zeig doch mal bitte die ganze Logik mit Livewerten!
[TABLE="border: 0, cellpadding: 0, cellspacing: 0"] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]278840[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]===== === = LBS was triggered (v3.13) = === ==========================================[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]278871[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]<Input>: <Refreshed>|<Value>[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]279076[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]Trigger: 0| Trigger changed output: 1|1 Brightness: 0|52550 Brightness dawn: 0|26200 Elevation: 0|31.014968138515 Azimut: 0|228.13999634677 Lockstate: 0|0 Lockstate with position: 0|0 Internal timer: 0[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]279125[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]===== === = General trigger for changed outputs refreshed, starting LBS = ============[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]280297[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]UpdateAlways == false, previous value of A8 equals new value 0, skipping update[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]280354[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]No lock state detected, set explicit to unlocked[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]280783[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]===== === = Initial LBS run, updating all outputs = === ======================[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]280833[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]=== Validating input values... ===[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]280875[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]=== Finished validation of input values ===[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]280915[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]=== Checking if facade is in sun... ===[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]280986[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]Virtual depth and height of sun position in 90° to the facade: 0.66731281276851, 0.60121623573571, effective Elevation: 42.017306543841[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]281021[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]UpdateAlways == true, updating A1 with value 1 even if same value than previous LBS run[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]281953[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]UpdateAlways == true, updating A11 with value 0 even if same value than previous LBS run[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]282773[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]=== Finished facade check, real azimut 228.13999634677° and facade at 180° -> IN SUN (from 90° to 270°), effective elevation 42.017306543841° for given elevation of 31.014968138515° -> NOT in min-max-range (0-0) ===[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]282834[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]Storing current shutter state -2 and updating output if necessary[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]283199[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]UpdateAlways == true, updating A10 with value -2 even if same value than previous LBS run[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]283993[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]=== Calculating shutter state... ===[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]284287[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]Handling current shutter state DAWN_NEUTRAL_TIMER_RUNNING (-2)[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]284550[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]Switching from DAWN_NEUTRAL_TIMER_RUNNING to DAWN_NEUTRAL[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]284600[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]positionShutter(...), Values for height and angle: 100%/0%[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]284833[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]Initial LBS run, not updating outputs[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]285403[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]Timer already finished[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]286279[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]positionShutter(...) for height 100% and angle 0% finished[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]286334[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]Storing current shutter state -1 and updating output if necessary[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]286688[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]UpdateAlways == true, updating A10 with value -1 even if same value than previous LBS run[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]287481[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]Shutter state has changed from -2 to -1, checking if there might be another change...[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]287537[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]=== Calculating shutter state... ===[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]287790[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]Handling current shutter state DAWN_NEUTRAL (-1)[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]287842[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]Moving shutters to after-dawn-position out of state DAWN_NEUTRAL[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]287870[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]positionShutter(...), Values for height and angle: 0%/0%[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]288094[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]Initial LBS run, not updating outputs[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]288666[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]Timer already finished[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]289397[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]positionShutter(...) for height 0% and angle 0% finished[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]289450[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]Storing current shutter state -1 and updating output if necessary[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]289782[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]UpdateAlways == true, updating A10 with value -1 even if same value than previous LBS run[/TD] [/TR] [TR] [TD]2020-03-26 14:58:00[/TD] [TD]290719[/TD] [TD]21260[/TD] [TD]INFO: [/TD] [TD]===== === = LBS finished = === ===============================================[/TD] [/TR] [/TABLE]
| 2020-03-26 18:11:14 | 058876 | 19593 | INFO: | ================================================== ==================================== |
| 2020-03-26 18:11:14 | 059469 | 19593 | INFO: | ===== === = LBS was triggered (v3.13) = === ========================================== |
| 2020-03-26 18:11:14 | 059657 | 19593 | INFO: | <Input>: <Refreshed>|<Value> |
| 2020-03-26 18:11:14 | 060760 | 19593 | INFO: | Trigger: 0|1 Trigger changed output: 0| Brightness: 0|6178 Brightness dawn: 0|6178 Elevation: 0|5 Azimut: 0|268 Lockstate: 0|0 Lockstate with position: 0|0 Internal timer: 1 |
| 2020-03-26 18:11:14 | 061393 | 19593 | INFO: | ===== === = Timer running, starting LBS = === ======================================== |
| 2020-03-26 18:11:14 | 066559 | 19593 | INFO: | UpdateAlways == false, previous value of A8 equals new value 0, skipping update |
| 2020-03-26 18:11:14 | 066823 | 19593 | INFO: | No lock state detected, set explicit to unlocked |
| 2020-03-26 18:11:14 | 070877 | 19593 | INFO: | === Validating input values... === |
| 2020-03-26 18:11:14 | 071160 | 19593 | INFO: | === Finished validation of input values === |
| 2020-03-26 18:11:14 | 071352 | 19593 | INFO: | === Checking if facade is in sun... === |
| 2020-03-26 18:11:14 | 071559 | 19593 | INFO: | Virtual depth and height of sun position in 90° to the facade: 0.15643446504023, 0.087488663525924, effective Elevation: 29.216853061523 |
| 2020-03-26 18:11:14 | 073436 | 19593 | INFO: | UpdateAlways == false, previous value of A1 equals new value 1, skipping update |
| 2020-03-26 18:11:14 | 075038 | 19593 | INFO: | UpdateAlways == false, previous value of A11 equals new value 1, skipping update |
| 2020-03-26 18:11:14 | 075325 | 19593 | INFO: | === Finished facade check, real azimut 268° and facade at 187° -> IN SUN (from 120° to 277°), effective elevation 29.216853061523° for given elevation of 5° -> in min-max-range (10-90) === |
| 2020-03-26 18:11:14 | 075510 | 19593 | INFO: | Storing current shutter state 2 and updating output if necessary |
| 2020-03-26 18:11:14 | 079199 | 19593 | INFO: | UpdateAlways == false, previous value of A10 equals new value 2, skipping update |
| 2020-03-26 18:11:14 | 079497 | 19593 | INFO: | === Calculating shutter state... === |
| 2020-03-26 18:11:14 | 080995 | 19593 | INFO: | Handling current shutter state SHADOW_NEUTRAL_TIMER_RUNNING (2) |
| 2020-03-26 18:11:14 | 081239 | 19593 | INFO: | Facade is in sun |
| 2020-03-26 18:11:14 | 084028 | 19593 | INFO: | Updating outputs out of SHADOW_NEUTRAL_TIMER_RUNNING with previous values if necessary |
| 2020-03-26 18:11:14 | 087804 | 19593 | INFO: | positionShutter(...), Values for height and angle: 100%/50% |
| 2020-03-26 18:11:14 | 090693 | 19593 | INFO: | UpdateAlways == false, previous value of A2 equals new value 0, skipping update |
| 2020-03-26 18:11:14 | 091523 | 19593 | INFO: | UpdateAlways == false, previous value of A3 equals new value 100, skipping update |
| 2020-03-26 18:11:14 | 092905 | 19593 | INFO: | UpdateAlways == false, previous value of A5 equals new value 255, skipping update |
| 2020-03-26 18:11:14 | 093802 | 19593 | INFO: | UpdateAlways == false, previous value of A4 equals new value 50, skipping update |
| 2020-03-26 18:11:14 | 095208 | 19593 | INFO: | UpdateAlways == false, previous value of A6 equals new value 128, skipping update |
| 2020-03-26 18:11:14 | 095504 | 19593 | INFO: | Shutter angle 50% = 0° |
| 2020-03-26 18:11:14 | 096936 | 19593 | INFO: | UpdateAlways == false, previous value of A7 equals new value 0, skipping update |
| 2020-03-26 18:11:14 | 099406 | 19593 | INFO: | positionShutter(...) for height 100% and angle 50% finished |
| 2020-03-26 18:11:14 | 099649 | 19593 | INFO: | Storing current shutter state 2 and updating output if necessary |
| 2020-03-26 18:11:14 | 102834 | 19593 | INFO: | UpdateAlways == false, previous value of A10 equals new value 2, skipping update |
| 2020-03-26 18:11:14 | 105010 | 19593 | INFO: | ===== === = LBS finished = === =============================================== |
* This function calculates the effective elevation of sun position in an
* angle of 90° to the facade.
* @param $E
* @return float
* @internal param $azimut
* @internal param $facadeAngle
* @internal param $elevation
function LB_LBSID_calculateEffectiveElevation($E)
$elevation = $E[LB_LBSID_INPUT_Elevation]['value'];
$azimut = $E[LB_LBSID_INPUT_Azimut]['value'];
$facadeAngle = $E[LB_LBSID_INPUT_FacadeAngle]['value'];
$virtualDepth = cos(deg2rad(abs($azimut - $facadeAngle)));
$virtualHeight = tan(deg2rad($elevation));
$effectiveElevation = rad2deg(atan($virtualHeight / $virtualDepth));
LB_LBSID_debug(true, "Virtual depth and height of sun position in 90° to the facade: ${virtualDepth}, ${virtualHeight}, effective Elevation: ${effectiveElevation}");
return $effectiveElevation;
