Kauf dir halt noch ne IP-Schnittstelle
| 2016-04-07 17:53:58 | 696602 | MAIN | 2230 | START | Ok |
| 2016-04-07 17:53:58 | 809006 | EXEC | 2278 | Logs/Archive/Autobackups aufräumen | Ok |
| 2016-04-07 17:54:03 | 111778 | KNX | 2270 | ROUTER @ DE | TUNNELING_REQUEST / ErrMsg: Unbekannter Fehler / Raw: 06100420001f04010000290a06047d2b37eb80024158bce010 331d0c010080 | ERROR |
| 2016-04-07 17:54:04 | 120085 | KNX | 2270 | ROUTER @ DE | TUNNELING_REQUEST / ErrMsg: Unbekannter Fehler / Raw: 06100420001f04010000290a06047d2b37eb80024158bce010 331d0c010080 | ERROR |
| 2016-04-07 17:54:05 | 114836 | KNX | 2270 | ROUTER @ CE | DISCONNECT_REQUEST / Raw: 06100209001001000801c0a800760e57 | ERROR |
| 2016-04-07 17:54:05 | 125648 | KNX | 2270 | KNX-Verbindung verloren. | ERROR |
| 2016-04-07 17:54:05 | 125915 | KNX | 2270 | KNX-Verbindung verloren. | ERROR |
| 2016-04-07 17:54:08 | 166699 | KNX | 2270 | Tunnel-PA: 1.0.250 / Channel-ID: 1 | Ok |
| 2016-04-07 17:54:09 | 160799 | KNX | 2270 | ROUTER @ DE | TUNNELING_REQUEST / ErrMsg: Unbekannter Fehler / Raw: 06100420001f04010000290a06047db55ce18002416abce010 331d0e010080 | ERROR |
| 2016-04-07 17:54:10 | 147245 | KNX | 2270 | ROUTER @ DE | TUNNELING_REQUEST / ErrMsg: Unbekannter Fehler / Raw: 06100420001f04010000290a06047db55ce18002416abce010 331d0e010080 | ERROR |
| 2016-04-07 17:54:11 | 156734 | KNX | 2270 | ROUTER @ CE | DISCONNECT_REQUEST / Raw: 06100209001001000801c0a800760e57 | ERROR |
| 2016-04-07 17:54:11 | 169294 | KNX | 2270 | KNX-Verbindung verloren. | ERROR |
| 2016-04-07 17:54:11 | 169624 | KNX | 2270 | KNX-Verbindung verloren. | ERROR |
| 2016-04-07 17:54:14 | 207678 | KNX | 2270 | Tunnel-PA: 1.0.250 / Channel-ID: 1 | Ok |
| 2016-04-07 17:54:15 | 904560 | KNX | 2270 | ROUTER @ DE | TUNNELING_REQUEST / ErrMsg: Unbekannter Fehler / Raw: 06100420002004010000290a06047e50014b80024172bce010 04200c02008000 | ERROR |
| 2016-04-07 17:54:16 | 904596 | KNX | 2270 | ROUTER @ DE | TUNNELING_REQUEST / ErrMsg: Unbekannter Fehler / Raw: 06100420002004010000290a06047e50014b80024172bce010 04200c02008000 | ERROR |
| 2016-04-07 17:54:17 | 910808 | KNX | 2270 | ROUTER @ CE | DISCONNECT_REQUEST / Raw: 06100209001001000801c0a800760e57 | ERROR |
| 2016-04-07 17:54:17 | 921659 | KNX | 2270 | KNX-Verbindung verloren. | ERROR |
| 2016-04-07 17:54:17 | 921930 | KNX | 2270 | KNX-Verbindung verloren. | ERROR |
| 2016-04-07 17:54:20 | 955672 | KNX | 2270 | Tunnel-PA: 1.0.250 / Channel-ID: 1 | Ok |
| 2016-04-07 17:54:25 | 002815 | KNX | 2270 | ROUTER @ DE | TUNNELING_REQUEST / ErrMsg: Unbekannter Fehler / Raw: 06100420001f04010000290a06047f20529780024188bce010 331d11010080 | ERROR |
| 2016-04-07 17:54:26 | 011245 | KNX | 2270 | ROUTER @ DE | TUNNELING_REQUEST / ErrMsg: Unbekannter Fehler / Raw: 06100420001f04010000290a06047f20529780024188bce010 331d11010080 | ERROR |
| 2016-04-07 17:54:27 | 009646 | KNX | 2270 | ROUTER @ CE | DISCONNECT_REQUEST / Raw: 06100209001001000801c0a800760e57 | ERROR |
| 2016-04-07 17:54:27 | 020688 | KNX | 2270 | KNX-Verbindung verloren. | ERROR |
| 2016-04-07 17:54:27 | 021033 | KNX | 2270 | KNX-Verbindung verloren. |
Am Router sehe ich, dass ein Tunnel aufgemacht wird...
