Also wenn ich meinen Erinnerungen noch trauen kann war der E6 von Anfang an dabei
. Da steht eindeutig drin, dass ein während der Verzögerung eintreffendes Telegramm das vorhergehende ersetzt.
[TABLE="class: log, border: 0, cellpadding: 0, cellspacing: 0, width: 0, height: 12"] [TR] [TD]2017-05-24 20:45:57[/TD] [TD]860512[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]===== === = Brightness, Elevation or Azimut changed and LBS is active, starting it = === ======[/TD] [/TR] [TR] [TD]2017-05-24 20:45:57[/TD] [TD]860816[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]===== === = LBS was triggered = === ==========================================[/TD] [/TR] [TR] [TD]2017-05-24 20:45:57[/TD] [TD]860949[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]<Input>: <Refreshed>|<Value>[/TD] [/TR] [TR] [TD]2017-05-24 20:45:57[/TD] [TD]861300[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Trigger: 0| Trigger changed output: 0| Brightness: 0|119.12 Brightness dawn: 1|240.32 Elevation: 0|3 Azimut: 0|298 Activationstate: 0|1 Lockstate: 0|0 Internal timer: 0[/TD] [/TR] [TR] [TD]2017-05-24 20:45:57[/TD] [TD]861843[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Virtual depth and height of sun position in 90� to the facade: -0.64278760968654, 0.052407779283041, effective Elevation: -4.6611312665397[/TD] [/TR] [TR] [TD]2017-05-24 20:45:57[/TD] [TD]862337[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Previous value of A1 equals new value 0, skipping update of A1[/TD] [/TR] [TR] [TD]2017-05-24 20:45:57[/TD] [TD]862591[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Real azimut 298� and facade at 168� -> NOT IN SUN (shadow side, at sun from 83� to 253�), effective elevation -4.6611312665397� for given elevation of 3� -> NOT in min-max-range (0-90)[/TD] [/TR] [TR] [TD]2017-05-24 20:45:57[/TD] [TD]862740[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state 1 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-24 20:45:57[/TD] [TD]863728[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Previous value of A10 equals new value 1, skipping update of A10[/TD] [/TR] [TR] [TD]2017-05-24 20:45:57[/TD] [TD]864226[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Handling current shutter state SHADOW_NEUTRAL (1)[/TD] [/TR] [TR] [TD]2017-05-24 20:45:57[/TD] [TD]864741[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Updating outputs out of SHADOW_NEUTRAL if necessary[/TD] [/TR] [TR] [TD]2017-05-24 20:45:57[/TD] [TD]866113[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Values to write to outputs for height and angle: 0%/0%[/TD] [/TR] [TR] [TD]2017-05-24 20:45:57[/TD] [TD]866775[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Previous value of A3 equals new value 0, skipping update of A3[/TD] [/TR] [TR] [TD]2017-05-24 20:45:57[/TD] [TD]867149[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Previous value of A4 equals new value 0, skipping update of A4[/TD] [/TR] [TR] [TD]2017-05-24 20:45:57[/TD] [TD]867517[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Previous value of A5 equals new value 0, skipping update of A5[/TD] [/TR] [TR] [TD]2017-05-24 20:45:57[/TD] [TD]867876[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Previous value of A6 equals new value 0, skipping update of A6[/TD] [/TR] [TR] [TD]2017-05-24 20:45:57[/TD] [TD]868047[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Shutter angle 0% = 0�[/TD] [/TR] [TR] [TD]2017-05-24 20:45:57[/TD] [TD]868355[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Previous value of A7 equals new value 0, skipping update of A7[/TD] [/TR] [TR] [TD]2017-05-24 20:45:57[/TD] [TD]868736[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Previous value of A2 equals new value 0, skipping update of A2[/TD] [/TR] [TR] [TD]2017-05-24 20:45:57[/TD] [TD]870776[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state 1 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-24 20:45:57[/TD] [TD]871870[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Previous value of A10 equals new value 1, skipping update of A10[/TD] [/TR] [TR] [TD]2017-05-24 20:45:57[/TD] [TD]872721[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]===== === = LBS finished = === ===============================================[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]050224[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]===== === = Brightness, Elevation or Azimut changed and LBS is active, starting it = === ======[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]050570[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]===== === = LBS was triggered = === ==========================================[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]050704[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]<Input>: <Refreshed>|<Value>[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]051498[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Trigger: 0| Trigger changed output: 0| Brightness: 1|87.84 Brightness dawn: 0|240.32 Elevation: 0|3 Azimut: 0|298 Activationstate: 0|1 Lockstate: 0|0 Internal timer: 0[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]052696[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Virtual depth and height of sun position in 90� to the facade: -0.64278760968654, 0.052407779283041, effective Elevation: -4.6611312665397[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]053925[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Previous value of A1 equals new value 0, skipping update of A1[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]054244[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Real azimut 298� and facade at 168� -> NOT IN SUN (shadow side, at sun from 83� to 253�), effective elevation -4.6611312665397� for given elevation of 3� -> NOT in min-max-range (0-90)[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]054394[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state 1 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]055897[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Previous value of A10 equals new value 1, skipping update of A10[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]057368[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Handling current shutter state SHADOW_NEUTRAL (1)[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]057738[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Switching from SHADOW_NEUTRAL to DAWN_FULL_CLOSE_TIMER_RUNNING (dawn handling activated and brightness below dawn threshold)[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]057898[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Starting new timer for 300 seconds up to 20:51:15[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]061485[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state -6 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]063807[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Updating A10 with value -6[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]065741[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Shutter state has changed from 1 to -6, checking if there might be another change...[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]067315[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Handling current shutter state DAWN_FULL_CLOSE_TIMER_RUNNING (-6)[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]067676[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Switching from DAWN_FULL_CLOSE_TIMER_RUNNING to NEUTRAL (too bright)[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]068650[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Stopping timer[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]072244[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Updating outputs out of DAWN_FULL_CLOSE_TIMER_RUNNING if necessary[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]074616[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Values to write to outputs for height and angle: 0%/0%[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]075896[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Previous value of A3 equals new value 0, skipping update of A3[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]077030[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Previous value of A4 equals new value 0, skipping update of A4[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]078505[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Previous value of A5 equals new value 0, skipping update of A5[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]079641[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Previous value of A6 equals new value 0, skipping update of A6[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]079935[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Shutter angle 0% = 0�[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]080893[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Previous value of A7 equals new value 0, skipping update of A7[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]082001[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Previous value of A2 equals new value 0, skipping update of A2[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]084629[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state -1 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]087100[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Updating A10 with value -1[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]089631[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Shutter state has changed from -6 to -1, checking if there might be another change...[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]090837[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Handling current shutter state DAWN_NEUTRAL (-1)[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]091140[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Moving shutters to after-dawn-position out of state DAWN_NEUTRAL[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]091284[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Values to write to outputs for height and angle: 100%/0%[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]093669[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Updating A3 with value 100[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]095979[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Previous value of A4 equals new value 0, skipping update of A4[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]097805[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Updating A5 with value 255[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]100955[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Previous value of A6 equals new value 0, skipping update of A6[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]101258[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Shutter angle 0% = 0�[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]102224[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Previous value of A7 equals new value 0, skipping update of A7[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]103347[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Previous value of A2 equals new value 0, skipping update of A2[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]105973[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Timer already finished[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]109247[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state -1 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]110924[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Previous value of A10 equals new value -1, skipping update of A10[/TD] [/TR] [TR] [TD]2017-05-24 20:46:15[/TD] [TD]111862[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]===== === = LBS finished = === ===============================================[/TD] [/TR] [TR] [TD]2017-05-24 20:46:33[/TD] [TD]243068[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]===== === = Brightness, Elevation or Azimut changed and LBS is active, starting it = === ======[/TD] [/TR] [TR] [TD]2017-05-24 20:46:33[/TD] [TD]243386[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]===== === = LBS was triggered = === ==========================================[/TD] [/TR] [TR] [TD]2017-05-24 20:46:33[/TD] [TD]243561[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]<Input>: <Refreshed>|<Value>[/TD] [/TR] [TR] [TD]2017-05-24 20:46:33[/TD] [TD]244302[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Trigger: 0| Trigger changed output: 0| Brightness: 0|87.84 Brightness dawn: 0|240.32 Elevation: 1|2 Azimut: 0|298 Activationstate: 0|1 Lockstate: 0|0 Internal timer: 0[/TD] [/TR] [TR] [TD]2017-05-24 20:46:33[/TD] [TD]245485[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Virtual depth and height of sun position in 90� to the facade: -0.64278760968654, 0.034920769491748, effective Elevation: -3.1096550982469[/TD] [/TR] [TR] [TD]2017-05-24 20:46:33[/TD] [TD]246649[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Previous value of A1 equals new value 0, skipping update of A1[/TD] [/TR] [TR] [TD]2017-05-24 20:46:33[/TD] [TD]246959[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Real azimut 298� and facade at 168� -> NOT IN SUN (shadow side, at sun from 83� to 253�), effective elevation -3.1096550982469� for given elevation of 2� -> NOT in min-max-range (0-90)[/TD] [/TR] [TR] [TD]2017-05-24 20:46:33[/TD] [TD]247109[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state -1 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-24 20:46:33[/TD] [TD]248569[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Previous value of A10 equals new value -1, skipping update of A10[/TD] [/TR] [TR] [TD]2017-05-24 20:46:33[/TD] [TD]249665[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Handling current shutter state DAWN_NEUTRAL (-1)[/TD] [/TR] [TR] [TD]2017-05-24 20:46:33[/TD] [TD]249979[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Moving shutters to after-dawn-position out of state DAWN_NEUTRAL[/TD] [/TR] [TR] [TD]2017-05-24 20:46:33[/TD] [TD]250507[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Values to write to outputs for height and angle: 100%/0%[/TD] [/TR] [TR] [TD]2017-05-24 20:46:33[/TD] [TD]251780[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Previous value of A3 equals new value 100, skipping update of A3[/TD] [/TR] [TR] [TD]2017-05-24 20:46:33[/TD] [TD]252870[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Previous value of A4 equals new value 0, skipping update of A4[/TD] [/TR] [TR] [TD]2017-05-24 20:46:33[/TD] [TD]253954[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Previous value of A5 equals new value 255, skipping update of A5[/TD] [/TR] [TR] [TD]2017-05-24 20:46:33[/TD] [TD]255036[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Previous value of A6 equals new value 0, skipping update of A6[/TD] [/TR] [TR] [TD]2017-05-24 20:46:33[/TD] [TD]255325[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Shutter angle 0% = 0�[/TD] [/TR] [TR] [TD]2017-05-24 20:46:33[/TD] [TD]256278[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Previous value of A7 equals new value 0, skipping update of A7[/TD] [/TR] [TR] [TD]2017-05-24 20:46:33[/TD] [TD]257414[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Previous value of A2 equals new value 0, skipping update of A2[/TD] [/TR] [TR] [TD]2017-05-24 20:46:33[/TD] [TD]259809[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Timer already finished[/TD] [/TR] [TR] [TD]2017-05-24 20:46:33[/TD] [TD]263235[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Storing current shutter state -1 and updating output if necessary[/TD] [/TR] [TR] [TD]2017-05-24 20:46:33[/TD] [TD]264413[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Previous value of A10 equals new value -1, skipping update of A10[/TD] [/TR] [TR] [TD]2017-05-24 20:46:33[/TD] [TD]265264[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]===== === = LBS finished = === ===============================================[/TD] [/TR] [TR] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [TD] [/TD] [/TR] [/TABLE] [TABLE="class: log, border: 0, cellpadding: 0, cellspacing: 0, width: 0, height: 12"] [TR] [TD]2017-05-24 20:47:26[/TD] [TD]187211[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]LBS disabled through external angle change (88.235294117647 vs -15/15)[/TD] [/TR] [TR] [TD]2017-05-24 20:47:51[/TD] [TD]777513[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]Timer already finished[/TD] [/TR] [TR] [TD]2017-05-24 20:47:51[/TD] [TD]780807[/TD] [TD]9874[/TD] [TD]INFO:[/TD] [TD]LBS is disabled, nothing changed[/TD] [/TR] [/TABLE]
if (LB_LBSID_isDawnHandlingActivated($E) && LB_LBSID_getCurrentBrightness($E) < LB_LBSID_getDawnThresholdClose($E)) {
if (LB_LBSID_getCurrentBrightness($E) < LB_LBSID_getDawnThresholdClose($E)) {
