Taucht was im Log auf (LogLevel dazu erhoehen)? Gibts irgendwelche Dateien im /tmp Verzeichnis die mit EDOMI_LBS190003 anfangen?
Weather Underground Bausteine
Log sagt folgendes:
0 (ID436) Emergency: Keine Daten empfangen, Abbruch
Loglevel habe ich auf 10 gestellt.
Was mich wundert ist, warum der Status auf "inaktiv" steht.
Ich habe zwei Key bereits ausprobiert und auch Key gewechselt.
Der Testabruf über den Link von WU funktioniert mit "San Francisco"
{ "response": { "version": "0.1", "termsofService": "http://www.wunderground.com/weather/api/d/terms.html", "features": { "conditions": 1 } }, "current_observation": { "image": { "url": "http://icons-ak.wxug.com/graphics/wu2/logo_130x80.png", "title": "Weather Underground", "link": "http://www.wunderground.com" }, "display_location": { "full": "San Francisco, CA", "city": "San Francisco", "state": "CA", "state_name": "California", "country": "US", "country_iso3166": "US", "zip": "94101", "latitude": "37.77500916", "longitude": "-122.41825867", "elevation": "47.00000000" }, "observation_location": { "full": "SOMA - Near Van Ness, San Francisco, California", "city": "SOMA - Near Van Ness, San Francisco", "state": "California", "country": "US", "country_iso3166": "US", "latitude": "37.773285", "longitude": "-122.417725", "elevation": "49 ft" }, "estimated": {}, "station_id": "KCASANFR58", "observation_time": "Last Updated on June 27, 5:27 PM PDT", "observation_time_rfc822": "Wed, 27 Jun 2012 17:27:13 -0700", "observation_epoch": "1340843233", "local_time_rfc822": "Wed, 27 Jun 2012 17:27:14 -0700", "local_epoch": "1340843234", "local_tz_short": "PDT", "local_tz_long": "America/Los_Angeles", "local_tz_offset": "-0700", "weather": "Partly Cloudy", "temperature_string": "66.3 F (19.1 C)", "temp_f": 66.3, "temp_c": 19.1, "relative_humidity": "65%", "wind_string": "From the NNW at 22.0 MPH Gusting to 28.0 MPH", "wind_dir": "NNW", "wind_degrees": 346, "wind_mph": 22.0, "wind_gust_mph": "28.0", "wind_kph": 35.4, "wind_gust_kph": "45.1", "pressure_mb": "1013", "pressure_in": "29.93", "pressure_trend": "+", "dewpoint_string": "54 F (12 C)", "dewpoint_f": 54, "dewpoint_c": 12, "heat_index_string": "NA", "heat_index_f": "NA", "heat_index_c": "NA", "windchill_string": "NA", "windchill_f": "NA", "windchill_c": "NA", "feelslike_string": "66.3 F (19.1 C)", "feelslike_f": "66.3", "feelslike_c": "19.1", "visibility_mi": "10.0", "visibility_km": "16.1", "solarradiation": "", "UV": "5", "precip_1hr_string": "0.00 in ( 0 mm)", "precip_1hr_in": "0.00", "precip_1hr_metric": " 0", "precip_today_string": "0.00 in (0 mm)", "precip_today_in": "0.00", "precip_today_metric": "0", "icon": "partlycloudy", "icon_url": "http://icons-ak.wxug.com/i/c/k/partlycloudy.gif", "forecast_url": "http://www.wunderground.com/US/CA/San_Francisco.html", "history_url": "http://www.wunderground.com/history/airport/KCASANFR58/2012/6/27/DailyHistory.html", "ob_url": "http://www.wunderground.com/cgi-bin/findweather/getForecast?query=37.773285,-122.417725" } }
Habe mal beide Bausteine ausprobiert.
19000322
19000323
hmm, wenn DNS funktioniert, dann sieht die Welt ganz anders aus.... Warum auch immer ich einen alten DNS Server drinnen hatte ^^ und plötzlich kommen Daten an. Was mich jedoch wundert ist, warum mein Baustein mit dem Sonnenaufgang und Untergang funktioniert. Eventuell direkte IP hinterlegt...
Ich bräuchte mal einen guten Tipp zum LBS 19000324.
Ich bekomme leider überhaupt keine Ausgaben an den Ausgängen. Auch habe ich kein Logfile oder irgendwelche Eintragungen in einem Logfile gefunden.
Da der Download vom Modul bei mir nicht funktioniert hatte, habe ich alles kopiert, einen eigenen LBS erstellt und alles eingefügt. Kann es hieran liegen?
Folgendes habe ich schon probiert:
- ping google.de hatte unaufhörlich Ergebnisse produziert, d.h. DNS und Internetzugang sollte funktionieren
- E1: Triggerbaustein oder manuelles Triggern
- E2: wget http://.../San_Francisco.json bringt folgendes Ergebnis: San_Francisco.json gespeichert, d.h. API Key sollte auch funktionieren
- E3,4,5,6: Ich habe es sowohl mit einer PWS, als auch mit Land/Stadt und jetzt Länge/ Breite probiert
- E7: leer und mit 1
- E11: leer und alle möglichen Werte
Hat noch einer eine Idee woran es liegen könnte?
Hänge doch mal den Inhalt des von Dir verwendeten LBS hier an!Zitat von Aktor Beitrag anzeigenHat noch einer eine Idee woran es liegen könnte?Kind regards,
Yves
Nach der Hilfe dachte ich das 6 das Debug log sein sollte. Jetzt habe ich aber gesehen, dass die 6 zweimal aufgeführt ist. Wahrscheinlich handelt es sich hier um einen Copy/Paste-Fehler in der Hilfe. 7 hat aber leider auch keine Ergebnisse gebracht. Projekt war aktiviert.
Wie hänge ich den Inhalt denn am besten an, dass es hier nicht alles sprengt? Hatte es als txt-Datei versucht. Sind aber wohl zu viele Zeichen.
Bevor du den Inhalt postest kannst auch Mal das pruefen
https://knx-user-forum.de/forum/proj...294#post949294
passiert bei copy & paste
@Simone: Super, das war's. Vielen, vielen Dank. Ich habe den Fehler mal wieder viel zu kompliziert gesucht. Am Ende liegt's an einem einfachen Copy&Paste. Ich habe aber gesehen, dass wenn man sich das Modul anzeigen lässt, das <? da schon direkt fehlt.
P.S.: Der Download hatte bei mir anscheinend doch funktioniert. Es wurde nur nie angezeigt dass etwas downgeloaded wurde. Habe mal die Festplatte durchsuchen lassen und da lag dann tatsächlich das zip-file rum.
Ich habe mich nun auch mal hier dran gewagt.
Es kommen an allen Ausgangsboxen Werte bisher an.
Allerdings wird nicht jedes KO mit Werten versorgt.
Temperatur minimum z.B. geht (KO371)
Temperatur maximum kommen keine Werte (KO 372)
Ist aber sonst alles gleich angelegt. Jemand ne Erklärung?
