Downgrade war es zwar nicht, aber es hat geholfen
[root@edomi php-telegram-bot]# composer install Your version of PHP, 5.3.3, is affected by CVE-2013-6420 and cannot safely perform certificate validation, we strongly suggest you upgrade. Do not run Composer as root/super user! See https://getcomposer.org/root for details Loading composer repositories with package information Installing dependencies (including require-dev) from lock file Warning: The lock file is not up to date with the latest changes in composer.json. You may be getting outdated dependencies. It is recommended that you run `composer update` or `composer update <package name>`. Your requirements could not be resolved to an installable set of packages. Problem 1 - This package requires php ^5.5|^7.0 but your PHP version (5.3.3) does not satisfy that requirement. Problem 2 - Installation request for guzzlehttp/guzzle 6.3.3 -> satisfiable by guzzlehttp/guzzle[6.3.3]. - guzzlehttp/guzzle 6.3.3 requires php >=5.5 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 3 - Installation request for guzzlehttp/promises v1.3.1 -> satisfiable by guzzlehttp/promises[v1.3.1]. - guzzlehttp/promises v1.3.1 requires php >=5.5.0 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 4 - Installation request for guzzlehttp/psr7 1.6.1 -> satisfiable by guzzlehttp/psr7[1.6.1]. - guzzlehttp/psr7 1.6.1 requires php >=5.4.0 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 5 - Installation request for ralouphie/getallheaders 3.0.3 -> satisfiable by ralouphie/getallheaders[3.0.3]. - ralouphie/getallheaders 3.0.3 requires php >=5.6 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 6 - Installation request for dms/phpunit-arraysubset-asserts v0.1.0 -> satisfiable by dms/phpunit-arraysubset-asserts[v0.1.0]. - dms/phpunit-arraysubset-asserts v0.1.0 requires php ^7.2 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 7 - Installation request for doctrine/instantiator 1.2.0 -> satisfiable by doctrine/instantiator[1.2.0]. - doctrine/instantiator 1.2.0 requires php ^7.1 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 8 - Installation request for monolog/monolog 2.0.0 -> satisfiable by monolog/monolog[2.0.0]. - monolog/monolog 2.0.0 requires php ^7.2 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 9 - Installation request for myclabs/deep-copy 1.9.3 -> satisfiable by myclabs/deep-copy[1.9.3]. - myclabs/deep-copy 1.9.3 requires php ^7.1 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 10 - Installation request for phar-io/manifest 1.0.3 -> satisfiable by phar-io/manifest[1.0.3]. - phar-io/manifest 1.0.3 requires php ^5.6 || ^7.0 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 11 - Installation request for phar-io/version 2.0.1 -> satisfiable by phar-io/version[2.0.1]. - phar-io/version 2.0.1 requires php ^5.6 || ^7.0 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 12 - Installation request for phpdocumentor/reflection-common 2.0.0 -> satisfiable by phpdocumentor/reflection-common[2.0.0]. - phpdocumentor/reflection-common 2.0.0 requires php >=7.1 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 13 - Installation request for phpdocumentor/reflection-docblock 4.3.2 -> satisfiable by phpdocumentor/reflection-docblock[4.3.2]. - phpdocumentor/reflection-docblock 4.3.2 requires php ^7.0 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 14 - Installation request for phpdocumentor/type-resolver 1.0.1 -> satisfiable by phpdocumentor/type-resolver[1.0.1]. - phpdocumentor/type-resolver 1.0.1 requires php ^7.1 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 15 - Installation request for phpunit/php-code-coverage 7.0.8 -> satisfiable by phpunit/php-code-coverage[7.0.8]. - phpunit/php-code-coverage 7.0.8 requires php ^7.2 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 16 - Installation request for phpunit/php-file-iterator 2.0.2 -> satisfiable by phpunit/php-file-iterator[2.0.2]. - phpunit/php-file-iterator 2.0.2 requires php ^7.1 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 17 - Installation request for phpunit/php-timer 2.1.2 -> satisfiable by phpunit/php-timer[2.1.2]. - phpunit/php-timer 2.1.2 requires php ^7.1 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 18 - Installation request for phpunit/php-token-stream 3.1.1 -> satisfiable by phpunit/php-token-stream[3.1.1]. - phpunit/php-token-stream 3.1.1 requires php ^7.1 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 19 - Installation request for phpunit/phpunit 8.4.1 -> satisfiable by phpunit/phpunit[8.4.1]. - phpunit/phpunit 8.4.1 requires php ^7.2 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 20 - Installation request for sebastian/code-unit-reverse-lookup 1.0.1 -> satisfiable by sebastian/code-unit-reverse-lookup[1.0.1]. - sebastian/code-unit-reverse-lookup 1.0.1 requires php ^5.6 || ^7.0 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 21 - Installation request for sebastian/comparator 3.0.2 -> satisfiable by sebastian/comparator[3.0.2]. - sebastian/comparator 3.0.2 requires php ^7.1 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 22 - Installation request for sebastian/diff 3.0.2 -> satisfiable by sebastian/diff[3.0.2]. - sebastian/diff 3.0.2 requires php ^7.1 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 23 - Installation request for sebastian/environment 4.2.2 -> satisfiable by sebastian/environment[4.2.2]. - sebastian/environment 4.2.2 requires php ^7.1 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 24 - Installation request for sebastian/exporter 3.1.2 -> satisfiable by sebastian/exporter[3.1.2]. - sebastian/exporter 3.1.2 requires php ^7.0 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 25 - Installation request for sebastian/global-state 3.0.0 -> satisfiable by sebastian/global-state[3.0.0]. - sebastian/global-state 3.0.0 requires php ^7.2 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 26 - Installation request for sebastian/object-enumerator 3.0.3 -> satisfiable by sebastian/object-enumerator[3.0.3]. - sebastian/object-enumerator 3.0.3 requires php ^7.0 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 27 - Installation request for sebastian/object-reflector 1.1.1 -> satisfiable by sebastian/object-reflector[1.1.1]. - sebastian/object-reflector 1.1.1 requires php ^7.0 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 28 - Installation request for sebastian/recursion-context 3.0.0 -> satisfiable by sebastian/recursion-context[3.0.0]. - sebastian/recursion-context 3.0.0 requires php ^7.0 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 29 - Installation request for sebastian/resource-operations 2.0.1 -> satisfiable by sebastian/resource-operations[2.0.1]. - sebastian/resource-operations 2.0.1 requires php ^7.1 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 30 - Installation request for sebastian/type 1.1.3 -> satisfiable by sebastian/type[1.1.3]. - sebastian/type 1.1.3 requires php ^7.2 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 31 - Installation request for sebastian/version 2.0.1 -> satisfiable by sebastian/version[2.0.1]. - sebastian/version 2.0.1 requires php >=5.6 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 32 - Installation request for squizlabs/php_codesniffer 3.5.1 -> satisfiable by squizlabs/php_codesniffer[3.5.1]. - squizlabs/php_codesniffer 3.5.1 requires php >=5.4.0 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 33 - Installation request for theseer/tokenizer 1.1.3 -> satisfiable by theseer/tokenizer[1.1.3]. - theseer/tokenizer 1.1.3 requires php ^7.0 -> your PHP version (5.3.3) does not satisfy that requirement. Problem 34 - doctrine/instantiator 1.2.0 requires php ^7.1 -> your PHP version (5.3.3) does not satisfy that requirement. - phpspec/prophecy 1.9.0 requires doctrine/instantiator ^1.0.2 -> satisfiable by doctrine/instantiator[1.2.0]. - Installation request for phpspec/prophecy 1.9.0 -> satisfiable by phpspec/prophecy[1.9.0]. [root@edomi php-telegram-bot]# composer update Your version of PHP, 5.3.3, is affected by CVE-2013-6420 and cannot safely perform certificate validation, we strongly suggest you upgrade. Do not run Composer as root/super user! See https://getcomposer.org/root for details Loading composer repositories with package information Updating dependencies (including require-dev) Your requirements could not be resolved to an installable set of packages. Problem 1 - This package requires php ^5.5|^7.0 but your PHP version (5.3.3) does not satisfy that requirement. Problem 2 - guzzlehttp/guzzle 6.5.2 requires php >=5.5 -> your PHP version (5.3.3) does not satisfy that requirement. - guzzlehttp/guzzle 6.5.1 requires php >=5.5 -> your PHP version (5.3.3) does not satisfy that requirement. - guzzlehttp/guzzle 6.5.0 requires php >=5.5 -> your PHP version (5.3.3) does not satisfy that requirement. - guzzlehttp/guzzle 6.4.1 requires php >=5.5 -> your PHP version (5.3.3) does not satisfy that requirement. - guzzlehttp/guzzle 6.4.0 requires php >=5.5 -> your PHP version (5.3.3) does not satisfy that requirement. - guzzlehttp/guzzle 6.3.3 requires php >=5.5 -> your PHP version (5.3.3) does not satisfy that requirement. - guzzlehttp/guzzle 6.3.2 requires php >=5.5 -> your PHP version (5.3.3) does not satisfy that requirement. - guzzlehttp/guzzle 6.3.1 requires php >=5.5 -> your PHP version (5.3.3) does not satisfy that requirement. - guzzlehttp/guzzle 6.3.0 requires php >=5.5 -> your PHP version (5.3.3) does not satisfy that requirement. - Installation request for guzzlehttp/guzzle ^6.3 -> satisfiable by guzzlehttp/guzzle[6.3.0, 6.3.1, 6.3.2, 6.3.3, 6.4.0, 6.4.1, 6.5.0, 6.5.1, 6.5.2].
| 2020-04-19 11:36:01 | 236783 | 14321 | debug | LBS19000303 [v0.8.3]: ================ ARRAY/OBJECT START ================ |
| 2020-04-19 11:36:01 | 237097 | 14321 | debug | LBS19000303 [v0.8.3]: {"text":"Fenster OG geschlossen"} |
| 2020-04-19 11:36:01 | 237289 | 14321 | debug | LBS19000303 [v0.8.3]: ================ ARRAY/OBJECT END ================ |
| 2020-04-19 11:37:05 | 841671 | 14383 | debug | EXE19000303 [v0.8.3]: Telegram text message sent: Fenster OG geschlossen (xxxxxxxxxx) (943) |
| 2020-04-19 11:37:05 | 844940 | 14383 | debug | EXE19000303 [v0.8.3]: Telegram message execution finished (943) |
