[TABLE="border: 0, cellpadding: 0, cellspacing: 0"] [TR] [TD]2017-05-21 12:38:31[/TD] [TD]977293[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = Brightness, Elevation or Azimut changed and LBS is active, starting it = === ======[/TD] [/TR] [TR] [TD]2017-05-21 12:38:31[/TD] [TD]977499[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = LBS was triggered = === ==========================================[/TD] [/TR] [TR] [TD]2017-05-21 12:38:31[/TD] [TD]977552[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]<Input>: <Refreshed>|<Value>[/TD] [/TR] [TR] [TD]2017-05-21 12:38:31[/TD] [TD]977747[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Trigger: 0| Trigger changed output: 0| Brightness: 1|111411.2 Brightness dawn: 1|111411.2 Elevation: 0|60.68380355835 Azimut: 0|156.67051696777 Activationstate: 0|1 Lockstate: 0|0 Internal timer: 1[/TD] [/TR] [TR] [TD]2017-05-21 12:38:31[/TD] [TD]978033[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Virtual depth and height of sun position in 90� to the facade: 0.9473751320793, 1.7807993148547, effective Elevation: 61.987275939497[/TD] [/TR] [TR] [TD]2017-05-21 12:38:31[/TD] [TD]978315[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Real azimut 156.67051696777� and facade at 138� -> IN SUN (from 48� to 228�), effective elevation 61.987275939497� for given elevation of 60.68380355835� -> in min-max-range (0-90)[/TD] [/TR] [TR] [TD]2017-05-21 12:38:31[/TD] [TD]978385[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state -1 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:38:31[/TD] [TD]979445[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Handling current shutter state DAWN_NEUTRAL (-1)[/TD] [/TR] [TR] [TD]2017-05-21 12:38:31[/TD] [TD]979531[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Facade is in sun[/TD] [/TR] [TR] [TD]2017-05-21 12:38:31[/TD] [TD]979585[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Switching from DAWN_NEUTRAL to SHADOW_FULL_CLOSE_TIMER_RUNNING[/TD] [/TR] [TR] [TD]2017-05-21 12:38:31[/TD] [TD]979634[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Starting new timer for 150 seconds up to 12:41:01[/TD] [/TR] [TR] [TD]2017-05-21 12:38:31[/TD] [TD]980226[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state 6 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:38:31[/TD] [TD]981018[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Shutter state has changed from -1 to 6, checking if there might be another change...[/TD] [/TR] [TR] [TD]2017-05-21 12:38:31[/TD] [TD]981278[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Handling current shutter state SHADOW_FULL_CLOSE_TIMER_RUNNING (6)[/TD] [/TR] [TR] [TD]2017-05-21 12:38:31[/TD] [TD]981343[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Facade is in sun[/TD] [/TR] [TR] [TD]2017-05-21 12:38:31[/TD] [TD]981729[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Updating outputs out of SHADOW_FULL_CLOSE_TIMER_RUNNING if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:38:31[/TD] [TD]982892[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Shutter angle 0% = 0�[/TD] [/TR] [TR] [TD]2017-05-21 12:38:31[/TD] [TD]983689[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state 6 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:38:31[/TD] [TD]984134[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = LBS finished = === ===============================================[/TD] [/TR] [TR] [TD]2017-05-21 12:39:31[/TD] [TD]910594[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = Brightness, Elevation or Azimut changed and LBS is active, starting it = === ======[/TD] [/TR] [TR] [TD]2017-05-21 12:39:31[/TD] [TD]910700[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = LBS was triggered = === ==========================================[/TD] [/TR] [TR] [TD]2017-05-21 12:39:31[/TD] [TD]910758[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]<Input>: <Refreshed>|<Value>[/TD] [/TR] [TR] [TD]2017-05-21 12:39:31[/TD] [TD]910953[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Trigger: 0| Trigger changed output: 0| Brightness: 1|111329.28 Brightness dawn: 1|111329.28 Elevation: 0|60.68380355835 Azimut: 0|156.67051696777 Activationstate: 0|1 Lockstate: 0|0 Internal timer: 1[/TD] [/TR] [TR] [TD]2017-05-21 12:39:31[/TD] [TD]911235[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Virtual depth and height of sun position in 90� to the facade: 0.9473751320793, 1.7807993148547, effective Elevation: 61.987275939497[/TD] [/TR] [TR] [TD]2017-05-21 12:39:31[/TD] [TD]911509[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Real azimut 156.67051696777� and facade at 138� -> IN SUN (from 48� to 228�), effective elevation 61.987275939497� for given elevation of 60.68380355835� -> in min-max-range (0-90)[/TD] [/TR] [TR] [TD]2017-05-21 12:39:31[/TD] [TD]911576[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state -1 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:39:31[/TD] [TD]912621[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Handling current shutter state DAWN_NEUTRAL (-1)[/TD] [/TR] [TR] [TD]2017-05-21 12:39:31[/TD] [TD]912699[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Facade is in sun[/TD] [/TR] [TR] [TD]2017-05-21 12:39:31[/TD] [TD]912759[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Switching from DAWN_NEUTRAL to SHADOW_FULL_CLOSE_TIMER_RUNNING[/TD] [/TR] [TR] [TD]2017-05-21 12:39:31[/TD] [TD]912808[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Starting new timer for 150 seconds up to 12:42:01[/TD] [/TR] [TR] [TD]2017-05-21 12:39:31[/TD] [TD]913392[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state 6 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:39:31[/TD] [TD]914180[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Shutter state has changed from -1 to 6, checking if there might be another change...[/TD] [/TR] [TR] [TD]2017-05-21 12:39:31[/TD] [TD]914428[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Handling current shutter state SHADOW_FULL_CLOSE_TIMER_RUNNING (6)[/TD] [/TR] [TR] [TD]2017-05-21 12:39:31[/TD] [TD]914505[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Facade is in sun[/TD] [/TR] [TR] [TD]2017-05-21 12:39:31[/TD] [TD]914891[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Updating outputs out of SHADOW_FULL_CLOSE_TIMER_RUNNING if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:39:31[/TD] [TD]916050[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Shutter angle 0% = 0�[/TD] [/TR] [TR] [TD]2017-05-21 12:39:31[/TD] [TD]916853[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state 6 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:39:31[/TD] [TD]917295[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = LBS finished = === ===============================================[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]915518[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = Brightness, Elevation or Azimut changed and LBS is active, starting it = === ======[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]915622[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = LBS was triggered = === ==========================================[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]915673[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]<Input>: <Refreshed>|<Value>[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]915868[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Trigger: 0| Trigger changed output: 0| Brightness: 0|111329.28 Brightness dawn: 0|111329.28 Elevation: 0|60.68380355835 Azimut: 1|157.59211730957 Activationstate: 0|1 Lockstate: 0|0 Internal timer: 1[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]916146[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Virtual depth and height of sun position in 90� to the facade: 0.94210359493015, 1.7807993148547, effective Elevation: 62.119632297313[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]916414[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Real azimut 157.59211730957� and facade at 138� -> IN SUN (from 48� to 228�), effective elevation 62.119632297313� for given elevation of 60.68380355835� -> in min-max-range (0-90)[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]916490[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state -1 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]917526[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Handling current shutter state DAWN_NEUTRAL (-1)[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]917607[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Facade is in sun[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]917659[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Switching from DAWN_NEUTRAL to SHADOW_FULL_CLOSE_TIMER_RUNNING[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]917717[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Starting new timer for 150 seconds up to 12:42:31[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]918292[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state 6 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]919117[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Shutter state has changed from -1 to 6, checking if there might be another change...[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]919374[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Handling current shutter state SHADOW_FULL_CLOSE_TIMER_RUNNING (6)[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]919440[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Facade is in sun[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]919841[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Updating outputs out of SHADOW_FULL_CLOSE_TIMER_RUNNING if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]921111[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Shutter angle 0% = 0�[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]921922[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state 6 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]922365[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = LBS finished = === ===============================================[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]975872[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = Brightness, Elevation or Azimut changed and LBS is active, starting it = === ======[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]975949[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = LBS was triggered = === ==========================================[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]975996[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]<Input>: <Refreshed>|<Value>[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]976171[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Trigger: 0| Trigger changed output: 0| Brightness: 0|111329.28 Brightness dawn: 0|111329.28 Elevation: 1|60.814163208008 Azimut: 0|157.59211730957 Activationstate: 0|1 Lockstate: 0|0 Internal timer: 1[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]976435[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Virtual depth and height of sun position in 90� to the facade: 0.94210359493015, 1.7903283806777, effective Elevation: 62.245832701216[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]976713[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Real azimut 157.59211730957� and facade at 138� -> IN SUN (from 48� to 228�), effective elevation 62.245832701216� for given elevation of 60.814163208008� -> in min-max-range (0-90)[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]976779[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state -1 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]977782[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Handling current shutter state DAWN_NEUTRAL (-1)[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]977860[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Facade is in sun[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]977912[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Switching from DAWN_NEUTRAL to SHADOW_FULL_CLOSE_TIMER_RUNNING[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]977962[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Starting new timer for 150 seconds up to 12:42:31[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]978528[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state 6 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]979307[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Shutter state has changed from -1 to 6, checking if there might be another change...[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]979562[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Handling current shutter state SHADOW_FULL_CLOSE_TIMER_RUNNING (6)[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]979626[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Facade is in sun[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]980026[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Updating outputs out of SHADOW_FULL_CLOSE_TIMER_RUNNING if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]981174[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Shutter angle 0% = 0�[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]982038[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state 6 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:40:01[/TD] [TD]982486[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = LBS finished = === ===============================================[/TD] [/TR] [TR] [TD]2017-05-21 12:40:31[/TD] [TD]802146[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = Brightness, Elevation or Azimut changed and LBS is active, starting it = === ======[/TD] [/TR] [TR] [TD]2017-05-21 12:40:31[/TD] [TD]802251[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = LBS was triggered = === ==========================================[/TD] [/TR] [TR] [TD]2017-05-21 12:40:31[/TD] [TD]802299[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]<Input>: <Refreshed>|<Value>[/TD] [/TR] [TR] [TD]2017-05-21 12:40:31[/TD] [TD]802495[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Trigger: 0| Trigger changed output: 0| Brightness: 1|109608.96 Brightness dawn: 1|109608.96 Elevation: 0|60.814163208008 Azimut: 0|157.59211730957 Activationstate: 0|1 Lockstate: 0|0 Internal timer: 1[/TD] [/TR] [TR] [TD]2017-05-21 12:40:31[/TD] [TD]802779[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Virtual depth and height of sun position in 90� to the facade: 0.94210359493015, 1.7903283806777, effective Elevation: 62.245832701216[/TD] [/TR] [TR] [TD]2017-05-21 12:40:31[/TD] [TD]803054[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Real azimut 157.59211730957� and facade at 138� -> IN SUN (from 48� to 228�), effective elevation 62.245832701216� for given elevation of 60.814163208008� -> in min-max-range (0-90)[/TD] [/TR] [TR] [TD]2017-05-21 12:40:31[/TD] [TD]803119[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state -1 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:40:31[/TD] [TD]804160[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Handling current shutter state DAWN_NEUTRAL (-1)[/TD] [/TR] [TR] [TD]2017-05-21 12:40:31[/TD] [TD]804240[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Facade is in sun[/TD] [/TR] [TR] [TD]2017-05-21 12:40:31[/TD] [TD]804294[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Switching from DAWN_NEUTRAL to SHADOW_FULL_CLOSE_TIMER_RUNNING[/TD] [/TR] [TR] [TD]2017-05-21 12:40:31[/TD] [TD]804343[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Starting new timer for 150 seconds up to 12:43:01[/TD] [/TR] [TR] [TD]2017-05-21 12:40:31[/TD] [TD]804939[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state 6 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:40:31[/TD] [TD]805712[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Shutter state has changed from -1 to 6, checking if there might be another change...[/TD] [/TR] [TR] [TD]2017-05-21 12:40:31[/TD] [TD]805974[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Handling current shutter state SHADOW_FULL_CLOSE_TIMER_RUNNING (6)[/TD] [/TR] [TR] [TD]2017-05-21 12:40:31[/TD] [TD]806041[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Facade is in sun[/TD] [/TR] [TR] [TD]2017-05-21 12:40:31[/TD] [TD]806420[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Updating outputs out of SHADOW_FULL_CLOSE_TIMER_RUNNING if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:40:31[/TD] [TD]807576[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Shutter angle 0% = 0�[/TD] [/TR] [TR] [TD]2017-05-21 12:40:31[/TD] [TD]808377[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state 6 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:40:31[/TD] [TD]808850[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = LBS finished = === ===============================================[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]700607[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = Brightness, Elevation or Azimut changed and LBS is active, starting it = === ======[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]700702[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = LBS was triggered = === ==========================================[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]700752[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]<Input>: <Refreshed>|<Value>[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]700936[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Trigger: 0| Trigger changed output: 0| Brightness: 0|109608.96 Brightness dawn: 0|109608.96 Elevation: 0|60.814163208008 Azimut: 1|158.05534362793 Activationstate: 0|1 Lockstate: 0|0 Internal timer: 1[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]701211[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Virtual depth and height of sun position in 90� to the facade: 0.93936181544891, 1.7903283806777, effective Elevation: 62.314592974163[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]701491[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Real azimut 158.05534362793� and facade at 138� -> IN SUN (from 48� to 228�), effective elevation 62.314592974163� for given elevation of 60.814163208008� -> in min-max-range (0-90)[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]701560[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state -1 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]702598[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Handling current shutter state DAWN_NEUTRAL (-1)[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]702677[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Facade is in sun[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]702738[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Switching from DAWN_NEUTRAL to SHADOW_FULL_CLOSE_TIMER_RUNNING[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]702789[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Starting new timer for 150 seconds up to 12:43:55[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]703375[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state 6 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]704169[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Shutter state has changed from -1 to 6, checking if there might be another change...[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]704422[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Handling current shutter state SHADOW_FULL_CLOSE_TIMER_RUNNING (6)[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]704495[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Facade is in sun[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]704885[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Updating outputs out of SHADOW_FULL_CLOSE_TIMER_RUNNING if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]706104[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Shutter angle 0% = 0�[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]706921[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state 6 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]707370[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = LBS finished = === ===============================================[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]761061[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = Brightness, Elevation or Azimut changed and LBS is active, starting it = === ======[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]761140[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = LBS was triggered = === ==========================================[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]761187[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]<Input>: <Refreshed>|<Value>[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]761364[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Trigger: 0| Trigger changed output: 0| Brightness: 0|109608.96 Brightness dawn: 0|109608.96 Elevation: 1|60.877513885498 Azimut: 0|158.05534362793 Activationstate: 0|1 Lockstate: 0|0 Internal timer: 1[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]761645[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Virtual depth and height of sun position in 90� to the facade: 0.93936181544891, 1.7949872854419, effective Elevation: 62.375810732137[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]761915[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Real azimut 158.05534362793� and facade at 138� -> IN SUN (from 48� to 228�), effective elevation 62.375810732137� for given elevation of 60.877513885498� -> in min-max-range (0-90)[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]761981[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state -1 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]762984[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Handling current shutter state DAWN_NEUTRAL (-1)[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]763063[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Facade is in sun[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]763115[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Switching from DAWN_NEUTRAL to SHADOW_FULL_CLOSE_TIMER_RUNNING[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]763164[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Starting new timer for 150 seconds up to 12:43:55[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]763730[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state 6 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]764502[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Shutter state has changed from -1 to 6, checking if there might be another change...[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]764754[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Handling current shutter state SHADOW_FULL_CLOSE_TIMER_RUNNING (6)[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]764818[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Facade is in sun[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]765194[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Updating outputs out of SHADOW_FULL_CLOSE_TIMER_RUNNING if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]766334[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Shutter angle 0% = 0�[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]767132[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state 6 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:41:25[/TD] [TD]767577[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = LBS finished = === ===============================================[/TD] [/TR] [TR] [TD]2017-05-21 12:41:31[/TD] [TD]687617[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = Brightness, Elevation or Azimut changed and LBS is active, starting it = === ======[/TD] [/TR] [TR] [TD]2017-05-21 12:41:31[/TD] [TD]687719[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = LBS was triggered = === ==========================================[/TD] [/TR] [TR] [TD]2017-05-21 12:41:31[/TD] [TD]687767[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]<Input>: <Refreshed>|<Value>[/TD] [/TR] [TR] [TD]2017-05-21 12:41:31[/TD] [TD]687979[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Trigger: 0| Trigger changed output: 0| Brightness: 1|108625.92 Brightness dawn: 1|108625.92 Elevation: 0|60.877513885498 Azimut: 0|158.05534362793 Activationstate: 0|1 Lockstate: 0|0 Internal timer: 1[/TD] [/TR] [TR] [TD]2017-05-21 12:41:31[/TD] [TD]688277[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Virtual depth and height of sun position in 90� to the facade: 0.93936181544891, 1.7949872854419, effective Elevation: 62.375810732137[/TD] [/TR] [TR] [TD]2017-05-21 12:41:31[/TD] [TD]688551[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Real azimut 158.05534362793� and facade at 138� -> IN SUN (from 48� to 228�), effective elevation 62.375810732137� for given elevation of 60.877513885498� -> in min-max-range (0-90)[/TD] [/TR] [TR] [TD]2017-05-21 12:41:31[/TD] [TD]688618[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state -1 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:41:31[/TD] [TD]689656[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Handling current shutter state DAWN_NEUTRAL (-1)[/TD] [/TR] [TR] [TD]2017-05-21 12:41:31[/TD] [TD]689745[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Facade is in sun[/TD] [/TR] [TR] [TD]2017-05-21 12:41:31[/TD] [TD]689816[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Switching from DAWN_NEUTRAL to SHADOW_FULL_CLOSE_TIMER_RUNNING[/TD] [/TR] [TR] [TD]2017-05-21 12:41:31[/TD] [TD]689868[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Starting new timer for 150 seconds up to 12:44:01[/TD] [/TR] [TR] [TD]2017-05-21 12:41:31[/TD] [TD]690462[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state 6 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:41:31[/TD] [TD]691239[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Shutter state has changed from -1 to 6, checking if there might be another change...[/TD] [/TR] [TR] [TD]2017-05-21 12:41:31[/TD] [TD]691498[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Handling current shutter state SHADOW_FULL_CLOSE_TIMER_RUNNING (6)[/TD] [/TR] [TR] [TD]2017-05-21 12:41:31[/TD] [TD]691562[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Facade is in sun[/TD] [/TR] [TR] [TD]2017-05-21 12:41:31[/TD] [TD]691946[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Updating outputs out of SHADOW_FULL_CLOSE_TIMER_RUNNING if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:41:31[/TD] [TD]693099[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Shutter angle 0% = 0�[/TD] [/TR] [TR] [TD]2017-05-21 12:41:31[/TD] [TD]693922[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state 6 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:41:31[/TD] [TD]694366[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = LBS finished = === ===============================================[/TD] [/TR] [TR] [TD]2017-05-21 12:42:31[/TD] [TD]518254[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = Brightness, Elevation or Azimut changed and LBS is active, starting it = === ======[/TD] [/TR] [TR] [TD]2017-05-21 12:42:31[/TD] [TD]518348[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = LBS was triggered = === ==========================================[/TD] [/TR] [TR] [TD]2017-05-21 12:42:31[/TD] [TD]518398[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]<Input>: <Refreshed>|<Value>[/TD] [/TR] [TR] [TD]2017-05-21 12:42:31[/TD] [TD]518585[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Trigger: 0| Trigger changed output: 0| Brightness: 1|111738.88 Brightness dawn: 1|111738.88 Elevation: 0|60.877513885498 Azimut: 0|158.05534362793 Activationstate: 0|1 Lockstate: 0|0 Internal timer: 1[/TD] [/TR] [TR] [TD]2017-05-21 12:42:31[/TD] [TD]518868[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Virtual depth and height of sun position in 90� to the facade: 0.93936181544891, 1.7949872854419, effective Elevation: 62.375810732137[/TD] [/TR] [TR] [TD]2017-05-21 12:42:31[/TD] [TD]519145[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Real azimut 158.05534362793� and facade at 138� -> IN SUN (from 48� to 228�), effective elevation 62.375810732137� for given elevation of 60.877513885498� -> in min-max-range (0-90)[/TD] [/TR] [TR] [TD]2017-05-21 12:42:31[/TD] [TD]519212[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state -1 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:42:31[/TD] [TD]520272[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Handling current shutter state DAWN_NEUTRAL (-1)[/TD] [/TR] [TR] [TD]2017-05-21 12:42:31[/TD] [TD]520354[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Facade is in sun[/TD] [/TR] [TR] [TD]2017-05-21 12:42:31[/TD] [TD]520406[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Switching from DAWN_NEUTRAL to SHADOW_FULL_CLOSE_TIMER_RUNNING[/TD] [/TR] [TR] [TD]2017-05-21 12:42:31[/TD] [TD]520458[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Starting new timer for 150 seconds up to 12:45:01[/TD] [/TR] [TR] [TD]2017-05-21 12:42:31[/TD] [TD]521070[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state 6 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:42:31[/TD] [TD]521862[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Shutter state has changed from -1 to 6, checking if there might be another change...[/TD] [/TR] [TR] [TD]2017-05-21 12:42:31[/TD] [TD]522120[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Handling current shutter state SHADOW_FULL_CLOSE_TIMER_RUNNING (6)[/TD] [/TR] [TR] [TD]2017-05-21 12:42:31[/TD] [TD]522187[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Facade is in sun[/TD] [/TR] [TR] [TD]2017-05-21 12:42:31[/TD] [TD]522568[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Updating outputs out of SHADOW_FULL_CLOSE_TIMER_RUNNING if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:42:31[/TD] [TD]523741[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Shutter angle 0% = 0�[/TD] [/TR] [TR] [TD]2017-05-21 12:42:31[/TD] [TD]524539[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state 6 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:42:31[/TD] [TD]525062[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = LBS finished = === ===============================================[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]929311[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = Brightness, Elevation or Azimut changed and LBS is active, starting it = === ======[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]929409[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = LBS was triggered = === ==========================================[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]929465[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]<Input>: <Refreshed>|<Value>[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]929651[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Trigger: 0| Trigger changed output: 0| Brightness: 0|111738.88 Brightness dawn: 0|111738.88 Elevation: 0|60.877513885498 Azimut: 1|158.98678588867 Activationstate: 0|1 Lockstate: 0|0 Internal timer: 1[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]929934[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Virtual depth and height of sun position in 90� to the facade: 0.93366305197863, 1.7949872854419, effective Elevation: 62.518793264372[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]930273[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Real azimut 158.98678588867� and facade at 138� -> IN SUN (from 48� to 228�), effective elevation 62.518793264372� for given elevation of 60.877513885498� -> in min-max-range (0-90)[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]930337[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state -1 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]931385[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Handling current shutter state DAWN_NEUTRAL (-1)[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]931473[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Facade is in sun[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]931529[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Switching from DAWN_NEUTRAL to SHADOW_FULL_CLOSE_TIMER_RUNNING[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]931580[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Starting new timer for 150 seconds up to 12:45:31[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]932162[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state 6 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]933000[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Shutter state has changed from -1 to 6, checking if there might be another change...[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]933250[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Handling current shutter state SHADOW_FULL_CLOSE_TIMER_RUNNING (6)[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]933315[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Facade is in sun[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]933710[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Updating outputs out of SHADOW_FULL_CLOSE_TIMER_RUNNING if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]934859[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Shutter angle 0% = 0�[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]935724[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state 6 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]936165[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = LBS finished = === ===============================================[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]989978[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = Brightness, Elevation or Azimut changed and LBS is active, starting it = === ======[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]990053[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = LBS was triggered = === ==========================================[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]990106[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]<Input>: <Refreshed>|<Value>[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]990286[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Trigger: 0| Trigger changed output: 0| Brightness: 0|111738.88 Brightness dawn: 0|111738.88 Elevation: 1|61.000354766846 Azimut: 0|158.98678588867 Activationstate: 0|1 Lockstate: 0|0 Internal timer: 1[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]990555[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Virtual depth and height of sun position in 90� to the facade: 0.93366305197863, 1.8040740993363, effective Elevation: 62.637064797996[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]990823[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Real azimut 158.98678588867� and facade at 138� -> IN SUN (from 48� to 228�), effective elevation 62.637064797996� for given elevation of 61.000354766846� -> in min-max-range (0-90)[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]990890[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state -1 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]991897[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Handling current shutter state DAWN_NEUTRAL (-1)[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]991974[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Facade is in sun[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]992026[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Switching from DAWN_NEUTRAL to SHADOW_FULL_CLOSE_TIMER_RUNNING[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]992074[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Starting new timer for 150 seconds up to 12:45:31[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]992643[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state 6 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]993453[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Shutter state has changed from -1 to 6, checking if there might be another change...[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]993720[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Handling current shutter state SHADOW_FULL_CLOSE_TIMER_RUNNING (6)[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]993784[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Facade is in sun[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]994167[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Updating outputs out of SHADOW_FULL_CLOSE_TIMER_RUNNING if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]995320[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Shutter angle 0% = 0�[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]996186[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state 6 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-21 12:43:01[/TD] [TD]996632[/TD] [TD]9656[/TD] [TD]INFO:[/TD] [TD]===== === = LBS finished = === ===============================================[/TD] [/TR] [/TABLE]
Hi Leute, ich glaub ich hab den Fehler. Typischer Copy Paste Fehler. Alle Raffstores hatten ausversehen das selbe iKo welches den Zustand bei Neustart von Edomi speichert. Schauen wir mal, obs das war
