[/TD]
         		[/TR]
         		[TR]
         			[TD]935805[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         			[TD]===== === = Brightness, Elevation or Azimut changed = === ====================[/TD]
         		[/TR]
         		[TR]
         			[TD]936436[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         			[TD]=== Validating input values... ===[/TD]
         		[/TR]
         		[TR]
         			[TD]936714[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         			[TD]=== Finished validation of input values ===[/TD]
         		[/TR]
         		[TR]
         			[TD]936841[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         			[TD]=== Checking if facade is in sun... ===[/TD]
         		[/TR]
         		[TR]
         			[TD]937026[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         			[TD]Virtual depth and height of sun position in 90° to the facade: 0.19454504562596, 0.54844802147132, effective Elevation: 70.469426741776[/TD]
         		[/TR]
         		[TR]
         			[TD]937743[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         			[TD]UpdateAlways == false, previous value of A1 equals new value 1, skipping update[/TD]
         		[/TR]
         		[TR]
         			[TD]939038[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         			[TD]UpdateAlways == false, previous value of A8 equals new value 1, skipping update[/TD]
         		[/TR]
         		[TR]
         			[TD]939243[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         			[TD]=== Finished facade check, real azimut 111.218147656° and facade at 190° -> IN SUN (from 110° to 270°), effective elevation 70.469426741776° for given elevation of 28.742478894452° -> in min-max-range (0-90) ===[/TD]
         		[/TR]
         		[TR]
         			[TD]939379[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         			[TD]Storing current shutter state 5 and updating output if necessary[/TD]
         		[/TR]
         		[TR]
         			[TD]940607[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         			[TD]UpdateAlways == false, previous value of A7 equals new value 5, skipping update[/TD]
         		[/TR]
         		[TR]
         			[TD]940836[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         			[TD]=== Calculating shutter state... ===[/TD]
         		[/TR]
         		[TR]
         			[TD]941623[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         			[TD]Handling current shutter state SHADOW_FULL_CLOSED (5)[/TD]
         		[/TR]
         		[TR]
         			[TD]941844[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         			[TD]Facade is in sun[/TD]
         		[/TR]
         		[TR]
         			[TD]941981[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         			[TD]Recalculating shutter position out of state SHADOW_FULL_CLOSED[/TD]
         		[/TR]
         		[TR]
         			[TD]942171[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         			[TD]Elevation: 28.742478894452°, window height 2000, width of light strip 600, value of resulting shutter height greater than given max height, so using given max height 45[/TD]
         		[/TR]
         		[TR]
         			[TD]942313[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         			[TD]positionShutter(...), Value for height: 50%[/TD]
         		[/TR]
         		[TR]
         			[TD]942759[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         			[TD]LBS locked, not updating outputs[/TD]
         		[/TR]
         		[TR]
         			[TD]944273[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         			[TD]Timer already finished[/TD]
         		[/TR]
         		[TR]
         			[TD]945760[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         			[TD]positionShutter(...) for height 50% finished[/TD]
         		[/TR]
         		[TR]
         			[TD]945960[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         		[/TR]
         		[TR]
         			[TD]946959[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         		[/TR]
         		[TR]
         			[TD]947820[/TD]
         			[TD]11479[/TD]
         			[TD]INFO:[/TD]
         			[TD]===== === = LBS finished = === ===============================================[/TD]
         		[/TR]
         	 [/TABLE]
          Ok, nachdenken hilft
          Der Rollo stand auf 50%, die Toleranz ist mit 8% definiert. D.h. die Grenzen liegen bei 42% und 58%.
          Im Endeffekt muss nur der Eingangswert auf % umgerechnet werden. Das steht am Eingang E9 sogar bereits dran...
            Hi starwarsfan,
            ich bin gerade mit deinem 707 Baustein ein bisschen am rumspielen.
            Dabei ist mir in der Hilfe ein Fehler aufgefallen.
            Bei E27 steht was von E32 den es bei mir aber nicht gibt.
            E27: Lichtstreifen (mm)
            Breite eines gewuenschten Lichtstreifens. Legt fest, wie weit die Sonne in den Raum hinein scheinen soll und muss
            in der gleichen Einheit wie E32 angegeben werden. Beide Eingaenge also bspw. in mm oder cm. Default: 0
            Schöne güße
              Hi
              OK, danke. Ein Überbleibsel vom grossen Beschattungsbaustein...
              Kind regards,
              Yves
                ich habe ein aktuelles Problem mit dem Baustein.
                Die Verzögerung habe ich bei der Dämmerungssteuerung für einen Rollo relativ hoch eingestellt (14400s).
                Dies wird auch im Log übernommen (z.B. 16:56:08).
                Um 16:57:59 erscheint "=== Calculating shutter state... ===" und dann sofort "=== = LBS finished = ==="
                Im nächsten Lauf wird dann der Rollo auf 100% gestellt und somit deutlich zu früh.
                Was könnte da los sein?
                [Log entfernt]
                Danke & Gruß
                KNX2013
                Zuletzt geändert von KNX2013; 04.11.2019, 19:16.
                  Bitte das Log in dieser Grössenordnung als Anhang, mir friert der Browser auf dem Handy ein...
                  Kind regards,
                  Yves
                    Sorry, aber HTM geht nicht im Anhang und die Größe ist auf 19.5kB begrenzt, so dass auch .txt nicht geht... Keine Ahnung, wie ich den Log hochladen soll...
                      Hi
                      Wie wär's als Zip-Archiv?
                      Kind regards,
                      Yves
                        Ok... Jetzt ;-)
                          Das sieht in der Tat seltsam aus. Bitte noch Screenshots der kompletten Logik mit Live-Werten, am besten jeweils von vorher und nachher.
                          Kind regards,
                          Yves
                            So, hier jetzt die Logik und die Werte nach Einbruch der Dämmerung. Den Screenshot davor kann ich erst am Wochenende machen - es ist ja mittlerweile dunkel, wenn man zur Arbeit geht und heimkommt...
                            Vielleicht eine kleine Erklärung zur Logik.
                            Ich habe folgendes umgesetzt:
                            - 2 stufige Beschattung in Abhängigkeit von 2 Helligkeits-Schwellen
                            - Beschattung abhängig von Raumtemperatur
                            - Hochfahren des Rollos bei Öffnen des Fensters mittels Bauseinsperre
                            - 2-stufige Sperre mit Zwangsposition:
                            --> 100%-Stufe mit Zeitsteuerung (spätestens um 22 Uhr runter, frühestens um 6 Uhr hoch)
                            --> 35%-Anti-Neugier-Stufe (Unterhalb einer bestimmten Außenhelligkeit fährt der Rollo auf 35%, wenn das Licht im Raum eingeschaltet wird)
                            Ich werde jetzt parallel mal die einzelnen Logikteile abkoppeln, kann aber wie gesagt erst am Wochenende wieder sinnvoll testen.
                            Wenn Dir vorher eine mögliche Eingrenzung des Problems einfällt - immer her damit.
                            Vielen Dank schonmal.
                            KNX2013
                              Ich hätte noch die Frage, ob es möglich ist den Beschattungsbaustein schon ein zu setzen, obwohl noch nicht die Lichtwerte von den Fassaden verfügbar sind?
                              Hintergrund ist der das die Wetterstation erst mitte nächstes Jahr dran kommt, weil dann eh am Dach gearbeitet wird. Trotzdem würde ich gerne jetzt schon den Baustein nutzen, damit ich nicht nächstes Jahr schon wieder umbauen müsste.
                              Meine Idee wäre die Eingänge einfach mit einem sehr kleinen fest eingegebenen Lichtwert belegen, so hätte ich zwar noch nicht die Beschattung aber der Rest müsste doch dann schon gehen oder?
                                Hallo Yves,
                                bei meinem neuen Ansatz mit Deinem LBS haben sich ein paar Verbesserungsvorschläge/Wünsche ergeben, die ich jetzt noch mit zusätzlicher Logik "außenrum" löse aber vielleicht eine Bereicherung des LBS sein könnten. Ein paar Sachen möchte ich erst noch etwa besser testen, aber folgendes wäre vielleicht schon ein prima Fortschritt - wie ich finden - oder benutze ich den LBS vielleicht nur falsch?
                                • Zusätzliches Eingangs-Schalter "automatische Zurücknehmen der Sperre", denn das manuelle Entfernen der Sperre empfinde ich meist als unnötig.
                                • Funktion, wenn 1: Sperre automatisch wieder entfernen, wenn die SOLL-LBS-Pos (die ist dem LBS intern ja auch gesperrt bekannt) (wieder) gleich der aktuellen IST-Pos. ist.
                                • Hintergrund: Ich sehe zwei Hauptgründe für Sperren:
                                  • Manuelle Verfahren/Übersteuern (meist tagsüber bei Beschattung).
                                    -> Wenn man den Rollladen danach wieder z.B. ganz auf macht und später der LBS die Beschattung auch beendet hätte, sind SOLL = IST (mit Toleranz), die Sperre könnte automatisch gelöscht werden.
                                  • Manuelles Setzen der Sperre um das Verfahren abends (Dämmerung) zu unterdrücken, wenn man z.B. auf der Terrasse länger sitzen möchte.
                                    -> Wenn man dann beim zu Bett gehen den Rollladen manuell ganz zu macht, sind SOLL = IST (mit Toleranz), die Sperre könnte automatisch gelöscht werden.
                                und
                                • Offen gesagt finde ich A1 + A8 für eine Visu wenig hilfreich/theoretisch, weil sie auch auf 1 gehen, wenn die Sonne unter'm Horizont steht. Ich wünsche mir die Ausgabe von kombiniertem A1 + A8 und eben auch nur, wenn Elev>0. Zweck: In der Visu anzeigen, wann Sonnenposition beider Eingangsparameter tatsächlich im Beschattungssegment liegt. Vielleicht als A9 "Azi./Elev. Beschattungssegement (1/0)"
                                Danke für's drüber nachdenken...
                                VG,
                                Carsten
