was genau heisst denn "mit Wert lesen"? Und zudem wäre das Log nicht schlecht (aber bitte in Code-Tags)...
2019-08-30 09:44:0016265215306INFO:===2019-08-30 09:44:0016279615306INFO:===2019-08-30 09:45:0039304515306INFO:======================================================================================2019-08-30 09:45:0039339815306INFO:===== === = LBS was triggered (v0.6) = === ==========================================2019-08-30 09:45:0039354315306INFO:<Input>: <Refreshed>|<Value>2019-08-30 09:45:0039444415306INFO:Trigger: 0|1 Trigger changed output: 0|1 Brightness: 0|15390.72 Brightness dawn: 0|988.8 Elevation: 1|30.414522739284 Azimut: 1|117.87296640841 Lockstate: 0|0 Lockstate with position: 0|0 Internal timer: 02019-08-30 09:45:0039477415306INFO:===== === = Elevation refreshed, starting LBS = === ==================================2019-08-30 09:45:0039740315306INFO:===== === = LBS locked, disabling update of position outputs = === ===================2019-08-30 09:45:0039774315306INFO:===== === = Brightness, Elevation or Azimut changed = === ====================2019-08-30 09:45:0039823215306INFO:=== Validating input values... ===2019-08-30 09:45:0039856415306INFO:=== Finished validation of input values ===2019-08-30 09:45:0039893515306INFO:=== Checking if facade is in sun... ===2019-08-30 09:45:0039918715306INFO:Virtual depth and height of sun position in 90° to the facade: -0.92136890150077, 0.58703728308496, effective Elevation: -32.5026785316022019-08-30 09:45:0039973315306INFO:UpdateAlways == false, previous value of A1 equals new value 0, skipping update2019-08-30 09:45:0040183715306INFO:UpdateAlways == false, previous value of A8 equals new value 0, skipping update2019-08-30 09:45:0040219415306INFO:=== Finished facade check, real azimut 117.87296640841° and facade at 275° -> NOT IN SUN (shadow side, at sun from 215° to 335°), effective elevation -32.502678531602° for given elevation of 30.414522739284° -> NOT in min-max-range (0-90) ===2019-08-30 09:45:0040236315306INFO:Storing current shutter state 0 and updating output if necessary2019-08-30 09:45:0040409315306INFO:UpdateAlways == false, previous value of A7 equals new value 0, skipping update2019-08-30 09:45:0040439015306INFO:=== Calculating shutter state... ===2019-08-30 09:45:0040483915306INFO:Handling current shutter state NEUTRAL (0)2019-08-30 09:45:0040511115306INFO:positionShutter(...), Value for height: 0%2019-08-30 09:45:0040571815306INFO:LBS locked, not updating outputs2019-08-30 09:45:0040747915306INFO:Timer already finished2019-08-30 09:45:0041158115306INFO:positionShutter(...) for height 0% finished2019-08-30 09:45:0041189215306INFO:Storing current shutter state 0 and updating output if necessary2019-08-30 09:45:0041367415306INFO:UpdateAlways == false, previous value of A7 equals new value 0, skipping update2019-08-30 09:45:0041524915306INFO:===== === = LBS finished = === ===============================================2019-08-30 09:45:0041555315306INFO:===2019-08-30 09:45:0041568515306INFO:===2019-08-30 09:46:0025313515306INFO:======================================================================================2019-08-30 09:46:0025350815306INFO:===== === = LBS was triggered (v0.6) = === ==========================================2019-08-30 09:46:0025365915306INFO:<Input>: <Refreshed>|<Value>2019-08-30 09:46:0025455915306INFO:Trigger: 0|1 Trigger changed output: 0|1 Brightness: 0|15390.72 Brightness dawn: 0|988.8 Elevation: 1|30.548853323888 Azimut: 1|118.11338654729 Lockstate: 0|0 Lockstate with position: 0|0 Internal timer: 02019-08-30 09:46:0025622515306INFO:===== === = Elevation refreshed, starting LBS = === ==================================2019-08-30 09:46:0025745215306INFO:===== === = LBS locked, disabling update of position outputs = === ===================2019-08-30 09:46:0025784915306INFO:===== === = Brightness, Elevation or Azimut changed = === ====================2019-08-30 09:46:0025844715306INFO:=== Validating input values... ===2019-08-30 09:46:0025873915306INFO:=== Finished validation of input values ===2019-08-30 09:46:0025889115306INFO:=== Checking if facade is in sun... ===2019-08-30 09:46:0025914015306INFO:Virtual depth and height of sun position in 90° to the facade: -0.91972980683791, 0.59019409305227, effective Elevation: -32.6884427472362019-08-30 09:46:0026085515306INFO:UpdateAlways == false, previous value of A1 equals new value 0, skipping update2019-08-30 09:46:0026292315306INFO:UpdateAlways == false, previous value of A8 equals new value 0, skipping update2019-08-30 09:46:0026327815306INFO:=== Finished facade check, real azimut 118.11338654729° and facade at 275° -> NOT IN SUN (shadow side, at sun from 215° to 335°), effective elevation -32.688442747236° for given elevation of 30.548853323888° -> NOT in min-max-range (0-90) ===2019-08-30 09:46:0026344115306INFO:Storing current shutter state 0 and updating output if necessary2019-08-30 09:46:0026515615306INFO:UpdateAlways == false, previous value of A7 equals new value 0, skipping update2019-08-30 09:46:0026545315306INFO:=== Calculating shutter state... ===2019-08-30 09:46:0026589215306INFO:Handling current shutter state NEUTRAL (0)2019-08-30 09:46:0026622515306INFO:positionShutter(...), Value for height: 0%2019-08-30 09:46:0026681915306INFO:LBS locked, not updating outputs2019-08-30 09:46:0026955315306INFO:Timer already finished2019-08-30 09:46:0027284115306INFO:positionShutter(...) for height 0% finished2019-08-30 09:46:0027318415306INFO:Storing current shutter state 0 and updating output if necessary2019-08-30 09:46:0027490915306INFO:UpdateAlways == false, previous value of A7 equals new value 0, skipping update2019-08-30 09:46:0027650915306INFO:===== === = LBS finished = === ===============================================2019-08-30 09:46:0027681815306INFO:===2019-08-30 09:46:0027694815306INFO:===
LBS disabled through external height change (85 vs 42/58)
[TABLE="class: log, border: 0, cellpadding: 0, cellspacing: 0"] [TR] [TD]2019-08-31 09:45:06[/TD] [TD]009792[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]======================================================================================[/TD] [/TR] [TR] [TD]2019-08-31 09:45:06[/TD] [TD]010034[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]===== === = LBS was triggered (v0.6) = === ==========================================[/TD] [/TR] [TR] [TD]2019-08-31 09:45:06[/TD] [TD]010160[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]<Input>: <Refreshed>|<Value>[/TD] [/TR] [TR] [TD]2019-08-31 09:45:06[/TD] [TD]010469[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]Trigger: 0| Trigger changed output: 0| Brightness: 0|25784.32 Brightness dawn: 0| Elevation: 0|28.742478894452 Azimut: 0|111.218147656 Lockstate: 0|0 Lockstate with position: 0|0 Internal timer: 0[/TD] [/TR] [TR] [TD]2019-08-31 09:45:06[/TD] [TD]010772[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]===== === = Nothing refreshed, nothing to do = === ===================================[/TD] [/TR] [TR] [TD]2019-08-31 09:45:09[/TD] [TD]467999[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]======================================================================================[/TD] [/TR] [TR] [TD]2019-08-31 09:45:09[/TD] [TD]468274[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]===== === = LBS was triggered (v0.6) = === ==========================================[/TD] [/TR] [TR] [TD]2019-08-31 09:45:09[/TD] [TD]468401[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]<Input>: <Refreshed>|<Value>[/TD] [/TR] [TR] [TD]2019-08-31 09:45:09[/TD] [TD]468966[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]Trigger: 0| Trigger changed output: 0| Brightness: 0|25784.32 Brightness dawn: 0| Elevation: 0|28.742478894452 Azimut: 0|111.218147656 Lockstate: 0|0 Lockstate with position: 0|0 Internal timer: 0[/TD] [/TR] [TR] [TD]2019-08-31 09:45:09[/TD] [TD]471904[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]UpdateAlways == false, previous A5: 0, updating with 1[/TD] [/TR] [TR] [TD]2019-08-31 09:45:09[/TD] [TD]472614[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]LBS disabled through external height change (85 vs 42/58)[/TD] [/TR] [TR] [TD]2019-08-31 09:45:09[/TD] [TD]473443[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]===== === = Nothing refreshed, nothing to do = === ===================================[/TD] [/TR] [TR] [TD]2019-08-31 09:46:05[/TD] [TD]933881[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]======================================================================================[/TD] [/TR] [TR] [TD]2019-08-31 09:46:05[/TD] [TD]934159[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]===== === = LBS was triggered (v0.6) = === ==========================================[/TD] [/TR] [TR] [TD]2019-08-31 09:46:05[/TD] [TD]934288[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]<Input>: <Refreshed>|<Value>[/TD] [/TR] [TR] [TD]2019-08-31 09:46:05[/TD] [TD]934863[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]Trigger: 0| Trigger changed output: 0| Brightness: 1|25784.32 Brightness dawn: 0| Elevation: 0|28.742478894452 Azimut: 0|111.218147656 Lockstate: 0|0 Lockstate with position: 0|0 Internal timer: 0[/TD] [/TR] [TR] [TD]2019-08-31 09:46:05[/TD] [TD]935156[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]===== === = Brightness refreshed, starting LBS = === =================================[/TD] [/TR] [TR] [TD]2019-08-31 09:46:05[/TD] [TD]935647[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]===== === = LBS locked, disabling update of position outputs = === ===================[/TD] [/TR] [TR] [TD]2019-08-31 09:46:05[/TD] [TD]935805[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]===== === = Brightness, Elevation or Azimut changed = === ====================[/TD] [/TR] [TR] [TD]2019-08-31 09:46:05[/TD] [TD]936436[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]=== Validating input values... ===[/TD] [/TR] [TR] [TD]2019-08-31 09:46:05[/TD] [TD]936714[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]=== Finished validation of input values ===[/TD] [/TR] [TR] [TD]2019-08-31 09:46:05[/TD] [TD]936841[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]=== Checking if facade is in sun... ===[/TD] [/TR] [TR] [TD]2019-08-31 09:46:05[/TD] [TD]937026[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]Virtual depth and height of sun position in 90° to the facade: 0.19454504562596, 0.54844802147132, effective Elevation: 70.469426741776[/TD] [/TR] [TR] [TD]2019-08-31 09:46:05[/TD] [TD]937743[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]UpdateAlways == false, previous value of A1 equals new value 1, skipping update[/TD] [/TR] [TR] [TD]2019-08-31 09:46:05[/TD] [TD]939038[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]UpdateAlways == false, previous value of A8 equals new value 1, skipping update[/TD] [/TR] [TR] [TD]2019-08-31 09:46:05[/TD] [TD]939243[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]=== Finished facade check, real azimut 111.218147656° and facade at 190° -> IN SUN (from 110° to 270°), effective elevation 70.469426741776° for given elevation of 28.742478894452° -> in min-max-range (0-90) ===[/TD] [/TR] [TR] [TD]2019-08-31 09:46:05[/TD] [TD]939379[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state 5 and updating output if necessary[/TD] [/TR] [TR] [TD]2019-08-31 09:46:05[/TD] [TD]940607[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]UpdateAlways == false, previous value of A7 equals new value 5, skipping update[/TD] [/TR] [TR] [TD]2019-08-31 09:46:05[/TD] [TD]940836[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]=== Calculating shutter state... ===[/TD] [/TR] [TR] [TD]2019-08-31 09:46:05[/TD] [TD]941623[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]Handling current shutter state SHADOW_FULL_CLOSED (5)[/TD] [/TR] [TR] [TD]2019-08-31 09:46:05[/TD] [TD]941844[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]Facade is in sun[/TD] [/TR] [TR] [TD]2019-08-31 09:46:05[/TD] [TD]941981[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]Recalculating shutter position out of state SHADOW_FULL_CLOSED[/TD] [/TR] [TR] [TD]2019-08-31 09:46:05[/TD] [TD]942171[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]Elevation: 28.742478894452°, window height 2000, width of light strip 600, value of resulting shutter height greater than given max height, so using given max height 45[/TD] [/TR] [TR] [TD]2019-08-31 09:46:05[/TD] [TD]942313[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]positionShutter(...), Value for height: 50%[/TD] [/TR] [TR] [TD]2019-08-31 09:46:05[/TD] [TD]942759[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]LBS locked, not updating outputs[/TD] [/TR] [TR] [TD]2019-08-31 09:46:05[/TD] [TD]944273[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]Timer already finished[/TD] [/TR] [TR] [TD]2019-08-31 09:46:05[/TD] [TD]945760[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]positionShutter(...) for height 50% finished[/TD] [/TR] [TR] [TD]2019-08-31 09:46:05[/TD] [TD]945960[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state 5 and updating output if necessary[/TD] [/TR] [TR] [TD]2019-08-31 09:46:05[/TD] [TD]946959[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]UpdateAlways == false, previous value of A7 equals new value 5, skipping update[/TD] [/TR] [TR] [TD]2019-08-31 09:46:05[/TD] [TD]947820[/TD] [TD]11479[/TD] [TD]INFO:[/TD] [TD]===== === = LBS finished = === ===============================================[/TD] [/TR] [/TABLE]
