LBS 19000145 - Beschattungssteuerung-NG
     [TABLE="border: 0, cellpadding: 0, cellspacing: 0"]
    [TR]
    [TD]2017-05-21 12:38:31[/TD]
     			[TD]977293[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]===== === = Brightness, Elevation or Azimut changed and LBS is active, starting it = === ======[/TD]
     		[/TR]
    [TR]
     			[TD]977499[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]===== === = LBS was triggered = === ==========================================[/TD]
     		[/TR]
    [TR]
     			[TD]977552[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]<Input>: <Refreshed>|<Value>[/TD]
     		[/TR]
    [TR]
     			[TD]977747[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Trigger: 0| Trigger changed output: 0| Brightness: 1|111411.2 Brightness dawn: 1|111411.2 Elevation: 0|60.68380355835 Azimut: 0|156.67051696777 Activationstate: 0|1 Lockstate: 0|0 Internal timer: 1[/TD]
     		[/TR]
    [TR]
     			[TD]978033[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Virtual depth and height of sun position in 90� to the facade: 0.9473751320793, 1.7807993148547, effective Elevation: 61.987275939497[/TD]
     		[/TR]
    [TR]
     			[TD]978315[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Real azimut 156.67051696777� and facade at 138� -> IN SUN (from 48� to 228�), effective elevation 61.987275939497� for given elevation of 60.68380355835� -> in min-max-range (0-90)[/TD]
     		[/TR]
    [TR]
     			[TD]978385[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Storing current shutter state -1 and updating output if necessary[/TD]
     		[/TR]
    [TR]
     			[TD]979445[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Handling current shutter state DAWN_NEUTRAL (-1)[/TD]
     		[/TR]
    [TR]
     			[TD]979531[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Facade is in sun[/TD]
     		[/TR]
    [TR]
     			[TD]979585[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Switching from DAWN_NEUTRAL to SHADOW_FULL_CLOSE_TIMER_RUNNING[/TD]
     		[/TR]
    [TR]
     			[TD]979634[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Starting new timer for 150 seconds up to 12:41:01[/TD]
     		[/TR]
    [TR]
     			[TD]980226[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Storing current shutter state 6 and updating output if necessary[/TD]
     		[/TR]
    [TR]
     			[TD]981018[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Shutter state has changed from -1 to 6, checking if there might be another change...[/TD]
     		[/TR]
    [TR]
     			[TD]981278[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Handling current shutter state SHADOW_FULL_CLOSE_TIMER_RUNNING (6)[/TD]
     		[/TR]
    [TR]
     			[TD]981343[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]981729[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Updating outputs out of SHADOW_FULL_CLOSE_TIMER_RUNNING if necessary[/TD]
     		[/TR]
    [TR]
     			[TD]982892[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Shutter angle 0% = 0�[/TD]
     		[/TR]
    [TR]
     			[TD]983689[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]984134[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]===== === = LBS finished = === ===============================================[/TD]
     		[/TR]
    [TR]
    [TD]2017-05-21 12:39:31[/TD]
     			[TD]910594[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]910700[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]910758[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]910953[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Trigger: 0| Trigger changed output: 0| Brightness: 1|111329.28 Brightness dawn: 1|111329.28 Elevation: 0|60.68380355835 Azimut: 0|156.67051696777 Activationstate: 0|1 Lockstate: 0|0 Internal timer: 1[/TD]
     		[/TR]
    [TR]
     			[TD]911235[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]911509[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]911576[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]912621[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]912699[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]912759[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]912808[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Starting new timer for 150 seconds up to 12:42:01[/TD]
     		[/TR]
    [TR]
     			[TD]913392[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]914180[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]914428[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]914505[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]914891[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]916050[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]916853[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]917295[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
    [TD]2017-05-21 12:40:01[/TD]
     			[TD]915518[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]915622[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]915673[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]915868[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Trigger: 0| Trigger changed output: 0| Brightness: 0|111329.28 Brightness dawn: 0|111329.28 Elevation: 0|60.68380355835 Azimut: 1|157.59211730957 Activationstate: 0|1 Lockstate: 0|0 Internal timer: 1[/TD]
     		[/TR]
    [TR]
     			[TD]916146[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Virtual depth and height of sun position in 90� to the facade: 0.94210359493015, 1.7807993148547, effective Elevation: 62.119632297313[/TD]
     		[/TR]
    [TR]
     			[TD]916414[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Real azimut 157.59211730957� and facade at 138� -> IN SUN (from 48� to 228�), effective elevation 62.119632297313� for given elevation of 60.68380355835� -> in min-max-range (0-90)[/TD]
     		[/TR]
    [TR]
     			[TD]916490[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]917526[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]917607[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]917659[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]917717[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Starting new timer for 150 seconds up to 12:42:31[/TD]
     		[/TR]
    [TR]
     			[TD]918292[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]919117[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]919374[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]919440[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]919841[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]921111[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]921922[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]922365[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]975872[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]975949[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]975996[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]976171[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Trigger: 0| Trigger changed output: 0| Brightness: 0|111329.28 Brightness dawn: 0|111329.28 Elevation: 1|60.814163208008 Azimut: 0|157.59211730957 Activationstate: 0|1 Lockstate: 0|0 Internal timer: 1[/TD]
     		[/TR]
    [TR]
     			[TD]976435[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Virtual depth and height of sun position in 90� to the facade: 0.94210359493015, 1.7903283806777, effective Elevation: 62.245832701216[/TD]
     		[/TR]
    [TR]
     			[TD]976713[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Real azimut 157.59211730957� and facade at 138� -> IN SUN (from 48� to 228�), effective elevation 62.245832701216� for given elevation of 60.814163208008� -> in min-max-range (0-90)[/TD]
     		[/TR]
    [TR]
     			[TD]976779[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]977782[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]977860[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]977912[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]977962[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]978528[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]979307[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]979562[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]979626[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]980026[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]981174[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]982038[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]982486[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
    [TD]2017-05-21 12:40:31[/TD]
     			[TD]802146[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]802251[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]802299[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]802495[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Trigger: 0| Trigger changed output: 0| Brightness: 1|109608.96 Brightness dawn: 1|109608.96 Elevation: 0|60.814163208008 Azimut: 0|157.59211730957 Activationstate: 0|1 Lockstate: 0|0 Internal timer: 1[/TD]
     		[/TR]
    [TR]
     			[TD]802779[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]803054[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]803119[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]804160[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]804240[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]804294[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]804343[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Starting new timer for 150 seconds up to 12:43:01[/TD]
     		[/TR]
    [TR]
     			[TD]804939[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]805712[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]805974[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]806041[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]806420[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]807576[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]808377[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]808850[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
    [TD]2017-05-21 12:41:25[/TD]
     			[TD]700607[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]700702[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]700752[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]700936[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Trigger: 0| Trigger changed output: 0| Brightness: 0|109608.96 Brightness dawn: 0|109608.96 Elevation: 0|60.814163208008 Azimut: 1|158.05534362793 Activationstate: 0|1 Lockstate: 0|0 Internal timer: 1[/TD]
     		[/TR]
    [TR]
     			[TD]701211[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Virtual depth and height of sun position in 90� to the facade: 0.93936181544891, 1.7903283806777, effective Elevation: 62.314592974163[/TD]
     		[/TR]
    [TR]
     			[TD]701491[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Real azimut 158.05534362793� and facade at 138� -> IN SUN (from 48� to 228�), effective elevation 62.314592974163� for given elevation of 60.814163208008� -> in min-max-range (0-90)[/TD]
     		[/TR]
    [TR]
     			[TD]701560[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]702598[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]702677[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]702738[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]702789[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Starting new timer for 150 seconds up to 12:43:55[/TD]
     		[/TR]
    [TR]
     			[TD]703375[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]704169[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]704422[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]704495[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]704885[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]706104[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]706921[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]707370[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]761061[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]761140[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]761187[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]761364[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Trigger: 0| Trigger changed output: 0| Brightness: 0|109608.96 Brightness dawn: 0|109608.96 Elevation: 1|60.877513885498 Azimut: 0|158.05534362793 Activationstate: 0|1 Lockstate: 0|0 Internal timer: 1[/TD]
     		[/TR]
    [TR]
     			[TD]761645[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Virtual depth and height of sun position in 90� to the facade: 0.93936181544891, 1.7949872854419, effective Elevation: 62.375810732137[/TD]
     		[/TR]
    [TR]
     			[TD]761915[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Real azimut 158.05534362793� and facade at 138� -> IN SUN (from 48� to 228�), effective elevation 62.375810732137� for given elevation of 60.877513885498� -> in min-max-range (0-90)[/TD]
     		[/TR]
    [TR]
     			[TD]761981[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]762984[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]763063[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]763115[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]763164[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]763730[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]764502[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]764754[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]764818[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]765194[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]766334[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]767132[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]767577[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
    [TD]2017-05-21 12:41:31[/TD]
     			[TD]687617[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]687719[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]687767[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]687979[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Trigger: 0| Trigger changed output: 0| Brightness: 1|108625.92 Brightness dawn: 1|108625.92 Elevation: 0|60.877513885498 Azimut: 0|158.05534362793 Activationstate: 0|1 Lockstate: 0|0 Internal timer: 1[/TD]
     		[/TR]
    [TR]
     			[TD]688277[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]688551[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]688618[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]689656[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]689745[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]689816[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]689868[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Starting new timer for 150 seconds up to 12:44:01[/TD]
     		[/TR]
    [TR]
     			[TD]690462[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]691239[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]691498[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]691562[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]691946[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]693099[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]693922[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]694366[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
    [TD]2017-05-21 12:42:31[/TD]
     			[TD]518254[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]518348[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]518398[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]518585[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Trigger: 0| Trigger changed output: 0| Brightness: 1|111738.88 Brightness dawn: 1|111738.88 Elevation: 0|60.877513885498 Azimut: 0|158.05534362793 Activationstate: 0|1 Lockstate: 0|0 Internal timer: 1[/TD]
     		[/TR]
    [TR]
     			[TD]518868[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]519145[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]519212[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]520272[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]520354[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]520406[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]520458[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Starting new timer for 150 seconds up to 12:45:01[/TD]
     		[/TR]
    [TR]
     			[TD]521070[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]521862[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]522120[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]522187[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]522568[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]523741[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]524539[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]525062[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
    [TD]2017-05-21 12:43:01[/TD]
     			[TD]929311[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]929409[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]929465[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]929651[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Trigger: 0| Trigger changed output: 0| Brightness: 0|111738.88 Brightness dawn: 0|111738.88 Elevation: 0|60.877513885498 Azimut: 1|158.98678588867 Activationstate: 0|1 Lockstate: 0|0 Internal timer: 1[/TD]
     		[/TR]
    [TR]
     			[TD]929934[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Virtual depth and height of sun position in 90� to the facade: 0.93366305197863, 1.7949872854419, effective Elevation: 62.518793264372[/TD]
     		[/TR]
    [TR]
     			[TD]930273[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Real azimut 158.98678588867� and facade at 138� -> IN SUN (from 48� to 228�), effective elevation 62.518793264372� for given elevation of 60.877513885498� -> in min-max-range (0-90)[/TD]
     		[/TR]
    [TR]
     			[TD]930337[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]931385[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]931473[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]931529[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]931580[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Starting new timer for 150 seconds up to 12:45:31[/TD]
     		[/TR]
    [TR]
     			[TD]932162[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]933000[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]933250[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]933315[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]933710[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]934859[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]935724[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]936165[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]989978[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]990053[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]990106[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]990286[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Trigger: 0| Trigger changed output: 0| Brightness: 0|111738.88 Brightness dawn: 0|111738.88 Elevation: 1|61.000354766846 Azimut: 0|158.98678588867 Activationstate: 0|1 Lockstate: 0|0 Internal timer: 1[/TD]
     		[/TR]
    [TR]
     			[TD]990555[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Virtual depth and height of sun position in 90� to the facade: 0.93366305197863, 1.8040740993363, effective Elevation: 62.637064797996[/TD]
     		[/TR]
    [TR]
     			[TD]990823[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     			[TD]Real azimut 158.98678588867� and facade at 138� -> IN SUN (from 48� to 228�), effective elevation 62.637064797996� for given elevation of 61.000354766846� -> in min-max-range (0-90)[/TD]
     		[/TR]
    [TR]
     			[TD]990890[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]991897[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]991974[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]992026[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]992074[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]992643[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]993453[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]993720[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]993784[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]994167[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]995320[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]996186[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [TR]
     			[TD]996632[/TD]
     			[TD]9656[/TD]
     			[TD]INFO:[/TD]
     		[/TR]
    [/TABLE]
    Hi Leute, ich glaub ich hab den Fehler. Typischer Copy Paste Fehler. Alle Raffstores hatten ausversehen das selbe iKo welches den Zustand bei Neustart von Edomi speichert. Schauen wir mal, obs das war
    Zuletzt geändert von g0bi; 21.05.2017, 19:03. Grund: Mögliche Lösung:
      N'abend
      Genau das habe ich vermutet denn aus dem Log geht hervor, dass der Status bei jedem neuen Lauf des LBS wieder der alte war:
      2017-05-21 12:38:31    979585    9656    INFO:    Switching from DAWN_NEUTRAL to SHADOW_FULL_CLOSE_TIMER_RUNNING
      2017-05-21 12:38:31    980226    9656    INFO:    Storing current shutter state 6 and updating output if necessary
      2017-05-21 12:38:31    981018    9656    INFO:    Shutter state has changed from -1 to 6, checking if there might be another change...
      2017-05-21 12:39:31    912759    9656    INFO:    Switching from DAWN_NEUTRAL to SHADOW_FULL_CLOSE_TIMER_RUNNING
      2017-05-21 12:39:31    913392    9656    INFO:    Storing current shutter state 6 and updating output if necessary
      2017-05-21 12:39:31    914180    9656    INFO:    Shutter state has changed from -1 to 6, checking if there might be another change...
      2017-05-21 12:40:01    917659    9656    INFO:    Switching from DAWN_NEUTRAL to SHADOW_FULL_CLOSE_TIMER_RUNNING
      2017-05-21 12:40:01    918292    9656    INFO:    Storing current shutter state 6 and updating output if necessary
      2017-05-21 12:40:01    919117    9656    INFO:    Shutter state has changed from -1 to 6, checking if there might be another change...
      Kind regards,
      Yves
        Ok, beim testen hab ich extern die Toleranz überschritten. Die scheint auch für die Dämerung zu gelten, somit hat sich der baustein deaktiviert. Also muss ich die Toleranz hochsetzen. Aber ist das überhaupt für die Dämmerung gewünscht? Hier besteht ja nicht die Gefahr dass anschließend verstellt wird?
        Gruß Stefan
          Hallo Stefan,
          sry aber ich verstehe gerade nur Bahnhof.
          Kind regards,
          Yves
            Hehe, Sorry...
            Also, dein LBS macht ja Beschattung und Dämmerung? Du hast bei den Eingängen die Eingänge E16 und E17. Hier kann man eine Toleranz angeben, bei welcher sich der LBS deaktiviert, wenn die Jalousien von extern verstellt wurden. Ist der LBS aber deaktiviert, weil extern verstellt wurde zieht auch die Dämmerung nicht mehr. Ich verstehe ja, dass die Jalousien die externe Verstellung nicht alle 5 Minuten wieder verändern soll, aber so fahren Sie komplett nicht herunter, auch wenn außen die Dämmerung einsetzt.
            Wie könnte man das lösen?
              Mit einem Verzögerungsbaustein den LBS wieder aktivieren! Deaktiviert ist deaktiviert wo ist das Problem?
                Hi Vento, Deaktiviert ist deaktiviert, nur nicht alles muss einen Sinn haben?? Hier sollte man doch wohl hinterfragen dürfen? Wäre es hier nicht geschickter man deaktiviert dann nur den Beschattungsteil? Und dann ist leider nicht angegeben wo man wieder aktivieren kann. Per Trigger an E1?
                  Wer sagt denn das ich nach, manuellen verfahren die Dämmerungsautomatik wieder aktivieren will? Dann musst Du eine Logik bauen, die bei Eintreten der Dämmerung den LBS wieder aktiviert, Habt ihr alle zu viele Taster? bei mir stellt keiner an der Jalousie. Erstens mangels Taster, und zweitens mangels Bedarf
                    Ähhm, definitiv nein!
                    Wenn das anders wäre, würden alle die es brauchen den Dämmerungsteil nie(!) deaktiviert bekommen. Andersherum kannst du doch ohne Probleme - wenn du das so haben möchtest - bei einsetzen der Dämmerung (Helligkeitsschwelle) den LBS mit einer externe Vorschaltung wieder aktivieren...!
                      Hallo Stefan
                      Nein, das wäre nicht sinnvoller. Die Idee des gesamten Bausteines ist, dass er vollständig die Steuerung des Behang übernimmt und aber andererseits diese vollständig abschaltet, sobald jemand manuell eingreift. Das heisst, entweder der LBS steuert den Behang komplett oder er deaktiviert sich, sobald der Behang manuell verfahren wurde und man nicht will, dass der Baustein beim nächsten Lauf den Behang wieder neu positioniert.
                      Bei externer Manipulation deaktiviert sich der Baustein und es gibt einen Eingang zum Aus- und Einschalten resp. Deaktivieren und Aktivieren des Bausteines. Du siehst den Zusammenhang? Aber ich werde die Doku dahingehend ergänzen, danke für den Hinweis.
                      Kind regards,
                      Yves
                        Zitat von MrMirror Beitrag anzeigen
                        Ich Werte hierzu den "Bewölkungsgrad" in % aus, wenn der >75% dann sind Sonnenstrahlen relativ unwahrscheinlich. Zwar keine 100% Lösung, aber eine sehr zuverlässige!
                        Ja natürlich nicht nur von dem Wert der Bewölkung, sondern in Kombination mit Helligkeit und Temperaturen...!
                        Bei mir läuft das so: Helligkeit > 30.000 & Bewölunkgsrgrad < 75 & Außentemp > 15° & (Innentemp Ist > Innentemp Soll) = Beschattung 1
                        Das klingt interessant und müsste ich mal testen. Von wo erhälst du den Bewölkungsgrad? Irgendein Wetterdienst?
                        Ich hab mir mal einen weiteren Helligkeitssensor für die Westfassade bestellt, was zumindest die Helligkeit für die Westseite verbessern müsste. (Eigentlich müsste meine Wetterstation auf dem Dach an einer Stange befestigt sein, dann hätte ich wohl auch bessere Werte, auch von O/S/W...aber dafür ist es jetzt leider zu spät.
                        Abgesehen von diesem Problem kämpfe ich aber auch sonst noch mit dem Baustein. Irgendwie funktioniert das mit der Sperre (Sitzplatztür) bei mir nicht immer. Und der WAF sinkt schon etwas...aber sie ist zum Glück sehr geduldig. :-)
                          Zitat von rdeckard Beitrag anzeigen
                          ... Ich hab mir mal einen weiteren Helligkeitssensor für die Westfassade bestellt ...
                          Ich bin auch noch auf der Suche nach einem Sensor. Welchen verwendest du?
                            Hi
                            Da müssten diejenigen etwas dazu sagen, die die Sperre verwenden. Ich habe sie selbst nicht im Einsatz, da ich direkt am Aktor sperre und nicht via LBS...
                            Kind regards,
                            Yves
                              Ich wollte eigentlich nicht viel dafür ausgeben und habe mich auch bisschen im Bastlerbereich umgeschaut, da man ja mit Edomi recht flexibel ist, von wo man die Daten ausliest. Aber irgendwie waren alle Lösungen nicht so das Wahre und hätten viel Zeit in Aufbau, Testing, Kalibrierung etc. gekostet.
                              Also bin ich dann am Ende beim Elsner KNX L gelandet. Der Helligkeitsensor deckt den gleichen Bereich wie meine bereits vorhandene Elsner Suntracer sl ab. Zudem habe ich von meinem lokalen Händler einen guten Preis bekommen.
                                Ok, heute komme ich nach hause und 3 LBS haben sich deaktiviert und ich weiß leider nicht wieso. Daheim war zu der Zeit keiner, daher ist eine externe Bewegung unwahrscheinlich
                                [TR]
                                [TD]2017-05-22 11:58:06[/TD]
                                 			[TD]225169[/TD]
                                 			[TD]29870[/TD]
                                 			[TD]INFO: [/TD]
                                 		[/TR]
                                [TR]
                                 			[TD]245522[/TD]
                                 			[TD]29870[/TD]
                                 			[TD]INFO: [/TD]
                                 		[/TR]
                                [TR]
                                 			[TD]245588[/TD]
                                 			[TD]29870[/TD]
                                 			[TD]INFO: [/TD]
                                 		[/TR]
                                [TR]
                                 			[TD]245629[/TD]
                                 			[TD]29870[/TD]
                                 			[TD]INFO: [/TD]
                                 		[/TR]
                                [TR]
                                 			[TD]245729[/TD]
                                 			[TD]29870[/TD]
                                 			[TD]INFO: [/TD]
                                 			[TD]Trigger: 0|0 Trigger changed output: 0| Brightness: 1|104202.24 Brightness dawn: 1|104202.24 Elevation: 0|57.307201385498 Azimut: 0|139.58592224121 Activationstate: 0|1 Lockstate: 0|0 Internal timer: 0[/TD]
                                 		[/TR]
                                [TR]
                                 			[TD]245876[/TD]
                                 			[TD]29870[/TD]
                                 			[TD]INFO: [/TD]
                                 			[TD]Virtual depth and height of sun position in 90� to the facade: 0.027676030437036, 1.5580908114525, effective Elevation: 88.982374464921[/TD]
                                 		[/TR]
                                [TR]
                                 			[TD]246006[/TD]
                                 			[TD]29870[/TD]
                                 			[TD]INFO: [/TD]
                                 			[TD]Real azimut 139.58592224121� and facade at 228� -> IN SUN (from 138� to 318�), effective elevation 88.982374464921� for given elevation of 57.307201385498� -> in min-max-range (0-90)[/TD]
                                 		[/TR]
                                [TR]
                                 			[TD]246062[/TD]
                                 			[TD]29870[/TD]
                                 			[TD]INFO: [/TD]
                                 			[TD]Storing current shutter state 5 and updating output if necessary[/TD]
                                 		[/TR]
                                [TR]
                                 			[TD]246344[/TD]
                                 			[TD]29870[/TD]
                                 			[TD]INFO: [/TD]
                                 			[TD]Handling current shutter state SHADOW_FULL_CLOSED (5)[/TD]
                                 		[/TR]
                                [TR]
                                 			[TD]246402[/TD]
                                 			[TD]29870[/TD]
                                 			[TD]INFO: [/TD]
                                 		[/TR]
                                [TR]
                                 			[TD]246445[/TD]
                                 			[TD]29870[/TD]
                                 			[TD]INFO: [/TD]
                                 			[TD]Recalculating shutter position out of state SHADOW_FULL_CLOSED[/TD]
                                 		[/TR]
                                [TR]
                                 			[TD]246511[/TD]
                                 			[TD]29870[/TD]
                                 			[TD]INFO: [/TD]
                                 			[TD]Elevation/Azimut: 57.307201385498�/139.58592224121�, resulting effective elevation and shutter angle: 88.982374464921�/-88� (without stepping and offset)[/TD]
                                 		[/TR]
                                [TR]
                                 			[TD]246560[/TD]
                                 			[TD]29870[/TD]
                                 			[TD]INFO: [/TD]
                                 			[TD]Resulting shutter angle with offset and stepping: 0%[/TD]
                                 		[/TR]
                                [TR]
                                 			[TD]246936[/TD]
                                 			[TD]29870[/TD]
                                 			[TD]INFO: [/TD]
                                 		[/TR]
                                [TR]
                                 			[TD]247509[/TD]
                                 			[TD]29870[/TD]
                                 			[TD]INFO: [/TD]
                                 			[TD]Timer already finished[/TD]
                                 		[/TR]
                                [TR]
                                 			[TD]248012[/TD]
                                 			[TD]29870[/TD]
                                 			[TD]INFO: [/TD]
                                 		[/TR]
                                [TR]
                                 			[TD]248353[/TD]
                                 			[TD]29870[/TD]
                                 			[TD]INFO: [/TD]
                                 		[/TR]
                                [TR]
                                [TD]2017-05-22 11:58:40[/TD]
                                 			[TD]499880[/TD]
                                 			[TD]29870[/TD]
                                 			[TD]INFO: [/TD]
                                 			[TD]LBS disabled through external angle change (100 vs -10/10)[/TD]
                                 		[/TR]
                                [TR]
                                [TD]2017-05-22 11:58:42[/TD]
                                 			[TD]134696[/TD]
                                 			[TD]29870[/TD]
                                 			[TD]INFO: [/TD]
                                 		[/TR]
                                [TR]
                                 			[TD]135137[/TD]
                                 			[TD]29870[/TD]
                                 			[TD]INFO: [/TD]
                                 			[TD]LBS is disabled, nothing changed
                                [/TD]
                                 		[/TR]
                                [/TABLE]
                                Wenn ich das richtig interpretiere, hat der LBS andere Werte der Lamelen von dem Aktor bekommen ie er zuvor gesendet hat?
